9G-STM32 LwIP测试过程简介
一,准备STM32 LwIP软件包
1,在http://www.st.com/mcu/devicedocs-STM32F107RC-110.html
下载lwIP TCP/IP stack demonstration for STM32F107xx connectivity line microcontrollers软件包
an3102.zip
2,在http://www.st.com/mcu/devicedocs-STM32F107RC-110.html
下载lwIP TCP/IP stack demonstration for STM32F107xx connectivity line microcontrollers文档
16620.pdf
3,有关STM32F107VC-PKT的PCB和SCH和测试代码见下面连接:
http://www.freescaleic.org/yuanxihua/blog/10-01/183297_155bc.html
二,建立STM32 LwIP开发工程
1,把an3102.zip解压到D:works形成工程文件夹:D:worksSTM32F107_ETH_LwIP_V1.0.0 ;
2,进入到目录D:worksSTM32F107_ETH_LwIP_V1.0.0ProjectEWARMv5,双击Project.eww打开工程;
3,在EWARM中的Project->make 编译通过整个项目。
三,修改STM32 LwIP开发工程
1,打开Project->Options ,在Category中选择Debugger的setup驱动用J-Link/J-Trace,在J-Link/J-Trace
中选择connection的SWD接口;
2,对STM32F107VC-PKT开发板加上5V的直流电源,把J-LINK用USB线连接到PC的USB口上,执行Project->Download and Debug
下载代码到板子后,执行Debug->Go 。
四,修改STM32 LwIP开发源码
1,在D:worksSTM32F107_ETH_LwIP_V1.0.0Projectsrcmain.c 的53行后添加如下代码:
/* Output a message on Hyperterminal using printf function */
printf('nrnrnrnr');
printf('*** STM32F107VC-PKT V1.0 Build by on ('__DATE__ ' - ' __TIME__ ')nr');
printf('*** STM32F107VC-PKT V1.0 Rebooting ...nr');
2,在D:worksSTM32F107_ETH_LwIP_V1.0.0Projectsrcstm32f107.c 的包含头文件中添加:
#include 'stdio.h'
在第30行选择用MII模式:
#define MII_MODE /* MII mode for STM3210C-EVAL Board (MB784) (check jumpers setting) */
//#define RMII_MODE /* RMII mode for STM3210C-EVAL Board (MB784) (check jumpers setting) */
在54行后添加:
USART_InitTypeDef USART_InitStructure;
在125行后添加:
/* Configure the com port */
/* USARTx configuration ------------------------------------------------------*/
/* USARTx configured as follow:
- BaudRate = 115200 baud
- Word Length = 8 Bits
- One Stop Bit
- No parity
- Hardware flow control disabled (RTS and CTS signals)
- Receive and transmit enabled
USART_InitStructure.USART_BaudRate = 115200;
USART_InitStructure.USART_WordLength = USART_WordLength_8b;
USART_InitStructure.USART_StopBits = USART_StopBits_1;
USART_InitStructure.USART_Parity = USART_Parity_No ;
USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None;
USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx;
STM_EVAL_COMInit(COM1, &USART_InitStructure);
* @brief Retargets the C library printf function to the USART.
* @param None
* @retval : None
int fputc(int ch, FILE *f)
/* Write a character to the USART */
USART_SendData(USART2, (uint8_t) ch);
/* Loop until the end of transmission */
while(USART_GetFlagStatus(USART2, USART_FLAG_TXE) == RESET)
return ch;
* @brief Get a key from the HyperTerminal
* @param None
* @retval : The Key Pressed
int fgetc(FILE *f)
/* Waiting for user input */
while ( USART_GetFlagStatus(USART2, USART_FLAG_RXNE) == RESET);
return (uint8_t)USART2->DR;
在341-344行修改为:
/* ADC Channel10 config --------------------------------------------------------*/
/* Relative to STM32F107VC-PKT Board */
/* Configure PC.00 (ADC Channel10) as analog input -------------------------*/
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0;
在375-376行修改为:
/* ADC1 regular channel10 configuration */
ADC_RegularChannelConfig(ADC1, ADC_Channel_10, 1, ADC_SampleTime_13Cycles5);
3,在D:worksSTM32F107_ETH_LwIP_V1.0.0Projectsrcnetconf.c 中的119-121行和316-318行把
IP地址都修改如下:
IP4_ADDR(&ipaddr, 192, 168, 1, 8);
IP4_ADDR(&netmask, 255, 255, 255, 0);
IP4_ADDR(&gw, 192, 168, 1, 1);
4,在D:worksSTM32F107_ETH_LwIP_V1.0.0Utilitieslwip-1.3.1portlwipopts.h中把
#define LWIP_DHCP 1
修改成:
#define LWIP_DHCP 0
5,在D:worksSTM32F107_ETH_LwIP_V1.0.0UtilitiesSTM32_EVALSTM3210C_EVALstm3210c_eval.h中把
#define LED1_GPIO_PIN GPIO_Pin_7
修改成:
#define LED1_GPIO_PIN GPIO_Pin_13
把
#define LED2_GPIO_PIN GPIO_Pin_13
修改成:
#define LED2_GPIO_PIN GPIO_Pin_14
把
#define LED3_GPIO_PIN GPIO_Pin_3
修改成:
#define LED3_GPIO_PIN GPIO_Pin_15
把
#define COMn 1
修改成
#define COMn 2
6,同样执行Project->Download and Debug 下载代码到板子后,执行Debug->Go 可以全速仿真运行。
五,演示STM32 LwIP开发工程
1,用交叉网线连接STM32F107VC-PKT到PC的网口,用交叉串口线连接RS232到PC的串口中,再对板子用5V上电
复位启动工作;
2,可以在串口终端上用115200 8N1的格式看到:
*** STM32F107VC-PKT V1.0 Build by on (Jan 12 2010 - 12:43:08)
3,在PC的IE浏览器中输入: 回车刷新可以访问到板子,看到Home page主页:
STM32F107 Webserver Demo
Based on the lwIP TCP/IP stack
4,点击Led control从Home page切换LED控制,任意勾上或者去掉LED1-3,再按SEND,可以看到板子的LED相应的
被控制亮或者灭;
5,点击ADC status bar从Led control页面切换到ADC采集,旋转板子上的RV1,可以看到STM32F107 ADC status bar
上绿色的滚动条被ADC的输入电压控制增减;
6,在SecureCRT 5.1终端中可以以telnet协议访问192.168.1.8,端口就是23,连接上了会显示:
Hello. What is your name? ,输入字符串YUANXIHUA,马上会回复Hello YUANXIHUA
上一篇:STM32启动文件
下一篇:stm32之SPI学习
推荐阅读最新更新时间:2024-11-06 07:15
设计资源 培训 开发板 精华推荐
- 大道至简 书法(PCB版本)
- 触感魔方和脉动汇总
- LTC3550-1 的典型应用——具有 600mA 降压转换器的双输入 USB/AC 适配器锂离子电池充电器
- 低功耗运算放大器TC75S102F的应用电路
- 【训练营】小贱钟DIY
- 具有分立栅极驱动器和 MOSFET 的 LTC3861EUH-1 双相 1.2V/60A 转换器的典型应用电路,fSW = 300kHz
- OM7865: BGA3018演示板,40 MHz至2600 MHz宽带放大器应用
- OP284ESZ-REEL7 高端负载电流监控器的典型应用
- 基于ISO8200AQ的工业数字输出扩展板,适用于STM32 Nucleo
- LTM8054IY 2 同步和开关降压-升压转换器 LTM8054 的典型应用电路由具有不同电流能力的输入源供电共享输出电流以运行单个负载
