u-boot-2009.08在mini2440上的移植 增加nand flash功能
发布者:PeacefulWarrior最新更新时间:2024-07-01 来源: elecfans关键字:u-boo  mini2440  移植  nand  flash功能 手机看文章 扫描二维码
随时随地手机看文章
【2】在上面添加的代码中有一个跳转:bl nand_read_ll ,它跳入是新增的C 语言文件board/samsung/mini2440/nand_read.c中的函数,这个文件原本是用vivi 的代码,后来经过openmoko 的修改,并支持不同的Nand Flash 芯片,我又这里多加了几个个芯片ID以支持所有mini2440 的Nand Flash。代码如下:
 * nand_read.c: Simple NAND read functions for booting from NAND
 * This is used by cpu/arm920/start.S assembler code,
 * and the board-specific linker script must make sure this
 * file is linked within the first 4kB of NAND flash.
 * Taken from GPLv2 licensed vivi bootloader,
 * Copyright (C) 2002 MIZI Research, Inc.
 * Author: Hwang, Chideok
 * Date  : $Date: 2004/02/04 10:37:37 $
 * u-boot integration and bad-block skipping (C) 2006 by OpenMoko, Inc.
 * Author: Harald Welte
#include
#include
#define __REGb(x) (*(volatile unsigned char *)(x))
#define __REGw(x) (*(volatile unsigned short *)(x))
#define __REGi(x) (*(volatile unsigned int *)(x))
#define NF_BASE  0x4e000000
#if defined(CONFIG_S3C2410)
#define NFCONF  __REGi(NF_BASE + 0x0)
#define NFCMD  __REGb(NF_BASE + 0x4)
#define NFADDR  __REGb(NF_BASE + 0x8)
#define NFDATA  __REGb(NF_BASE + 0xc)
#define NFSTAT  __REGb(NF_BASE + 0x10)
#define NFSTAT_BUSY 1
#define nand_select() (NFCONF &= ~0x800)
#define nand_deselect() (NFCONF |= 0x800)
#define nand_clear_RnB() do {} while (0)
#elif defined(CONFIG_S3C2440) || defined(CONFIG_S3C2442)
#define NFCONT  __REGi(NF_BASE + 0x4)
#define NFCMD  __REGb(NF_BASE + 0x8)
#define NFADDR  __REGb(NF_BASE + 0xc)
#define NFDATA  __REGb(NF_BASE + 0x10)
#define NFDATA16 __REGw(NF_BASE + 0x10)
#define NFSTAT  __REGb(NF_BASE + 0x20)
#define nand_select() (NFCONT &= ~(1 << 1))
#define nand_deselect() (NFCONT |= (1 << 1))
#define nand_clear_RnB() (NFSTAT |= (1 << 2))
#endif
static inline void nand_wait(void)
 int i;
 while (!(NFSTAT & NFSTAT_BUSY))
  for (i=0; i<10; i++);
struct boot_nand_t {
 int page_size;
 int block_size;
 int bad_block_offset;
// unsigned long size;
#if 0
#if defined(CONFIG_S3C2410) || defined(CONFIG_MINI2440)
/* configuration for 2410 with 512byte sized flash */
#define NAND_PAGE_SIZE  512
#define BAD_BLOCK_OFFSET 5
#define NAND_BLOCK_MASK  (NAND_PAGE_SIZE - 1)
#define NAND_BLOCK_SIZE  0x4000
#else
/* configuration for 2440 with 2048byte sized flash */
#define NAND_5_ADDR_CYCLE
#define NAND_PAGE_SIZE  2048
