6.最后,我们把root-cramfs文件烧写到nandflash中的0x800000至0x1000000中。
当完成以上三个部分内容后,uboot就能够正确引导linux内核以及加载根文件系统了。下面列出了uboot启动后在串口显示的内容:
U-Boot2011.06 (Aug 31 2012 - 15:08:19)
DRAM: 64 MiB
Flash: ##Unknown flash on Bank 1 - Size = 0x00000000 = 0 MB
2 MiB
NAND: 256 MiB
***Warning - bad CRC, using default environment
In: serial
Out: serial
Err: serial
Net: dm9000
Hit anykey to stop autoboot: 0
NANDread: device 0 offset 0x200000, size 0x400000 4194304 bytes read: OK
##Booting kernel from Legacy Image at 31000000 ...
Image Name: linux
Created: 2012-09-01 14:46:43 UTC
Image Type: ARM Linux Kernel Image (uncompressed)
Data Size: 2428888 Bytes = 2.3 MiB
Load Address: 31000000
Entry Point: 31000040
Verifying Checksum ... OK
XIP Kernel Image ... OK
OK
Startingkernel ...
UncompressingLinux... done, booting the kernel.
BootingLinux on physical CPU 0
Linuxversion 3.4.6 (zcj@qihao) (gcc version 4.2.2) #3Sat Sep 1 22:44:40 CST 2012
CPU:ARM920T [41129200] revision 0 (ARMv4T), cr=00007177
CPU: VIVTdata cache, VIVT instruction cache
Machine:SMDK2440
Memorypolicy: ECC disabled, Data cache writeback
CPU S3C2440A(id 0x32440001)
S3C24XX Clocks, Copyright 2004 SimtecElectronics
S3C244X: core 400.000 MHz, memory 100.000MHz, peripheral 50.000 MHz
CLOCK:Slow mode (1.500 MHz), fast, MPLL on, UPLL on
Built 1zonelists in Zone order, mobility grouping on. Total pages: 16256
Kernelcommand line: root=/dev/mtdblock3 ro noinitrd init=/linuxrcconsole=ttySAC,115200 rootfstype=cramfs mem=64M
PID hashtable entries: 256 (order: -2, 1024 bytes)
Dentrycache hash table entries: 8192 (order: 3, 32768 bytes)
Inode-cachehash table entries: 4096 (order: 2, 16384 bytes)
Memory:64MB = 64MB total
Memory:59980k/59980k available, 5556k reserved, 0K highmem
Virtualkernel memory layout:
vector : 0xffff0000 - 0xffff1000 ( 4 kB)
fixmap : 0xfff00000 - 0xfffe0000 ( 896kB)
vmalloc : 0xc4800000 - 0xff000000 ( 936 MB)
lowmem : 0xc0000000 - 0xc4000000 ( 64 MB)
modules : 0xbf000000 - 0xc0000000 ( 16MB)
.text : 0xc0108000 - 0xc0545868 (4343 kB)
.init : 0xc0546000 - 0xc0570000 ( 168 kB)
.data : 0xc0570000 - 0xc05a67a0 ( 218 kB)
.bss : 0xc05a67c4- 0xc05cf1dc ( 163 kB)
NR_IRQS:99
irq:clearing subpending status 00000002
sched_clock:32 bits at 200 Hz, resolution 5000000ns, wraps every 4294967291ms
Console:colour dummy device 80x30
Calibratingdelay loop... 49.56 BogoMIPS (lpj=123904)
pid_max:default: 32768 minimum: 301
Mount-cachehash table entries: 512
CPU:Testing write buffer coherency: ok
Settingup static identity map for 0x304355a0- 0x3043561c
gpiochip_add:registered GPIOs 0 to 23 on device: GPIOA
gpiochip_add:registered GPIOs 32 to 47 on device: GPIOB
gpiochip_add:registered GPIOs 64 to 79 on device: GPIOC
gpiochip_add:registered GPIOs 96 to 111 on device: GPIOD
gpiochip_add:registered GPIOs 128 to 143 on device: GPIOE
gpiochip_add:registered GPIOs 160 to 167 on device: GPIOF
gpiochip_add:registered GPIOs 192 to 207 on device: GPIOG
gpiochip_add:registered GPIOs 224 to 234 on device: GPIOH
gpiochip_add:registered GPIOs 256 to 271 on device: GPIOJ
NET:Registered protocol family 16
S3C Power Management, Copyright 2004Simtec Electronics
S3C2440: Initialising architecture
S3C2440: IRQ Support
S3C244X: Clock Support, DVS off
