S3C实现DMA驱动程序编写
发布者:DreamySunset最新更新时间:2024-08-05 来源: cnblogs关键字:S3C  DMA  驱动程序 手机看文章 扫描二维码
随时随地手机看文章
 54         {
 55             break;
 56         }
 57     }
 58
 59     return 0;
 60 }
 61
 62 static struct file_operations dma_fops = {
 63     .owner  = THIS_MODULE,
 64     .ioctl  = s3c_dma_ioctl,
 65 };
 66
 67 static int s3c_dma_init(void)
 68 {
 69     /* 分配SRC, DST对应的缓冲区 */
 70     src = dma_alloc_writecombine(NULL, BUF_SIZE, &src_phys, GFP_KERNEL);
 71     if (NULL == src)
 72     {
 73         printk('can't alloc buffer for srcn');
 74         return -ENOMEM;
 75     }
 76
 77     dst = dma_alloc_writecombine(NULL, BUF_SIZE, &dst_phys, GFP_KERNEL);
 78     if (NULL == dst)
 79     {
 80         dma_free_writecombine(NULL, BUF_SIZE, src, src_phys);
 81         printk('can't alloc buffer for dstn');
 82         return -ENOMEM;
 83     }
 84
 85     major = register_chrdev(0, 's3c_dma', &dma_fops);
 86
 87     /* 为了自动创建设备节点 */
 88     cls = class_create(THIS_MODULE, 's3c_dma');
 89     class_device_create(cls, NULL, MKDEV(major, 0), NULL, 'dma'); /* /dev/dma */
 90
 91     return 0;
 92 }
 93
 94 static void s3c_dma_exit(void)
 95 {
 96     class_device_destroy(cls, MKDEV(major, 0));
 97     class_destroy(cls);
 98     unregister_chrdev(major, 's3c_dma');
 99     dma_free_writecombine(NULL, BUF_SIZE, src, src_phys);
100     dma_free_writecombine(NULL, BUF_SIZE, dst, dst_phys);
101 }
102
103 module_init(s3c_dma_init);
104 module_exit(s3c_dma_exit);
105
106 MODULE_LICENSE('GPL');
附上测试程序2.
 1 #include
 2 #include
 3 #include
 4 #include
 5 #include
 6 #include
 8 /* ./dma_test nodma
 9  * ./dma_test dma
10  */
11 #define MEM_CPY_NO_DMA  0
12 #define MEM_CPY_DMA     1
14 void print_usage(char *name)
15 {
16     printf('Usage:n');
17     printf('%s n', name);
18 }
19
21 int main(int argc, char **argv)
22 {
23     int fd;
24
25      if (argc != 2)
26     {
27         print_usage(argv[0]);
28         return -1;
29     }
31     fd = open('/dev/dma', O_RDWR);
32     if (fd < 0)
33     {
34         printf('can't open /dev/dman');
35         return -1;
36     }
37
38     if (strcmp(argv[1], 'nodma') == 0)
39     {
40         while (1)
41         {
42             ioctl(fd, MEM_CPY_NO_DMA);
43         }
44     }
45     else if (strcmp(argv[1], 'dma') == 0)
46     {
47         while (1)
48         {
49             ioctl(fd, MEM_CPY_DMA);
50         }
51     }
52     else
53     {
54         print_usage(argv[0]);
55         return -1;
56     }
57     return 0;
58 }
三.映射s3c的DMA内存地址
测试程序时,不知道大家有没有发现,当我们运行test测试程序时,我们的拷贝进程占用了全部的CPU,以至于我们想运行一条命令都要等好久才能实现,
为了解决它,我们就引入了DMA,接下来,我们就真正开始DMA的编程
 1 #define DMA0_BASE_ADDR  0x4B000000
 2 #define DMA1_BASE_ADDR  0x4B000040
 3 #define DMA2_BASE_ADDR  0x4B000080
 4 #define DMA3_BASE_ADDR  0x4B0000C0
 6 struct s3c_dma_regs {
 7     unsigned long disrc;
 8     unsigned long disrcc;
 9     unsigned long didst;
10     unsigned long didstc;
11     unsigned long dcon;
12     unsigned long dstat;
13     unsigned long dcsrc;
14     unsigned long dcdst;
15     unsigned long dmasktrig;
16 };
如程序中所示:首先定义DMA的四个通道的基地址,接着定义一个s3c的dma的寄存器结构体.
分别再入口函数中映射DMA的内存IO端口,此处我们使用DMA0,当然如果要使用其他的DMA,类似.
在入口函数中映射:
dma_regs = ioremap(DMA0_BASE_ADDR, sizeof(struct s3c_dma_regs));
在出口函数中解除DMA映射.
iounmap(dma_regs);
四.注册DMA中断
前面我们已经映好DMA的内存地址了.
接下来,要想DMA工作,还需要对齐进行注册DMA中断和DMA配置.
