S3C2440实现dm9000网卡驱动程序移植
发布者:xi24最新更新时间:2024-08-05 来源: cnblogs关键字:S3C2440  dm9000  网卡驱动  程序移植 手机看文章 扫描二维码
随时随地手机看文章
 763     }else
 764         if (db->tx_pkt_cnt >= 2) return 1;
 765
 766     /* packet counting */
 767     db->tx_pkt_cnt++;
 768
 769     db->stats.tx_packets++;
 770     db->stats.tx_bytes+=skb->len;
 771     if (db->chip_revision != 0x1A)
 772     {
 773         if (db->Speed == 10)
 774             {if (db->tx_pkt_cnt >= 1) netif_stop_queue(dev);}
 775         else
 776             {if (db->tx_pkt_cnt >= 2) netif_stop_queue(dev);}
 777     }else
 778         if (db->tx_pkt_cnt >= 2) netif_stop_queue(dev);
 779
 780     /* Disable all interrupt */
 781     iow(db, DM9KS_IMR, DM9KS_DISINTR);
 782
 783     MDWAH = ior(db,DM9KS_MDWAH);
 784     MDWAL = ior(db,DM9KS_MDWAL);
 785
 786     /* Set TX length to reg. 0xfc & 0xfd */
 787     iow(db, DM9KS_TXPLL, (skb->len & 0xff));
 788     iow(db, DM9KS_TXPLH, (skb->len >> 8) & 0xff);
 789
 790     /* Move data to TX SRAM */
 791     data_ptr = (char *)skb->data;
 792
 793     outb(DM9KS_MWCMD, db->io_addr); // Write data into SRAM trigger
 794     switch(db->io_mode)
 795     {
 796         case DM9KS_BYTE_MODE:
 797             for (i = 0; i < skb->len; i++)
 798                 outb((data_ptr[i] & 0xff), db->io_data);
 799             break;
 800         case DM9KS_WORD_MODE:
 801             tmplen = (skb->len + 1) / 2;
 802             for (i = 0; i < tmplen; i++)
 803         outw(((u16 *)data_ptr)[i], db->io_data);
 804       break;
 805     case DM9KS_DWORD_MODE:
 806       tmplen = (skb->len + 3) / 4;
 807             for (i = 0; i< tmplen; i++)
 808                 outl(((u32 *)data_ptr)[i], db->io_data);
 809             break;
 810     }
 811
 812 #ifndef ETRANS
 813     /* Issue TX polling command */
 814     iow(db, DM9KS_TCR, 0x1); /* Cleared after TX complete*/
 815 #endif
 816
 817     #ifdef TDBUG /* check TX FIFO pointer */
 818             MDWAH1 = ior(db,DM9KS_MDWAH);
 819             MDWAL1 = ior(db,DM9KS_MDWAL);
 820             tx_ptr = (MDWAH<<8)|MDWAL;
 821             switch (db->io_mode)
 822             {
 823                 case DM9KS_BYTE_MODE:
 824                     tx_ptr += skb->len;
 825                     break;
 826                 case DM9KS_WORD_MODE:
 827                     tx_ptr += ((skb->len + 1) / 2)*2;
 828                     break;
 829                 case DM9KS_DWORD_MODE:
 830                     tx_ptr += ((skb->len+3)/4)*4;
 831                     break;
 832             }
 833             if (tx_ptr > 0x0bff)
 834                     tx_ptr -= 0x0c00;
 835             if (tx_ptr != ((MDWAH1<<8)|MDWAL1))
 836                     printk('[dm9ks:TX FIFO ERRORn');
 837     #endif
 838     /* Saved the time stamp */
 839     dev->trans_start = jiffies;
 840     db->cont_rx_pkt_cnt =0;
 841
 842     /* Free this SKB */
 843     dev_kfree_skb(skb);
 844
 845     /* Re-enable interrupt */
 846     iow(db, DM9KS_IMR, DM9KS_REGFF);
 847
 848     return 0;
