1 仿真现象
2 程序设计
2.1 主程序
#include
#include 'DisplaySmg.h'
#include 'Timer0.h'
unsigned int adc_result = 1234;
void disp_num(void) //显示四位十进制数
if(adc_result>=1000) //千位
LedBuf[0]= adc_result/1000;
else
LedBuf[0]=23; //不显示
if(adc_result>=100) //百位
LedBuf[1]= adc_result/100%10;
else
LedBuf[1]=23; //不显示
if(adc_result>=10) //十位
LedBuf[2]= adc_result/10%10;
else
LedBuf[2]=23; //不显示
LedBuf[3]= adc_result%10; //个位
void main()
Timer0_Init(); //定时/计数器T0初始化
EA=1; //中断总开关
DotDig1=1; //点亮第二个数码管的小数点
while(1)
disp_num(); //显示数据
void Timer0_ISR(void) interrupt 1
TR0=0; //关闭定时器
DisplaySmg(); //每过1ms,刷新一次数码管显示函数
TL0 = 0x66; //设置定时初始值,定时1ms
TH0 = 0xFC; //设置定时初始值,定时1ms
TR0=1; //打开定时器
2.2 数码管显示函数模块
#ifndef __DisplaySmg_H__
#define __DisplaySmg_H__
#include
#define GPIO_SEG P0 //段选端
#define GPIO_SEL P2 //位选端
extern unsigned char LedBuf[]; //外部变量声明
extern unsigned char DotDig0,DotDig1,DotDig2,DotDig3;
void DisplaySmg(void);
#endif
unsigned char code LedData[]={ //共阴型数码管的段码表,字符,序号
0x3F, //'0',0
0x06, //'1',1
0x5B, //'2',2
0x4F, //'3',3
0x66, //'4',4
0x6D, //'5',5
0x7D, //'6',6
0x07, //'7',7
0x7F, //'8',8
0x6F, //'9',9
0x77, //'A',10
0x7C, //'B',11
0x39, //'C',12
0x5E, //'D',13
0x79, //'E',14
0x71, //'F',15
0x76, //'H',16
0x38, //'L',17
0x37, //'n',18
0x3E, //'u',19
0x73, //'P',20
0x5C, //'o',21
0x40, //'-',22
0x00, //熄灭 23
unsigned char DotDig0=0,DotDig1=0,DotDig2=0,DotDig3=0; //小数点控制位
unsigned char code LedAddr[]={0xfe,0xfd,0xfb,0xf7}; //数码管位选
unsigned char LedBuf[]={22,22,22,22}; //显示缓存区
void DisplaySmg() //四位数码管,考虑小数点
unsigned char i; //等价于 'static unsigned char i = 0;'
unsigned char temp;
switch(i)
case 0:
GPIO_SEG = 0x00; //消影
if(DotDig0==1) //小数点
temp = LedData[LedBuf[0]] | 0x80; //点亮小数点
else
temp = LedData[LedBuf[0]];
GPIO_SEG = temp; //段码
GPIO_SEL = LedAddr[0]; //位选
i++;
break;
case 1:
GPIO_SEG = 0x00;
if(DotDig1==1) //小数点
temp = LedData[LedBuf[1]] | 0x80;
else
temp = LedData[LedBuf[1]];
GPIO_SEG = temp;
GPIO_SEL = LedAddr[1];
i++;
break;
case 2:
GPIO_SEG = 0x00;
if(DotDig2==1) //小数点
temp = LedData[LedBuf[2]] | 0x80;
else
temp = LedData[LedBuf[2]];
GPIO_SEG = temp;
GPIO_SEL = LedAddr[2];
i++;
break;
case 3:
GPIO_SEG = 0x00;
if(DotDig3==1) //小数点
temp = LedData[LedBuf[3]] | 0x80;
else
temp = LedData[LedBuf[3]];
GPIO_SEG = temp;
GPIO_SEL = LedAddr[3];
i=0;
break;
default:break;
2.3 定时计数器模块
#ifndef __Timer0_H__
#define __Timer0_H__
#include
void Timer0_Init(void);
#endif
#include 'Timer0.h'
void Timer0_Init(void) //1毫秒@11.0592MHz
TMOD &= 0xF0; //设置定时器模式
TMOD |= 0x01; //设置定时器模式
TF0 = 0; //清除TF0标志
TR0 = 1; //定时器0开始计时
ET0 = 1; //定时器0中断开关
// EA = 1; //中断总开关
//中断服务函数一定是一个没有返回值的函数
//中断服务函数一定是没有参数的函数
//中断服务函数函数名后跟着关键字interrupt
//interrupt n 0~4 5个中断源,8*n+0003H
// 0003H INT0, 00BH T0, 0013H INT1, 001BH T1, 0023H ES
//中断服务函数不能被主程序或者其他程序所调用
//n后面跟着using m(0~3)工作寄存器组
//void Timer0_ISR(void) interrupt 1
// TL0 = 0x66; //设置定时初始值
// TH0 = 0xFC; //设置定时初始值
3 参考来源
(1)单片机应用——ADC0809查询方式实现一路模拟信号的A/D转换(数码管显示)_哔哩哔哩_bilibili;
上一篇:简易数字电压表+ADC0809+程序查询(延时等待)方式
下一篇:数码管动态显示+定时器中断方式+Protues
推荐阅读最新更新时间:2024-11-17 12:56
设计资源 培训 开发板 精华推荐
- 使用 Richtek Technology Corporation 的 RT7249 的参考设计
- 使用 Richtek Technology Corporation 的 RT9363A 的参考设计
- 英集芯-IP2315评估板(OEM)
- 使用 Analog Devices 的 LTM4636-1EY 的参考设计
- 使用符合 EN50121-3-2(双输出)具有 EMC 滤波的 RP40-2412SFR DC/DC 转换器的典型应用
- AM1G-4807SZ 7.2V 1 瓦 DC/DC 转换器的典型应用
- NB6N14SMNGEVB,时钟/数据接收器评估板
- 基于MP9928-SW2303的快充电源模块
- SY898542 EV,用于 SY89542、2.5V、3.2 Gbps LVDS 多路复用器的评估板,带内部终端
- 51最小系统贴片-STC89C52RC
