u-boot2010.03 移植篇(三)-----进一步修改start.S,smdk6410.h,支持nand启动及配置DM9000网卡
发布者:EnchantedHeart最新更新时间:2024-11-07 来源: cnblogs关键字:u-boot  start  nand启动 手机看文章 扫描二维码
随时随地手机看文章
使用环境
PC:     Centos5.4
kernel: 3.0.1
corss:  arm-linux-gcc 4.4.1
arm:    s3c6410
uboot:  uboot-2010-03
第一处修改:
22
23
24
27
28
29
32
33
34
#ifndef CONFIG_NAND_SPL
 * flush v4 I/D caches
mov r0, #0
mcr p15, 0, r0, c7, c7, 0/* flush v3/v4 cache */
mcr p15, 0, r0, c8, c7, 0/* flush v4 TLB */
 * disable MMU stuff and caches////////////////////////////////////////////////
mrc p15, 0, r0, c1, c0, 0
bic r0, r0, #0x00002300 @ clear bits 13, 9:8 (--V- --RS)
bic r0, r0, #0x00000087 @ clear bits 7, 2:0 (B--- -CAM)
orr r0, r0, #0x00000002 @ set bit 2 (A) Align
orr r0, r0, #0x00001000 @ set bit 12 (I) I-Cache
mcr p15, 0, r0, c1, c0, 0//从后面拷贝过来的
///////////////////////////////以下的注释掉
/* Prepare to disable the MMU */
//adr r1, mmu_disable_phys
/* We presume we're within the first 1024 bytes */
//and r1, r1, #0x3fc
//ldr r2, _TEXT_PHY_BASE
//ldr r3, =0xfff00000
//and r2, r2, r3
//orr r2, r2, r1
//b mmu_disable
//.align 5
/* Run in a single cache-line */
//mmu_disable:
// mcr p15, 0, r0, c1, c0, 0
// nop
// nop
// mov pc, r2
第二处修改:
bl lowlevel_init  /* go setup pll,mux,memory */  之后
/* when we already run in ram, we don't need to relocate U-Boot.////////////////////////////////////////////////////////////////////
* and actually, memory controller must be configured before U-Boot
* is running in ram.
 ldr r0, =0xff000fff
 bic r1, pc, r0 /* r0 <- current base addr of code */
 ldr r2, _TEXT_BASE /* r1 <- original base addr in ram */
 bic r2, r2, r0 /* r0 <- current base addr of code */
 cmp     r1, r2                 /* compare r0, r1                  */
 beq      after_copy /* r0 == r1 then skip flash copy   */
#ifdef CONFIG_BOOT_NAND
  mov r0, #0x1000
 bl copy_from_nand
#endif
after_copy:////////////////////////////////////////////////////////
#ifdef CONFIG_ENABLE_MMU
上面的修改是判断到底是从Nand Flash启动还是RAM启动;
1.如果是从nandflash中启动,那么PC的值一定在4K之内。那么执行完bicr1,pc,r0 之后,r1为0。_TEXT_BASE要么等于0x57e00000,要么等于0xC7e00000.那么执行完bicr2,r2,r0 之后,r2为0x00e00000,那么不相等,则不跳转,下面应该就是copy_from_nand。
2.如果是从ram中启动,那么PC的值为0xx7e00000。那么执行完bicr1,pc,r0 之后,r1为0x00e00000。_TEXT_BASE要么等于0x57e00000,要么等于0xC7e00000.那么执行完bicr2,r2,r0 之后,r2为0x00e00000,那么相等,跳转到after_copy,也就是不需要copy。承接上面分析,如果没有完成copy,则接下来就是copy_from_nand。
第三处修改:
22
23
24
27
28
29
32
33
34
37
38
39
42
43
44
45
46
47
48
49
 * we assume that cache operation is done before. (eg. cleanup_before_linux())
 * actually, we don't need to do anything about cache if not use d-cache in
 * U-Boot. So, in this function we clean only MMU. by scsuh
 * void theLastJump(void *kernel, int arch_num, uint boot_params);
 .globl theLastJump
theLastJump:
之前加上以下语句
 * copy U-Boot to SDRAM and jump to ram (from NAND or OneNAND)
 * r0: size to be compared
 * Load 1'st 2blocks to RAM because U-boot's size is larger than 1block(128k) size
.globl copy_from_nand
copy_from_nand:
  mov r10, lr /* save return address */
  mov r9, r0
 /* get ready to call C functions */
ldr sp, _TEXT_PHY_BASE/* setup temp stack pointer */
 sub sp, sp, #12
 mov fp, #0  /* no previous frame, so fp=0 */
 mov r9, #0x1000
 bl copy_uboot_to_ram          //此函数需要添加,稍后说明。
3: tst  r0, #0x0
  bne copy_failed
  ldr r0, =0x0c000000
  ldr r1, _TEXT_PHY_BASE
1: ldr r3, [r0], #4
  ldr r4, [r1], #4
 teq r3, r4
 bne compare_failed/* not matched */
 subs r9, r9, #4
 bne 1b
4: mov lr, r10   /* all is OK */
  mov pc, lr
copy_failed:
  nop  /* copy from nand failed */
b copy_failed
compare_failed:
 nop  /* compare failed */
 b compare_failed
      接着进入u-boot-2010.03/include/configs编辑smdk6410.h,添加下面的宏定义;
1.