bio:create slab SCSIsubsystem initialized usbcore:registered new interface driver usbfs usbcore:registered new interface driver hub usbcore:registered new device driver usb s3c-i2cs3c2440-i2c: slave address 0x10 s3c-i2cs3c2440-i2c: bus frequency set to 97 KHz s3c-i2cs3c2440-i2c: i2c-0:S3C I2C adapter AdvancedLinux Sound Architecture Driver Version 1.0.25. NET:Registered protocol family 2 IP routecache hash table entries: 1024 (order: 0, 4096 bytes) TCPestablished hash table entries: 2048 (order: 2, 16384 bytes) TCP bindhash table entries: 2048 (order: 1, 8192 bytes) TCP: Hashtables configured (established 2048 bind 2048) TCP: reno registered UDP hashtable entries: 256 (order: 0, 4096 bytes) UDP-Litehash table entries: 256 (order: 0, 4096 bytes) NET:Registered protocol family 1 RPC:Registered named UNIX socket transport module. RPC:Registered udp transport module. RPC:Registered tcp transport module. RPC:Registered tcp NFSv4.1 backchannel transport module. NetWinderFloating Point Emulator V0.97 (extended precision) jffs2:version 2.2. (NAND) (SUMMARY) ?2001-2006 Red Hat, Inc. ROMFS MTD(C) 2007 Red Hat, Inc. msgmnihas been set to 117 ioscheduler noop registered ioscheduler deadline registered ioscheduler cfq registered (default) Console:switching to colour frame buffer device 30x40 fb0: s3c2410fb frame buffer device Serial:8250/16550 driver, 4 ports, IRQ sharing enabled s3c2440-uart.0: ttySAC0 at MMIO 0x50000000(irq = 70) is a S3C2440 console[ttySAC0] enabled s3c2440-uart.1: ttySAC1 at MMIO 0x50004000(irq = 73) is a S3C2440 s3c2440-uart.2: ttySAC2 at MMIO 0x50008000(irq = 76) is a S3C2440 lp:driver loaded but no devices found ppdev:user-space parallel port driver brd:module loaded loop:module loaded UniformMulti-Platform E-IDE driver ide-gddriver 1.18 ide-cddriver 5.00 S3C24XX NAND Driver, (c) 2004 SimtecElectronics s3c24xx-nand s3c2440-nand: Tacls=2, 20ns Twrph0=6 60ns, Twrph1=220ns s3c24xx-nand s3c2440-nand: NAND ECC disabled NANDdevice: Manufacturer ID: 0xec, Chip ID: 0xda (Samsung NAND 256MiB 3,3V 8-bit) NAND_ECC_NONEselected by board driver. This is not recommended! Scanningdevice for bad blocks Baderaseblock 615 at 0x000004ce0000 Baderaseblock 807 at 0x0000064e0000 Creating4 MTD partitions on 'NAND': 0x000000000000-0x000000080000: 'UBoot' 0x000000080000-0x000000100000: 'Para' 0x000000200000-0x000000600000: 'Kernel' 0x000000800000-0x000001000000: 'rootfs' dm9000Ethernet Driver, V1.31 ohci_hcd:USB 1.1 'Open' Host Controller (OHCI) Driver s3c2410-ohci s3c2410-ohci: S3C24XXOHCI s3c2410-ohci s3c2410-ohci: new USB bus registered, assigned busnumber 1 s3c2410-ohci s3c2410-ohci: irq 42, io mem 0x49000000 hub1-0:1.0: USB hub found hub1-0:1.0: 2 ports detected usbcore:registered new interface driver libusual usbcore:registered new interface driver usbserial usbcore:registered new interface driver usbserial_generic USBSerial support registered for generic usbserial:USB Serial Driver core usbcore:registered new interface driver ftdi_sio USB Serialsupport registered for FTDI USB Serial Device ftdi_sio:v1.6.0:USB FTDI Serial Converters Driver usbcore:registered new interface driver pl2303 USBSerial support registered for pl2303 mousedev:PS/2 mouse device common for all mice s3c2410_wdt: S3C2410 Watchdog Timer, (c) 2004 Simtec Electronics s3c2410-wdt s3c2410-wdt: watchdog inactive, reset disabled, irqdisabled TCP:cubic registered NET:Registered protocol family 17 drivers/rtc/hctosys.c:unable to open rtc device (rtc0) ALSAdevice list: No soundcards found. VFS:Mounted root (cramfs filesystem) readonly on device 31:3. Freeinginit memory: 168K [root@zhaocj /]# 在该提示符下就可以运行一些linux命令了,如: [root@zhaocj /]#ls bin etc lib proc sys usr dev home linuxrc sbin temp
Pleasepress Enter to activate this console.
当我们按下回车键后,会看到linux的提示符:
上一篇:u-boot-2011.06在基于s3c2440开发板的移植之支持NandFlash读写
下一篇:u-boot-2011.06在基于s3c2440开发板的移植之nandflash启动
推荐阅读最新更新时间:2024-11-08 08:27
设计资源 培训 开发板 精华推荐
- 使用 Microchip Technology 的 MIC2774N-XXBM5 的参考设计
- LT1086CT-3.6 高效双路线性电源的典型应用
- 使用 Infineon Technologies AG 的 BTS 5230GS 的参考设计
- #第七届立创电赛#复刻电流表
- LTM8052MPV 5.6A、36Vin 为两个 2.5V 系列超级电容器充电的典型应用
- 【物联网】鸿蒙智能WiFi开关+4265974A
- 32U4键盘-Kawvin_KB1002_V1.2
- axp173电源模块
- NCP137AFCTADJT2GEVB:偏置轨 LDO 稳压器演示板
- LM2902VDTBR2G 维恩桥振荡器运算放大器的典型应用
