首页 > 控制电路 >报警电路 > 摩托车报警器电路图
摩托车报警器电路图
来源:互联网发布者:qoistoochee128 更新时间: 2016/10/11
摩托车报警器电路图 Any number of normally open switches may be used. Fit the mercury switches so that they close when the steering is moved or when the bike is lifted off its side-stand or pushed forward off its centre-stand. Use micro-switches to protect removable panels and the lids of panniers etc. While at least one switch remains closed, the siren will sound. About two minutes after the switches have been opened again, the alarm will reset. How long it takes to switch off depends on the characteristics of the actual components used. But, up to a point, you can adjust the time to suit your requirements by changing the value of C1. The circuit board and switches must be protected from the elements. Dampness or condensation will cause malfunction. Without its terminal blocks, the board is small. Ideally, you should try to find a siren with enough spare space inside to accommodate it. Fit a 1-amp in-line fuse close to the power source. This protects the wiring. Instead of using a key-switch you can use a hidden switch; or you could use the normally closed contacts of a small relay. Wire the relay coil so that it is energized while the ignition is on. Then every time you turn the ignition off, the alarm will set itself. When it"s not sounding, the circuit uses virtually no current. This should make it useful in other circumstances. For example, powered by dry batteries and with the relay and siren voltages to suit, it could be fitted inside a computer or anything else that"s in danger of being picked up and carried away. The low standby current and automatic reset means that for this sort of application an external on/off switch may not be necessary.
提问/讨论 常见疑问?
这里还没有内容,您有什么问题吗?
我要提问/讨论
推荐帖子 最新更新时间:2024-11-23 17:54
最新TI工业研讨会来啦~
最新的TI工业应用研讨会从多个方面多个角度对TI产品的技术及发展进行了介绍。内容涉及当今火热的DLP,工业机器人,IoT ,FRAM 等方向的多个解决放案。 本次研讨会第二集视频:方案助您决胜 PLC & 变送器 之 TI全方位解决方案 点击此
 EEWORLD社区TI技术论坛
ISE11.0 中怎么调用RAM
ISE11.0 怎么条用片内RAM,我没用过ISE11.0 ISE11.0 中怎么调用RAM 原帖由 eeleader 于 2010-5-4 17:06 发表 ISE11.0 怎么条用片内RAM,我没用过ISE11.0 如果你说的是BLOCK RAM ,原理图方式可以
 eeleaderFPGA/CPLD
项目合作,语音读取短信,要求所在地长沙,会EVC
具体联系QQ83272874,合适面谈 项目合作,语音读取短信,要求所在地长沙,会EVC ding LZ有什么资源? windows mobile ? 我刚做了一个,哈哈,TTS用的是捷通的 我只是帮人家发个贴,具体都问那个人罗
 bogedahan12嵌入式系统
这是什么情况?
CCS突然出现这个东东是什麽意思 这是什么情况? :time:没见过。。
 张锋微控制器 MCU
TI嵌入式直播资料汇总小站上线啦!快来带走干货!
很多场直播过去了,相信很多网友都想获取这些直播的相关资料 比如直播回顾、PPT、技术文档…… 那么,如你所需! 一个专门汇总TI嵌入式直播资料的小站来了! 超声波的、Simpleink、Sitara、DSP、C2000、Capt
 EEWORLD社区TI技术论坛
wince6.0下不能正确获得主机名
使用GetHostByAddr通过Ip地址获取主机名,但是经常不能获取成功,偶尔成功后获取的主机名是localhost。错误时,返回值是11001,并且通过抓包软件不能抓到任何的数据。希望高手指教。 wince6.0下不能正确获得主机名 不好判断 我已经找到原因了,跟程序的代码没
 kerong12WindowsCE
About Us 关于我们 客户服务 联系方式 器件索引 网站地图 最新更新 手机版 版权声明
EEWORLD 电路图 站点相关: 下载中心 Datasheet 参考设计