#define BAD_BLOCK_OFFSET NAND_PAGE_SIZE
#define NAND_BLOCK_SIZE  (NAND_PAGE_SIZE * 64)
#endif
/* compile time failure in case of an invalid configuration */
#if defined(CONFIG_S3C2410) && (NAND_PAGE_SIZE != 512)
#error 'S3C2410 does not support nand page size != 512'
#endif
#endif
static int is_bad_block(struct boot_nand_t * nand, unsigned long i)
 unsigned char data;
 unsigned long page_num;
 nand_clear_RnB();
 if (nand->page_size == 512) {
  NFCMD = NAND_CMD_READOOB; /* 0x50 */
  NFADDR = nand->bad_block_offset & 0xf;
  NFADDR = (i >> 9) & 0xff;
  NFADDR = (i >> 17) & 0xff;
  NFADDR = (i >> 25) & 0xff;
 } else if (nand->page_size == 2048) {
  page_num = i >> 11; /* addr / 2048 */
  NFCMD = NAND_CMD_READ0;
  NFADDR = nand->bad_block_offset & 0xff;
  NFADDR = (nand->bad_block_offset >> 8) & 0xff;
  NFADDR = page_num & 0xff;
  NFADDR = (page_num >> 8) & 0xff;
  NFADDR = (page_num >> 16) & 0xff;
  NFCMD = NAND_CMD_READSTART;
 } else {
  return -1;
 nand_wait();
 data = (NFDATA & 0xff);
 if (data != 0xff)
  return 1;
 return 0;
static int nand_read_page_ll(struct boot_nand_t * nand, unsigned char *buf, unsigned long addr)
 unsigned short *ptr16 = (unsigned short *)buf;
 unsigned int i, page_num;
 nand_clear_RnB();
  /* Write Address */
  NFADDR = addr & 0xff;
  NFADDR = (addr >> 9) & 0xff;
  NFADDR = (addr >> 17) & 0xff;
  NFADDR = (addr >> 25) & 0xff;
  page_num = addr >> 11; /* addr / 2048 */
  /* Write Address */
  NFADDR = 0;
  NFADDR = 0;
 } else {
  return -1;
 nand_wait();
 for (i = 0; i < nand->page_size; i++) {
  *buf = (NFDATA & 0xff);
  buf++;
 for (i = 0; i < (nand->page_size>>1); i++) {
  *ptr16 = NFDATA16;
  ptr16++;
#endif
 return nand->page_size;
static unsigned short nand_read_id(void)
 unsigned short res = 0;
 NFCMD = NAND_CMD_READID;
 NFADDR = 0;
 res = NFDATA;
 res = (res << 8) | NFDATA;
 return res;
extern unsigned int dynpart_size[];
/* low level nand read function */
int nand_read_ll(unsigned char *buf, unsigned long start_addr, int size)
 int i, j;
 unsigned short nand_id;
 struct boot_nand_t nand;
 /* chip Enable */
 nand_select();
 nand_clear_RnB();
 for (i = 0; i < 10; i++)
 nand_id = nand_read_id();
 if (0) { /* dirty little hack to detect if nand id is misread */
  unsigned short * nid = (unsigned short *)0x31fffff0;
  *nid = nand_id;
       if (nand_id == 0xec76   /* Samsung K91208 */
           ||nand_id == 0xad76 ) { /*Hynix HY27US08121A*/
