STM32中SD的初始化代码
发布者:温暖心情最新更新时间:2024-09-29 来源: cnblogs关键字:STM32  初始化代码 手机看文章 扫描二维码
随时随地手机看文章
STM32中SD的初始化代码:
SD_Error SD_Init(void)
        /*重置SD_Error状态*/
        SD_Error errorstatus = SD_OK;
        /* SDIO 外设底层引脚初始化 */
        GPIO_Configuration();
        /*对SDIO的所有寄存器进行复位*/
        SDIO_DeInit();
        /*上电并进行卡识别流程,确认卡的操作电压*/
        errorstatus = SD_PowerON();
        /*如果上电,识别不成功,返回“响应超时”错误 */
        if (errorstatus != SD_OK)
                /*!< CMD Response TimeOut (wait for CMDSENT flag) */
                return(errorstatus);
        /*卡识别成功,进行卡初始化    */
        errorstatus = SD_InitializeCards();
        if (errorstatus != SD_OK)          //失败返回
        /*!< Configure the SDIO peripheral
        上电识别,卡初始化都完成后,进入数据传输模式,提高读写速度
        速度若超过24M要进入bypass模式
        !< on STM32F2xx devices, SDIOCLK is fixed to 48MHz
        !< SDIOCLK = HCLK, SDIO_CK = HCLK/(2 + SDIO_TRANSFER_CLK_DIV) */
        SDIO_InitStructure.SDIO_ClockDiv = SDIO_TRANSFER_CLK_DIV;
        SDIO_InitStructure.SDIO_ClockEdge = SDIO_ClockEdge_Rising;                //上升沿采集数据
        SDIO_InitStructure.SDIO_ClockBypass = SDIO_ClockBypass_Disable;//时钟频率若超过24M,要开启此模式
        SDIO_InitStructure.SDIO_ClockPowerSave = SDIO_ClockPowerSave_Disable;           //若开启此功能,在总线空闲时关闭sd_clk时钟
        SDIO_InitStructure.SDIO_BusWide = SDIO_BusWide_1b;                                                //1位模式
        SDIO_InitStructure.SDIO_HardwareFlowControl = SDIO_HardwareFlowControl_Disable; //硬件流,若开启,在FIFO不能进行发送和接收数据时,数据传输暂停
        SDIO_Init(&SDIO_InitStructure);
        if (errorstatus == SD_OK)
                /*----------------- Read CSD/CID MSD registers ------------------*/
                errorstatus = SD_GetCardInfo(&SDCardInfo);       //用来读取csd/cid寄存器
                /*----------------- Select Card --------------------------------*/
                errorstatus = SD_SelectDeselect((uint32_t) (SDCardInfo.RCA << 16));          //通过cmd7,rca选择要操作的卡
                errorstatus = SD_EnableWideBusOperation(SDIO_BusWide_4b);        //开启4bits模式
SD_Error SD_PowerON(void)
        uint32_t response = 0, count = 0, validvoltage = 0;
        uint32_t SDType = SD_STD_CAPACITY;
        /*!< Power ON Sequence -----------------------------------------------------*/
        /*!< Configure the SDIO peripheral */
        /*!< SDIOCLK = HCLK, SDIO_CK = HCLK/(2 + SDIO_INIT_CLK_DIV) */
        /*!< on STM32F2xx devices, SDIOCLK is fixed to 48MHz */
        /*!< SDIO_CK for initialization should not exceed 400 KHz */
