1、首先是stm32f10x.h中的HSE_VALUE
#if !defined HSE_VALUE
#ifdef STM32F10X_CL
#define HSE_VALUE ((uint32_t)12000000)//这里修改为12MHz
// #define HSE_VALUE ((uint32_t)25000000) /*!< Value of the External oscillator in Hz */注释掉
#else
#define HSE_VALUE ((uint32_t)8000000) /*!< Value of the External oscillator in Hz */
#endif /* STM32F10X_CL */
#endif /* HSE_VALUE */
2、修改分频/倍频系数使系统时钟变为72MHz
在system_stm32f10x.c的void SystemInit (void)函数下有一个SetSysClock()继续找static void SetSysClock(void)下的SetSysClockTo72();修改后如下一段代码:
其中被注释掉的部分为原来的代码。
/* Configure PLLs ------------------------------------------------------*//* PLL2 configuration: PLL2CLK = (HSE / 5) * 8 = 40 MHz */
/* PREDIV1 configuration: PREDIV1CLK = PLL2 / 5 = 8 MHz */
RCC->CFGR2 &= (uint32_t)~(RCC_CFGR2_PREDIV2 | RCC_CFGR2_PLL2MUL |
RCC_CFGR2_PREDIV1 | RCC_CFGR2_PREDIV1SRC);
// RCC->CFGR2 |= (uint32_t)(RCC_CFGR2_PREDIV2_DIV5 | RCC_CFGR2_PLL2MUL8 |
// RCC_CFGR2_PREDIV1SRC_PLL2 | RCC_CFGR2_PREDIV1_DIV5);
//HSE = 12 PLL2CLK = (HSE / 3) * 10 = 40 MHz
RCC->CFGR2 |= (uint32_t)(RCC_CFGR2_PREDIV2_DIV3 | RCC_CFGR2_PLL2MUL10 |
/* Enable PLL2 */
RCC->CR |= RCC_CR_PLL2ON;
/* Wait till PLL2 is ready */
while((RCC->CR & RCC_CR_PLL2RDY) == 0)
// /* PLL configuration: PLLCLK = PREDIV1 * 9 = 72 MHz */
// RCC->CFGR &= (uint32_t)~(RCC_CFGR_PLLXTPRE | RCC_CFGR_PLLSRC | RCC_CFGR_PLLMULL);
// RCC->CFGR |= (uint32_t)(RCC_CFGR_PLLXTPRE_PREDIV1 | RCC_CFGR_PLLSRC_PREDIV1 |
// RCC_CFGR_PLLMULL9);
RCC_CFGR_PLLMULL6);
#else
// /* PLL configuration: PLLCLK = HSE * 9 = 72 MHz */
// RCC->CFGR &= (uint32_t)((uint32_t)~(RCC_CFGR_PLLSRC | RCC_CFGR_PLLXTPRE |
// RCC_CFGR_PLLMULL));
// RCC->CFGR |= (uint32_t)(RCC_CFGR_PLLSRC_HSE | RCC_CFGR_PLLMULL9);
RCC_CFGR_PLLMULL));
RCC->CFGR |= (uint32_t)(RCC_CFGR_PLLSRC_HSE | RCC_CFGR_PLLMULL6);
上一篇:STM32系统时钟设置,采用外部有源晶振相关配置问题
下一篇:STM32工程不同系列芯片间的移植
