硬件平台:OK6410开发板
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 | KK U-Boot 1.1.6 (Sep 19 2014 - 10:00:03) for SMDK6410 **************************************** ** u-boot 1.1.6 ** ** Updated for OK6410 TE6410 Board ** ** Version (2012-09-23) ** ** OEM: Forlinx Embedded ** ** Web: http://www.witech.com.cn ** **************************************** CPU: S3C6410 @532MHz Fclk = 532MHz, Hclk = 133MHz, Pclk = 66MHz, Serial = CLKUART (SYNC Mode) Board: SMDK6410 DRAM: 256 MB Flash: 0 kB NAND: 1024 MB In: serial Out: serial Err: serial Hit any key to stop autoboot: 0 NAND read: device 0 offset 0x500000, size 0x500000 5242880 bytes read: OK Boot with zImage Starting kernel ... Uncompressing Linux... done, booting the kernel. Linux version 3.0.1 (root@ubuntu) (gcc version 4.3.2 (Sourcery G++ Lite 2008q3-72) ) #676 Fri Sep 19 10:39:58 CST 2014 Ignoring unrecognised tag 0x54410008 camera: no parent clock specified camera: no parent clock specified Kernel command line: root=/dev/mtdblock2 rootfstype=yaffs2 init=/linuxrc console=ttySAC0,115200 Memory: 196660k/196660k available, 65484k reserved, 0K highmem Virtual kernel memory layout: vector : 0xffff0000 - 0xffff1000 ( 4 kB) fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB) DMA : 0xff600000 - 0xffe00000 ( 8 MB) vmalloc : 0xd0800000 - 0xf4000000 ( 568 MB) lowmem : 0xc0000000 - 0xd0000000 ( 256 MB) pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB) modules : 0xbf000000 - 0xbfe00000 ( 14 MB) .init : 0xc0008000 - 0xc0036000 ( 184 kB) .text : 0xc0036000 - 0xc07d4434 (7802 kB) .data : 0xc07d6000 - 0xc082eaf0 ( 355 kB) .bss : 0xc082eb14 - 0xc08b1124 ( 522 kB) SCSI subsystem initialized ------------[ cut here ]------------ WARNING: at drivers/gpio/gpiolib.c:101 gpio_ensure_requested+0x58/0x124() ---[ end trace da227214a82491b7 ]--- type=2000 audit(0.190:1): initialized Hello, world Creating 4 MTD partitions on 'NAND 2GiB 1,8V 8-bit': 0x000000000000-0x000000200000 : 'Bootloader' 0x000000500000-0x000001e00000 : 'Kernel' 0x000001e00000-0x00000e600000 : 'File System' 0x00000e600000-0x000040000000 : 'User' mcp2515 spi1.0: MCP251x didn't enter in conf mode after reset mcp2515 spi1.0: probe failed dm9000 dm9000.0: read wrong id 0x01010101 s3c_g2d_probe called s3c_g2d_probe Success Registering the dns_resolver key type FAT-fs (mmcblk0p1): utf8 is not a recommended IO charset for FAT filesystems, filesystem will be case sensitive! Try to bring eth0 interface up......Done Starting Qtopia2, please waiting... Please press Enter to activate this console. touch... [root@FORLINX6410]# |
上一篇:OK6410开发板启动过程(详细信息)
下一篇:wince bsp中的g_oalAddressTable表
推荐阅读最新更新时间:2024-11-11 11:34
设计资源 培训 开发板 精华推荐
- arduino 扩展板
- LTC1174 高效 3.3V 降压型稳压器的典型应用电路
- 用于医疗的 4 节锂离子/锂聚合物电池充电器
- DER-359 - 使用LYTSwitchTM-4 LYT4312E设计的8 W非隔 离降压式、可控硅调光、带功率因数校正的LED 驱动器
- 具有 2.5V LDO 输出的 LTC3633AIUFD 3.3V/1.8V 降压稳压器的典型应用电路
- PK-HCS08GB60: 恩智浦MC9S08GB60入门套件
- AD8657ACPZ-RL比较器A典型应用电路
- NCV33161正负欠压检测器典型应用电路
- 基于ESP8266的物联网开关
- 适用于 R41Z-TA-R R41Z 模块螺纹 + 蓝牙 4.2 LE 的 DC-DC 降压模式 PSWITCH 应用