在入口函数中注册DMA中断,再出口函数中释放DMA中断
在入口函数中注册中断:
1 if (request_irq(IRQ_DMA3, s3c_dma_irq, 0, 's3c_dma', 1))
2     {
3         printk('can't request_irq for DMAn');
4         return -EBUSY;
5     }
在出口函数中释放中断:
free_irq(IRQ_DMA3, 1);
当用户程序中定义为 MEM_CPY_DMA 使用DMA传输时,便会在ioctl函数中进入case MEM_CPY_DMA :中.
接着我们便在其中配置号DMA的源.目的参数,接着便启动传输,CPU则进入休眠状态,让出CPU供其他进程使用.当DMA拷贝完成时,便会触发中断,从而唤醒.
ioctl函数的部分程序如下面所示:
 1         case MEM_CPY_DMA :
 2         {
 3             ev_dma = 0;
 5             /* 把源,目的,长度告诉DMA */
 6             dma_regs->disrc      = src_phys;        /* 源的物理地址 */
 7             dma_regs->disrcc     = (0<<1) | (0<<0); /* 源位于AHB总线, 源地址递增 */
 8             dma_regs->didst      = dst_phys;        /* 目的的物理地址 */
 9             dma_regs->didstc     = (0<<2) | (0<<1) | (0<<0); /* 目的位于AHB总线, 目的地址递增 */
10             dma_regs->dcon       = (1<<30)|(1<<29)|(0<<28)|(1<<27)|(0<<23)|(0<<20)|(BUF_SIZE<<0);  /* 使能中断,单个传输,软件触发, */
12             /* 启动DMA */
13             dma_regs->dmasktrig  = (1<<1) | (1<<0);
15             /* 如何知道DMA什么时候完成? */
16             /* 休眠 */
17             wait_event_interruptible(dma_waitq, ev_dma);
19             if (memcmp(src, dst, BUF_SIZE) == 0)
20             {
21                 printk('MEM_CPY_DMA OKn');
22             }
23             else
24             {
25                 printk('MEM_CPY_DMA ERRORn');
26             }
27
28             break;
29         }
中断服务程序:
1 static irqreturn_t s3c_dma_irq(int irq, void *devid)
2 {
3     /* 唤醒 */
4     ev_dma = 1;
5     wake_up_interruptible(&dma_waitq);   /* 唤醒休眠的进程 */
6     return IRQ_HANDLED;
7 }
附上驱动程序3:
  1 #include
  2 #include
  3 #include
  4 #include
  5 #include
  6 #include
  7 #include
  8 #include
  9 #include
 10 #include
 11 #include
 12 #include
 13 #include
 15 #define MEM_CPY_NO_DMA  0
 16 #define MEM_CPY_DMA     1
 17
 18 #define BUF_SIZE  (512*1024)
 19
 20 #define DMA0_BASE_ADDR  0x4B000000
 21 #define DMA1_BASE_ADDR  0x4B000040
 22 #define DMA2_BASE_ADDR  0x4B000080
 23 #define DMA3_BASE_ADDR  0x4B0000C0
 24
 25 struct s3c_dma_regs {
 26     unsigned long disrc;
 27     unsigned long disrcc;
 28     unsigned long didst;
 29     unsigned long didstc;
 30     unsigned long dcon;
 31     unsigned long dstat;
 32     unsigned long dcsrc;
 33     unsigned long dcdst;
 34     unsigned long dmasktrig;
 35 };
 36
 37
 38 static int major = 0;
 39
 40 static char *src;
 41 static u32 src_phys;
 42
 43 static char *dst;
 44 static u32 dst_phys;
 45
 46 static struct class *cls;
 47
 48 static volatile struct s3c_dma_regs *dma_regs;
 49
 50 static DECLARE_WAIT_QUEUE_HEAD(dma_waitq);
 51 /* 中断事件标志, 中断服务程序将它置1,ioctl将它清0 */
 52 static volatile int ev_dma = 0;
 53
 54 static int s3c_dma_ioctl(struct inode *inode, struct file *file, unsigned int cmd, unsigned long arg)
[1] [2] [3]
关键字:S3C  DMA  驱动程序 引用地址:S3C实现DMA驱动程序编写
上一篇:S3C2440实现dm9000网卡驱动程序移植
下一篇:S3C2440 nand_flash驱动程序
推荐阅读最新更新时间:2024-11-13 17:25
接近开关的51单片机驱动程序
