开发平台:主处理器是意法半导体的stm32f103系列,这款芯片应用广泛,并且资料很多。
主要定位模块:ublox的一款芯片
开发环境:MDK5.0
主要代码还是参考原子的历程,在它的基础上实现了只提取经纬度,海拔等操作
硬件连接:3.3V电源给GPS模块供电,stm32串口2接GPS。
软件实现主要流程:stm32串口初始化,模块初始化,设置更新速率,保存配置,串口2接收消息,对接收到的消息进行字符串处理,提取有用的信息加以利用。
以下给出主要程序:
串口部分:
串口2初始化代码:
void USART2_Init_JAVE( u32 bound )
GPIO_InitTypeDef GPIO_InitStructure;
USART_InitTypeDef USART_InitStructure;
NVIC_InitTypeDef NVIC_InitStructure;
USART_DeInit(USART2);
//使能串口3的时钟 和对应GPIO时钟
RCC_APB1PeriphClockCmd(RCC_APB1Periph_USART2, ENABLE);
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA, ENABLE);
//配置TX引脚GPIO
GPIO_InitStructure.GPIO_Pin=GPIO_Pin_2;
GPIO_InitStructure.GPIO_Speed=GPIO_Speed_2MHz;
GPIO_InitStructure.GPIO_Mode=GPIO_Mode_AF_PP;
GPIO_Init(GPIOA,&GPIO_InitStructure);
//配置RX引脚GPIO
GPIO_InitStructure.GPIO_Pin=GPIO_Pin_3;
GPIO_InitStructure.GPIO_Mode=GPIO_Mode_IN_FLOATING;
//配置串口2
USART_InitStructure.USART_BaudRate = bound;
USART_InitStructure.USART_WordLength = USART_WordLength_8b;
USART_InitStructure.USART_StopBits = USART_StopBits_1;
USART_InitStructure.USART_Parity = USART_Parity_No;
USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None;
USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx;
USART_Init(USART2, &USART_InitStructure);
//使能串口2
USART_Cmd(USART2,ENABLE);
USART_ITConfig(USART2, USART_IT_RXNE, ENABLE);
//配置串口2接收中断
NVIC_InitStructure.NVIC_IRQChannel = USART2_IRQn;
NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 1;
NVIC_InitStructure.NVIC_IRQChannelSubPriority = 1;
NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
NVIC_Init(&NVIC_InitStructure);
USART_ClearFlag(USART2, USART_FLAG_RXNE);
USART_GetFlagStatus(USART2,USART_FLAG_TC); /* 先读SR,再写DR */
串口2中断函数:
void RX2_Handler( void )
char temp = 0;
#ifdef OS_TICKS_PER_SEC //如果时钟节拍数定义了,说明要使用ucosII了.
OSIntEnter();
#endif
if(USART_GetITStatus(USART2, USART_IT_RXNE) == SET)
temp = USART_ReceiveData( USART2 ); /* 读取USART2数据,自动清零标志位 RXNE */
if( RX2_Point <= 1999)
RX2_Temp[RX2_Point] = temp;
RX2_Point++;
else RX2_Point=0;
OSIntExit();
#endif
串口2接收扫描:
unsigned short USART2_Scan(u16 *len)
unsigned short int ftemp = 0;
ftemp = RX2_Point;
*len=0;
if( ftemp != 0 )
delay_ms(100);
while ( ftemp != RX2_Point )
ftemp = RX2_Point;
delay_ms(100);
RX2_Point = 0; /* 重置指针 */
*len= ftemp;
return 1; /* 扫描到数据,返回1 */
return 0;
GPS驱动部分:
设置更新速率代码:
//配置UBLOX NEO-6的更新速率
//measrate:测量时间间隔,单位为ms,最少不能小于200ms(5Hz)
//reftime:参考时间,0=UTC Time;1=GPS Time(一般设置为1)
//返回值:0,发送成功;其他,发送失败.
unsigned char Ublox_Cfg_Rate(unsigned short measrate,unsigned char reftime)
_ublox_cfg_rate *cfg_rate=(_ublox_cfg_rate *)USART2_TX_BUF;
if(measrate<200)return 1; //小于200ms,直接退出
cfg_rate->header=0X62B5; //cfg header
cfg_rate->id=0X0806; //cfg rate id
cfg_rate->dlength=6; //数据区长度为6个字节.
