【改进】IMX257实现GPIO-IRQ中断按键获取键值驱动程序
发布者:温暖梦想最新更新时间:2024-08-16 来源: cnblogs关键字:中断按键 手机看文章 扫描二维码
随时随地手机看文章
一、使用struct pin_desc 管理按键的值
1.定义结构体
2.将前面我们申请中断时写的(void *)1修改为 &pins_desc[n]
在ioctl中,设置中断中修改
在key_release中释放中修改
3.在中断程序中利用我们定义的struc pins_desc判断并得到按键的值
4.得到按键键值后,唤醒程序,在read函数中返回键值
附上驱动源程序:
  1 /******************************
  2     linux key_query
  3  *****************************/
  4 #include
  5 #include
  6 #include
  7 #include
  8 #include
  9 #include
 10 #include
 11 #include
 12 #include
 13 #include
 14 #include
 15 #include
 16 #include //error: 'TASK_INTERRUPTIBLE' undeclared
 17 #include
 19 #include 'mx257_gpio.h'
 20 #include 'mx25_pins.h'
 21 #include 'iomux.h'
 22
 23 #define Driver_NAME 'key_interrupt'
 24 #define DEVICE_NAME 'key_interrupt'
 26 #define GPIO2_21    MX25_PIN_CLKO
 27 #define GPIO3_15    MX25_PIN_EXT_ARMCLK
 28 #define GPIO2_10    MX25_PIN_A24
 29 #define GPIO2_11    MX25_PIN_A25
 30 #define GPIO2_8     MX25_PIN_A22
 31 #define GPIO2_9     MX25_PIN_A23
 32 #define GPIO2_6     MX25_PIN_A20
 33 #define GPIO2_7     MX25_PIN_A21
 34 //command
 35 #define key_input     0
 36 #define version        1
 37 //定义各个按键按下的键值
 38 struct pin_desc{
 39     unsigned int pin;
 40     unsigned int key_val;
 41 };
 42 //当按键按下时,键值分别为 以下值
 43 struct pin_desc pins_desc[8] = {
 44     {GPIO2_6,    0x01},
 45     {GPIO2_7,    0x02},
 46     {GPIO2_8,    0x03},
 47     {GPIO2_9,    0x04},
 48     {GPIO2_10,    0x05},
 49     {GPIO2_11,    0x06},
 50     {GPIO2_21,    0x07},
 51     {GPIO3_15,    0x08},
 52 };
 53 //定义一个全局变量,用于保存按下的键值
 54 static unsigned int key_val;
 55
 56 //interrupt head
 57 static DECLARE_WAIT_QUEUE_HEAD(key_interrupt_wait);
 58 static volatile unsigned char ev_press;
 59
 60 static int major=0;
 61
 62 //auto to create device node
 63 static struct class *drv_class = NULL;
 64 static struct class_device *drv_class_dev = NULL;
 65
 66
 67 /* 应用程序对设备文件/dev/key_query执行open(...)时,
 68  * 就会调用key_open函数*/
 69 static int key_open(struct inode *inode, struct file *file)
 70 {
 71     printk('<0>function open!nn');
 72
 73     return 0;
 74 }
 75
 76 /* 中断程序key_irq */
 77 static irqreturn_t key_irq(int irq, void *dev_id)
 78 {
 79     struct pin_desc * pindesc = (struct pin_desc *)dev_id;
 80     //发生了中断
 81     //printk('<0>function interrupt key_irq!nn');
 82     //获取按键键值
 83     if(gpio_get_value(IOMUX_TO_GPIO(pindesc->pin))){
 84         /* 按下 */
 85         key_val = pindesc->key_val;
 86     }else{
