Linux-2.6.32.2内核自带RTC驱动,但mach_smdk2440.c中没有添加该设备集,因此没有被激活,加入该平台设备,RTC平台设备定义在arch/arm/plat-s3c24xx/devs.c。
static struct platform_device *smdk2440_devices[] __initdata = {
&s3c_device_usb, /* arch/arm/mach-s3c2440/mach-smdk2440.c */
&s3c_device_lcd,
&s3c_device_wdt,
&s3c_device_i2c0,
&s3c_device_iis,
&s3c_device_rtc,
驱动实现:
#include
#include
#include
#include
#include
#include
#include
#include
#include
#include
#include
#include
#include
#include
#include
/* I have yet to find an S3C implementation with more than one
* of these rtc blocks in */
static struct resource *s3c_rtc_mem;
static void __iomem *s3c_rtc_base;
static int s3c_rtc_alarmno = NO_IRQ;
static int s3c_rtc_tickno = NO_IRQ;
static DEFINE_SPINLOCK(s3c_rtc_pie_lock);
/* IRQ Handlers */
static irqreturn_t s3c_rtc_alarmirq(int irq, void *id)
struct rtc_device *rdev = id;
/* 报警中断到来时,设定报警相关信息,函数实现位于drivers/rtc/interface.c */
rtc_update_irq(rdev, 1, RTC_AF | RTC_IRQF);
return IRQ_HANDLED;
static irqreturn_t s3c_rtc_tickirq(int irq, void *id)
rtc_update_irq(rdev, 1, RTC_PF | RTC_IRQF);
return IRQ_HANDLED;
/* Update control registers 设置RTCALM全局报警使能位*/
static void s3c_rtc_setaie(int to)
unsigned int tmp;
pr_debug('%s: aie=%dn', __func__, to);
tmp = readb(s3c_rtc_base + S3C2410_RTCALM) & ~S3C2410_RTCALM_ALMEN;
if (to)
tmp |= S3C2410_RTCALM_ALMEN;
writeb(tmp, s3c_rtc_base + S3C2410_RTCALM);
/* 节拍时间计数器使能 */
static int s3c_rtc_setpie(struct device *dev, int enabled)
unsigned int tmp;
pr_debug('%s: pie=%dn', __func__, enabled);
spin_lock_irq(&s3c_rtc_pie_lock);
tmp = readb(s3c_rtc_base + S3C2410_TICNT) & ~S3C2410_TICNT_ENABLE;
if (enabled)
tmp |= S3C2410_TICNT_ENABLE;
writeb(tmp, s3c_rtc_base + S3C2410_TICNT);
spin_unlock_irq(&s3c_rtc_pie_lock);
return 0;
/* 节拍时间计数值设置*/
static int s3c_rtc_setfreq(struct device *dev, int freq)
unsigned int tmp;
if (!is_power_of_2(freq))
return -EINVAL;
tmp = readb(s3c_rtc_base + S3C2410_TICNT) & S3C2410_TICNT_ENABLE;
tmp |= (128 / freq)-1;
return 0;
/* Time read/write */
/* 读取RTC中时间:分、时、日期、月、年、秒 */
static int s3c_rtc_gettime(struct device *dev, struct rtc_time *rtc_tm)
unsigned int have_retried = 0;
void __iomem *base = s3c_rtc_base;
retry_get_time:
rtc_tm->tm_min = readb(base + S3C2410_RTCMIN);
rtc_tm->tm_hour = readb(base + S3C2410_RTCHOUR);
rtc_tm->tm_mday = readb(base + S3C2410_RTCDATE);
rtc_tm->tm_mon = readb(base + S3C2410_RTCMON);
rtc_tm->tm_year = readb(base + S3C2410_RTCYEAR);
rtc_tm->tm_sec = readb(base + S3C2410_RTCSEC);
/* the only way to work out wether the system was mid-update
* when we read it is to check the second counter, and if it
* is zero, then we re-try the entire read
/* 如果读到秒为0,可能有进位,根据2440手册知道,要重新读一次 */
if (rtc_tm->tm_sec == 0 && !have_retried) {
have_retried = 1;
goto retry_get_time;
pr_debug('read time %02x.%02x.%02x %02x/%02x/%02xn',
rtc_tm->tm_year, rtc_tm->tm_mon, rtc_tm->tm_mday,
rtc_tm->tm_hour, rtc_tm->tm_min, rtc_tm->tm_sec);
/* 将BCD码转换为二进制数 */
rtc_tm->tm_sec = bcd2bin(rtc_tm->tm_sec);
rtc_tm->tm_min = bcd2bin(rtc_tm->tm_min);
rtc_tm->tm_hour = bcd2bin(rtc_tm->tm_hour);
rtc_tm->tm_mday = bcd2bin(rtc_tm->tm_mday);
rtc_tm->tm_mon = bcd2bin(rtc_tm->tm_mon);
rtc_tm->tm_year = bcd2bin(rtc_tm->tm_year);
/*这里为什么要加100年和减1月,查看数据手册得知区别1900年和2000年闰年的因素,1900年不是闰年而2000年是闰年*/
rtc_tm->tm_year += 100;
rtc_tm->tm_mon -= 1;
return 0;
/* 与s3c_rtc_gettime功能相反 */
static int s3c_rtc_settime(struct device *dev, struct rtc_time *tm)
int year = tm->tm_year - 100;
pr_debug('set time %02d.%02d.%02d %02d/%02d/%02dn',
tm->tm_year, tm->tm_mon, tm->tm_mday,
tm->tm_hour, tm->tm_min, tm->tm_sec);
/* we get around y2k by simply not supporting it */
if (year < 0 || year >= 100) {
dev_err(dev, 'rtc only supports 100 yearsn');
上一篇:S3C2440驱动篇—Linux平台设备驱动
下一篇:S3C2440-SDRAM连线分析
推荐阅读最新更新时间:2024-11-03 12:13
设计资源 培训 开发板 精华推荐
- 使用 Analog Devices 的 ADR01AKSZ 的参考设计
- LT3011EMSE 演示板、50mA、具有 PWRGD 的高压低压差线性稳压器
- DIY远程控制开关灯-涂鸦WIFI版
- 用于可调电流源的 LT1764AET-1.8 LDO 稳压器的典型应用
- OP184ESZ-REEL7 运算放大器噪声电路模型的典型应用,用于确定总电路等效输入噪声电压
- 基于LM2596的直流可调电源设计+778314A
- AN30182A-EVB,基于AN30182A多电源(高效电源LSI)的评估板
- ZR431可调精密齐纳分流稳压器的典型应用与更高电流分流稳压器
- LT8330ES6 4V 至 36V 输入、12V SEPIC 转换器的典型应用电路
- L78L10AC正压稳压器的电流调节器典型应用
