S3C2440实现dm9000网卡驱动程序移植
发布者:xi24最新更新时间:2024-08-05 来源: cnblogs关键字:S3C2440  dm9000  网卡驱动  程序移植 手机看文章 扫描二维码
随时随地手机看文章
 865     iow(db, DM9KS_RXCR, 0x00);    /* Disable RX */
 866
 867     /* Dump Statistic counter */
 868 #if FALSE
 869     printk('nRX FIFO OVERFLOW %lxn', db->stats.rx_fifo_errors);
 870     printk('RX CRC %lxn', db->stats.rx_crc_errors);
 871     printk('RX LEN Err %lxn', db->stats.rx_length_errors);
 872     printk('RESET %xn', db->reset_counter);
 873     printk('RESET: TX Timeout %xn', db->reset_tx_timeout);
 874     printk('g_TX_nsr %xn', g_TX_nsr);
 875 #endif
 876
 877     return 0;
 878 }
 879
 880 static void dmfe_tx_done(unsigned long unused)
 881 {
 882     struct net_device *dev = dmfe_dev;
 883     board_info_t *db = (board_info_t *)dev->priv;
 884     int  nsr;
 885
 886     DMFE_DBUG(0, 'dmfe_tx_done()', 0);
 887
 888     nsr = ior(db, DM9KS_NSR);
 889     if (nsr & 0x0c)
 890     {
 891         if(nsr & 0x04) db->tx_pkt_cnt--;
 892         if(nsr & 0x08) db->tx_pkt_cnt--;
 893         if(db->tx_pkt_cnt < 0)
 894         {
 895             printk(KERN_DEBUG 'DM9KS:tx_pkt_cnt ERROR!!n');
 896             while(ior(db,DM9KS_TCR) & 0x1){}
 897             db->tx_pkt_cnt = 0;
 898         }
 899
 900     }else{
 901         while(ior(db,DM9KS_TCR) & 0x1){}
 902         db->tx_pkt_cnt = 0;
 903     }
 904
 905     netif_wake_queue(dev);
 906
 907     return;
 908 }
 909
 910 /*
 911   DM9000 insterrupt handler
 912   receive the packet to upper layer, free the transmitted packet
 913 */
 914 #if LINUX_VERSION_CODE < KERNEL_VERSION(2,5,0)
 915 static void dmfe_interrupt(int irq, void *dev_id, struct pt_regs *regs)
 916 #else
 917     #if LINUX_VERSION_CODE < KERNEL_VERSION(2,6,19)
 918     static irqreturn_t dmfe_interrupt(int irq, void *dev_id, struct pt_regs *regs)
 919     #else
 920     static irqreturn_t dmfe_interrupt(int irq, void *dev_id) /* for kernel 2.6.20*/
 921     #endif
 922 #endif
 923 {
 924     struct net_device *dev = dev_id;
 925     board_info_t *db;
 926     int int_status,i;
 927     u8 reg_save;
 928
 929     DMFE_DBUG(0, 'dmfe_interrupt()', 0);
 930
 931     /* A real interrupt coming */
 932     db = (board_info_t *)dev->priv;
 933     spin_lock(&db->lock);
 934
 935     /* Save previous register address */
 936     reg_save = inb(db->io_addr);
 937
 938     /* Disable all interrupt */
 939     iow(db, DM9KS_IMR, DM9KS_DISINTR);
 940
 941     /* Got DM9000/DM9010 interrupt status */
 942     int_status = ior(db, DM9KS_ISR);        /* Got ISR */
 943     iow(db, DM9KS_ISR, int_status);        /* Clear ISR status */
 944
 945     /* Link status change */
 946     if (int_status & DM9KS_LINK_INTR)
 947     {
 948         netif_stop_queue(dev);
 949         for(i=0; i<500; i++) /*wait link OK, waiting time =0.5s */
 950         {
 951             phy_read(db,0x1);
 952             if(phy_read(db,0x1) & 0x4) /*Link OK*/
 953             {
 954                 /* wait for detected Speed */
 955                 for(i=0; i<200;i++)
 956                     udelay(1000);
 957                 /* set media speed */
 958                 if(phy_read(db,0)&0x2000) db->Speed =100;
 959                 else db->Speed =10;
 960                 break;
 961             }
 962             udelay(1000);
 963         }
 964         netif_wake_queue(dev);
 965         //printk('[INTR]i=%d speed=%dn',i, (int)(db->Speed));
 966     }
 967     /* Received the coming packet */
 968     if (int_status & DM9KS_RX_INTR)
 969         dmfe_packet_receive(dev);
 970
 971     /* Trnasmit Interrupt check */
 972     if (int_status & DM9KS_TX_INTR)
 973         dmfe_tx_done(0);
 974
 975     if (db->cont_rx_pkt_cnt>=CONT_RX_PKT_CNT)
 976     {
 977         iow(db, DM9KS_IMR, 0xa2);
 978     }
 979     else
 980     {
 981         /* Re-enable interrupt mask */
 982         iow(db, DM9KS_IMR, DM9KS_REGFF);
 983     }
 984
 985     /* Restore previous register address */
 986     outb(reg_save, db->io_addr);
 987
 988     spin_unlock(&db->lock);
 989 #if LINUX_VERSION_CODE > KERNEL_VERSION(2,5,0)
 990     return IRQ_HANDLED;