 87         key_val = 0x80 | pindesc->key_val;
 88     }
 89     printk('<0>get key 0x%x',key_val);
 90     ev_press = 1;
 91     wake_up_interruptible(&key_interrupt_wait);
 92
 93     return IRQ_RETVAL(IRQ_HANDLED);
 94 }
 95
 96
 97 static int key_read(struct file *filp, char __user *buff, size_t count, loff_t *offp)
 98 {
 99     int ret;
100     //如果按键没有按下,没有中断,休眠
101     wait_event_interruptible(key_interrupt_wait,ev_press);
102
103     ret = copy_to_user(buff,&key_val,sizeof(key_val));
104     if(ret){
105         ;
106     }
107     ev_press = 0;
108     return sizeof(key_val);
109
110     //int cnt=0;
111     //unsigned char key_vals[8];
112
113     /*
114     // reading the pins value
115     key_vals[0] = gpio_get_value(IOMUX_TO_GPIO(GPIO2_6)) ? 1 : 0;
116     key_vals[1] = gpio_get_value(IOMUX_TO_GPIO(GPIO2_7)) ? 1 : 0;
117     key_vals[2] = gpio_get_value(IOMUX_TO_GPIO(GPIO2_8)) ? 1 : 0;
118     key_vals[3] = gpio_get_value(IOMUX_TO_GPIO(GPIO2_9)) ? 1 : 0;
119     key_vals[4] = gpio_get_value(IOMUX_TO_GPIO(GPIO2_10)) ? 1 : 0;
120     key_vals[5] = gpio_get_value(IOMUX_TO_GPIO(GPIO2_11)) ? 1 : 0;
121     key_vals[6] = gpio_get_value(IOMUX_TO_GPIO(GPIO2_21)) ? 1 : 0;
122     key_vals[7] = gpio_get_value(IOMUX_TO_GPIO(GPIO3_15)) ? 1 : 0;
123
124     //printk('<0>%04d key pressed: %d %d %d %d %d %d %d %dn',cnt++,key_vals[0],key_vals[1],key_vals[2],key_vals[3],key_vals[4],key_vals[5],key_vals[6],key_vals[7]);
125     */
126 }
127
128 static ssize_t key_write(struct file *file, const char __user *buf, size_t count, loff_t * ppos)
129 {
130     printk('<0>function write!nn');
131
132     return 1;
133 }
134
135 static int  key_release(struct inode *inode, struct file *filp)
136 {
137     printk('<0>function release!nn');
138     //释放中断
139     free_irq(IOMUX_TO_IRQ(GPIO2_21),  &pins_desc[6]);
140     //free_irq(IOMUX_TO_IRQ(GPIO3_15),&pins_desc[7]);
141     free_irq(IOMUX_TO_IRQ(GPIO2_11),  &pins_desc[5]);
142     free_irq(IOMUX_TO_IRQ(GPIO2_10),  &pins_desc[4]);
143     free_irq(IOMUX_TO_IRQ(GPIO2_9),   &pins_desc[3]);
144     //free_irq(IOMUX_TO_IRQ(GPIO2_8), &pins_desc[2]);
145     free_irq(IOMUX_TO_IRQ(GPIO2_7),   &pins_desc[1]);
146     free_irq(IOMUX_TO_IRQ(GPIO2_6),   &pins_desc[0]);
147     return 0;
148 }
149
150 static int key_ioctl(struct inode *inode,struct file *flip,unsigned int command,unsigned long arg)
151 {
152     int ret;
153     printk('<0>function ioctl!nn');
154     switch (command) {
155         case key_input:
