芯片型号STM32H743IIT6,测试时发现如果外面没有连接CAN设备,程序调用CAN发送时会一直等待发送反馈,导致相关线程挂起。
分析发现是卡在can.c文件的168行_can_int_tx函数:rt_completion_wait(&(tx_tosnd->completion), RT_WAITING_FOREVER);
rt_inline int _can_int_tx(struct rt_can_device *can, const struct rt_can_msg *data, int msgs)
int size;
struct rt_can_tx_fifo *tx_fifo;
RT_ASSERT(can != RT_NULL);
size = msgs;
tx_fifo = (struct rt_can_tx_fifo *) can->can_tx;
RT_ASSERT(tx_fifo != RT_NULL);
while (msgs)
rt_base_t level;
rt_uint32_t no;
rt_uint32_t result;
struct rt_can_sndbxinx_list tx_tosnd = RT_NULL;
rt_sem_take(&(tx_fifo->sem), RT_WAITING_FOREVER);
level = rt_hw_interrupt_disable();
tx_tosnd = rt_list_entry(tx_fifo->freelist.next, struct rt_can_sndbxinx_list, list);
RT_ASSERT(tx_tosnd != RT_NULL);
rt_list_remove(&tx_tosnd->list);
rt_hw_interrupt_enable(level);
no = ((rt_uint32_t)tx_tosnd - (rt_uint32_t)tx_fifo->buffer) / sizeof(struct rt_can_sndbxinx_list);
tx_tosnd->result = RT_CAN_SND_RESULT_WAIT;
if (can->ops->sendmsg(can, data, no) != RT_EOK)
/ send failed. */
rt_list_insert_after(&tx_fifo->freelist, &tx_tosnd->list);
rt_sem_release(&(tx_fifo->sem));
continue;
can->status.sndchange = 1;
说明一直在等待完成信号,而发送完成信号的地方在can.c文件的900行rt_hw_can_isr函数:
rt_completion_done(&(tx_fifo->buffer[no].completion));
case RT_CAN_EVENT_TX_DONE:
case RT_CAN_EVENT_TX_FAIL:
rt_uint32_t no;
no = event > > 8;
tx_fifo = (struct rt_can_tx_fifo *) can- >can_tx;
if ((event & 0xff) == RT_CAN_EVENT_TX_DONE)
tx_fifo- >buffer[no].result = RT_CAN_SND_RESULT_OK;
else
tx_fifo- >buffer[no].result = RT_CAN_SND_RESULT_ERR;
rt_completion_done(&(tx_fifo- >buffer[no].completion));
break;
然后想到如果can总线没有其他设备,CAN发送报文应该属于出错的情况,查看drv_fdcan.c文件中关于几种中断的处理,发现故障后的回调函数里没有调用rt_hw_can_isr。
于是参考HAL_FDCAN_TxBufferCompleteCallback函数的处理方式,对HAL_FDCAN_ErrorCallback进行了如下处理。
void HAL_FDCAN_ErrorCallback(FDCAN_HandleTypeDef *hfdcan)
rt_uint32_t tmp_u32Errcount;
rt_uint32_t tmp_u32status;
uint32_t ret = HAL_FDCAN_GetError(hfdcan);
if(hfdcan->Instance == FDCAN1)
#ifdef BSP_USING_FDCAN1
//can1
if( (ret & FDCAN_IT_ARB_PROTOCOL_ERROR) &&
(hfdcan->Instance->CCCR & FDCAN_CCCR_INIT_Msk))
//hfdcan->Instance->CCCR |= FDCAN_CCCR_CCE_Msk;
hfdcan->Instance->CCCR &= ~FDCAN_CCCR_INIT_Msk;
st_DrvCan1.device.status.errcode = 0xff;
else
tmp_u32Errcount = st_DrvCan1.fdcanHandle.Instance->ECR;
tmp_u32status = st_DrvCan1.fdcanHandle.Instance->PSR;
st_DrvCan1.device.status.rcverrcnt = (tmp_u32Errcount>>8)&0x000000ff;
st_DrvCan1.device.status.snderrcnt = (tmp_u32Errcount)&0x000000ff;
st_DrvCan1.device.status.lasterrtype = tmp_u32status&0x000000007;
rt_hw_can_isr(&st_DrvCan1.device, RT_CAN_EVENT_TX_FAIL);
#endif / BSP_USING_FDCAN1 /
else
#ifdef BSP_USING_FDCAN2
st_DrvCan2.device.status.errcode = 0xff;
else
//can2
tmp_u32Errcount = st_DrvCan2.fdcanHandle.Instance->ECR;
tmp_u32status = st_DrvCan2.fdcanHandle.Instance->PSR;
st_DrvCan2.device.status.rcverrcnt = (tmp_u32Errcount>>8)&0x000000ff;
st_DrvCan2.device.status.snderrcnt = (tmp_u32Errcount)&0x000000ff;
st_DrvCan2.device.status.lasterrtype = tmp_u32status&0x000000007;
rt_hw_can_isr(&st_DrvCan2.device, RT_CAN_EVENT_TX_FAIL);
#endif / BSP_USING_FDCAN2 /
经过测试发现即使CAN总线上没有别的设备,调用发送函数也不会一直等待,而是返回发送失败
设计资源 培训 开发板 精华推荐
- ESP32WROOM开发板-全0805焊接友好
- LF60CV 6V 多路低压降稳压器电源的典型应用,带 ON/OFF 拨动开关
- 适用于工业物联网应用的STWIN SensorTile无线工业节点开发套件和参考设计
- 充电式蓝牙转485通讯测试盒
- LTC3548A 的典型应用 - 双路同步 400mA/800mA、2.25MHz 降压型 DC/DC 稳压器
- 使用 Analog Devices 的 ADP5070A 的参考设计
- 使用 ROHM Semiconductor 的 BU4840 的参考设计
- SY89876L,用于 GB 以太网交换机的 2000MHz 时钟分频器的评估板
- AD7305 四路、8 位轨至轨 DAC 的典型应用
- NanoVNA-J 矢量网络分析仪