cfg_rate->measrate=measrate;//脉冲间隔,ms
cfg_rate->navrate=1; //导航速率(周期),固定为1
cfg_rate->timeref=reftime; //参考时间为GPS时间
Ublox_CheckSum((unsigned char*)(&cfg_rate->id),sizeof(_ublox_cfg_rate)-4,&cfg_rate->cka,&cfg_rate->ckb);
// while(DMA1_Channel7->CNDTR!=0); //等待通道7传输完成
// UART_DMA_Enable(DMA1_Channel7,sizeof(_ublox_cfg_rate));//通过dma发送出去
Ublox_Send_Date((unsigned char*)cfg_rate,sizeof(_ublox_cfg_rate));//发送数据给NEO-6M
return Ublox_Cfg_Ack_Check();
GPS初始化:
unsigned char GPS_Init(void)
unsigned char key = 0xFF,cnt=0; //保存配置成功的标志,成功时返回的值是0;
MyPrintf("GPS 初始化\r\n");
Ublox_Cfg_Prt(38400); //重新设置模块的波特率为38400
while((Ublox_Cfg_Rate(2000,1)!=0)&&key) //持续判断,直到可以检查到NEO-6M,且数据保存成功
{ MyPrintf("2");
USART2_Init_JAVE( 38400 ); //初始化串口2波特率为9600(EEPROM没有保存数据的时候,波特率为9600.)
if(++cnt>=5) return 1; //错误
key=Ublox_Cfg_Cfg_Save(); //保存配置,配置成功,返回0
delay_ms(50);
return 0;
算法处理部分:(字符串处理)
对于接收到的消息进行提取处理:
//分析GPGGA信息
//gpsx:nmea信息结构体
//buf:接收到的GPS数据缓冲区首地址
void NMEA_GPGGA_Analysis(GPS_PacketTypeDef *GPS_Packet,u8 *buf)
unsigned char *p1,dx,posx;
unsigned int temp;
float rs;
p1=(unsigned char *)strstr((const char *)buf,"$GPGGA"); //此处可改为"$GPGGA"
posx=NMEA_Comma_Pos(p1,9); //得到海拔高度
if(posx!=0XFF){
GPS_Packet->altitude=NMEA_Str2num(p1+posx,&dx);
MyPrintf("altitude=%d\r\n",GPS_Packet->altitude);
posx=NMEA_Comma_Pos(p1,2); //得到纬度
if(posx!=0XFF)
temp=NMEA_Str2num(p1+posx,&dx);
GPS_Packet->latitude=temp/NMEA_Pow(10,dx+2); //得到°
rs=temp%NMEA_Pow(10,dx+2); //得到'
GPS_Packet->latitude=GPS_Packet->latitude*NMEA_Pow(10,5)+(rs*NMEA_Pow(10,5-dx))/60;//转换为°
MyPrintf("latitude=%d\r\n",GPS_Packet->latitude);
posx=NMEA_Comma_Pos(p1,4); //得到经度
if(posx!=0XFF)
GPS_Packet->longitude=temp/NMEA_Pow(10,dx+2); //得到°
GPS_Packet->longitude=GPS_Packet->longitude*NMEA_Pow(10,5)+(rs*NMEA_Pow(10,5-dx))/60;//转换为°
MyPrintf("longitude=%d\r\n",GPS_Packet->longitude);
posx=NMEA_Comma_Pos(p1,6); //定位状态
if(posx!=0XFF){
GPS_Packet->status=*(p1+posx)-'0';
MyPrintf("status=%d\r\n",GPS_Packet->status);
GPS测试主程序:
unsigned char GPS_Run(void)
unsigned char flag=0; //定位信息成功标志
unsigned short rxlen,i; //rxlen:数据长度
unsigned char cnt=0;
while(1)
if(cnt>2) {sign_run=1;return 0;}
cnt++;
rxlen=0;
USART2_Scan(&rxlen);
if(rxlen !=0)