        /* 上电顺序 -------------------------------------------------------------------------*/
        /* 为卡识别模式配置 SDIO 外设 */
        /* SDIOCLK = HCLK, SDIO_CK = HCLK/(2 + SDIO_INIT_CLK_DIV) = 400KHz */
        /* 卡识别模式时的 SDIO_CK 不能超过 400KHz */
        /*初始化时的时钟不能大于400KHz*/
        SDIO_InitStructure.SDIO_ClockDiv = SDIO_INIT_CLK_DIV;/*设置时钟分频=178*/        /* HCLK = 72MHz, SDIOCLK = 72MHz, SDIO_CK = HCLK/(178 + 2) = 400 KHz
        SDIO_InitStructure.SDIO_ClockEdge = SDIO_ClockEdge_Rising; //时钟上升沿采集数据
        SDIO_InitStructure.SDIO_ClockBypass = SDIO_ClockBypass_Disable;//不使用bypass模式,直接用HCLK进行分频得到SDIO_CK
        SDIO_InitStructure.SDIO_ClockPowerSave = SDIO_ClockPowerSave_Disable;        // 空闲时不关闭时钟电源
        SDIO_InitStructure.SDIO_BusWide = SDIO_BusWide_1b;                                       //1位数据线
        SDIO_InitStructure.SDIO_HardwareFlowControl = SDIO_HardwareFlowControl_Disable;//硬件流
        SDIO_Init(&SDIO_InitStructure);//初始化SDIO
        /*!< Set Power State to ON */          /*打开SDIO的电源*/
        SDIO_SetPowerState(SDIO_PowerState_ON);
        /*!< Enable SDIO Clock */        /*开SDIO的时钟*/
        SDIO_ClockCmd(ENABLE);
        /*下面发送一系列命令,开始卡识别流程*/
        /************************发送CMD0***************************************        */
        /*!< CMD0: GO_IDLE_STATE变为空闲状态---------------------------------------------------*/
        /*!< No CMD response required */
        /* 发送 CMD0 复位卡,该命令不需要响应 */
        SDIO_CmdInitStructure.SDIO_Argument = 0x0;//命令参数,是命令的一部分,和命令一起发送
        SDIO_CmdInitStructure.SDIO_CmdIndex = SD_CMD_GO_IDLE_STATE; //cmd0命令索引,变为空闲状态
        SDIO_CmdInitStructure.SDIO_Response = SDIO_Response_No;//无响应        SDIO响应类型
        SDIO_CmdInitStructure.SDIO_Wait = SDIO_Wait_No;           //SDIO不等待中断
        SDIO_CmdInitStructure.SDIO_CPSM = SDIO_CPSM_Enable;//则CPSM在开始发送命令之前等待数据传输结束。
        SDIO_SendCommand(&SDIO_CmdInitStructure);                          //写命令进SDIO命令寄存器
        errorstatus = CmdError();//检测是否正确接收到cmd0
        /* 没发送CMD0,返回命令超时错误 */
        if (errorstatus != SD_OK)        //命令发送出错,返回
        /************************发送CMD8***************************************        */
        /*!< CMD8: SEND_IF_COND ----------------------------------------------------*/
        /*!< Send CMD8 to verify SD card interface operating condition */
        /*!< Argument: - : Reserved (shall be set to '0')
                   - : Supply Voltage (VHS) 0x1 (Range: 2.7-3.6 V)
                   - : Check Pattern (recommended 0xAA) */
        /*!< CMD Response: R7 */