 991 #endif
 992 }
 993
 994 /*
 995   Get statistics from driver.
 996 */
 997 static struct net_device_stats * dmfe_get_stats(struct net_device *dev)
 998 {
 999     board_info_t *db = (board_info_t *)dev->priv;
1000     DMFE_DBUG(0, 'dmfe_get_stats', 0);
1001     return &db->stats;
1002 }
1003 /*
1004  *    Process the ethtool ioctl command
1005  */
1006 static int dmfe_ethtool_ioctl(struct net_device *dev, void *useraddr)
1007 {
1008     //struct dmfe_board_info *db = dev->priv;
1009     struct ethtool_drvinfo info = { ETHTOOL_GDRVINFO };
1010     u32 ethcmd;
1011
1012     if (copy_from_user(ðcmd, useraddr, sizeof(ethcmd)))
1013         return -EFAULT;
1014
1015     switch (ethcmd)
1016     {
1017         case ETHTOOL_GDRVINFO:
1018             strcpy(info.driver, DRV_NAME);
1019             strcpy(info.version, DRV_VERSION);
1020
1021             sprintf(info.bus_info, 'ISA 0x%lx %d',dev->base_addr, dev->irq);
1022             if (copy_to_user(useraddr, &info, sizeof(info)))
1023                 return -EFAULT;
1024             return 0;
1025     }
1026
1027     return -EOPNOTSUPP;
1028 }
1029 /*
1030   Process the upper socket ioctl command
1031 */
1032 static int dmfe_do_ioctl(struct net_device *dev, struct ifreq *ifr, int cmd)
1033 {
1034     board_info_t *db = (board_info_t *)dev->priv;
1035     #if LINUX_VERSION_CODE < KERNEL_VERSION(2,6,7) /* for kernel 2.6.7 */
1036     struct mii_ioctl_data *data=(struct mii_ioctl_data *)&ifr->ifr_data;
1037     #endif
1038   int rc=0;
1039
1040     DMFE_DBUG(0, 'dmfe_do_ioctl()', 0);
1041
1042         if (!netif_running(dev))
1043             return -EINVAL;
1044
1045         if (cmd == SIOCETHTOOL)
1046         rc = dmfe_ethtool_ioctl(dev, (void *) ifr->ifr_data);
1047     else {
1048         spin_lock_irq(&db->lock);
1049         #if LINUX_VERSION_CODE < KERNEL_VERSION(2,6,7) /* for kernel 2.6.7 */
1050             rc = generic_mii_ioctl(&db->mii, data, cmd, NULL);
1051         #else
1052             rc = generic_mii_ioctl(&db->mii, if_mii(ifr), cmd, NULL);
1053         #endif
[1] [2] [3] [4] [5] [6] [7] [8] [9] [10] ..[20]
关键字:S3C2440  dm9000  网卡驱动  程序移植 引用地址:S3C2440实现dm9000网卡驱动程序移植
上一篇:s3c2440的USB热插拔驱动问题
下一篇:S3C实现DMA驱动程序编写
推荐阅读最新更新时间:2024-11-10 01:21
裸机系列——s3c2440之触摸屏
平台:mini2440 触摸屏:索尼x-35 3.5寸触摸屏 1.0、触摸屏与lcd 触摸屏与lcd是俩个独立的屏在lcd中已经讲过了,但是这里在提一下,主要是涉及到一个触摸屏校正的问题,我以前一直很是不解我手指点的什么东西电脑是怎么知道的,直到我弄触摸屏的时候在明白,原来是因为lcd与触摸屏分开但是他们之间有对应关系,简单的说就是一个触摸屏的坐标点对应lcd的一个像素点,这样当我们按下触摸屏后,系统通过计算得到该地方的坐标,然后通过对应关系找到相应位置的lcd显示的内容。因为触摸屏和lcd是独立的,总是因为一些物理的原因会有一些位置上的改变,所以这种对应关系不是不变的,我们可以通过开机的时候的校验来确定这种关系,比如
[单片机]
冲孔打桩机的自动控制系统设计
