s3c6410_uart初始化及读写
发布者:自由梦想最新更新时间:2024-09-04 来源: cnblogs关键字:s3c6410  uart  初始化  读写 手机看文章 扫描二维码
随时随地手机看文章
参考:
1)《USER'S MANUAL-S3C6410X》第31章 UART
2)u-boot uart初始化及读写:u-boot-x.x.x/board/samsumg/smdk6410/lowlevel_init.S
                u-boot-x.x.x/cpu/s3c64xx/serial.c
3) 内核串口驱动:linux-x.x.x/driver/tty/serial/s3c6400.c samsung.c serial_core.c
代码:
uart.c
 1 #include 'uart.h'
 3 #define GPACON        (*((volatile unsigned long *)0x7f008000))
 5 #define ULCON0        (*((volatile unsigned long *)0x7f005000))
 6 #define UCON0        (*((volatile unsigned long *)0x7f005004))
 7 #define UFCON0        (*((volatile unsigned long *)0x7f005008))
 8 #define UMCON0        (*((volatile unsigned long *)0x7f00500c))
 9 #define UTRSTAT0    (*((volatile unsigned long *)0x7f005010))
10 #define UERSTAT0    (*((volatile unsigned long *)0x7f005014))
11 #define UFSTAT0        (*((volatile unsigned long *)0x7f005018))
12 #define UMSTAT0        (*((volatile unsigned long *)0x7f00501c))
13 #define UTXH0        (*((volatile unsigned long *)0x7f005020))
14 #define URXH0        (*((volatile unsigned long *)0x7f005024))
15 #define UBRDIV0        (*((volatile unsigned long *)0x7f005028))
16 #define UDIVSLOT0    (*((volatile unsigned long *)0x7f00502c))
17 #define UINTP0        (*((volatile unsigned long *)0x7f005030))
18 #define UINTSP0        (*((volatile unsigned long *)0x7f005034))
19 #define UINTM0        (*((volatile unsigned long *)0x7f005038))
21 void uart0_init(void)
22 {
23     GPACON &= ~0xff;
24     GPACON |= 0X22;
26     ULCON0 = 0x03; //data frame: 8n1
27     /*
28     clk: pclk
29     tx int type: level
30     rx int type: pulse
31     rx err int enable
32     tx/rx mode: interrupt or polling
33     */
34     UCON0 = 0x245;
35     UFCON0 = 0x00; //disable fifo;
36     UMCON0 = 0X00; //disable auto flow control(AFC)
37     /*
38     DIV_VAL = UBRDIV + (num of 1's in UDIVSLOT)/16
39     DIV_VAL = (PCLK/(bps*16))-1 = (66000000/115200)-1=34.8
40     UBRDIV = 34;
41     num of 1's in UDIVSLOT = 13;
42     */
43     UBRDIV0 = 0x22;
44     UDIVSLOT0 = 0x1fff;
45 }
46
47 int uart0_getc(void)
48 {
49     while (!(UTRSTAT0 & 0x1));
50     return (URXH0 & 0xff);
51 }
52
53 void uart0_putc(const char c)
54 {
55     while (!(UTRSTAT0 & 0x2));
56     UTXH0 = c;
57     if (c == 'n')
58     {
59         uart0_putc('r');
60     }
61 }
62
63 void uart0_puts(const char *s)
64 {
65     while (*s)
66     {
67         uart0_putc(*s++);
68     }
69 }
关键字:s3c6410  uart  初始化  读写 引用地址:s3c6410_uart初始化及读写
上一篇:s3c6410_uboot中的代码重定位(nand->sdram)
下一篇:s3c6410_时钟初始化
推荐阅读最新更新时间:2024-11-12 23:35
SD卡SPI读写子程序以及SD卡设置成SPI总线的操作
上节讲了SD卡有两种总线操作方式,我选择SPI总线方式。这样我可以利用自己以前的SPI读写程序。 #define SD_CS p1_1//为SPI的使能端 #define CLK p1_2//为SPI时钟输入 #define MOSI p1_3//为SPI数据主输从人端 #define MISO p1_4//为SPI数据主人从输端 #define uchar unsigned char uchar SD_SPI_RW(uchar data_byte)//spi通信的读写子程序 { uchar bit_ctr; for(bit_ctr=0;bit_ctr 8;bit_ctr++) { if((data_by