  nand.page_size = 512;
  nand.block_size = 16 * 1024;
  nand.bad_block_offset = 5;
 // nand.size = 0x4000000;
 } else if (nand_id == 0xecf1  /* Samsung K9F1G08U0B */
     ||nand_id == 0xecda  /* Samsung K9F2G08U0B */
     ||nand_id == 0xecd3 ) { /* Samsung K9K8G08 */
  nand.page_size = 2048;
  nand.block_size = 128 * 1024;
  nand.bad_block_offset = nand.page_size;
 // nand.size = 0x8000000;
 } else {
  return -1; // hang
 if ((start_addr & (nand.block_size-1)) || (size & ((nand.block_size-1))))
  return -1; /* invalid alignment */
 for (i=start_addr; i < (start_addr + size);) {
#ifdef CONFIG_S3C2410_NAND_SKIP_BAD
 //if (i & (nand.block_size-1)== 0) {//warning: suggest parentheses around comparison in operand of '&'
 if ((i & (nand.block_size-1))== 0) {
  if (is_bad_block(&nand, i) ||
       is_bad_block(&nand, i + nand.page_size)) {
    /* Bad block */
    i += nand.block_size;
    size += nand.block_size;
    continue;
#endif
  j = nand_read_page_ll(&nand, buf, i);
  i += j;
  buf += j;
 /* chip Disable */
 nand_deselect();
 return 0;
然后保存为nand_read.c,还要记得路径是在board/samsung/mini2440/目录下。
注意:上面这段代码中对Nand进行寻址的部分,这跟具体的Nand Flash的寻址方式有关。根据我们开发板上的Nand Flash(K9F1G08U0C)数据手册得知,片内寻址是采用27位地址形式。从第0位开始分四次通过I/O0-I/O7进行传送,并进行片内寻址。具体含义和结构图如下(相关概念参考Nand数据手册):
0-11位:Y-Buffers偏移地址
12-27位:X-Buffers偏移地址
u-boot-2009.08在mini2440上的移植(三)
【3】在board/samsung/mini2440/Makefile中添加nand_read.c的编译选项,使他编译到u-boot中,修改后代码如下:
include $(TOPDIR)/config.mk
LIB = $(obj)lib$(BOARD).a
COBJS :=  nand_read.o mini2440.o flash.o
SOBJS := lowlevel_init.o
【4】在mini2440.h头文件中加入Nand要用到的宏和寄存器的定义。
用gedit打开include/configs/mini2440.h头文件,定位到文件末尾处加入下列代码:
 * NAND flash settings
#define CONFIG_S3C2410_NAND_SKIP_BAD 1
【5】在cpu/arm920t/u-boot.lds中添加下面两行代码,主要目的是防止编译器把我们自己添加的用于nandboot的子函数放到4K之后,否则是无法启动的,修改后代码如下:
 .text :
     cpu/arm920t/start.o (.text)
     board/samsung/mini2440/lowlevel_init.o (.text)
     board/samsung/mini2440/nand_read.o (.text)
     *(.text)
3.3,重新编译
编译成功后生成u-boot.bin文件。下载时先将mini2440开发板调到Nor启动档,利用supervivi的a命令将u-boot.bin下载到开发板的Nand Flash中,再把开发板调到Nand启动档,打开电源就从Nand Flash启动了,启动结果如下:
Enter your selection: ?
U-Boot 2009.08 ( 5鏈?06 2011 - 14:17:44)
DRAM:  64 MB
Flash:  2 MB
*** Warning - bad CRC, using default environment
In:    serial
Out:   serial
Err:   serial
[u-boot@MINI2440]#nand info
Unknown command nand' - try 'help'
[u-boot@MINI2440]#
