如何采用STM32单片机产生PWM
发布者:TranquilMind88最新更新时间:2024-08-20 来源: elecfans关键字:STM32  单片机  PWM 手机看文章 扫描二维码
随时随地手机看文章
STM32产生PWM是非常的方便的,要需要简单的设置定时器,即刻产生!
(1)使能定时器时钟:RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM3, ENABLE);
(2)定义相应的GPIO:
/* PA2,3,4,5,6输出-》Key_Up,Key_Down,Key_Left,Key_Right,Key_Ctrl */
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_2|GPIO_Pin_3|GPIO_Pin_4|GPIO_Pin_5|GPIO_Pin_6;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IPU; //下拉接地,检测输入的高电平
GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; //50M时钟速度
GPIO_Init(GPIOA, &GPIO_InitStructure);
/* PA7用于发出PWM波 */
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_7;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; //50M时钟速度
(3)如果是产生PWM(频率不变,占空比可变),记得打开PWM控制,在TIM_Configuration()中。
TIM_Cmd(TIM3,ENABLE);
/* TIM1 Main Output Enable */
TIM_CtrlPWMOutputs(TIM1,ENABLE);
利用定时器产生不同频率的PWM有时候,需要产生不同频率的PWM,这个时候,设置与产生相同PWM的程序,有关键的不一样。
(一) 设置的原理
利用改变定时器输出比较通道的捕获值,当输出通道捕获值产生中断时,在中断中将捕获值改变,这时, 输出的I/O会产生一个电平翻转,利用这种办法,实现不同频率的PWM输出。
(二)关键设置
在定时器设置中:TIM_OC2PreloadConfig(TIM3, TIM_OCPreload_Disable);
在中断函数中:
if (TIM_GetITStatus(TIM3, TIM_IT_CC2) != RESET)
TIM_ClearITPendingBit(TIM3, TIM_IT_CC2);
capture = TIM_GetCapture2(TIM3);
TIM_SetCompare2(TIM3, capture + Key_Value);
一个定时器四个通道,分别产生不同频率(这个例子网上也有)
vu16 CCR1_Val = 32768;
vu16 CCR2_Val = 16384;
vu16 CCR3_Val = 8192;
vu16 CCR4_Val = 4096;
void TIM_Configuration(void)
TIM_TimeBaseInitTypeDef TIM_TimeBaseStructure;
TIM_OCInitTypeDef TIM_OCInitStructure;
/* TIM2 clock enable */
RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM2, ENABLE);
TIM2 Configuration: Output Compare Toggle Mode:
TIM2CLK = 36 MHz, Prescaler = 0x2, TIM2 counter clock = 12 MHz
CC1 update rate = TIM2 counter clock / CCR1_Val = 366.2 Hz
CC2 update rate = TIM2 counter clock / CCR2_Val = 732.4 Hz
CC3 update rate = TIM2 counter clock / CCR3_Val = 1464.8 Hz
CC4 update rate = TIM2 counter clock / CCR4_Val = 2929.6 Hz
/* Time base configuration */
TIM_TimeBaseStructure.TIM_Period = 65535;
TIM_TimeBaseStructure.TIM_Prescaler = 2;
TIM_TimeBaseStructure.TIM_ClockDivision = 0;
TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;
TIM_TimeBaseInit(TIM2, &TIM_TimeBaseStructure);
/* Channel 1 Configuration in PWM mode */
TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_Toggle; //PWM模式2
TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable; //正向通道有效
TIM_OCInitStructure.TIM_OutputNState = TIM_OutputNState_Disable;//反向通道无效
TIM_OCInitStructure.TIM_Pulse = CCR1_Val;//占空时间
TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_Low; //输出极性
TIM_OCInitStructure.TIM_OCNPolarity = TIM_OCNPolarity_High; //互补端的极性