#definevirt_to_phys(x) virt_to_phy_smdk6410(x)
2.
#defineCONFIG_SYS_PROMPT 'SMDK6410#' /*MonitorCommandPrompt */
这里的”SMDK6410”可以自己修改,这就是你进入uboot的命令模式的#前面的文字。
//#definePHYS_SDRAM_1_SIZE 0x08000000 /*128MBinBank#1 */
#definePHYS_SDRAM_1_SIZE 0x10000000 /*256MBinBank#1 */
修改SDRAM内存为256M的。
/*NANDconfiguration*/
#defineNAND_DISABLE_CE()(NFCONT_REG|= (1<<1))
#defineNAND_ENABLE_CE()(NFCONT_REG&=~(1<<1))
#defineNF_TRANSRnB() do{while(!(NFSTAT_REG&(1<<0)));}while(0)
这里的定义是后面写nand_cp.c要用到的宏定义
*Architecturemagicandmachinetype
//#define MACH_TYPE 1270/*smdk6400ID*/
#defineMACH_TYPE 1626/*smdk6410ID*/
6410的ID号;
*Sizeofmalloc()pool
//#define CONFIG_SYS_MALLOC_LEN (CONFIG_ENV_SIZE+1024*1024)
#defineCONFIG_SYS_MALLOC_LEN (CONFIG_ENV_SIZE+512*1024)
#defineCONFIG_SYS_GBL_DATA_SIZE 128 /*sizeinbytesforinitialdata*/
修改内存大小;
#defineCONFIG_BOOTDELAY 3
修改bootdelay延迟时间
//#define CONFIG_SYS_MEMTEST_END (CONFIG_SYS_SDRAM_BASE +0x7e00000)
/*126MBinDRAM*/
#defineCONFIG_SYS_MEMTEST_END (CONFIG_SYS_SDRAM_BASE +0x9e00000)
/*256MBinDRAM*/
修改SDROM大小;
/*the PWMTImer4usesacounterof15625for10ms,soweneed*/
/*ittowrap100times (total1562500)toget1sec.*/
//#define CONFIG_SYS_HZ 1000 //atPCLK50MHz
#defineCONFIG_SYS_HZ 1562500
时钟修改;
//#define CONFIG_STACKSIZE 0x40000 /*regularstack256KB*/
#defineCONFIG_STACKSIZE 0x80000 /*regularstack512KB*/
堆栈大小修改;
//#define PHYS_SDRAM_1_SIZE 0x08000000 /*128MBinBank#1 */
#definePHYS_SDRAM_1_SIZE0x10000000 /*256MBinBank#1 */
Nand Flash每块大小修改;
//#define CONFIG_ENV_SIZE 0x4000 /*TotalSizeofEnvironmentSector*/
#defineCONFIG_ENV_SIZE 0x80000 /*TotalSizeofEnvironmentSector*/
Total Size of Environment Sector修改;
//#define CONFIG_BOOTCOMMAND 'nand read 0x50018000 0x60000 0x1c0000;'
//'bootm0x50018000'
#define CONFIG_BOOTCOMMAND 'nand read 0x50018000 0x100000 0x500000;'
'bootm0x50018000'
CONFIG_BOOTCOMMAND修改
#defineCONFIG_ENV_OFFSET 0x0080000
CONFIG_ENV_OFFSET修改
//#define CONFIG_SYS_NAND_PAGE_SIZE 2048
#defineCONFIG_SYS_NAND_PAGE_SIZE 4096
Nand Flash每一页大小的修改
/*NANDchipblocksize */
//#define CONFIG_SYS_NAND_BLOCK_SIZE (128*1024)
#defineCONFIG_SYS_NAND_BLOCK_SIZE (512*1024)
Nand Flash每一块大小的修改
/*NANDchippageperblockcount */
//#define CONFIG_SYS_NAND_PAGE_COUNT 64
#defineCONFIG_SYS_NAND_PAGE_COUNT 128
校验位修改
并将里面的所有6400除了(#define CONFIG_S3C6400          1)替换为6410
接下来在u-boot-2010.03/cpu/arm1176/下面新建一个nand_cp.c文件,代码如下:
#include
#ifdefCONFIG_S3C64XX
#include
#include
