S3C2440 spi驱动简单测试
发布者:HarmonyInLife最新更新时间:2024-07-09 来源: elecfans关键字:S3C2440  spi驱动  测试 手机看文章 扫描二维码
随时随地手机看文章
这两天参考网上的资料,自己写了个SPI的驱动,并实际测试通过。
硬件平台:mini2440 用的是S3C2440 的SPI1(共有2个SPI模块)
操作系统:linux-2.6.32.2
测试方法:将SPI的MISO与MOSI管脚短路,这样读数据的时候第一个发出的dummy字节即为收到的字节。
下面是驱动的源代码(mini2440_spi.c):
#include
#include
#include
#include
#include
#include
#include
#include
#include
#include
#include
#include
#include
#include
#include
#include
#include
#include
#include
#include
#include
#include
#include
#include
#include
#include
#include
#include
#include
int loopChar=0x88;
module_param(loopChar,int,S_IRUGO);
static int spi_major = 55;
#define spi_name 'mini2440_spi'
struct cdev spiCdev;
static int spi_open(struct inode *,struct file *);
static int spi_release(struct inode *,struct file *);
static ssize_t spi_write(struct file *filp,const char *buf,size_t count,loff_t *f_ops);
static ssize_t spi_read(struct file *filp,char *buf,size_t count,loff_t *f_ops);
static ssize_t spi_ioctl(struct inode *inode,struct file *filp,unsigned int cmd,unsigned long data);
volatile int *spi_gpfcon=NULL;//GPF Part define
volatile int *spi_gpfdat=NULL;
volatile int *spi_gpfup=NULL;
volatile int *spi_gpgcon=NULL;//GPG Part define
volatile int *spi_gpgdat=NULL;
volatile int *spi_gpgup=NULL;
volatile int *s3c2440_clkcon;
volatile int *spi_spcon1;//SPI Part define
volatile int *spi_spsta1;
volatile int *spi_sppin1;
volatile int *spi_sppre1;
volatile int *spi_sptdat1;
volatile int *spi_sprdat1;
#define SPI_TXRX_READY      (((*spi_spsta1)&0x1) == 0x1)
static const struct file_operations spi_fops =
    .owner=THIS_MODULE,
    .open=spi_open,
    .read=spi_read,
    .ioctl=spi_ioctl,
    .release=spi_release,
    .write=spi_write,
static int spi_open(struct inode *inode,struct file *filp)
    filp->private_data =&spiCdev;
    *PCLK
    /*control PCLK into spi block*/
    *s3c2440_clkcon |=0x40000;
    printk('s3c2440_clkcon=%08Xn',*s3c2440_clkcon);
    *GPG PORTS
    /*config SCK1,MOSI1,MISO1 = 11*/
    *spi_gpgcon |=0x0000FC00;
    /*poll up MISO1 MOSI1,SCK1*/
    *spi_gpgup &=0xFF1F;
    *spi_gpgup |=0x0060;
    *GPF PORTS
    *spi_gpfcon &= 0xFCF3;
    *spi_gpfcon |= 0x0108;
    *spi_gpfup &= 0xED;
    *spi_gpfdat |= 0x10;
    *SPI REGS
    //SPI Baud Rate Prescaler Register,Baud Rate=PCLK/2/(Prescaler value+1)
