驱动模块分离概念
发布者:闪耀的星空最新更新时间:2024-08-14 来源: cnblogs关键字:驱动模块 手机看文章 扫描二维码
随时随地手机看文章
 88     beep_pin = res->start;
 89
 90
 91     /* 注册字符设备驱动程序 */
 92     major = register_chrdev(0,DEVICE_NAME,&beep_fops);
 93     //创建类,然后再类下面创建设备节点
 94     beep_class = class_create(THIS_MODULE,DEVICE_NAME);
 95     device_create(beep_class,NULL,MKDEV(major,0),NULL,DEVICE_NAME);//dev/beep_dev
 96
 97     return 0;
 98 }
 99
100 static int beep_remove(struct platform_device *pdev){
101     printk('<0> beep_remove, remove beepnn');
102     //删除类
103     device_destroy(beep_class,MKDEV(major,0));
104     class_destroy(beep_class);
105     /* 卸载字符设备驱动程序 */
106     unregister_chrdev(major,DEVICE_NAME);    /* iounmap */
107     //解除地址映射
108     iounmap((void __iomem *)base_iomux);
109     iounmap((void __iomem *)base_gpio1);
110     return 0;
111 }
112
113 //定义一个平台驱动结构体
114 struct platform_driver beep_drv = {
115     .probe = beep_probe,
116     .remove = beep_remove,
117     .driver = {
118         .name = DRIVER_NAME,
119     }
120 };
121
122
123 static int beep_drv_init(void){
124     platform_driver_register(&beep_drv);
125     return 0;
126 }
127
128 static void beep_drv_exit(void){
129     platform_driver_unregister(&beep_drv);
130 }
131
132 module_init(beep_drv_init);
133 module_exit(beep_drv_exit);
134
135 MODULE_AUTHOR('Lover雪儿');
136 MODULE_VERSION('0.1.0');
137 MODULE_LICENSE('GPL');
附 应用程序 beep_test.c 程序:
 1 #include
 2 #include
 3 #include
 4 #include
 6 /* beep_test on
 7  * beep_test off
 8  */
 9 int main(int argc, char **argv)
10 {
11     int fd;
12     int i = 0;
13     int val = 1;
14     fd = open('/dev/beep_dev', O_RDWR);
15     if (fd < 0){
16         printf('can't open!n');
17     }
18     if (argc != 2){
19         printf('Usage :n');
20         printf('%s n', argv[0]);
21         return 0;
22     }
23     if (strcmp(argv[1], 'on') == 0){
24         val  = 1;
25         write(fd, &val, 4);
26     }else if (strcmp(argv[1], 'off') == 0){
27         val = 0;
28         write(fd, &val, 4);
29     }else{
30         i=5;
31         while(i--){
32             val = 0;
33             write(fd, &val, 4);
34             val  = 1;
35             write(fd, &val, 4);
36         }
37         val = 0;
38         write(fd, &val, 4);
39     }
40     return 0;
41 }
[1] [2]
关键字:驱动模块 引用地址:驱动模块分离概念
上一篇:构建Linux下IMX257 开发环境
下一篇:NorFlash驱动
小广播
设计资源 培训 开发板 精华推荐
最新单片机文章
何立民专栏 单片机及嵌入式宝典
电子工程世界版权所有 京ICP证060456号 京ICP备10001474号-1 电信业务审批[2006]字第258号函 京公网安备 11010802033920号 Copyright © 2005-2024 EEWORLD.com.cn, Inc. All rights reserved
