stm32串口接收数据程序
发布者:Xiaohan521最新更新时间:2024-09-11 来源: elecfans关键字:stm32  串口  接收数据 手机看文章 扫描二维码
随时随地手机看文章
void init_usart(void)
//RCC初始化
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA | RCC_APB2Periph_AFIO,,ENABLE);//使能GPIOA时钟
RCC_APB1PeriphClockCmd(RCC_APB1Periph_USART2,ENABLE);
//nvic
NVIC_ InitTypeDef NVIC_InitStructure;#ifdef VECT_TAB_RAM
NVIC_SetVectorTable(NVIC_VectTab_RAM,Ox0);#else
NVIC_SetVectorTable(NVIC_VectTab_FLASH,Ox0);#endif
NVIC_PriorityGroupConfig(NVIC_PriorityGroup_0);
NVIC_InitStructure.NVIC_IRQChannel = USART2_IRQn;NVIC_InitStructure.NVIC_IRQChannelSubPriority = o;NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;NVIC_Init(&NVIC_lnitStructure);
//GPIO初始化
GPIO_IlnitTypeDef GPIO_InitStructure;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;GPIO_IlnitStructure.GPIO_Speed = GPIO_Speed_5OMHz;GPIO_InitStructure.GPIO_Pin = GPIO_Pin_2;
GPIO_Init(GPIOA,&GPIO_InitStructure);
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;GPIO_InitStructure.GPIO_Speed = GPIO_Speed_5OMHz;GPIO_InitStructure.GPIO_Pin = GPIO_Pin_3;
//USART初始
//USART_DeInit(USART2);
USART_InitTypeDef USART_InitStructure;
//串口设置恢复默认参数
USART_ClockInitTypeDef USART_ClocklnitStructure;
USART_InitStructure.USART_BaudRate = 9600;
//波特率9600
USART_InitStructure.USART_WordLength = USART_WordLength_8b;//字长8位USART_InitStructure.USART_StopBits = USART_StopBits_1;
//1位停止字节
USART_InitStructure.USART_Parity = USART_Parity_No;
川/无奇偶校验
USART_IlnitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None;//无流控制
USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx;//打开Rx接收和Tx发送功能
USART_ClockInitStructure.USART_Clock =USART_Clock_Disable;USART_ClockInitStructure.USART_CPOL =USART_CPOL_High;USART_ClockInitStructure.USART_CPHA =USART_CPHA_2Edge;USART_ClocklnitStructure.USART_LastBit =USART_LastBit_Disable;USART_Clocklnit(USART2,&USART_ClockInitStructure);
USART_Init(USART2,&USART_InitStructure);
//初始化
USART_ITConfig(USART2,USART_IT_RXNE,ENABLE);//开启接收中断,这个必须在打开串口之前设置USART_Cmd(USART2,ENABLE);
/启动串口
void USART2_IRQHandler(void)
//接收中断
if(USART_GetlTStatus(USART2,USART_IT_RXNE)==SET)(
USART_ClearlTPendingBit(USART2,USART_IT_RXNE);usart_rx=USART_ReceiveData(USART2);
usart_rx_flag=1;
//溢出-如果发生溢出需要先读SR,再读DR寄存器则可清除不断入中断的问题[牛人说要这样]if(USART_GetFlagStatus(USART2,USART_FLAG_ORE)==SET)
USART_ClearFlag(USART2,USART_FLAG_ORE);//读SR其实就是清除标志USART_ReceiveData(USART2);//读DR
关键字:stm32  串口  接收数据 引用地址:stm32串口接收数据程序
上一篇:stm32任务调度和管理
下一篇:关于STM32半主机机制的作用
推荐阅读最新更新时间:2024-11-12 07:19
STM32平衡小车】APP调试协议及代码分析