    *spi_sppre1=0x18;       //freq = 1M
    printk('spi_sppre1=%02Xn',*spi_sppre1);
    //polling,en-sck,master,low,format A,nomal = 0 | TAGD = 1
    *spi_spcon1=(0<<6)|(0<<5)|(1<<4)|(1<<3)|(0<<2)|(0<<1)|(0<<0);
    printk('spi_spcon1=%02Xn',*spi_spcon1);
    //Multi Master error detect disable,reserved,rech=*spi_sprdat0;lease
    *spi_sppin1=(0<<2)|(0<<0);
    printk('spi_sppin1=%02Xn',*spi_sppin1);
    return 0;
static int spi_release(struct inode *inode,struct file *filp)
    //free irq
    free_irq(IRQ_EINT1, NULL);
    printk('<1>releasen');
    return 0;
static void writeByte(const char c)
    int j = 0;
    *spi_sptdat1 = c;
    for(j=0;j<0xFF;j++);
    while(!SPI_TXRX_READY)
static char readByte(void)
    int j = 0;
    char ch = 0;
    *spi_sptdat1 = (char)loopChar;
    ch=*spi_sprdat1;
    return ch;
static ssize_t spi_read(struct file *filp,char __user *buf,size_t count,loff_t *f_ops)
    //int len=0;
    char ch;
    printk('<1>spi read!n');
    ch=readByte();
    copy_to_user(buf,&ch,1);
    return 1;
static ssize_t spi_write(struct file *filp,const char __user *buf,size_t count,loff_t *f_ops)
    int i;
    char *kbuf;
    printk('<1>spi write!,count=%dn',count);
    kbuf=kmalloc(count,GFP_KERNEL);
    if(copy_from_user(kbuf,buf,count))
        printk('no enough memory!n');
        return -1;
    for(i=0;i    {
        writeByte(*kbuf);
        printk('write 0x%02X!n',*kbuf);
        kbuf++;
    return count;
    return 0;
static int __init spi_init(void)
    int result;
    dev_t devno = MKDEV(spi_major, 0);
    if (spi_major)
        result = register_chrdev_region(devno, 1, spi_name);
    else  /**/
        result = alloc_chrdev_region(&devno, 0, 1, spi_name);
        spi_major = MAJOR(devno);
    if (result < 0)
        return result;
    cdev_init(&spiCdev, &spi_fops);
    spiCdev.owner = THIS_MODULE;
    spiCdev.ops = &spi_fops;
    if (cdev_add(&spiCdev, devno, 1))
        printk(KERN_NOTICE 'Error adding spi %d', 0);
    s3c2440_clkcon = (int *)ioremap(0x4C00000c,3);
    spi_gpgcon = (int *)ioremap (0x56000060,4);
    spi_gpgdat = (int *)ioremap (0x56000064,2);
    spi_gpgup = (int *)ioremap (0x56000068,2);
    spi_gpfcon = (int *)ioremap (0x56000050,2);
    spi_gpfdat = (int *)ioremap (0x56000054,1);