0 引言 冲孔打桩机主要由桩锤、支架、卷扬机以及其他辅助设备组成,其工作原理是利用冲孔打桩机的卷扬机构,将电动机输出动力的回转运动转变为往复运动,通过钢丝绳来带动桩锤的提升,并在一定高度时使桩锤自由下落,利用桩锤的冲击作用冲挤土层或破碎岩石,同时钻渣随泥浆(或用取渣桶)排出,最后在地基土中形成桩孔。施工人员在桩孔内放置钢筋笼,灌注混凝土而制成桩。 目前,冲孔打桩机的打桩作业均由人工手动机械式操纵来完成。操作人员在工作过程中需要频繁对离合装置、刹车装置等控制部件进行操纵,劳动强度很大。随着微电子技术和自动控制理论的发展,将自动控制技术应用于冲孔打桩机,实现打桩的全自动化或半自动化,使操作人员从繁琐重复的体力劳动中解放出来成为
[单片机]
冲孔打桩机的自动控制系统设计
学习笔记--- S3C2440 对NANDFLASH操作原理与测试代码分析
首先来看一下NANDFLASH接口: 图上看出只有数据口和控制口,没有地址线,所以它不能像网卡,SDRAM那样统一寻址,它的操作方法步骤: 1 使能芯片 2 发操作指令(读,写,擦,复位) 3 发操作地址 5 等待忙信号释放(只有读) 6 发送数据(写),接收数据(读) 7 等待忙信号,低电平忙 8 禁能芯片 这些控制信号线都是通过软件设置寄存器,然后硬件自动产生其他控制线的控制信号; 操作信号含义如下: R/B :读/忙状态线 CE : 片选 CLE :发送指令信号 ALE :发送地址信号 WE:写信号 RE:读信号 这里要注意的: 1 数据按字节传输,刚好8位
[单片机]
学习笔记--- <font color='red'>S3C2440</font> 对NANDFLASH操作原理与测试代码分析
S3C2440移植uboot之编译烧写uboot
文章目录 移植环境 获取uboot 更新交叉编译工具 配置环境变量 移植环境 主 机:VMWare–ubuntu16.04 开发板:S3C2440 编译器:arm-linux-gcc-4.3.2.tgz u-boot:u-boot-2012.04.01.tar.bz2 获取uboot 进入https://www.denx.de/wiki/U-Boot下载uboot 一直往下拉选择如下 将下载好的压缩包解压到任意文件夹,并创建source insight工程。将下载好的u-boot-2012.04.01.tar_2.bz2放到ubuntu服务器/work/system中。执行以下命令解压uboot: cd
[单片机]
<font color='red'>S3C2440</font><font color='red'>移植</font>uboot之编译烧写uboot
s3c2440串口调试函数
#include 2440addr.h #include stdarg.h #include string.h #include stdlib.h #include stdio.h #include ctype.h #define TXD0READY (1 2) #define RXD0READY (1) #define UART_CLK 50000000 // UART0的时钟源设为PCLK #define UART_BAUD_RATE 115200 // 波特率 #define UART_BRD ((UART_CLK / (UART_BAUD_RAT
[单片机]
s3c2440烧写第一步
开发板是jz2440。 视频是韦东山的,看了那么久,讲解的很全面,包括openJtag,并口,串口的连接以及驱动安装等,唯独不讲怎么安装jlink的驱动,也是很奇怪了。毕竟新人,怀着忐忑的心情下载了Jflash,终于看到了教程里面相关界面,于是接下来可以按部就班的烧写了。 烧写所需软件:SecureCRT 5.2,J-LINK v4.90(两个软件都没考虑版本)。 烧写所需文件:s3c2440.jflash,uboot.bin。 接线准备:连接jlink,连接usb-com1(串口),开发板flash开关拨到nor flash一侧。 第一步:1、打开Jflash,选择File- Open data file -
[单片机]
<font color='red'>s3c2440</font>烧写第一步
s3c2440的系统时钟
下面内容是《ARM处理器裸机开发实战—机制而非策略》里的,以s3c2440开发板为例 系统时钟是整个电路的心脏。 总体来说,与s3c2440处理器有关的时钟主要有4种:Fin、FCLK、HCLK和PCLK。 Fin: 外部输入的晶振频率 FCLK: 主要用于CPU核 HCLK: 主要用在与AHB总线互连的设备上(存储器控制器、lcd控制器、dma) PCLK: 主要用在与APB总线互连的低速设备上(uart adc 定时器) S3c2440系统时钟概述 S3c2440处理器的系统时钟分为两部分,外部有时钟输入引脚,内部有2个锁相环将外部输入时钟倍频到处理器工作所需要的时钟。锁相环相当于一个时钟变换电
[单片机]
<font color='red'>s3c2440</font>的系统时钟
s3c2440裸机-内存控制器(三-3、norflash编程之uboot中操作norflash)
前提: norflash初始化正常,能够正常从nor上执行。 cpu总是从0地址读取指令执行程序。当cpu设置成nor启动时,0地址对应nor。cpu从nand启动时,0地址对应sram。 1.读取norFlash 我们将板子设为nor启动,那么0地址对应nor,我们先将uboot烧写到nor中。我们先看下这款NorFlash的手册,找到操作flash的命令表: 下面简单的举一些例子: 1)复位(reset): 往任何一个地址写入F0即可。 2)读ID: 很多的Nor Flash可以配置成位宽16bit(Word),位宽8bit(Byte),我们这款norflash数据位宽为16bit。下面我们按照nor手册上的命令表
[单片机]
<font color='red'>s3c2440</font>裸机-内存控制器(三-3、norflash编程之uboot中操作norflash)
小广播
设计资源 培训 开发板 精华推荐
最新单片机文章
何立民专栏 单片机及嵌入式宝典
电子工程世界版权所有 京ICP证060456号 京ICP备10001474号-1 电信业务审批[2006]字第258号函 京公网安备 11010802033920号 Copyright © 2005-2024 EEWORLD.com.cn, Inc. All rights reserved