 849 }
 850
 851 /*
 852   Stop the interface.
 853   The interface is stopped when it is brought.
 854 */
 855 static int dmfe_stop(struct net_device *dev)
 856 {
 857     board_info_t *db = (board_info_t *)dev->priv;
 858     DMFE_DBUG(0, 'dmfe_stop', 0);
 859
 860     /* deleted timer */
 861     del_timer(&db->timer);
 862
 863     netif_stop_queue(dev);
 864
 865     /* free interrupt */
 866     free_irq(dev->irq, dev);
 867
 868     /* RESET devie */
 869     phy_write(db, 0x00, 0x8000);    /* PHY RESET */
 870     //iow(db, DM9KS_GPR, 0x01);     /* Power-Down PHY */
 871     iow(db, DM9KS_IMR, DM9KS_DISINTR);    /* Disable all interrupt */
 872     iow(db, DM9KS_RXCR, 0x00);    /* Disable RX */
 873
 874     /* Dump Statistic counter */
 875 #if FALSE
 876     printk('nRX FIFO OVERFLOW %lxn', db->stats.rx_fifo_errors);
 877     printk('RX CRC %lxn', db->stats.rx_crc_errors);
 878     printk('RX LEN Err %lxn', db->stats.rx_length_errors);
 879     printk('RESET %xn', db->reset_counter);
 880     printk('RESET: TX Timeout %xn', db->reset_tx_timeout);
 881     printk('g_TX_nsr %xn', g_TX_nsr);
 882 #endif
 883
 884     return 0;
 885 }
 886
 887 static void dmfe_tx_done(unsigned long unused)
 888 {
 889     struct net_device *dev = dmfe_dev;
 890     board_info_t *db = (board_info_t *)dev->priv;
 891     int  nsr;
 892
 893     DMFE_DBUG(0, 'dmfe_tx_done()', 0);
 894
 895     nsr = ior(db, DM9KS_NSR);
 896     if (nsr & 0x0c)
 897     {
 898         if(nsr & 0x04) db->tx_pkt_cnt--;
 899         if(nsr & 0x08) db->tx_pkt_cnt--;
 900         if(db->tx_pkt_cnt < 0)
 901         {
 902             printk(KERN_DEBUG 'DM9KS:tx_pkt_cnt ERROR!!n');
 903             while(ior(db,DM9KS_TCR) & 0x1){}
 904             db->tx_pkt_cnt = 0;
 905         }
 906
 907     }else{
 908         while(ior(db,DM9KS_TCR) & 0x1){}
 909         db->tx_pkt_cnt = 0;
 910     }
 911
 912     netif_wake_queue(dev);
 913
 914     return;
 915 }
 916
 917 /*
 918   DM9000 insterrupt handler
 919   receive the packet to upper layer, free the transmitted packet
 920 */
 921 #if LINUX_VERSION_CODE < KERNEL_VERSION(2,5,0)
 922 static void dmfe_interrupt(int irq, void *dev_id, struct pt_regs *regs)
 923 #else
 924     #if LINUX_VERSION_CODE < KERNEL_VERSION(2,6,19)
 925     static irqreturn_t dmfe_interrupt(int irq, void *dev_id, struct pt_regs *regs)
 926     #else
 927     static irqreturn_t dmfe_interrupt(int irq, void *dev_id) /* for kernel 2.6.20*/
 928     #endif
 929 #endif
 930 {
 931     struct net_device *dev = dev_id;
 932     board_info_t *db;
 933     int int_status,i;
 934     u8 reg_save;
 935
 936     DMFE_DBUG(0, 'dmfe_interrupt()', 0);
 937
 938     /* A real interrupt coming */
 939     db = (board_info_t *)dev->priv;
 940     spin_lock(&db->lock);
 941
[1].. [11] [12] [13] [14] [15] [16] [17] [18] [19] [20]
关键字:S3C2440  dm9000  网卡驱动  程序移植 引用地址:S3C2440实现dm9000网卡驱动程序移植
上一篇:s3c2440的USB热插拔驱动问题
下一篇:S3C实现DMA驱动程序编写
推荐阅读最新更新时间:2024-11-13 19:29
S3C2440时钟系统详解