今天用做了个小东西:数码管显示接近开关变化值接近开关通过外部中断0连接单片机;数码管示数增加到50后清零; #include reg51.h // 引用标准库的头文件 #include intrins.h #define uchar unsigned char #define uint unsigned int #define NoOp 0x00 // 空操作寄存器 #define Digit0 0x01 // 数码管1寄存器 #define Digit1 0x02 // 数码管2寄存器 #define Digit2 0x03 // 数码管3寄存器
[单片机]
stm32舵机驱动程序分享
  STM32系列基于专为要求高性能、低成本、低功耗的嵌入式应用专门设计的ARM Cortex-M3内核。按内核架构分为不同产品:   其中STM32F系列有:   STM32F103“增强型”系列   STM32F101“基本型”系列   STM32F105、STM32F107“互联型”系列   增强型系列时钟频率达到72MHz,是同类产品中性能最高的产品;基本型时钟频率为36MHz,以16位产品的价格得到比16位产品大幅提升的性能,是32位产品用户的最佳选择。两个系列都内置32K到128K的闪存,不同的是SRAM的最大容量和外设接口的组合。时钟频率72MHz时,从闪存执行代码,STM32功耗36mA,相当于0.5mA/MHz。
[单片机]
STM32F3的ADC使用DMA模式传输转换数据
本文使用ADC转换电位器输出的电压值,并用DMA模式传输转换的结果,每8次采样转换取平均值,做一个简单的数字滤波。 ADC的详细配置与使用 见之前的日记 STM32中ADC的使用 ,只是最后增加一步配置DMA: DMA for ADC channels features configuration  To enable the DMA mode for ADC channels group, use the ADC_DMACmd() function.  To configure the DMA transfer request, use ADC_DMAConfig() function. DMA的配置 (摘自STM32F3
[单片机]
micro2440 按键驱动程序
my_buttons.c文件: #include linux/fs.h #include linux/poll.h #include linux/irq.h #include linux/interrupt.h #include mach/regs-gpio.h #include mach/hardware.h #include linux/miscdevice.h #define DEVICE_NAME mybuttons struct button_irq_desc { int irq; int pin; int pin_setting; int number; char *na
[单片机]
关于STM32F107VCT6串口DMA接收数字控制LED亮灭的功能实现
主函数中代码如下: #include stm32f10x.h void GPIO_Config(void); void USART_Config(void); void DMA_Config(void); void NVIC_Config(void); void LED1_ON(void); void LED2_ON(void); void LED3_ON(void); void LED4_ON(void); void LED_ALL_OFF(void); void delay(void); uint8_t DMA_BUFFER ; int main() { GPIO_Config(); USART_Co
[单片机]
关于STM32F107VCT6串口<font color='red'>DMA</font>接收数字控制LED亮灭的功能实现
关于STM32 ADC DMA 使用心得(2)
(二)ADC循环采集六路电压,使用DMA. 这次实验真的很郁闷,对DMA的不了解让我深陷误区,明白之后,让我更加佩服DMA的强大。 误区就是:从实验的目标我们知道这次是用DMA把ADC转换的数据传送到内存中的一个数组里存起来,因为是采集6个通道,这里使能了ADC的扫描模式。一旦启动ADC,就会按顺序转换SQRX里选中的通道,问题就是我一开始以为ADC与DMA并不会协调工做,也就是ADC自己转自己的,DMA自己传自己的,这样的话内存里的数组就不是我想要的了,后来着实的研究了很长时间,在群里的一位兄弟的提醒下,我才知道,可能我想的复杂了,也许就可以在ADC转一次,然后DMA把数据传一次,Ok,经过实验得知,这个想法是正确的。
[单片机]
S3C内部中断和外部中断
1.中断分两大类:内部中断和外部中断。 2.外部中断。24个外部中断占用GPF0-GPF7(EINT0-EINT7),GPG0-GPG15(EINT8-EINT23)。用这些脚做中断输入,则必须配置引脚为中断,并且不要上拉。具体参考datesheet数据手册。 寄存器:EXTINT0-EXTINT2:三个寄存器设定EINT0-EINT23的触发方式。 EINTFLT0-EINTFLT3:控制滤波时钟和滤波宽度。 EINTPEND:这个是中断挂起寄存器,清除时要写1,后面还有几个是写1清除。当一个外部中断(EINT4-EINT23)发生后,那么相应的位会被置1。为什么没有EINT0-EINT3,呵呵,看
[单片机]
12.2440串口驱动程序设计
串口的功能就是接受数据跟发送数据的,在上一节已经了解串口的引脚信号。但是数据的收发需要一定的条件,也就是串口的初始化。所以所以今天的内容就会被划分为三个部分: 1.串口的初始化: 创建一个uart.c来对串口进行处理,然后把它加入到Makefile工程文件里: 接着就是串口处理程序的实现了。 程序的刚开始是对串口进行初始化,初始化的步骤: 配置引脚功能 设置数据模式 设置工作模式 设置波特率。 1)配置引脚功能: 在2440里的串口底板原理图: 上面的11 TXD0和12 RXD0就是串口的发送和接受引脚,对应的编号里的3,2口,5口是接地的。接下来在核心板原理图里找对应的共用引脚。在核心板原理图里搜
[单片机]
12.2440串口<font color='red'>驱动程序</font>设计
小广播
设计资源 培训 开发板 精华推荐
最新单片机文章
何立民专栏 单片机及嵌入式宝典
电子工程世界版权所有 京ICP证060456号 京ICP备10001474号-1 电信业务审批[2006]字第258号函 京公网安备 11010802033920号 Copyright © 2005-2024 EEWORLD.com.cn, Inc. All rights reserved