从上面的运行结果看,显然现在的Nand还不能做任何事情,而且也没有显示有关Nand的任何信息,所以只能说明上面的这些步骤只是��成了Nand移植的Stage1部分。下面我们来添加我们开发板上的Nand Flash(K9F1G08U0B)的Stage2部分的有关操作支持。
3.4,在U-boot 启动的第一阶段,初始化了Nand Flash 控制器。但到第二阶段start_armboot函数还是会再次初始化Nand Flash 控制器。因为第二阶段和第一阶段的代码基本是独立的,第一阶段的代码基本只起到代码重定位的作用,到了第二阶段才是真正U-boot 的开始,以前的初始化过程还会重做一遍,比如始化Nand Flash 控制器、CPU 频率等。因为 S3C2440 和S3C2410 之间的很大差别就是:S3C2410 的Nand Flash 控制器只支持512B+16B 的Nand Flash,而S3C2440 还支持2KB+64B 的大容量Nand Flash。所以在Nand Flash 控制器上寄存器和控制流程上的差别很明显,底层驱动代码的修改也是必须的。具体的差别还是需要对比芯片数据手册的,下面我们结合代码来分析一下u-boot在第二阶段的执行流程:
<1>.lib_arm/board.c文件中的start_armboot函数调用了drivers/mtd/nand/nand.c文件中的nand_init函数,如下:
  #if defined(CONFIG_CMD_NAND) //可以看到CONFIG_CMD_NAND宏决定了Nand的初始化
      puts ('NAND: ');
      nand_init();
  #endif
<2>.nand_init调用了同文件下的nand_init_chip函数;
<3>.nand_init_chip函数调用drivers/mtd/nand/s3c2410_nand.c文件下的board_nand_init函数,然后再调用drivers/mtd/nand/nand_base.c函数中的nand_scan函数;
<4>.nand_scan函数调用了同文件下的nand_scan_ident函数等。
【1】Nand Flash 相关代码的修改
打开/drivers/mtd/nand/s3c2410_nand.c,定位到37行,修改如下:
#define S3C2410_ADDR_NALE 4
#define S3C2410_ADDR_NCLE 8
#endif
#if defined(CONFIG_S3C2440)
#define S3C2410_ADDR_NALE 0x08
#define S3C2410_ADDR_NCLE 0x0c
#define NFCONT    __REGb(NF_BASE + 0x4)
#define NFMECCD0   __REGb(NF_BASE + 0x14)
#define NFMECCD1   __REGb(NF_BASE + 0x18)
#define NFSECCD   __REGb(NF_BASE + 0x1c)
#define NFESTAT0 __REGb(NF_BASE + 0x24)
#define NFESTAT1 __REGb(NF_BASE + 0x28)
#define NFMECC0  __REGb(NF_BASE + 0x2c)
#define NFMECC1  __REGb(NF_BASE + 0x30)
#define NFSECC  __REGb(NF_BASE + 0x34)
#define NFSBLK  __REGb(NF_BASE + 0x38)
#define NFEBLK  __REGb(NF_BASE + 0x3c)
#define NFECC0  __REGb(NF_BASE + 0x2c)
#define NFECC1  __REGb(NF_BASE + 0x2d)
#define NFECC2  __REGb(NF_BASE + 0x2e)
#define S3C2410_NFCONT_EN          (1<<0)
#define S3C2410_NFCONT_INITECC     (1<<4)
#define S3C2410_NFCONT_nFCE        (1<<1)
#define S3C2410_NFCONT_MAINECCLOCK (1<<5)
#define S3C2410_NFCONF_TACLS(x)    ((x)<<12)
#define S3C2410_NFCONF_TWRPH0(x)   ((x)<<8)
#define S3C2410_NFCONF_TWRPH1(x)   ((x)<<4)
#endif
ulong IO_ADDR_W = NF_BASE;
static void s3c2410_hwcontrol(struct mtd_info *mtd, int cmd, unsigned int ctrl)
 //struct nand_chip *chip = mtd->priv;
 DEBUGN('hwcontrol(): 0x%02x 0x%02xn', cmd, ctrl);
 if (ctrl & NAND_CTRL_CHANGE) {
  //ulong IO_ADDR_W = NF_BASE;//应注释掉这个局部变量否则找不到ID 'No NAND device found!!!'
 if (!(ctrl & NAND_CLE))
   IO_ADDR_W |= S3C2410_ADDR_NCLE;
  if (!(ctrl & NAND_ALE))
   IO_ADDR_W |= S3C2410_ADDR_NALE;