TIM_OCInitStructure.TIM_OCIdleState = TIM_OCIdleState_Set;
TIM_OCInitStructure.TIM_OCNIdleState = TIM_OCIdleState_Reset;
TIM_OC1Init(TIM2,&TIM_OCInitStructure); //通道1
TIM_OC1PreloadConfig(TIM2, TIM_OCPreload_Disable);
TIM_OCInitStructure.TIM_Pulse = CCR2_Val; //占空时间
TIM_OC2Init(TIM2,&TIM_OCInitStructure);//通道2
TIM_OC2PreloadConfig(TIM2, TIM_OCPreload_Disable);
TIM_OCInitStructure.TIM_Pulse = CCR3_Val; //占空时间
TIM_OC3Init(TIM2,&TIM_OCInitStructure); //通道3
TIM_OC3PreloadConfig(TIM2, TIM_OCPreload_Disable);
TIM_OCInitStructure.TIM_Pulse = CCR4_Val; //占空时间
TIM_OC4Init(TIM2,&TIM_OCInitStructure);//通道4
TIM_OC4PreloadConfig(TIM2, TIM_OCPreload_Disable);
/* TIM2 counter enable */
TIM_Cmd(TIM2,ENABLE);
/* TIM2 Main Output Enable */
//TIM_CtrlPWMOutputs(TIM2,ENABLE);
/* TIM IT enable */
TIM_ITConfig(TIM2, TIM_IT_CC1 | TIM_IT_CC2 | TIM_IT_CC3 | TIM_IT_CC4, ENABLE);
void GPIO_Configuration(void)
GPIO_InitTypeDef GPIO_InitStructure;
/*允许总线CLOCK,在使用GPIO之前必须允许相应端的时钟。
从STM32的设计角度上说,没被允许的端将不接入时钟,也就不会耗能,
这是STM32节能的一种技巧,*/
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA, ENABLE);
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB, ENABLE);
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOC, ENABLE);
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOD, ENABLE);
/* PA2,3,4,5,6,7输出-》LED1,LED2,LED3,LED4,LED5,LED6 */
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_2|GPIO_Pin_3|GPIO_Pin_4|GPIO_Pin_5|GPIO_Pin_6|GPIO_Pin_7;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_OD; //开漏输出
/* PB0,1输出-》LED7,LED8*/
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0|GPIO_Pin_1;
GPIO_Init(GPIOB, &GPIO_InitStructure);
/* PA0,1-》KEY_LEFT,KEY_RIGHT*/
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IPU;? //上拉输入
/* PC13-》KEY_UP*/
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_13;
GPIO_Init(GPIOC, &GPIO_InitStructure);
/* PB5-》KEY_DOWN*/
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_5;
/* GPIOA Configuration:TIM2 Channel1, 2, 3 and 4 in Output */
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0 | GPIO_Pin_1 | GPIO_Pin_2 | GPIO_Pin_3;
void NVIC_Configuration(void)
NVIC_InitTypeDef NVIC_InitStructure;
/* Configure one bit for preemption priority */
NVIC_PriorityGroupConfig(NVIC_PriorityGroup_1);
NVIC_InitStructure.NVIC_IRQChannel=TIM2_IRQn;
NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority=0;
NVIC_InitStructure.NVIC_IRQChannelSubPriority=1;
NVIC_InitStructure.NVIC_IRQChannelCmd=ENABLE;
NVIC_Init(&NVIC_InitStructure);
u16 capture = 0;
extern vu16 CCR1_Val;
extern vu16 CCR2_Val;
extern vu16 CCR3_Val;
extern vu16 CCR4_Val;
void TIM2_IRQHandler(void)
/* TIM2_CH1 toggling with frequency = 183.1 Hz */