        /* CMD8: SEND_IF_COND -------------------------------------------------------------*/
        /* 发送 CMD8 核实 SD 卡接口操作条件 */
        /* 参数: - : 保留('0')
                - : 供电电压(VHS) 0x1 (范围: 2.7-3.6 V)
                - : 检查类型 (推荐 0xAA) */
        /* 响应类型: R7 */
        SDIO_CmdInitStructure.SDIO_Argument = SD_CHECK_PATTERN;        //接收到命令sd会返回这个参数
        SDIO_CmdInitStructure.SDIO_CmdIndex = SDIO_SEND_IF_COND;        //cmd8
        SDIO_CmdInitStructure.SDIO_Response = SDIO_Response_Short;       //r7
        SDIO_CmdInitStructure.SDIO_Wait = SDIO_Wait_No;                       //关闭等待中断
        /*检查是否接收到命令*/
        errorstatus = CmdResp7Error();
        /* 如果已收到响应 R7,则符合SD卡2.0标准,并且可以设置HCS(HCS=1,表示主机支持SDHC) */
        if (errorstatus == SD_OK)                  //有响应则card遵循sd协议2.0版本
                CardType = SDIO_STD_CAPACITY_SD_CARD_V2_0; /*!< SD Card 2.0 ,先把它定义会sdsc类型的卡*/ /* 标准容量SD卡2.0 */
                SDType = SD_HIGH_CAPACITY;        //这个变量用作acmd41的参数,用来询问是sdsc卡还是sdhc卡
        else        //无响应,说明是1.x的或mmc的卡
                /*!< CMD55 也就是PDF图中的ACMD41 0x41=d55*/
                /* CMD55: APP_CMD */
                /* 发送CMD55判断是不是SD卡 */
                /* 参数: - : RCA = 0x0000
                         - : 保留('0') */
                /* 响应类型: R1 */
                SDIO_CmdInitStructure.SDIO_Argument = 0x00;
                SDIO_CmdInitStructure.SDIO_CmdIndex = SD_CMD_APP_CMD;
                errorstatus = CmdResp1Error(SD_CMD_APP_CMD);
                 - : 保留('0') */
        /* 响应类型: R1 */
        /*!< CMD55 */                //为什么在else里和else外面都要发送CMD55?
        //发送cmd55,用于检测是sd卡还是mmc卡,或是不支持的卡
        SDIO_CmdInitStructure.SDIO_Response = SDIO_Response_Short; //r1
        errorstatus = CmdResp1Error(SD_CMD_APP_CMD);        //是否响应,没响应的是mmc或不支持的卡
        /*!< If errorstatus is Command TimeOut, it is a MMC card */
        /*!< If errorstatus is SD_OK it is a SD card: SD card 2.0 (voltage range mismatch)
           or SD card 1.x */
        /* 如果 errorstatus 是命令响应超时,则是 MMC 卡 */
        /* 如果 errorstatus 是 SD_OK ,则是 SD 卡: SD卡1.x(不符合SD卡2.0标准)或SD 卡 2.0(不支持设置的电压范围(2.7~3.6V)) */
        if (errorstatus == SD_OK)        //响应了cmd55,是sd卡,可能为1.x,可能为2.0
                /*下面开始循环地发送sdio支持的电压范围,循环一定次数*/
                /*!< SD CARD */
                /*!< Send ACMD41 SD_APP_OP_COND with Argument 0x80100000 */
                while ((!validvoltage) && (count < SD_MAX_VOLT_TRIAL))
                        /* 必须在发送 ACMD41 之前发送 CMD55 通知卡,下面一条命令是应用特定命令 */
