u-boot2011.03支持s3c2440,寄存器在arch/arm/includer/asm/目录下s3c24x0_cpu.h中定义。
代码中包含了s3c2410读写nandflash函数,因此在s3c2410基础上进行修改
U-Boot源代码下载地址 http://www.linuxidc.com/Linux/2011-07/38897.htm
建一个s3c2440_nand.c文件
cd drivers/mtd/nand/
cp s3c2410_nand.c s3c2440_nand.c
代码如下
寄存器操作说明:
readl函数原型
#define readl(addr) (*(volatile unsigned int*)(addr))
writeb函数原型
#define writel(b,addr) ((*(volatile unsigned int *) (addr)) = (b))
#include
#include
#include
#include
#define S3C2440_NFCONT_EN (1<<0)
#define S3C2440_NFCONT_nFCE (0<<1)
#define S3C2440_NFCONT_INITECC (1<<4)
#define S3C2440_NFCONF_TACLS(x) ((x)<<12)
#define S3C2440_NFCONF_TWRPH0(x) ((x)<<8)
#define S3C2440_NFCONF_TWRPH1(x) ((x)<<4)
#define S3C2440_ADDR_NALE 0x0c
#define S3C2440_ADDR_NCLE 0x08
#ifdef CONFIG_NAND_SPL
/* in the early stage of NAND flash booting, printf() is not available */
#define printf(fmt, args...)
static void nand_read_buf(struct mtd_info *mtd, u_char *buf, int len)
int i;
struct nand_chip *this = mtd->priv;
for (i = 0; i < len; i++)
buf[i] = readb(this->IO_ADDR_R);
#endif
static void s3c2440_hwcontrol(struct mtd_info *mtd, int cmd, unsigned int ctrl)
struct nand_chip *chip = mtd->priv;
struct s3c2440_nand *nand = s3c2440_get_base_nand();
debugX(1, 'hwcontrol(): 0x%02x 0x%02xn', cmd, ctrl);
if (ctrl & NAND_CTRL_CHANGE) {
ulong IO_ADDR_W = (ulong)nand;
if (!(ctrl & NAND_CLE))
IO_ADDR_W |= S3C2440_ADDR_NALE;
if (!(ctrl & NAND_ALE))
IO_ADDR_W |= S3C2440_ADDR_NCLE;//特别注意修改
chip->IO_ADDR_W = (void *)IO_ADDR_W;
if (ctrl & NAND_NCE)
writel(readl(&nand->nfcont) & (~(1<<1)),
&nand->nfcont);
else
writel(readl(&nand->nfcont) | (1<<1),
&nand->nfcont);
if (cmd != NAND_CMD_NONE)
writeb(cmd, chip->IO_ADDR_W);
static int s3c2440_dev_ready(struct mtd_info *mtd)
debugX(1, 'dev_readyn');
return readl(&nand->nfstat) & 0x01;
#ifdef CONFIG_S3C2440_NAND_HWECC
void s3c2440_nand_enable_hwecc(struct mtd_info *mtd, int mode)
debugX(1, 's3c2440_nand_enable_hwecc(%p, %d)n', mtd, mode);
writel(readl(&nand->nfconf) | S3C2440_NFCONF_INITECC, &nand->nfconf);
static int s3c2440_nand_calculate_ecc(struct mtd_info *mtd, const u_char *dat, u_char *ecc_code)
ecc_code[0] = readb(&nand->nfecc);
ecc_code[1] = readb(&nand->nfecc + 1);
ecc_code[2] = readb(&nand->nfecc + 2);
debugX(1, 's3c2440_nand_calculate_hwecc(%p,): 0x%02x 0x%02x 0x%02xn',
mtd , ecc_code[0], ecc_code[1], ecc_code[2]);
return 0;
static int s3c2440_nand_correct_data(struct mtd_info *mtd, u_char *dat, u_char *read_ecc, u_char *calc_ecc)
if (read_ecc[0] == calc_ecc[0] &&
read_ecc[1] == calc_ecc[1] &&
read_ecc[2] == calc_ecc[2])
return 0;
printf('s3c2440_nand_correct_data: not implementedn');
return -1;
#endif
int board_nand_init(struct nand_chip *nand)
u_int32_t cfg;
u_int8_t tacls, twrph0, twrph1;
struct s3c24x0_clock_power *clk_power = s3c24x0_get_base_clock_power();