  //chip->IO_ADDR_W = (void *)IO_ADDR_W;
  if (ctrl & NAND_NCE)
   NFCONF &= ~S3C2410_NFCONF_nFCE;
  else
   NFCONF |= S3C2410_NFCONF_nFCE;
#endif
   NFCONT &= ~S3C2410_NFCONT_nFCE;
  else
   NFCONT |= S3C2410_NFCONT_nFCE;
#endif
 if (cmd != NAND_CMD_NONE)
  //writeb(cmd, chip->IO_ADDR_W);
  writeb(cmd, (void *)IO_ADDR_W);
#ifdef CONFIG_S3C2410_NAND_HWECC
void s3c2410_nand_enable_hwecc(struct mtd_info *mtd, int mode)
 DEBUGN('s3c2410_nand_enable_hwecc(%p, %d)n', mtd, mode);
 NFCONF |= S3C2410_NFCONF_INITECC;
#endif
 NFCONT |= S3C2410_NFCONT_INITECC;
#endif
#endif
int board_nand_init(struct nand_chip *nand)
 u_int32_t cfg;
 u_int8_t tacls, twrph0, twrph1;
 S3C24X0_CLOCK_POWER * const clk_power = S3C24X0_GetBase_CLOCK_POWER();
 DEBUGN('board_nand_init()n');
 clk_power->CLKCON |= (1 << 4);
 /* initialize hardware */
  twrph0 = 3; twrph1 = 0; tacls = 0;
  cfg = S3C2410_NFCONF_EN;
  cfg |= S3C2410_NFCONF_TACLS(tacls - 1);
  cfg |= S3C2410_NFCONF_TWRPH0(twrph0 - 1);
  cfg |= S3C2410_NFCONF_TWRPH1(twrph1 - 1);
  NFCONF = cfg;
 /* initialize nand_chip data structure */
 nand->IO_ADDR_R = nand->IO_ADDR_W = (void *)0x4e00000c;
#endif
  twrph0 = 4; twrph1 = 2; tacls = 0;
  cfg = 0;
  NFCONF = cfg;
  NFCONT = (0<<13)|(0<<12)|(0<<10)|(0<<9)|(0<<8)|(0<<6)|(0<<5)|(1<<4)|(0<<1)|(1<<0);
  nand->IO_ADDR_R = nand->IO_ADDR_W = (void *)0x4e000010;
#endif
 /* read_buf and write_buf are default */
 /* read_byte and write_byte are default */
[1] [2] [3]
关键字:u-boo  mini2440  移植  nand  flash功能 引用地址:u-boot-2009.08在mini2440上的移植 增加nand flash功能
上一篇:u-boot-2009.08在mini2440上的移植 增加nor flash功能
下一篇:u-boot-2009.08在mini2440上的移植 增加DM9000网卡驱动
推荐阅读最新更新时间:2024-11-13 16:46
传海力士和Intel谈判 计划收购大连工厂及3D NAND业务
7月11日,集微网独家获悉,海力士计划收购Intel位于中国大连的Fab 68工厂。知情人士透露,“根据目前进展,海力士正在跟Intel谈判,海力士想收购整个Intel大连工厂和3D NAND业务,Intel只保留与XPoint相关的技术。” “海力士正处在高速扩张阶段,突然被日本断供,急需寻找救命方案。”一业内人士向集微网记者分析,“一方面,Intel大连工厂已基本充分释放产能,可以帮海力士保证产能、维持市场;另一方面,海力士也有可能借助Intel的供应链缓解断供压力。”日本对韩国的断供危机对韩国半导体产业造成了沉重打击,韩国机构分析,如果韩国因日本断供停产,每日损失将高达7万亿韩元。 在此前存储涨价周期中积累了大量的现金流之后
[手机便携]
基于S3C2440的Linux内核移植和yaffs2文件系统制作--启动系统
第三章 启动系统 将前面两章生成的内核映像文件和根文件系统映像文件下载到mini2440开发板,查看启动信息。我成功移植启动信息如下: VIVI version 0.1.4 ( root@capcross ) (gcc version 2.95.3 20010315 (release)) #0.1.4 Mon Oct 27 10:18:15 CST 2008 MMU table base address = 0x33DFC000 Succeed memory mapping. DIVN_UPLL0 MPLLVal CLKDIVN:5h +------------------------------------------
[单片机]
