1、实现1+2+3------+100
AREA test02,CODE,READONLY
start
MOV R0,#0
MOV R1,#1
MOV R2,#1
LOOP
ADD R2,R2,R0
ADD R1,R1,#1
CMP R1,#101
BEQ label
ADD R2,R2,R1
B LOOP
label
NOP
NOP
NOP
END
2、汇编LED测试
*注意修改段名为testLED(两处修改)
*在MDK中,要添加簇文件RuninRAM.sct
*在MDK中,要添加初始化文件Ext_RAM.ini
AREA testLED,CODE,READWRITE
ENTRY
rGPBCON EQU 0x56000010
rGPBDAT EQU 0x56000014
rGPBUP EQU 0x56000018
start
ldr r0, =rGPBCON
ldr r1, [r0]
bic r1,r1,#(0xff<<10)
orr r1,r1,#0x01
orr r1,r1,#(0x55<<10)
str r1,[r0]
ldr r0, =rGPBUP
mov r1, #0xff
str r1,[r0]
LED_LOOP
ldr r0, =rGPBDAT
mov r1, #0xE0
str r1, [r0]
mov r2, #0x120000
delay1
sub r2, r2, #1
cmp r2, #0
bne delay1
ldr r0, =rGPBDAT
mov r1, #0x00
str r0, [r0]
mov r2, #0x120000
delay2
sub r2, r2, #1
cmp r2,#0
bne delay2
b LED_LOOP
end
3、C语言LED测试
*在MDK中需要修改段名(RESET)
*在MDK中S3C2440A.S初始化文件已存在
*在MDK中需要添加簇文件RuninRAM.sct
#define rGPBCON (*(volatile unsigned *)0x56000010)
#define rGPBDAT (*(volatile unsigned *)0x56000014)
#define rGPBUP (*(volatile unsigned *)0x56000018)
void msdelay(int time)
volatile unsigned int i,j;
for(i=0;i<2000;i++)
for(j=0;j }
void GPIO_init()
rGPBCON &= ~((3<<10)|(3<<12)|(3<<14)|(3<<16));
rGPBCON |= (1<<10)|(1<<12)|(1<<14)|(1<<16);
//rGPBCON = 0x15400;//0001 0101 0100 0000 0000
rGPBUP = 0xff;
void ledtestC()
volatile unsigned int i;
while(1)
for(i=0;i<4;i++)
rGPBDAT = 0x000;
rGPBDAT |=(1<<(5+i));
msdelay(500);
rGPBDAT &=~(1<<(5+i));
msdelay(500);
int main(int argc, char **argv)
GPIO_init();
ledtestC();
return 0;
一、编写源代码
源代码:
/*******************************led_off.S**************************/
.text
.global _start
_start:
LDR R0,=0x56000010
MOV R1,#0x00015400
STR R1,[R0]
LDR R0,=0x56000014
MOV R1,#0x0df
STR R1,[R0]
MAIN_LOOP:
B MAIN_LOOP
/*******************************Makefile****************************/
*指定链接文件地址
*指定链接文件顺序
led_off.bin : led_off.S
arm-linux-gcc -g -c -o led_off.o led_off.S
arm-linux-ld -Ttext 0x0000000 -g led_off.o -o led_off_elf
arm-linux-objcopy -O binary -S led_off_elf led_off.bin
clean:
rm -f led_off.bin led_off_elf *.o
二、使用Jlink下载led_off.bin到nand flash(参考烧写Uboot方法)
5.1 打开 J-Link Commander,输入-r
5.2 speed 12000
5.3 J-Link Commonder 输入loadbin f:init.bin 0
5.4 setpc 0
5.5 g
5.5 h
5.6 J-Link Commonder 输入loadbin f:u-boot.bin_openjtag 0x33f80000
5.7 setpc 0x33f80000
5.8 g
5.9 h
5.10 J-Link Commonder 输入loadbin f:u-boot.bin 0x30000000
J-Link Commonder 输入loadbin f:led_off.bin 0x30000000,即可以烧写汇编程序
5.11 g
5.12 h
5.13 在secretcat 中输入nand scrub
5.14 y
5.15 在secretcat 中输入nand erase 0 0x40000
5.16 在secretcat 中输入nand write.jffs2 30000000 0 0x40000
5.17 重新启动进入nand flash
三、开发板重启即可。
一、编写源程序(init.S、testledC.lds、testledC.c、Makefile)