[单片机]
51单片机串口通信(UART)
项目描述: 1.串口工作方式为1(8位UART,波特率可变),无校验位; 2.通信数据格式为:1位起始位 + 8位数据位 + 1位停止位; 3.上电后MCU给上位机发送问候语,之后等待上位机的信息;MCU和上位机的通信为收发交替进行。MCU接收到的信息会实时的显示在LCD上。上位机接收到的信息会在串口助手上显示。 C语言程序如下: /*----------------------- FileName: UART.h Function: 头文件 Author: Zhang Kaizhou Date: 2019-6-10 11:33:35 ------------------------*/ #include reg52.h
[单片机]
51单片机串口通信(<font color='red'>UART</font>)
学会了单片机的UART,就学会了通信
UART(英文全称:Universal Asynchronous Receiver / Transmitter)是一种异步全双工串行通信协议,由Tx和Rx两根数据线组成,因为没有参考时钟信号,所以通信的双方必须约定串口波特率、数据位宽、奇偶校验位、停止位等配置参数,从而按照相同的速率进行通信。 异步通信以一个字符为传输单位,通信中两个字符间的时间间隔多少是不固定的,然而在同一个字符中的两个相邻位间的时间间隔是固定的。当波特率为9600bps时,传输一个bit的时间间隔大约为104.16us;波特率为115200bps时,传输一个bit的时间间隔大约为8us。 数据传送速率用波特率来表示,即每秒钟传送的二进制位数。例如数据传
[单片机]
【STM库应用】stm32 之 中断按键初始化(注意事项)
之前做终端按键的时候都是只做了一个,没有做多个,昨天在把所有按键都设置成中断模式的时候遇到问题,于是乎还跟一个网上的哥们进行了热议,后来还是我发现了问题!最终把问题给解决了! 我的按键的GPIO连接有点奇葩,他不是连续的,这可能就是竞赛板故意设置的难度吧! 首先管脚初始化: GPIO_InitTypeDef key; RCC- APB2ENR |= ((1 0)|(1 2)|(1 3)); key.GPIO_Pin = GPIO_Pin_0|GPIO_Pin_8; key.GPIO_Mode = GPIO_Mode_IPD; GPIO_Init(GPIOA, &key); key.GPIO
[单片机]
【STM库应用】stm32 之 中断按键<font color='red'>初始化</font>(注意事项)
通过调试的AT93C46读写程序(C语言)
/********************************************************************* 通过调试的AT93C46读写程序(C语言) * 程序说明:本程序实现51系列单片机对AT93C46的读写,ORG端接地 * 版本: v1.1 *********************************************************************/ #include reg51.h #include intrins.h unsigned char uchar; #define READ_D 0xc0 //读指令 #define
[单片机]
STM32F427 内部晶振初始化
void SystemHSIInit(void) { /* FPU settings ------------------------------------------------------------*/ #if (__FPU_PRESENT == 1) && (__FPU_USED == 1) SCB- CPACR |= ((3UL 10*2)|(3UL 11*2)); /* set CP10 and CP11 Full Access */ #endif /* Reset the RCC clock configuration to the default reset state
[单片机]
S3C2440 测试程序(七) IIC实验1--读写EEPROM(不开中断)
硬件IIC类似软件模拟IIC,硬件IIC读取ACK需要判断寄存器IICCON的bit4是否发生中断为1。 初始化: rGPEUP = 0xc000; //SDA SCL关上拉 rGPECON = 0xa0000000; //GPE14 GPE15设为SDA SCL功能 rIICCON = (1 7)|(0 6)|(1 5)|(0xf); 注: bit : 1--enable ACK bit : 0--IICCLK = PCLK/16 bit : 1--enable interrupt 该为不管用不用到中断都必须为1 bit : 1--interrupt
[单片机]
S3C2440 测试程序(七) IIC实验1--<font color='red'>读写</font>EEPROM(不开中断)
如何禁止KEIL初始化RAM为零& 如何判断是软复位还是上电复位
笔记: (1)如何禁止KEIL初始化RAM为零? 1. 在KEIL Noinit 打钩 2. 1 另须对需要热启动保持的变量用__at关键字指定某个区域,否则还是没用 (#include absacc.h ) 2 或者__attribute__((zero_init)) 关键字 .bss段 int test1=1; __attribute__((zero_init)) int test2; int test3 __at(0x20001000); 查看MAP文件 test1 0x20000000 Data 4 main.o(.data) tes
[单片机]
如何禁止KEIL<font color='red'>初始化</font>RAM为零& 如何判断是软复位还是上电复位
小广播
设计资源 培训 开发板 精华推荐
最新单片机文章
何立民专栏 单片机及嵌入式宝典
电子工程世界版权所有 京ICP证060456号 京ICP备10001474号-1 电信业务审批[2006]字第258号函 京公网安备 11010802033920号 Copyright © 2005-2024 EEWORLD.com.cn, Inc. All rights reserved