mini2440开发板FTP上传文件的问题
用了一个多月的ubuntu了感觉不错,还是不用虚拟机开发简单。今天切回windows,在VM虚拟机上,用FTP向开发板传输文件,竟然传不了,以前用虚拟机安装fedora9可以传的。但是现在不能了,情况是可以ping 通开发板,但在windows上用ftp 192.168.1.230 (这个是我开发板的ip) 老是出现未知错误,在linux上也连不上开发板。后来发现windows防火墙没关,以为是这个问题,后来发现不是。搞了一个晚上,头都大了。最后终于发现问题了。现在发现遇到问题一定要仔细分析,一定是有原因的。不要瞎着急,乱操作。下面说明一下配置的注意事项: 1:windows防火墙 和linux防火墙 首先都确保关闭 2:笔记
[单片机]
Mini2440移植qt-extended4.4.3
因为项目需求,前段时间在Mini2440上移植了qt-extended4.4.3,现将移植过程简单的说下,希望对做相关的工作的朋友有帮助。 一、开发环境 上位机: Fedora 9.0 交叉编译器版本:arm-linux-gcc4.4.3(友善之臂提供,在此说明下:arm-linux-gcc4.4.3或arm-linux-gcc4.4.2是支持arm9的,建议在arm9上移植不要使用友善之臂提供的arm-linux-gcc4.5(支持的是arm11的)); 网络文件系统目录:/opt/root_nfs/root_qtopia(大家根据自己的情况而定) 开发板LCD版本:w35 开发板bootloader:u-boo
[单片机]
<font color='red'>Mini2440</font><font color='red'>移植</font>qt-extended4.4.3
IC Insights:全球半导体2017年上调市场预测提升至22%
  据IC Insights预测,2017年的IC市场增长率有望提高到22%,较今年年中预期的16%再提升6个百分点,出货量增长率预测也从年中更新的11%上升至目前的14%。大部分市场预测是由于 DRAM 和 NAND 闪存市场的激增。下面就随网络通信小编一起来了解一下相关内容吧。   此外,IC Insights同时调稿对O-S-D(光电子,传感器/执行器和分立器件)市场的预测。总体而言,2017年半导体产业整体预计增长达20%,比年中预期调高5个百分点。   2017年,IC Insights预测 DRAM 的平均售价将大涨77%,预计今年将推动 DRAM 市场至少增长74%,是继1994年DRAM市场78%增长率以来的最大
[网络通信]
u-boot-2009.08在mini2440上的移植 增加I2C EEPROM功能
移植环境 1,主机环境:VMare下CentOS 5.5 ,1G内存。 2,集成开发环境:Elipse IDE 3,编译编译环境:arm-linux-gcc v4.4.3,arm-none-eabi-gcc v4.5.1。 4,开发板:mini2440,2M nor flash,128M nand flash。 5,u-boot版本:u-boot-2009.08 6,参考文章: 10.1,实现u-boot的I2C EEPROM功能 mini2440开发板上的AT24C08A芯片提供了8kbyte的非易失的EEPROM存储空间,而且是通过I2C协议进行读写的,U-boot提供了对I2C和EEPROM的操作支持。 打开/include
[单片机]
明年上半年DRAM吃紧、NAND恐供大于求
集微网消息,内存明年市况恐将不同调,DRAM市场仍将持续吃紧,NAND Flash市场则将于明年上半年转为供过于求。 DRAM 与 NAND Flash 市场今年都处于供不应求状态,产品价格同步高涨,只是业界普遍预期,明年 DRAM 与 NAND Flash 市况恐将不同调。 内存模块厂创见指出,DRAM 市场供货持续吃紧,价格未见松动迹象。 NAND Flash 方面,随着 3D NAND Flash 技术日益成熟,生产良率改善,可望填补供货缺口。 另一内存模块厂威刚表示,短期内全球 DRAM 大厂仍理性看待产能议题,并未有大幅破坏产业生态的计划,持续正面看待 DRAM 市况。 NAND Flash 方面,威刚指出,随着供货商
[手机便携]
2018年内存产业DRAM/NAND Flash恐是两样情
2017年,整体内存产业不论DRAM或NAND Flash,都度过了一个黄金好年,那么2018年可否持续荣景呢? 综合目前业界的看法,DRAM热度可望延续,供不应求态势依旧,但NAND部分,恐怕就不会那么乐观了,由于大厂3D NAND良率大跃进,供给过剩问题已经提前在2017年第四季引爆,至少2018年上半年恐怕都不会太理想, 最快2018年第二季供需平衡,第三季再度供给吃紧,届时产业由悲转喜。 DRAM无新增产能 首先就DRAM部分,以大方向来说,2018年在Fab端并无新增产能,顶多就是制程从2X奈米推进到1X奈米或是1Y奈米,带动位的成长。 市调单位集邦科技更直接表示,2018年各DRAM厂资本支出计划都倾向保守,新增投片量
[手机便携]
小广播
设计资源 培训 开发板 精华推荐
最新单片机文章
何立民专栏 单片机及嵌入式宝典
电子工程世界版权所有 京ICP证060456号 京ICP备10001474号-1 电信业务审批[2006]字第258号函 京公网安备 11010802033920号 Copyright © 2005-2024 EEWORLD.com.cn, Inc. All rights reserved