@ File:init.S
@ 功能:通过它转入C程序
.text
.global _start
_start:
ldr r0, =0x53000000 @ WATCHDOG寄存器地址
mov r1, #0x0
str r1, [r0] @ 写入0,禁止WATCHDOG,否则CPU会不断重启
ldr sp, =1024*4 @ 设置堆栈,注意:不能大于4k, 因为现在可用的内存只有4K
@ nand flash中的代码在复位后会移到内部ram中,此ram只有4K
bl main @ 调用C程序中的main函数
halt_loop:
b halt_loop
*功能:链接文件TestledC.lds
SECTIONS {
. = 0x00;
.text : { *(.text) }
.rodata ALIGN(4) : {*(.rodata)}
.data ALIGN(4) : { *(.data) }
.bss ALIGN(4) : { *(.bss) *(COMMON) }
SECTIONS {
. = 0x00;
*编写testledC.c源程序
* File: testledC.c
* funtion:stream light
* author:zhaochuang
* data: 2013.5.8
* vision 1.0
for(i=0;i<2000;i++)
for(j=0;j }
void GPIO_init()
rGPBUP = 0xff;
void ledtestC()
while(1)
for(i=0;i<4;i++)
rGPBDAT = 0x000;
msdelay(5);
msdelay(5);
GPIO_init();
ledtestC();
return 0;
* File: int_test.c
* Author: Hanson
* 嵌入式家园 www.embedclub.com
* 上海嵌入式家园-开发板商城 http://embedclub.taobao.com
* Desc: LED test using c code
* History: May 16th 2011
/* include files */
#define rGPBCON (*(volatile unsigned *)0x56000010) //Port B control
#define rGPBDAT (*(volatile unsigned *)0x56000014) //Port B data
#define rGPBUP (*(volatile unsigned *)0x56000018) //Pull-up control B
#define U32 unsigned long
#define LED1_ON ~(1<<5)
#define LED2_ON ~(1<<6)
#define LED3_ON ~(1<<7)
#define LED4_ON ~(1<<8)
#define LED1_OFF (1<<5)
#define LED2_OFF (1<<6)
#define LED3_OFF (1<<7)
#define LED4_OFF (1<<8)
void dely(U32 tt)
U32 i;
for(;tt>0;tt--)
for(i=0;i<10000;i++){}
int main()
rGPBDAT = rGPBDAT|(LED1_OFF)|(LED2_OFF)|(LED3_OFF)|(LED4_OFF);
while (1)
rGPBDAT = rGPBDAT&(LED1_ON);
dely(100);
dely(100);
rGPBDAT = rGPBDAT&(LED2_ON);
dely(100);
dely(100);
rGPBDAT = rGPBDAT&(LED3_ON);
dely(100);
dely(100);
rGPBDAT = rGPBDAT&(LED4_ON);
dely(100);
dely(100);
*Makefile编写规则
CFLAGS := -Wall -O2
testledC.bin : init.S testledC.c
arm-linux-gcc $(CFLAGS) -c -o init.o init.S
arm-linux-gcc $(CFLAGS) -c -o testledC.o testledC.c
arm-linux-ld -TtestledC.lds init.o testledC.o -o testledC_elf
arm-linux-objcopy -O binary -S testledC_elf testledC.bin
arm-linux-objdump -D -m arm testledC_elf > testledC.dis
clean:
rm -f testledC.bin testledC_elf testledC.dis *.o
上一篇:u-boot-2009.11移植到mini2440
下一篇:mini2440 LED驱动程序开发
推荐阅读最新更新时间:2024-11-12 23:11
设计资源 培训 开发板 精华推荐
- STEVAL-TLL010V1,演示板使用 STLA02 升压转换器来控制 6 个用于显示背光的白色 LED
- Res12222 十进制电阻器
- 使用 Infineon Technologies AG 的 OMR7812NH 的参考设计
- OP484FSZ-REEL 仅 5V、12 位 DAC 摆幅轨到轨运算放大器的典型应用
- 使用 Microchip Technology 的 TC18C46MJE 的参考设计
- IS31FL3216、16通道LED驱动器的典型应用
- #第四届立创大赛#基于STC8A的WAV播放器
- OM13496: 表面贴装到DIP评估板
- TAR5SB31 点稳压器(低压降稳压器)的典型应用
- TA48S03F 1A 输出电流和 3V 低压差稳压器的典型应用,带 ON/OFF 控制开关