                                 - : 保留('0') */
                        /* 响应类型: R1 */
                        //因为下面要用到ACMD41,是ACMD命令,在发送ACMD命令前都要先向卡发送CMD55
                        /*!< SEND CMD55 APP_CMD with RCA as 0 */
                        SDIO_CmdInitStructure.SDIO_CmdIndex = SD_CMD_APP_CMD;          //CMD55
                        errorstatus = CmdResp1Error(SD_CMD_APP_CMD); //检测响应
                                return(errorstatus);//没响应CMD55,返回
                        //acmd41,命令参数由支持的电压范围及HCS位组成,HCS位置一来区分卡是SDSc还是sdhc
                        /* ACMD41: SD_SEND_OP_COND */
                        /* 发送 ACMD41 要求卡发送操作条件寄存器(OCR) */
                        /* 参数: - : 保留('0')
                                - : 主机容量支持(HCS) SDType = 0x40000000
                                - : VDD电压窗口 SD_VOLTAGE_WINDOW_SD = 0x00100000(3.2~3.3V) */
                        /* 响应类型: R3 */
                        SDIO_CmdInitStructure.SDIO_Argument = SD_VOLTAGE_WINDOW_SD | SDType;          //参数为主机可供电压范围及hcs位
                        SDIO_CmdInitStructure.SDIO_CmdIndex = SD_CMD_SD_APP_OP_COND;
                        SDIO_CmdInitStructure.SDIO_Response = SDIO_Response_Short;//r3
                        errorstatus = CmdResp3Error();        //检测是否正确接收到数据
                        /* 命令响应超时,返回命令响应超时错误 */
                                return(errorstatus);//没正确接收到acmd41,出错,返回
                        /* 从SDIO_RESP1寄存器中读取响应R3(OCR),并解析 */
                        /*若卡需求电压在SDIO的供电电压范围内,会自动上电并标志pwr_up位*/
                        response = SDIO_GetResponse(SDIO_RESP1);       //读取卡寄存器,卡状态
                        /* 判断busy位(OCR)是否为1(busy=1,表示ACMD41的初始化完成) */
                        validvoltage = (((response >> 31) == 1) ? 1 : 0);        //读取卡的ocr寄存器的pwr_up位,看是否已工作在正常电压
                        count++;                          //计算循环次数
                /* 如果尝试了 SD_MAX_VOLT_TRIAL 次,初始化还没有完成,则VDD电压窗口(3.2~3.3V)是无效的 */
                if (count >= SD_MAX_VOLT_TRIAL)        //循环检测超过一定次数还没上电
                        errorstatus = SD_INVALID_VOLTRANGE;           //SDIO不支持card的供电电压
                /*检查卡返回信息中的HCS位*/
                /* 判断CCS位(OCR)是否为1(CCS=1,表示卡是高容量SD卡) */
                if (response &= SD_HIGH_CAPACITY)//判断ocr中的ccs位 ,如果是sdsc卡则不执行下面的语句
                        CardType = SDIO_HIGH_CAPACITY_SD_CARD;//把卡类型从初始化的sdsc型改为sdhc型
        }/*!< else MMC Card *//* 否则是 MMC 卡 */
SD_Error SD_InitializeCards(void)
        uint16_t rca = 0x01;
        if (SDIO_GetPowerState() == SDIO_PowerState_OFF)
                errorstatus = SD_REQUEST_NOT_APPLICABLE;
