#define ACTLR_DODMBS_Pos 10U /*!< ACTLR: DODMBS Position */
#define ACTLR_DODMBS_Msk (1UL << ACTLR_DODMBS_Pos) /*!< ACTLR: DODMBS Mask */
#define ACTLR_SMP_Pos 6U /*!< ACTLR: SMP Position */
#define ACTLR_SMP_Msk (1UL << ACTLR_SMP_Pos) /*!< ACTLR: SMP Mask */
/* CP15的CPACR寄存器
* 参考资料:Cortex-A7 Technical ReferenceManua.pdf P115
typedef union
struct
uint32_t _reserved0:20; /*!< bit: 0..19 Reserved */
uint32_t cp10:2; /*!< bit:20..21 Access rights for coprocessor 10 */
uint32_t cp11:2; /*!< bit:22..23 Access rights for coprocessor 11 */
uint32_t _reserved1:6; /*!< bit:24..29 Reserved */
uint32_t D32DIS:1; /*!< bit: 30 Disable use of registers D16-D31 of the VFP register file */
uint32_t ASEDIS:1; /*!< bit: 31 Disable Advanced SIMD Functionality */
} b; /*!< Structure used for bit access */
uint32_t w; /*!< Type used for word access */
} CPACR_Type;
#define CPACR_ASEDIS_Pos 31U /*!< CPACR: ASEDIS Position */
#define CPACR_ASEDIS_Msk (1UL << CPACR_ASEDIS_Pos) /*!< CPACR: ASEDIS Mask */
#define CPACR_D32DIS_Pos 30U /*!< CPACR: D32DIS Position */
#define CPACR_D32DIS_Msk (1UL << CPACR_D32DIS_Pos) /*!< CPACR: D32DIS Mask */
#define CPACR_cp11_Pos 22U /*!< CPACR: cp11 Position */
#define CPACR_cp11_Msk (3UL << CPACR_cp11_Pos) /*!< CPACR: cp11 Mask */
#define CPACR_cp10_Pos 20U /*!< CPACR: cp10 Position */
#define CPACR_cp10_Msk (3UL << CPACR_cp10_Pos) /*!< CPACR: cp10 Mask */
/* CP15的DFSR寄存器
* 参考资料:Cortex-A7 Technical ReferenceManua.pdf P128
typedef union
struct
uint32_t FS0:4; /*!< bit: 0.. 3 Fault Status bits bit 0-3 */
uint32_t Domain:4; /*!< bit: 4.. 7 Fault on which domain */
uint32_t _reserved0:2; /*!< bit: 8.. 9 Reserved */
uint32_t FS1:1; /*!< bit: 10 Fault Status bits bit 4 */
uint32_t WnR:1; /*!< bit: 11 Write not Read bit */
uint32_t ExT:1; /*!< bit: 12 External abort type */
uint32_t CM:1; /*!< bit: 13 Cache maintenance fault */
uint32_t _reserved1:18; /*!< bit:14..31 Reserved */
} DFSR_Type;
#define DFSR_CM_Pos 13U /*!< DFSR: CM Position */
#define DFSR_CM_Msk (1UL << DFSR_CM_Pos) /*!< DFSR: CM Mask */
#define DFSR_Ext_Pos 12U /*!< DFSR: Ext Position */
#define DFSR_Ext_Msk (1UL << DFSR_Ext_Pos) /*!< DFSR: Ext Mask */
#define DFSR_WnR_Pos 11U /*!< DFSR: WnR Position */
#define DFSR_WnR_Msk (1UL << DFSR_WnR_Pos) /*!< DFSR: WnR Mask */
#define DFSR_FS1_Pos 10U /*!< DFSR: FS1 Position */
#define DFSR_FS1_Msk (1UL << DFSR_FS1_Pos) /*!< DFSR: FS1 Mask */
#define DFSR_Domain_Pos 4U /*!< DFSR: Domain Position */
#define DFSR_Domain_Msk (0xFUL << DFSR_Domain_Pos) /*!< DFSR: Domain Mask */
#define DFSR_FS0_Pos 0U /*!< DFSR: FS0 Position */
#define DFSR_FS0_Msk (0xFUL << DFSR_FS0_Pos) /*!< DFSR: FS0 Mask */
/* CP15的IFSR寄存器
* 参考资料:Cortex-A7 Technical ReferenceManua.pdf P131
typedef union
struct
uint32_t _reserved0:6; /*!< bit: 4.. 9 Reserved */
uint32_t _reserved1:1; /*!< bit: 11 Reserved */
uint32_t _reserved2:19; /*!< bit:13..31 Reserved */
} IFSR_Type;
#define IFSR_ExT_Pos 12U /*!< IFSR: ExT Position */
上一篇:通用裸机-传感器-1-DHT11温湿度sensor
下一篇:IMX6ULL裸机-4-ADC控制器
推荐阅读最新更新时间:2024-11-13 16:46
设计资源 培训 开发板 精华推荐
- LTC3588EDD-1 交流线路供电 3.6V 降压稳压器的典型应用电路,具有大输出电容器以支持重负载
- C500630_CH340S(C109467)USB转打印并口
- 30A机箱风扇集线器[检测通过可用]
- LT1021DIN8-5 电压基准的典型应用,将 10V 单元调整为 10.24V
- NCP130AMX110TCGEVB:NCP130AMX110TCG 偏置轨 LDO 稳压器演示板
- 具有输出排序功能的 LT1940、3.3V 和 5V 双路输出降压转换器的典型应用电路
- EDA工程:采用GD32F103CBT6芯片设计出的系统板
- 心电图模拟
- DC425B,基于 LTC3440EMS 1 MHz 同步降压-升压的演示板,Vin = 2.5 至 5.5V,Vout = 3.3V @ 500mA
- L7806C 跟踪稳压器的典型应用