    spi_gpfup = (int *)ioremap (0x56000058,1);
    spi_spcon1 = (int *)ioremap(0x59000020,1);
    spi_spsta1 = (int *)ioremap(0x59000024,1);
    spi_sppin1 = (int *)ioremap(0x59000028,1);
    spi_sppre1 = (int *)ioremap(0x5900002c,1);
    spi_sptdat1 = (int *)ioremap(0x59000030,1);
    spi_sprdat1 = (int *)ioremap(0x59000034,1);
    printk('Init spi success!n');
    return result;
static void __exit spi_exit(void)
    cdev_del(&spiCdev);
    unregister_chrdev_region(MKDEV(spi_major, 0), 1);
    printk('<1>spi_exit!n');
module_init(spi_init);
module_exit(spi_exit);
MODULE_LICENSE('GPL');
MODULE_AUTHOR('nkzc');
MODULE_DESCRIPTION('SPI driver for S3C2440');
几点需要注意的地方:
1.一开始在spi_exit()函数中使用了void unregister_chrdev(unsigned int major, const char *name)函数来注销设备,但再次insmod驱动的时候提示'Device or resource busy',改为unregister_chrdev_region()后一切正常,说明即使只注册了一个设备,register_chrdev_region()和unregister_chrdev_region()也要配套使用。
2.定义spi_spcon1等寄存器变量时前面要加上volatile关键字,这样每次访问该变量时cpu会从实际内存中读取该值而不是使用寄存器中的值。尤其是spi_spsta1变量,它的最低位代表了spi发送接收是否ready,如果没有volatile,可能会在readByte()或writeByte()函数中导致死循环。
3.使用了module_param()宏向驱动传递参数,这里定义了一个int型的loopChar参数,加载模块时使用insmod mini2440_spi.ko loopChar=123 来设置loopChar的值。
测试程序:spi_test.c
#include
#include
#include
#include
#include
#include
#include
int main(int argc, char **argv)
    int fd;
    int count=0;
    char buf[]={0x11,0x22,0x33,0x44,0x55};
    fd = open('/dev/mini2440_spi', O_RDWR);
    if (fd < 0) {
        perror('open device spi');
        exit(1);
    count=write(fd,buf,sizeof(buf)/sizeof(buf[0]));
    read(fd,buf,1);
    printf('read byte is: 0x%02Xn',buf[0]);
    close(fd);
    return 0;
很简单的一个程序,分别调用了open,write,read,close函数,可以观察输出结果,验证驱动程序是否正确,read的输出即为loopChar的值。
注意:open的时候要注意第二个参数flag,只有当flag为O_RDWR时,驱动中的相应的spi_read,spi_write函数才会被调用。
关键字:S3C2440  spi驱动  测试 引用地址:S3C2440 spi驱动简单测试
上一篇:linux-2.6.32在mini2440开发板上移植 移植I2C-EEPROM 驱动
下一篇:ARM9 S3C2440 定时器中断
推荐阅读最新更新时间:2024-11-11 14:02
通用汽车或将推出无人驾驶打车服务 正进行内部测试
  北京时间8月9日早间消息,去年, 通用 汽车收购Crusie Automation,增强了自动驾驶汽车部门的实力。Crusie开发的工具能够将奥迪S4或者A4汽车变成自动驾驶汽车,有了它的技术, 通用 汽车准备与Lyft合作部署300多辆 无人驾驶 汽车, 通用 汽车曾向Lyft投资。下面就随汽车电子小编一起来了解一下相关内容吧。   现在通用汽车正在测试应用,通过该应用旧金山的员工可以搭乘雪佛兰Bolt EV去城市的任何地方。通用汽车说新服务名叫“Cruise Anywhere”,它已经成为部分员工出行的主要方式。   Cruise CEO兼联合创始人凯利·沃格特(Kyle Vogt)表示:“我们一直强调说,我们会率先推出
[汽车电子]
UR + Robotiq: 灵活高效的即插即用解决方案