if (TIM_GetITStatus(TIM2, TIM_IT_CC1) != RESET)
TIM_ClearITPendingBit(TIM2, TIM_IT_CC1 );
capture = TIM_GetCapture1(TIM2);
TIM_SetCompare1(TIM2, capture + CCR1_Val );
/* TIM2_CH2 toggling with frequency = 366.2 Hz */
if (TIM_GetITStatus(TIM2, TIM_IT_CC2) != RESET)
TIM_ClearITPendingBit(TIM2, TIM_IT_CC2);
capture = TIM_GetCapture2(TIM2);
TIM_SetCompare2(TIM2, capture + CCR2_Val);
/* TIM2_CH3 toggling with frequency = 732.4 Hz */
if (TIM_GetITStatus(TIM2, TIM_IT_CC3) != RESET)
TIM_ClearITPendingBit(TIM2, TIM_IT_CC3);
capture = TIM_GetCapture3(TIM2);
TIM_SetCompare3(TIM2, capture + CCR3_Val);
/* TIM2_CH4 toggling with frequency = 1464.8 Hz */
if (TIM_GetITStatus(TIM2, TIM_IT_CC4) != RESET)
TIM_ClearITPendingBit(TIM2, TIM_IT_CC4);
capture = TIM_GetCapture4(TIM2);
TIM_SetCompare4(TIM2, capture + CCR4_Val);
一个定时器一个通道,产生不同频率
其它的设置都一样,就是在主函数中修改一个参数,然后在定时器中断中,根据这个参数,改变频率。
#include “stm32lib\stm32f10x.h”
#include “hal.h”
volatile u16 Key_Value=1000;? //用于保存按键相应的PWM波占空比值
int main(void)
ChipHalInit();
ChipOutHalInit();
while(1)
? if( (!Get_Key_Up)&(!Get_Key_Down)&(!Get_Key_Left)&(!Get_Key_Right)&(!Get_Key_Ctrl) )
? ? Key_Value=12000;
? else
? ? if(Get_Key_Up)? ? //按键前进按下 ,对应1kHz
? ? Key_Value=6000;
? ? else if(Get_Key_Down)? //按键后退按下 ,对应2kHz
? ? ? Key_Value=3000;
? ? Delay_Ms(20);? ? ? //10ms延时
? ? if(Get_Key_Left)? ? //按键左转按下,对应3kHz
? ? Key_Value=2000;
? ? else if(Get_Key_Right) //按键右转按下,对应4kHz
? ? ? Key_Value=1500;
? ? if(Get_Key_Ctrl)? ? //按键控制按下,对应5kHz
? ? ? Key_Value=1200;
extern volatile u16 Key_Value;
u16 capture=0;
void TIM3_IRQHandler(void)
? ? TIM_ClearITPendingBit(TIM3, TIM_IT_CC2);
? ? TIM_SetCompare2(TIM3, capture + Key_Value);
void TIM3_Configuration(void)
/*TIM1时钟配置*/
TIM_TimeBaseStructure.TIM_Prescaler = 5;? ? ? //预分频(时钟分频)72M/6=12M
TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;? //向上计数
TIM_TimeBaseStructure.TIM_Period = 65535;? ? ? ? //装载值选择最大
TIM_TimeBaseStructure.TIM_ClockDivision = TIM_CKD_DIV1;
TIM_TimeBaseStructure.TIM_RepetitionCounter = 0x0;
TIM_TimeBaseInit(TIM3,&TIM_TimeBaseStructure);
TIM_OCInitStructure.TIM_Pulse = Key_Value; //占空时间
TIM_OCInitStruct
关键字:STM32  单片机  PWM 引用地址:如何采用STM32单片机产生PWM
上一篇:一文详解STM32端口复用及映射
下一篇:如何使STM32CubeMX新建工程
推荐阅读最新更新时间:2024-11-11 12:39
STM32之GPIO学习笔记
复位后,调试引脚处于复用功能上拉/下拉状态: PA15:JTDI处于上拉状态 PA14:JTCK/SWCLK处于下拉状态 PA13:JTMS/SWDAT处于下拉状态 PB4:NJTRST处于上拉状态 PB3:JTDO处于浮空状态
[单片机]
<font color='red'>STM32</font>之GPIO学习笔记
基于stm32的FIR滤波
这两天有个地方用到了距离传感器,选用的传感器是夏普的近红外距离传感器。后来调试的时候发现传感器出来的信号除了有个随着距离规律变化的直流信号以外还有一个周期为1ms的尖峰脉冲信号形状如下图示 这样的波形会影响采集数据的结果,硬件上已经固定了,所以就选择从软件方面来寻找解决方案。 之前涉及的软件滤波无非就是采用求平均值的方法或者用排序的方法取中间值。但是发现这种传统的方法都不能解决问题,无奈之下只好请出FIR了。在网上找到一段关于FIR滤波器的C代码, const double Gains = { 0.0009479362407674,0.0009929350550642, 0.003930214337694,0.000