#include
staticintnandll_read_page(uchar*buf,ulongaddr,intlarge_block)
inti;
intpage_size=512;
/* 2K */
if(large_block==1)
page_size=2048;
/* 4K */
if(large_block==2)
page_size=4096;
NAND_ENABLE_CE();
NFCMD_REG=NAND_CMD_READ0;
/*WriteAddress*/
NFADDR_REG=0;
if(large_block)
NFADDR_REG=0;
NFADDR_REG=(addr)&0xff;
NFADDR_REG=(addr>>8)&0xff;
NFADDR_REG=(addr>>16)&0xff;
#defineNFCMD_REG
__REG(ELFIN_NAND_BASE+NFCMMD_OFFSET)
#defineELFIN_NAND_BASE 0x70200000
#defineNFCMMD_OFFSET 0x08
NFCMD_REG=(*( (volatileu32*) (0x70200008) ))
NFCMMD 0x70200008 NANDFlash命令设置寄存器0
#define NAND_CMD_READSTART 0x30
if(large_block)
NFCMD_REG=NAND_CMD_READSTART;
define NF_TRANSRnB()
do{ while( !( NFSTAT_REG&(1<<0) ) ); }while(0)
#define NFSTAT_REG
__REG(ELFIN_NAND_BASE+NFSTAT_OFFSET)
NFSTAT_REG=(*( (volatileu32*) (0x70200028) ))
NFSTAT 0x70200028 NANDFlash操作状态寄存器
NF_TRANSRnB();
/*forcompatibility(2460).u32cannotbeused.byscsuh*/
for(i=0;i
*buf++=NFDATA8_REG;
#defineNFCONT_REG
__REG(ELFIN_NAND_BASE+NFCONT_OFFSET)
#define__REG(x) (*((volatileu32*)(x)))
#defineNFCONT_OFFSET 0x04
NAND_DISABLE_CE();
return0;
staticintnandll_read_blocks(ulongdst_addr,ulongsize,int large_block)
uchar*buf=(uchar*)dst_addr;
inti;
uintpage_shift=9;
if(large_block==1)
page_shift=11;
/*Readpages*/
if(large_block==2)
page_shift=12;
if(large_block==2)
/*Readpages*/
for(i=0;i<4;i++,buf+=(1<<(page_shift-1)))
nandll_read_page(buf,i,large_block);
/*Readpages*/
/* 0x3c000 = 111100000000000000 */
for(i=4;i<(0x3c000>>page_shift);i++,buf+=(1<
else
for(i=0;i<(0x3c000>>page_shift);i++,buf+=(1<
return0;
intcopy_uboot_to_ram(void)
intlarge_block =0;
inti;
vu_charid;
#defineNAND_ENABLE_CE() (NFCONT_REG&=~(1<<1))
#defineNFCONT_REG
NFCONT_REG=(*( (volatileu32*) (0x70200004) ))
NFCONT0x70200004 读/写NANDFlash控制寄存器
[0]1:NANDFlash控制器使能
NAND_ENABLE_CE();
#defineNFCMD_REG
#defineNAND_CMD_READID 0x90
NFCMD_REG=NAND_CMD_READID;
#defineNFADDR_REG
__REG(ELFIN_NAND_BASE+NFADDR_OFFSET)
#defineNFADDR_OFFSET 0x0C
NFADDR_REG =(*( (volatileu32*) (0x7020000C) ))
NFADDR0x7020000C NANDFlash地址设置寄存器
NFADDR_REG= 0x00;
#define NFDATA8_REG
__REGb(ELFIN_NAND_BASE+NFDATA_OFFSET)
#define__REGb(x) (*(vu_char*)(x))
NFDATA8_REG = (*( (vu_char*) (0x70200010) ))
NFDATA0x70200010 读/写NANDFlash数据寄存器
NANDFlash 读/烧写数据值用于I/O
/*waitforawhile*/
for(i=0;i<200;i++);
id=NFDATA8_REG;
id=NFDATA8_REG;
if(id>0x80)
large_block=1;
if(id ==0xd5)
large_block=2;
/*readNANDBlock.