一、首页界面 printf( {A%d:%d:%d:%d}$ ,a,b,c,d); a、b、c、d分别为需要显示的状态: a对应左边的码盘,b对应右边的码盘,通过百分比表示,可以用于速度等状态的显示,范围是0—100(%) c主要是用于显示电量,范围也是0—100(%) d是角度值,范围是-180°—180°。 APP控件名称与发送指令对应对应关系 二、波形界面 printf( {B%d:%d:%d:%d:%d}$ ,a,b,c,d,e); 5个波形通道! a、b、c、d、e 为需要显示的波形,发送的参数必须为整型变量,如果需要显示浮点数,放大一定的倍数之后再打印出来。 需要注意的是,每个通道发送的数据
[单片机]
【<font color='red'>STM32</font>平衡小车】APP调试协议及代码分析
程序结构理解(2) 以stm32为例
stm32启动流程分析 这个是一个汇编与c语言结合的流程 stm32入口为 startup_stm32f10x_hd.s (即第一个执行的文件) 在这个文件中首先定义定义CSTACK数据段和.intvec代码段还有全局函数和全局变量 然后就是向量表 在然后就是向量表中的定义了各个函数。 同时复位函数作为程序运行的第一个函数 里面设置了时钟和main入口等 就这样进入了main 然后就调用了各个外设资源 流程大致总结如下 大概意思就这样吧
[单片机]
程序结构理解(2) 以<font color='red'>stm32</font>为例
STM32的USARTx中u3_printf函数解析
我们在STM32中常常使用printf来将信息打印至PC端控制台上。但是有这样一种函数,它可以把数据以我们指定的格式装进字符串中——sprinft和vsprintf。 ⑴ sprintf函数使用的方式如下: ① 将多个参数以指定格式写入字符串 int a=1,b=2; char s ; sprintf(s, a=%d,b=%d ,1,2); puts(s); 输出结果:a=1,b=2 ② 错误使用:在函数封装中使用 void Myprintf(const char* fmt,...) // 传递个数不定的参数 { char s ; sprintf(s,fmt); // 出现错误 puts
[单片机]
<font color='red'>STM32</font>的USARTx中u3_printf函数解析
STM32 在温度监控系统中的应用
引言 现代工业控制领域通常要测量很多信号,将其转化为计算机可以识别的二进制信号,并利用计算机监视和记录各种测量的信号。这个过程就要涉及到信号的采集和处理。CAN 总线是一种串行多主总线,它卓越的特性、极高的可靠性和独特的设计,特别适合工业过程监控设备的互连,因此,越来越受到工业界的重视,并已公认为最有前途的 现场总线 之一。本文介绍了基于 STM32 和 CAN 总线的温度监控系统的设计,通过上位机与下位机的通信,实现对温度数据的监控,并经初步实验达到了设计的要求。 1 系统总体方案概述 系统总体框图如图 1 所示,本系统采用主站+从站的结构,CAN 主站主要实现温度数据的存储以及 CAN 总线协议和串口协议之间的 桥接 ,CA
[单片机]
STM32F207运用串口空闲中断+DMA接收不定长数据
1.我们知道DMA可以自动的不在CPU干预下,自动把数据重外设存储到内存(我们这节讲的),内存到外设,内存到内存等。但是DMA接收的是指定长度的,在接收不定长数据的时候DMA就傻眼了。网上有许多方法讲解运用定时器超时检测来接收不定长数据,而我们现在要讲的是运用串口空闲中断+DMA的方式接收不定长数据。 2.我们调试用的是串口1、DMA_Channel_4。具体的配置见下面程序: DMA接收配置: void USART1_DMA_Config(void) { DMA_InitTypeDef DMA_InitStructure; RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_DMA2,
[单片机]
STM32 USART串口初始化
1、初始化串口时钟以及串口IO端口时钟: 使用RCC_APB2PeriphClockCmd(uint32_t RCC_APB2Periph, FunctionalState NewState); 备注:为什么要使能IO口时钟? 参照用户手册 P165-P166 使用串口这个外设的时候需要将串口的IO属性配置为图示; 使用串口是否需要打开复用时钟,请见http://blog.csdn.net/u012411027/article/details/44217313,看到这位的解释才恍然大悟的。 2、串口参数设置(波特率、数据长度、停止位、校验位、发送接收模式、硬件控制流) 具体初始化及初始化方式如图:
[单片机]
STM32 FreeRTOS Keil环境搭建
由于FreeRTOS的官方已经支持STM32F1X系列的Cortex-M3的移植,所以只需要在Keil IDE中设置相关即可了; 在Keil中新建一工程,在工程中新建3个组,分别对应3个目录用来存放:user、rtos、stmlib user中添加用户自己的代码和头文件; rtos中添加rots的文件主要有:list.c、task.c、queue.c、head_2.c、port.c stmlib中添加STM32官方提供的STM32操作的lib库(注意stm32f10x_md.s中的内容和替换为FreeRTOS Demo 中的STM32F10X.s否则系统调度不能正常工作) 另外需要把FreeRTOS/source/inc
[单片机]
小广播
设计资源 培训 开发板 精华推荐
最新单片机文章
何立民专栏 单片机及嵌入式宝典
电子工程世界版权所有 京ICP证060456号 京ICP备10001474号-1 电信业务审批[2006]字第258号函 京公网安备 11010802033920号 Copyright © 2005-2024 EEWORLD.com.cn, Inc. All rights reserved