[单片机]
基于<font color='red'>stm32</font>的FIR滤波
基于c51单片机8位数码管显示电子时钟程序
/* 8位数码管显示 时间格式 05—50—00 标示05点50分00秒 S1 用于小时加1操作 S2 用于小时减1操作 S3 用于分钟加1操作 S4 用于分钟减1操作 */ #include reg52.h sbit KEY1=P3^0; //定义端口参数 sbit KEY2=P3^1; sbit KEY3=P3^2; sbit KEY4=P3^3; sbit LED =P1^2; //定义指示灯参数 code unsigned char tab ={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f}; //共阴极数码管0—9 unsigned
[单片机]
关于STM32的 一个TIM1 的PWM程序和PWM简单使用
高级定时器与通用定时器比较类似,下面是一个TIM1 的PWM 程序,TIM1是STM32唯一的高级定时器。共有4个通道有 死区有互补。 先是配置IO脚: GPIO_InitTypeDef GPIO_InitStructure; /* PA8设置为功能脚(PWM) */ GPIO_InitStructure.GPIO_Pin = GPIO_Pin_8; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP; GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; GPIO_Init(GPIOA, &GPIO_InitStructure); /*P
[单片机]
关于<font color='red'>STM32</font>的 一个TIM1 的<font color='red'>PWM</font>程序和<font color='red'>PWM</font>简单使用
国民技术:MCU产品已经导入华为/大疆等客户
7月1日上午,国民技术发布投资者调研信息。近日,国民技术迎来约百家机构的调研,其中就包括了信达澳银冯明远。国民技术表示,公司MCU产品已经在多家行业龙头客户成功导入,比如华为、大疆、宁德时代等,向华为的产品销售供货也已获得BIS许可。 过去几年,国民技术投入了较多时间、精力和资源在MCU芯片上,对于MCU产品的布局规划、对MCU产品的发展预估以及目前产能情况,国民技术做出详细回应。 国民技术表示,正如公司近年定期报告所述,公司聚焦“通用+安全”产品及市场战略,围绕安全技术、射频技术以及SoC技术三大核心技术,形成三大产品线:安全芯片产品、射频产品以及通用MCU产品。(2)截至目前,MCU产品市场仍主要为国际芯片跨国企业供应,本地芯
[手机便携]
意法半导体推出首批Stellar SR6汽车微控制器
6月16日,全球最大的半导体公司之一意法半导体宣布已开始为众多汽车行业领导者交付首批Stellar SR6汽车微控制器(MCU),从而实现下一代先进汽车电子产品,提高性能和安全性。Stellar SR6可扩展MCU系列专为高性能和高效车辆平台打造,预计于2024年投产。该MCU非常适用于域和区域控制器,可简化车辆布线、支持迁移到软件定义平台以获得更高灵活性和更多功能,以及提高系统可靠性。 (图片来源:意法半导体) 意法半导体汽车和分离集团(Automotive and Discrete Group)总裁Marco Monti表示:“我们与主要客户成功测试了Stellar SR6 MCU,并已取得里程碑成就,已为计划生产的
[汽车电子]
意法半导体推出首批Stellar SR6汽车<font color='red'>微控制器</font>
单片机电路与数字电路的抗干扰方法
  形成干扰的基本要素有三个:   (1)干扰源,指产生干扰的元件、设备或信号,用数学语言描述如下:du/dt,di/dt大的地方就是干扰源。如:雷电、继电器、可控硅、电机、高频时钟等都可能成为干扰源。   (2)传播路径,指干扰从干扰源传播到敏感器件的通路或媒介。典型的干扰传播路径是通过导线的传导和空间的辐射。   (3)敏感器件,指容易被干扰的对象。如:A/D、D/A变换器,单片机,数字IC,弱信号放大器等。   抗干扰设计的基本原则是:抑制干扰源,切断干扰传播路径,提高敏感器件的抗干扰性能。(类似于传染病的预防)   1、抑制干扰源   抑制干扰源就是尽可能的减小干扰源的du/dt,di/dt。这是抗干扰设计中最优先
[单片机]
一种基于单片机的基本参数测试仪的设计
1 引言 研究的是一台人体基本参数测试仪,可以测量体温、脉搏和呼吸间隔等参数。这些参数与记录是应用最多的基础护理技术操作,各项技术比较成熟。但普通便携式设备大多功能单一,精度不高,且仅能作为临时测量使用,无法跟踪病人的整个治疗过程:医院里使用的大型医疗设备能够提供很高的精度,且功能全面,但过于专业的使用方法以及高昂的价格导致它们的市场需求不高。鉴于这些缺点,该系统的研究具有以下两点意义:①通过一台仪器将人体各项参数集中在一起进行实时测量,从而提高测量仪器的集成度和便利性。②测量采用全自动的方式,通过对各项参数设定门限,可以在测量后对超出门限的参数自动给出相关说明。这部便携、精准和可记录的人体参数测试仪具有很高的科学价值和社会意义
[单片机]
一种基于<font color='red'>单片机</font>的基本参数测试仪的设计
小广播
设计资源 培训 开发板 精华推荐
最新单片机文章
何立民专栏 单片机及嵌入式宝典
换一换 更多 相关热搜器件
电子工程世界版权所有 京ICP证060456号 京ICP备10001474号-1 电信业务审批[2006]字第258号函 京公网安备 11010802033920号 Copyright © 2005-2024 EEWORLD.com.cn, Inc. All rights reserved