现如今,几乎全球所有工厂都在面临一个非常棘手的问题:缺乏足够的员工来维持工厂运行。针对这一问题,加拿大即插即用自动化工具公司Robotiq的答案就是:交给让机器人来做。制造商需要把资金投资于易于安装使用的平台,并将该平台标准化,这样可以不断地重用组件,减少定制,让操作和维护都变得非常容易、简单。此外,也要着重于人员培训,分享内部自动化方面的专业知识。 UR+Robotiq就是一个符合上述要求的机器人平台,它把Robotiq的夹抓、摄像头和力传感器这些部件与UR机器人组合在一起,是一个整合的、易于操作的、标准化平台。 在中国深圳举办的优傲机器人2017年中国经销商大会上,Robotiq公司CEO Bouchard
[工业控制]
NI技术提升ADAS和自动驾驶汽车的安全性和可靠性测试
NI(美国国家仪器,National Instruments, 简称NI) 作为致力于为工程师和科学家提供基于平台的系统解决方案来应对全球最严峻工程挑战的供应商,近日宣布推出车载雷达测试系统(Vehicle Radar Test System, VRTS)。VRTS可用于测试从研发实验室到量产、从单个雷达传感器到集成先进驾驶辅助系统(ADAS)等应用使用的76-81 GHz雷达技术。 客户可以从NI精选的联盟合作伙伴处购买VRTS,这些联盟伙伴为用户提供先进系统集成和支持服务。 VRTS结合了NI的毫米波前端技术、PXI矢量信号收发器(VST)和针对特定应用的软件。不同于传统汽车雷达模拟器,在功能行为测试中只能生成障碍物,VR
[物联网]
ARM历程十——毕业设计(钟表)
#include S3C2440addr.h #include math.h #define pi 3.141593 U16 SEC, MIN, HOUR, TmpSEC_10, TmpMIN_10, TmpHOUR_10,TmpSEC_1,TmpMIN_1,TmpHOUR_1; U16 SEC_x, SEC_y, MIN_x, MIN_y, HOUR_x, HOUR_y, OldMIN=10000; U16 PandColor_big ; U16 PandColor_sml ; extern U16 Flag; extern U16 fz; extern const unsigned char gImage_goback
[单片机]
手机市场迈入成熟期 高通力推VR芯片并开放测试
     手机销售成长趋缓已是不争的事实,这对手机芯片龙头高通(Qualcomm)造成的影响最大,加上高通长期客户苹果(Apple)预测季营收将出现13年来首度下滑,因此不少分析师已调降高通的营收展望。   据The Motley Fool网站报导,向来是高通主要收入来源的手机市场过去几年的爆发性成长期已过,2014年手机出货成长率为24%,2015年则降至13%。研调机构Gartner预测,2016年的成长率只有2.6%,消费者购买手机的预算也只小幅增加1.2%。   受到全球手机市场减缓和低价手机芯片的冲击,高通正积极朝新科技转型。除进军车用芯片市场,更推出支援虚拟实境(VR)的Snapdragon 820芯片及软体
[手机便携]
测试应用介绍示波器的使用方法
示波器的作用无可取代,它一直是工程师设计、调试产品的好帮手。但随着计算机、半导体和通信技术的发展,示波器的种类、型号越来越多,从而使示波器的作用得到详细的划分。示波器虽然分成好几类,各类又有许多种型号,但是一般的示波器除频带宽度、输入灵敏度等不完全相同外,但示波器的使用方法在基本方面都是相同的。下面小编从测试应用发面来介绍一下示波器的作用和它的基础使用方法。   示波器的作用是利用电子示波管的特性,将人眼无法直接观测的交变电信号转换成图像,显示在荧光屏上以便测量的电子测量仪器。它是观察数字电路实验现象、分析实验中的问题、测量实验结果必不可少的重要仪器。示波器由示波管和电源系统、同步系统、X轴偏转系统、Y轴偏转系统、延迟扫描系统、标
[测试测量]
开关损耗和传导损耗测试(连载六):损耗测试步骤要点
我们将介绍测试电源开关损耗和传导损耗的各个步骤。 记住,经过电源开关和磁性器件的开关损耗和传导损耗对系统整体损耗有着巨大影响,正因如此,应尽可能精确地使这些损耗达到最小,这一点至关重要。 MSO5000B示波器测量开关损耗和传导损耗的实例。 首先,记住不要单纯依赖产品技术资料,它们经常会产生误导,特别是在计算开关损耗和传导损耗时。此外,它们没有考虑工作条件和电路寄生信号,也没有提供完善的损耗信息。 在测试时,首先应检查整流器开关,如电路活动和负载时MOSFETs、IGBTs和磁性器件的损耗。由于大多数磁性器件采用定制设计,如开关器件,因此最好在工作状态下测试磁性器件。这一步可以正确分析
[测试测量]
开关损耗和传导损耗<font color='red'>测试</font>(连载六):损耗<font color='red'>测试</font>步骤要点
小广播
设计资源 培训 开发板 精华推荐
最新单片机文章
何立民专栏 单片机及嵌入式宝典
电子工程世界版权所有 京ICP证060456号 京ICP备10001474号-1 电信业务审批[2006]字第258号函 京公网安备 11010802033920号 Copyright © 2005-2024 EEWORLD.com.cn, Inc. All rights reserved