在讲述系统时钟之前,因为这些设备都是挂靠在系统时钟上的,所以必须先说系统时钟,S3C2440的时钟系统如下 外部时钟源分两种,晶振或者外部频率,由om3-2选择,时钟电路根据两种选择也有两种 我们来分析时钟图可以得到以下结论: 经过选择的外部时钟进入MPLL,进行锁相环倍频,经过锁相环之后的时钟MPLL_IN分成了三股,分别是FCLK,HCLK,PCLK.这其中HCLK和PCLK又是从HCLK分频得到的,最后ARM920T这个系统内核模块得到了两个时钟HCLK和FCLK,DMA控制器,LCD控制器,内存控制器,总线控制器,外部nand控制器和TIC,摄像头接口都来自于HCLK时钟,LCD控制器,nand控制器,cam摄像头
[单片机]
<font color='red'>S3C2440</font>时钟系统详解
了解S3C2440触摸屏驱动的原理及其应用
一、开发环境 主 机:VMWare--Fedora 9 开发板:Mini2440--64MB Nand, Kernel:2.6.30.4 编译器:arm-linux-gcc-4.3.2 二、前提知识 1、Linux输入子系统(Input Subsystem): 在Linux中,输入子系统是由输入子系统设备驱动层、输入子系统核心层(Input Core)和输入子系统事件处理层(Event Handler)组成。其中设备驱动层提供对硬件各寄存器的读写访问和将底层硬件对用户输入访问的响应转换为标准的输入事件,再通过核心层提交给事件处理层;而核心层对下提供了设备驱动层的编程接口,对上又提供了事件处理层的编程接口;而事件处理层就为我们用
[单片机]
了解<font color='red'>S3C2440</font>触摸屏<font color='red'>驱动</font>的原理及其应用
STM32网络通信之DM9000了解
简介: 3.3V 供电,IO端口最高支持5V,提供两个接口,一个是可以以8、16、32这三种不同的方式与处理器相连接的接口,一个是与EEPROM连接的I2C接口,如此在外接的EEPROM中可以存放要缓存的数据信息。此外,DM9000内部有一个16K缓存数据区,分为发送FIFO缓冲区和接收FIFO缓冲区。 DM9000有三类寄存器,数据寄存器、状态寄存器和控制寄存器。 常用到的寄存器有6个: (1)网络控制寄存器 NCR 作用:对DM9000芯片的网络相关功能的配置,各位解释如下: (2)网络状态寄存器 NSR 作用: 寄存器的各位表示网络连接状态,通过这些标志位判断芯片的状态,写驱动的时候,一般会用到连接
[单片机]
STM32网络通信之<font color='red'>DM9000</font>了解
s3c2440实时时钟中断
s3c2440实时时钟(RTC)中,定义了两个中断源:报警中断和时间节拍中断。前面有网友问到了这两个中断的用法,最近我抽出时间对这两个中断研究了一番,发现这两个中断都很实用。现在就给大家介绍一下它们的用法。 时间节拍中断,顾名思义,就像一个节拍器,可以等时性的控制节拍。因此它类似于定时器中断。但时间节拍中断是毫秒级的,而定时器中断可以达到微秒,甚至更小级别。时间节拍中断的周期公式为:(n+1) 128,单位是秒,即每隔这么长时间,会中断一次。其中n的值为1~127,它存储在寄存器TICNT的低6位中,当寄存器TICNT的第7位被置1时,表示开启时间节拍中断,这时n递减,当减为0时,进入时间节拍中断。 报警中断可以
[单片机]
基于S3C2440嵌入式系统的以太网接口电路设计方案
文章主要介绍了一个基于三星ARM9芯片S3C2440嵌入式系统的以太网接口电路设计方案,采用了工业级以太网控制器DM9000AEP成功实现了嵌入式系统网络数据交换。论文在重点阐述了网络接口电路基础之上,对Windows CE系统控制软件部分DM9000AEP的驱动程序和注册表项进行了具体分析。 随着微电子技术和计算机技术的发展,嵌入式技术得到广阔的发展,已成为现代工业控制、通信类和消费类产品发展的方向。以太网在实时操作、可靠传输、标准统一等方面的卓越性能及其便于安装、维护简单、不受通信距离限制等优点,已经被国内外很多监控、控制领域的研究人员广泛关注,并在实际应用中展露出显着的优势。本文提出了一种基于DM9000AE网络接口
[单片机]
基于<font color='red'>S3C2440</font>嵌入式系统的以太网接口电路设计方案
S3C2440——使用URAT0中断方式发送和接收字符串
设置中断向量表 ;文件ASM_Interrupt.s ;(1)设置中断向量表 Mode_USR EQU 0x50 ;IRQ中断开放,FIQ中断关闭 Mode_FIQ EQU 0xD1 ;关闭IRQ、FIQ中断 Mode_IRQ EQU 0xD2 ;关闭IRQ、FIQ中断 Mode_SVC EQU 0xD3 ;关闭IRQ、FIQ中断 GET 2440Reg_addr.inc AREA MyCode, CODE,READONLY IMPORT Uart_Init IMPORT INT_UART0 ENTRY ;设置中断向量表 B
[单片机]
S3C2440时钟电源管理
S3C2440的时钟可以选用晶振(XTAL),也可以使用外部时钟(EXTCLK),由系统复位时,在复位信号上升沿对引脚OM3、OM2所测的状态来确定。由于我所用的开发板这两个引脚接地,故外部晶振作为主锁相环(MPLL)和usb锁相环(UPLL)的时钟源。 含有两个锁相环MPLL、UPLL产生系统所需要的不同频率的时钟 MPLL: 为CPU产生FCLK时钟 为AHB产生HCLK时钟 为APB产生PCLK时钟 UPLL: 为usb(Host and Device)产生UCLK(48M) FCLK,HCLK和 PCLK FCLK是提供给ARM920T 的时钟。 HCLK 是提供给用于 ARM920T,存储器控制器,中断控
[单片机]
<font color='red'>S3C2440</font>时钟电源管理
linux 2.6.32 在arm9(s3c2440)平台的移植
板子用的友善的mini2440, 起初按照光盘提供的手册, 照猫画虎,,,,,,,,,但是遇到各种问题, 很多未解决.....原因是还没理解每层目录的Makefile和Kconfig的关系, 以及在Kernel Configure菜单树中对应的选项, 以及对nand_flash设备的结构体的意义没搞清楚,~ so~ 在http://www.kernel.org/ 下载2.6.32的源代码. 编译器用的arm-linux-gcc 4.1.2 . 1 内核代码/uboot代码中中机器码的定义位置,在/root/linux-2.6.32/arch/arm/tools/mach-types 和 uboot/include/asm-
[单片机]
小广播
设计资源 培训 开发板 精华推荐
最新单片机文章
何立民专栏 单片机及嵌入式宝典
电子工程世界版权所有 京ICP证060456号 京ICP备10001474号-1 电信业务审批[2006]字第258号函 京公网安备 11010802033920号 Copyright © 2005-2024 EEWORLD.com.cn, Inc. All rights reserved