        if (SDIO_SECURE_DIGITAL_IO_CARD != CardType)//判断卡的类型
                /*!< Send CMD2 ALL_SEND_CID */
                SDIO_CmdInitStructure.SDIO_CmdIndex = SD_CMD_ALL_SEND_CID;
                SDIO_CmdInitStructure.SDIO_Response = SDIO_Response_Long;
                errorstatus = CmdResp2Error();
                if (SD_OK != errorstatus)
                CID_Tab = SDIO_GetResponse(SDIO_RESP1);
                CID_Tab = SDIO_GetResponse(SDIO_RESP2);
                CID_Tab = SDIO_GetResponse(SDIO_RESP3);
                CID_Tab = SDIO_GetResponse(SDIO_RESP4);
        /*下面开始SD卡初始化流程*/
        if ((SDIO_STD_CAPACITY_SD_CARD_V1_1 == CardType) ||(SDIO_STD_CAPACITY_SD_CARD_V2_0 == CardType) ||(SDIO_SECURE_DIGITAL_IO_COMBO_CARD == CardType)
                ||(SDIO_HIGH_CAPACITY_SD_CARD == CardType))       //使用的是2.0的卡
                /*!< Send CMD3 SET_REL_ADDR with argument 0 */
                /*!< SD Card publishes its RCA. */
                SDIO_CmdInitStructure.SDIO_CmdIndex = SD_CMD_SET_REL_ADDR;        //cmd3
                SDIO_CmdInitStructure.SDIO_Response = SDIO_Response_Short; //r6
                errorstatus = CmdResp6Error(SD_CMD_SET_REL_ADDR, &rca);        //把接收到的卡相对地址存起来。
                RCA = rca;
                /*!< Send CMD9 SEND_CSD with argument as card's RCA */
                SDIO_CmdInitStructure.SDIO_Argument = (uint32_t)(rca << 16);
                SDIO_CmdInitStructure.SDIO_CmdIndex = SD_CMD_SEND_CSD;
                CSD_Tab = SDIO_GetResponse(SDIO_RESP1);
                CSD_Tab = SDIO_GetResponse(SDIO_RESP2);
                CSD_Tab = SDIO_GetResponse(SDIO_RESP3);
                CSD_Tab = SDIO_GetResponse(SDIO_RESP4);
        errorstatus = SD_OK; /*!< All cards get intialized */
[1] [2]
关键字:STM32  初始化代码 引用地址:STM32中SD的初始化代码
上一篇:2、STM32学习笔记——定时器
下一篇:用Keil编译STM32工程出现下面错误
推荐阅读最新更新时间:2024-11-12 22:56
STM32的位带操作分析
8051单片机可以直接对某一位IO进行读写操作,而Cortex-M3的位带操作是8051位寻址区的加强版。使用位带操作后,可以使用普通的加载/存储指令对单一的比特进行读写操作。 一、相关概念。 位带区:支持位带操作的地址区。 位带别名区:对别名地址的访问最终作用到位带区的访问上。位带别名区对位带区的访问有个地址映射过程。 二、位带操作的原理 位带操作的最终目的是想对位带区的比特位进行独立的读写操作。但它是通过对位带别名区的操作来实现的。 具体过程如下: 对位带别名区进行读写访问,位带别名区通过地址映射关系映射到相应的位带区,对位带区进行原始比特的读写操作。 三、地址映射 上面对位带操作进行了简
[单片机]
<font color='red'>STM32</font>的位带操作分析
利用STM32的FLASH模拟 EEPROM(F103)系列
STM32的FLASH是用来存储主程序的,ST公司为了节约成本,没有加入 EEPROM,但是许多场合下我们需要用EEPROM;不过FLASH的容量还是可观的,我们可以利用FLASH模拟EEPROM。 根据《STM32F10X闪存编程》中的介绍,FLASH除了保存用户代码的部分,其余部分我们是可以利用其作为数据存储使用的。stm32的FLASH分为主存储块和信息块。主存储块用于保存具体的程序代码和用户数据,信息块用于负责由stm32出厂是放置2KB的启动程序(Bootloader)并锁死,用户无法更改。选项字节存储芯片的配置信息及对主存储块的保护信息。STM32的FLASH主存储块按页组织,有的产品每页1KB,有的产