156             //设置所有的引脚为输入
157             gpio_direction_input(IOMUX_TO_GPIO(GPIO2_21));
158             gpio_direction_input(IOMUX_TO_GPIO(GPIO3_15));
159             gpio_direction_input(IOMUX_TO_GPIO(GPIO2_10));
160             gpio_direction_input(IOMUX_TO_GPIO(GPIO2_11));
161             gpio_direction_input(IOMUX_TO_GPIO(GPIO2_8));
162             gpio_direction_input(IOMUX_TO_GPIO(GPIO2_9));
163             gpio_direction_input(IOMUX_TO_GPIO(GPIO2_6));
164             gpio_direction_input(IOMUX_TO_GPIO(GPIO2_7));
165             printk('<0>have setting all pins to gpio input mod !n');
166             //设置GPIO引脚为上拉模式
167             mxc_iomux_set_pad(GPIO2_6, PAD_CTL_HYS_SCHMITZ | PAD_CTL_PKE_ENABLE | PAD_CTL_PUE_PULL | PAD_CTL_22K_PU);
168             mxc_iomux_set_pad(GPIO2_7, PAD_CTL_HYS_SCHMITZ | PAD_CTL_PKE_ENABLE | PAD_CTL_PUE_PULL | PAD_CTL_22K_PU);
169             //mxc_iomux_set_pad(GPIO2_8, PAD_CTL_HYS_SCHMITZ | PAD_CTL_PKE_ENABLE | PAD_CTL_PUE_PULL | PAD_CTL_22K_PU);
170             mxc_iomux_set_pad(GPIO2_9, PAD_CTL_HYS_SCHMITZ | PAD_CTL_PKE_ENABLE | PAD_CTL_PUE_PULL | PAD_CTL_22K_PU);
171             mxc_iomux_set_pad(GPIO2_10, PAD_CTL_HYS_SCHMITZ | PAD_CTL_PKE_ENABLE | PAD_CTL_PUE_PULL | PAD_CTL_22K_PU);
172             mxc_iomux_set_pad(GPIO2_11, PAD_CTL_HYS_SCHMITZ | PAD_CTL_PKE_ENABLE | PAD_CTL_PUE_PULL | PAD_CTL_22K_PU);
173             mxc_iomux_set_pad(GPIO2_21, PAD_CTL_HYS_SCHMITZ | PAD_CTL_PKE_ENABLE | PAD_CTL_PUE_PULL | PAD_CTL_22K_PU);
174             //mxc_iomux_set_pad(GPIO3_15, PAD_CTL_HYS_SCHMITZ | PAD_CTL_PKE_ENABLE | PAD_CTL_PUE_PULL | PAD_CTL_22K_PU);
175
176             //设置GPIO引脚中断  ,下降沿触发
177             request_irq(IOMUX_TO_IRQ(GPIO2_6), key_irq, IRQF_TRIGGER_FALLING, 'key_GPIO2_6', &pins_desc[0]);
178             request_irq(IOMUX_TO_IRQ(GPIO2_7), key_irq, IRQF_TRIGGER_FALLING, 'key_GPIO2_7', &pins_desc[1]);
179             request_irq(IOMUX_TO_IRQ(GPIO2_9), key_irq, IRQF_TRIGGER_FALLING, 'key_GPIO2_9', &pins_desc[3]);
180             request_irq(IOMUX_TO_IRQ(GPIO2_10), key_irq, IRQF_TRIGGER_FALLING, 'key_GPIO2_10', &pins_desc[4]);
[1] [2]
关键字:中断按键 引用地址:【改进】IMX257实现GPIO-IRQ中断按键获取键值驱动程序
上一篇:【改进Poll定时查询】IMX257实现GPIO-IRQ中断按键获取键值驱动程序
下一篇:IMX257实现GPIO-IRQ中断按键驱动程序
推荐阅读最新更新时间:2024-11-02 15:04
S3C2410 按键控制LED(中断
一、开发环境 1、硬件平台:UP-TECH2410DVK1.1 2、主机:PC+eclipse 二、相关原理图 LED1-- GPC5 LED2-- GPC6 LED3-- GPC7 KEY1-- EINIT3 KEY2-- EINIT5 KEY3-- EINIT9 三、基本原理 通过按键的按下而触发中断,从而进行中断处理,进而实现相应功能(如闪烁LED),然后退出中断。 如何判断按键被按下: 以KEY1为例,未按下时,因为EINT3连接的是VDD,所以为高电平,当按键发生,EINT3连接的是GND,接地,此时为低电平。 通过芯片手册可查到EINT3 、5、9连接的为复