*128KB->240KBbecauseofU-Bootsizeincrease.byscsuh
*So,read0x3c000bytesnot0x20000(128KB).
#define CONFIG_SYS_PHY_UBOOT_BASE
(CONFIG_SYS_SDRAM_BASE+0x07e00000)
#define CONFIG_SYS_SDRAM_BASE 0x50000000
CONFIG_SYS_PHY_UBOOT_BASE= 0x57e00000
0x3c000 = 1M
returnnandll_read_blocks(CONFIG_SYS_PHY_UBOOT_BASE,0x3c000,large_block);
#endif
修改u-boot-2010.03/cpu/arm1176/Makefile,在COBJS = cpu.o后面加nand_cp.o
COBJS   = cpu.o nand_cp.o
修改u-boot-2010.03/board/samsung/smdk6410/u-boot-nand.lds,添加nand_cp.o 如下:
cpu/arm1176/start.o (.text)
cpu/arm1176/s3c64xx/cpu_init.o (.text)
board/samsung/smdk6410/lowlevel_init.o (.text)
cpu/arm1176/nand_cp.o(.text)
lib_arm/board.o (.text)
*(.text)
[1] [2] [3]
关键字:u-boot  start  nand启动 引用地址:u-boot2010.03 移植篇(三)-----进一步修改start.S,smdk6410.h,支持nand启动及配置DM9000网卡
上一篇:u-boot2010.03 移植篇(二)-----修改start.S,支持nand启动
下一篇:u-boot2010.03 配置编译目标分析
小广播
设计资源 培训 开发板 精华推荐
最新单片机文章
  • 学习ARM开发(16)
    ARM有很多东西要学习,那么中断,就肯定是需要学习的东西。自从CPU引入中断以来,才真正地进入多任务系统工作,并且大大提高了工作效率。采 ...
  • 学习ARM开发(17)
    因为嵌入式系统里全部要使用中断的,那么我的S3C44B0怎么样中断流程呢?那我就需要了解整个流程了。要深入了解,最好的方法,就是去写程序 ...
  • 学习ARM开发(18)
    上一次已经了解ARM的中断处理过程,并且可以设置中断函数,那么它这样就可以工作了吗?答案是否定的。因为S3C44B0还有好几个寄存器是控制中 ...
  • 嵌入式系统调试仿真工具
    嵌入式硬件系统设计出来后就要进行调试,不管是硬件调试还是软件调试或者程序固化,都需要用到调试仿真工具。 随着处理器新品种、新 ...
  • 最近困扰在心中的一个小疑问终于解惑了~~
    最近在驱动方面一直在概念上不能很好的理解 有时候结合别人写的一点usb的例子能有点感觉,但是因为arm体系里面没有像单片机那样直接讲解引脚 ...
  • 学习ARM开发(1)
  • 学习ARM开发(2)
  • 学习ARM开发(4)
  • 学习ARM开发(6)
何立民专栏 单片机及嵌入式宝典
电子工程世界版权所有 京ICP证060456号 京ICP备10001474号-1 电信业务审批[2006]字第258号函 京公网安备 11010802033920号 Copyright © 2005-2024 EEWORLD.com.cn, Inc. All rights reserved