[单片机]
利用<font color='red'>STM32</font>的FLASH模拟 EEPROM(F103)系列
STM32单片机的FSMC对TFT的驱动
一、FSMC之我见 开始只是谈到别人对FSMC的理解,注意这里只讨论FSMC控制TFT,也就是在FSMC的NORPSRAM模式控制LCD,所以我们以下的分析都是基于这种模式的。 1、我们之前通过使用GPIO来模拟8080/6800时序从而达到驱动彩屏的,同样需要明白的一点就是我们也只是使用FSMC来模拟8080/6800时序,只不过这个读写速度有些快(使用了总线嘛),仅此而已! 简单一点就是:8080是通过“读使能(RE)”和“写使能(WE)”两条控制线进行读写操作。 6800是通过“总使能(E)”和“读写选择(W/R)”两条控制线进行 2、那么了解到FSMC的三总线如下! 数据线:这个可以分为8位的和16位,这个不难
[单片机]
<font color='red'>STM32</font>单片机的FSMC对TFT的驱动
STM32通过USB实现Bootloader/IAP功能
前沿: 最近在做STM32的USB Bootlader/IAP功能,也就是通过USB实现固件升级,本文介绍下实现的基本思路,希望对实现IAP的同学一个参考,改方法已经在产品中得到实际应用并验证是比较合理,稳定可靠的。 程序空间划分: 在单片机的程序Flash中分两个区,分别存储Bootloader代码和App代码,Bootloader放到代码起始地址,也就是0x08000000,App放到0x8020000地址,中间预留了很多的地址空间,主要是为了用来存储一些需要掉电保存的数据,比如我在0x0800C000地址就存放了App程序运行后写入该地址的标志数据。 启动流程: 上电后自然是运行Bootloader程序,Bootloader
[单片机]
<font color='red'>STM32</font>通过USB实现Bootloader/IAP功能
STM32 + GCC + J-Link :开源的力量
发现Keil自带的编译器有时候优化有问题,跑得跟没优化时完全不一样。以前使用GCC,现在自然而然想再次使用GCC。 搭配1:Keil+GCC+Ulink2 这类的介绍也较多,主要是一个链接脚本、启动代码、IDE选项配置的问题,大家可以google一下,个人觉得搭配一般般。 搭配2:emIDE+JLink 纯粹的Opensource血统,这个EMIDE已经带了GCC,只需要一个JLink,然后构建好工程就可以debug了,如果发展迅猛,估计Keil也会扛不住了。
[单片机]
关于STM32中PA15引脚作为普通io的使用
最近做一个项目,调试的时候,发现PA15引脚无论配置输出高还是低或者输入,均只能输出3.3V的高电平。 前提说明,目前STM的硬件调试有两种方法,JTAG和SW的方式,目前个人认为最好的方式就是SW,因为它只占用PA13和PA14两个io。而JTAG还要多占用PB3,PB4,PA15三个io口。很浪费资源。 本人使用SW的方式,但是STM默认会启用SW和JTAG两种。也就是说,默认情况下,PA13、PA14、PB3、PB4、PA15均不能作为普通io使用。 因为本人没用JTAG,所以为了让PB3,PB4,PA15这三个IO变为普通io,必须要进行如下的配置: *RCC_APB2PeriphClockCmd(RCC_APB2Per
[单片机]
STM32与四线电阻触摸屏的接口电路
如下图所示,STM32F103F103与四线电阻触摸屏直接通过自身的I/O口连接,实现触摸屏控制器功能。其中PA8、PA9、PA10、 PA11分别作为四个三极管的控制端,通过控制三极管通断,来控制四线触摸屏的Y+、Y-、X+、X-.PA1,PA2是两个A/D转换通道,分别连接 Y+和X+用于计算触摸点的X和 Y坐标。PA3连接内部中断用于检测触摸屏是否有触摸动作。触摸屏平时运行时,令PA8、PA9、PA11输出0,PA10=1,即只让VT2导通。当有触摸动作时,D1导通给PA3一个中断信号,STM32F103接收到中断请求后立即置PA8=1,导通VT1,这样在Y+、Y-方向上就加上电压,同时启动A/D转换通道PA2,通过输入X+
[模拟电子]
<font color='red'>STM32</font>与四线电阻触摸屏的接口电路
STM32复习笔记(九)OLED的介绍和使用方法
一、OLED的介绍: OLED,即有机发光二极管(Organic Light-Emitting Diode),又称为有机电激光显示(Organic Electroluminesence Display, OELD)。OLED由于同时具备自发光,不需背光源、对比度高、厚度薄、视角广、反应速度快、可用于挠曲性面板、使用温度范围广、构造及制程较简单等优异之特性,被认为是下一代的平面显示器新兴应用技术。 OLED显示技术具有自发光的特性,采用非常薄的有机材料涂层和玻璃基板,当有电流通过时,这些有机材料就会发光,而且OLED显示屏幕可视角度大,并且能够节省电能,从2003年开始这种显示设备在MP3播放器上得到了应用。 LCD都需要背
[单片机]
<font color='red'>STM32</font>复习笔记(九)OLED的介绍和使用方法
小广播
设计资源 培训 开发板 精华推荐
最新单片机文章
何立民专栏 单片机及嵌入式宝典
电子工程世界版权所有 京ICP证060456号 京ICP备10001474号-1 电信业务审批[2006]字第258号函 京公网安备 11010802033920号 Copyright © 2005-2024 EEWORLD.com.cn, Inc. All rights reserved