struct s3c2440_nand *nand_reg = s3c2440_get_base_nand();
debugX(1, 'board_nand_init()n');
writel(readl(&clk_power->clkcon) | (1 << 4), &clk_power->clkcon);
/* initialize hardware */
#if defined(CONFIG_S3C24XX_CUSTOM_NAND_TIMING)
tacls = CONFIG_S3C24XX_TACLS;
twrph0 = CONFIG_S3C24XX_TWRPH0;
twrph1 = CONFIG_S3C24XX_TWRPH1;
#else
tacls = 4;
twrph0 = 8;
twrph1 = 8;
#endif
cfg = S3C2440_NFCONF_TACLS(tacls - 1);
cfg |= S3C2440_NFCONF_TWRPH0(twrph0 - 1);
cfg |= S3C2440_NFCONF_TWRPH1(twrph1 - 1);
writel(cfg, &nand_reg->nfconf);
cfg = S3C2440_NFCONT_EN;
cfg |= S3C2440_NFCONT_nFCE;
cfg |= S3C2440_NFCONT_INITECC;
writel(cfg, &nand_reg->nfcont);
/* initialize nand_chip data structure */
nand->IO_ADDR_R = (void *)&nand_reg->nfdata;
nand->IO_ADDR_W = (void *)&nand_reg->nfdata;
nand->select_chip = NULL;
/* read_buf and write_buf are default */
/* read_byte and write_byte are default */
nand->read_buf = nand_read_buf;
#endif
/* hwcontrol always must be implemented */
nand->cmd_ctrl = s3c2440_hwcontrol;
nand->dev_ready = s3c2440_dev_ready;
nand->ecc.hwctl = s3c2440_nand_enable_hwecc;
nand->ecc.calculate = s3c2440_nand_calculate_ecc;
nand->ecc.correct = s3c2440_nand_correct_data;
nand->ecc.mode = NAND_ECC_HW;
nand->ecc.size = CONFIG_SYS_NAND_ECCSIZE;
nand->ecc.bytes = CONFIG_SYS_NAND_ECCBYTES;
#else
nand->ecc.mode = NAND_ECC_SOFT;
#endif
#ifdef CONFIG_S3C2440_NAND_BBT
nand->options = NAND_USE_FLASH_BBT;
#else
nand->options = 0;
#endif
debugX(1, 'end of nand_initn');
return 0;
再在include/configs/mini2440.h中添加
#define CONFIG_NAND_S3C2440
#define CONFIG_SYS_MAX_NAND_DEVICE 1
#define CONFIG_SYS_NAND_BASE 0x4E000000
#define CONFIG_MTD_DEVICE
#define CONFIG_CMD_NAND
编译好后使用supervivi 的d命令下载到sdram的0x33f80000地指出执行
U-Boot 2011.03 (Nov 29 2011 - 09:21:34)
DRAM: 64 MiB
Flash: 2 MiB
NAND: 256 MiB
*** Warning - bad CRC, using default environment
In: serial
Out: serial
Err: serial
Net: dm9000
mini2440 # nand info
Device 0: nand0, sector size 128 KiB
mini2440 #
mini2440已经能够很好的支持nand flash
上一篇:mini2440 驱动ds18b20
下一篇:QT_MPlayer移植到mini2440
推荐阅读最新更新时间:2024-11-03 18:01
设计资源 培训 开发板 精华推荐
- AN-H54 使用 MD1811 100V 超声脉冲器驱动高压脉冲器
- AM2LS-1212SH30-NZ 12V 2瓦DC-DC转换器的典型应用
- LT4276BHUFD 25.5W(类型 2)PoE+ 电源在反激模式下的典型应用电路,具有 24V、1A 输出
- 基于MT2492的3.3V5V输出降压模块(实物已验证)
- LT1764EFE-3.3 3.3 VIN 至 2.5 VOUT LDO 稳压器的典型应用
- LTC6263IMS 230 uA 电源电流运算放大器的典型应用
- 使用 ADA4077-2ARMZ-RL 双电源高精度放大器用于低功耗线性化 RTD 电路的典型应用电路
- CN0118
- AM2S-1203SH30Z 3.3V 2瓦直流转直流转换器的典型应用
- 用于汽车照明的四路 SPST 模拟开关
- 预报名有奖直播:煮酒数创客,看如何让好创意发生!
- MPS EMI 知识充电节盛大开启!赚积分赢好礼!
- 全民行动,大家一起上干货!发表,推荐干货就有礼~
- 改变你对万用表的看法!福禄克首款热成像万用表Fluke-279FC功能畅想大征集!
- 下载文档看视频有礼:获得更高效的PCIe一致性测试文档
- “慧眼”识PCIe——阅读《PCIe要了解的十件事》和泰克OPEN-DAY的培训资料 抽奖、分享赢好礼!
- TE 福利月|有奖调查、技术干货、限时折扣
- MPS有奖活动|梦想设计闪亮登场,便携式多功能电工台诞生啦!
- 你是课代表——TI培训最受欢迎课程由你做主 发帖荐课即可参与幸运抽奖!
- 《开关电源的早期历史》终结篇:烛古鉴今,如何解决问题?