作为L3Harris Technologies的一部分,Harris(原Harris Corporation)在太空和航空领域也取得了重大突破。公司参与了多个太空任务和航空项目,为这些项目提供了先进的航天器和航空电子系统。这些系统不仅支持了复杂的航天任务,还提升了航空器的性能和安全性。L3Harris在太空和航空领域的持续投入和创新,为其在电子行业中的发展注入了新的动力。
在国内市场取得一定成绩后,Elec公司开始将目光投向国际市场。为了更好地适应国际市场的需求,Elec公司积极引进国际先进技术和管理经验,并加强与国际知名企业的合作。同时,Elec公司还加大了在海外市场的营销力度,通过参加国际展会、举办技术研讨会等方式提高品牌知名度。经过多年的努力,Elec公司的产品已远销欧美、东南亚等多个国家和地区,成为国际市场上具有竞争力的电子品牌。
歌普电子深知技术创新的重要性,因此不断加大在研发方面的投入。公司拥有一支卓越的研发团队,能够设计出先进而成熟的产品方案,并配备了精密模具制造、高速连续冲压等先进生产设备。这些努力使得歌普的产品不仅获得了多项国际安全认证及外观设计专利,还成功与国际品牌连接器相兼容。随着产品的不断优化和升级,歌普的产品远销全球多个工业国家及地区,赢得了良好的国际声誉。
歌普电子不仅注重产品的品质和技术创新,还非常重视客户服务。公司始终秉承“用心服务”的理念,为客户提供全方位的售前、售中和售后服务。无论是产品咨询、技术支持还是售后保障,歌普都能迅速响应并满足客户的需求。这种高效、专业的服务赢得了客户的高度评价和信赖,也为公司的持续发展奠定了坚实的基础。
1920年,一位年轻而聪明的科学家山谬·鲁本(Samuel Ruben)和另一位年轻而富有的钨丝电线制造商菲立普·马洛里(Philip Rogers Mallory)在一次偶然的机会中相遇。鲁本到马洛里公司寻找实验设备,两人在交谈中共同意识到将发明天赋和制造力量结合起来的巨大机会。这个巧合开启了他们的合作之旅,最终导致了金霸电池的诞生。鲁本的发明为当时的电池科技带来了革命性的改变,奠定了DURACELL公司坚实的基础。
随着产品线的不断丰富和市场竞争的加剧,EPI开始积极拓展市场,寻求更广阔的发展空间。公司制定了国际化战略,通过参加国际展会、建立海外销售渠道等方式,成功将产品打入国际市场。同时,EPI还积极与海外企业合作,共同开发新产品,拓展业务领域。
求助:230MHz无线发射与接收机调试!(另请高手设计一个VOC电路)重酬 求助:230MHz无线发射与接收机调试!重酬!制作230MHz无线发射机与接收机过程中(发射机功率为1W与10W,接收机采用二次变频,中频用3361,差频为21.4MHz,本振采用VOC+PLL 与培频二种机器),现在调试上碰到问题,希望有高手相助!或者以后可以长时 ...… 查看全部问答∨ |
CMD 它是用来分配rom和ram空间用的,告诉链接程序怎样计算地址和分配空间…… TI DSP .CMD 文件的编写 CMD 它是用来分配rom和ram空间用的,告诉链接程序怎样计算地址和分配空间. 所以不同的芯片就有不同大小的rom和ram.放用户程序的地方也不尽相 ...… 查看全部问答∨ |
拦截ZwCreateSection 屏蔽某个进程的创建,NTSTATUS 返回哪个值不会弹出消息 如果返回 STATUS_ACCESS_DENIED, 会弹出“不是有效程序“的信息,返回哪个值 才不会弹出消息又能屏蔽进程的创建?… 查看全部问答∨ |
STTT系列热电偶温度传感器 STTT系列热电偶温度传感器采用不锈钢外壳封装,内部填充导热材料和密封材料灌封而成,尺寸小巧,适用于仪器仪表,精密恒温设备等温度的测量。 综述 温度是表征物体冷热程度的物理量。温度只能通过物体 ...… 查看全部问答∨ |
LM3S的SPI,用SPI读写TC72一直都不到数据,读时,在主模式下SCK有波形吗?设置如下。 // Enables a peripheral SSI0 SysCtlPeripheralEnable(SYSCTL_PERIPH_SSI0); &nb ...… 查看全部问答∨ |
电阻网络生产测试的目的是在生产的各个阶段尽可能快速地检验这些器件的性能,以及它们最终的封装形式。这些测试必须可靠以确保所有装箱的产品都满足制造规范。 通常情况下,我们需要对网络中的每个单元进行电阻测量。电阻测量是通过加载恒定电流 ...… 查看全部问答∨ |