[单片机]
S3C2410 <font color='red'>按键</font>控制LED(<font color='red'>中断</font>)
stm32f103按键中断实现方法
#include stm32f10x.h void LED_GPIO_Config() { /*定义一个GPIO_InitTypeDef类型的结构体*/ GPIO_InitTypeDef GPIO_InitStructure; /*开启GPIOB的外设时钟*/ RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB, ENABLE); /*选择要控制的GPIOB引脚*/ GPIO_InitStructure.GPIO_Pin = GPIO_Pin_5; /*设置引脚模式为通用推挽输出*/ GPIO_InitStructure.GPIO_Mode = GPIO_Mode
[单片机]
STM32CubeMX学习笔记2:GPIO按键外部中断控制LED状态
MCU:STM32F103ZET6 IDE: MDK-ARM V5 +STM32CubeMX5.0.0 本次实现的功能是通过按键的外部中断,来改变对应LED的状态,需要将按键的I/O端口映射到外部中断线上。 需要初始化的按键I/O口分别对应PA0PE2PE3PE4,LEDI/O口分别为PC0PC1PC2PC3PC4。 一. 在 Pinout&Configuration---System Core中: 1. 首先设置时钟RCC的HSE(外部高速时钟)为晶振模式:Crystal/ceramic Resonator 2. 设置系统SYS的Debug为Serial Wire: 3. 设置GPIO中的LED
[单片机]
STM32CubeMX学习笔记2:GPIO<font color='red'>按键</font>外部<font color='red'>中断</font>控制LED状态
STM32F103程序设计-7-引脚输入功能-按键中断
AFIO时钟的打开。外部中断、重映射、复用功能?当配置AFIO六个寄存器中的值时就需要打开AFIO时钟。 void EXTI0_Config(void) { /* Enable GPIOA clock */ RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA, ENABLE); /* Configure PA.00 pin as input floating */ GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;
[单片机]
STM32F103程序设计-7-引脚输入功能-<font color='red'>按键</font>(<font color='red'>中断</font>)
按键驱动程序中,如果不使用read函数中使程序休眠的,而是还是使用查询方式的话,可以使用Poll函数,来控制一定时间内,如果有按键发生,则立即返回键值。 同时,poll也可以同时监控多个(比如说按键,鼠标,等)一旦发生事件则立即返回。 我们在linux查看帮助: 从帮助中的说明得知, poll, ppoll - wait for some event on a file descriptor poll就是监控某个设备的事件。 修改驱动程序 1.增加头文件 #include linux/poll.h 2.增加key_poll 方法 static unsigned key_poll(struct file *fil
[单片机]
【改进Poll定时查询】<font color='red'>IMX257</font>实现<font color='red'>GPIO-IRQ</font><font color='red'>中断</font><font color='red'>按键</font><font color='red'>获取</font><font color='red'>键值</font>驱动程序
按键中断---那些年我们一起玩mini2440(arm9)裸机
ARM中断控制系统 按键驱动程序设计 一.Arm中断控制系统 1.查询方式 程序不断地查询设备的状态,并做出相应的反应。该方式实现比较简单,常用在比较单一的系统中,比如:一个温控系统中可以实用查询的方式不断检测温度变化。 特点:实现简单;但CPU利用率很低,不适合多任务的系统。 2.中断方式 当事件发生时,硬件会设置某个寄存器;CPU在每执行完一个指令时,查看这个寄存器,如果所关注的事件发生了,则中断当前程序,跳转到一个固定的地址处理这个事件,处理完后返回到被中断的程序中继续运行。 特点:实现相对复杂,但效率较高,是常用的方法。 中断处理流程: (1)中断控制器汇集各类外设发出的中断信号,然后通知CPU; (2)CPU保存当前
[单片机]
<font color='red'>按键</font><font color='red'>中断</font>---那些年我们一起玩mini2440(arm9)裸机
小广播
设计资源 培训 开发板 精华推荐
最新单片机文章
何立民专栏 单片机及嵌入式宝典
换一换 更多 相关热搜器件
随便看看
电子工程世界版权所有 京ICP证060456号 京ICP备10001474号-1 电信业务审批[2006]字第258号函 京公网安备 11010802033920号 Copyright © 2005-2024 EEWORLD.com.cn, Inc. All rights reserved