for(i=0;i GPS_Temp[i]=RX2_Temp[i]; // MyPrintf("%c",RX2_Temp[i]); } GPS_Temp[i]=0; //自动添加结束符 for(i=0;i MyPrintf("%c",GPS_Temp[i]); } MyPrintf("\r\n"); if(GPS_Check(GPS_Temp)!=0) { MyPrintf("无效定位数据\r\n"); continue ; } MyPrintf("开始解析定位数据\r\n"); NMEA_GPGGA_Analysis(&GPS_Packet,(unsigned char*)GPS_Temp); //分析GPS模块发送回来的数据,提取经纬度信息并换算成度 flag = GPS_Packet.status; //定位成功的标志 if(flag == 1 || flag == 2) //定位成功->读取数据存入MSG数据包并退出 { MyPrintf("GPS success\r\n"); GPS_Show( ); Task_LED( ); return 1; } } delay_ms(50); } } 由于位置信息还会受到卫星信号强弱的影响,因此从GPS模块里面接收到的信息不一定就是有效的位置信息。如果定位失败,模块会返回类似这样的信息 $GPRMC,,V,,,,,,,,,,N*53 $GPVTG,,,,,,,,,N*30 $GPGGA,,,,,,0,00,99.99,,,,,,*48 $GPGSA,A,1,,,,,,,,,,,,,99.99,99.99,99.99*30 $GPGSV,1,1,01,19,,,35*76 $GPGLL,,,,,,V,N*64 可以简单地认为,只要¥GPGLL这一行数据里含有“V”字符,那么这一次数据就是无效的,应当舍弃,等待下一次正确的信号输出。 如果卫星信号足够强,定位数据有效,那么模块会返回类似这样的信息 $GPRMC,031851.00,A,2309.86780,N,11325.74067,E,0.683,,060916,,,A*74 $GPVTG,,T,,M,0.683,N,1.265,K,A*2E $GPGGA,031851.00,2309.86780,N,11325.74067,E,1,04,5.43,19.1,M,-5.1,M,,*7B $GPGSA,A,3,28,17,19,01,,,,,,,,,6.77,5.43,4.04*03 $GPGSV,3,1,09,01,24,037,20,02,01,233,,03,44,084,29,06,35,242,*72 $GPGSV,3,2,09,08,01,087,,11,14,051,,17,40,326,30,19,26,302,29*76 $GPGSV,3,3,09,28,75,000,31*4A $GPGLL,2309.86798,N,11325.74064,E,031852.00,A,A*61 下面给出模块驱动部分的全部源码: C文件: //GPS校验和计算 //buf:数据缓存区首地址 //len:数据长度 //cka,ckb:两个校验结果. void Ublox_CheckSum(unsigned char *buf,unsigned short len,unsigned char* cka,unsigned char*ckb) { unsigned short i; *cka=0;*ckb=0; for(i=0;i { *cka=*cka+buf[i]; *ckb=*ckb+*cka; } } //检查CFG配置执行情况 //返回值:0,ACK成功 // 1,接收超时错误 // 2,没有找到同步字符 // 3,接收到NACK应答 unsigned char Ublox_Cfg_Ack_Check(void) { unsigned short len=0,i,rxlen; unsigned char rval=0; while(USART2_Scan(&rxlen)==0 && len<100)//等待接收到应答 { len++; delay_ms(5); } if(len<100) //超时错误. { for(i=0;i if(RX2_Temp[i]==0XB5) break;//查找同步字符 0XB5 if(i==rxlen) rval=2; //没有找到同步字符 else if(RX2_Temp[i+3]==0X00) rval=3;//接收到NACK应答 else rval=0; //接收到ACK应答 } else rval=1; //接收超时错误 MyPrintf("rval = %d\r\n",rval); return rval; } //配置NMEA输出信息格式 //baudrate:波特率,4800/9600/19200/38400/57600/115200/230400 //返回值:0,执行成功;其他,执行失败 unsigned char Ublox_Cfg_Prt(unsigned int baudrate) { _ublox_cfg_prt *cfg_prt=(_ublox_cfg_prt *)USART2_TX_BUF; cfg_prt->header=0X62B5; //cfg header cfg_prt->id=0X0006; //cfg prt id cfg_prt->dlength=20; //数据区长度为20个字节. cfg_prt->portid=1; //操作串口1 cfg_prt->reserved=0; //保留字节,设置为0 cfg_prt->txready=0; //TX Ready设置为0 cfg_prt->mode=0X08D0; //8位,1个停止位,无校验位 cfg_prt->baudrate=baudrate; //波特率设置 cfg_prt->inprotomask=0X0007;//0+1+2 cfg_prt->outprotomask=0X0007;//0+1+2 cfg_prt->reserved4=0; //保留字节,设置为0 cfg_prt->reserved5=0; //保留字节,设置为0 Ublox_CheckSum((unsigned char*)(&cfg_prt->id),sizeof(_ublox_cfg_prt)-4,&cfg_prt->cka,&cfg_prt->ckb); // while(DMA1_Channel7->CNDTR!=0); //等待通道7传输完成 // UART_DMA_Enable(DMA1_Channel7,sizeof(_ublox_cfg_prt)); //通过dma发送出去 Ublox_Send_Date((unsigned char*)cfg_prt,sizeof(_ublox_cfg_prt));//发送数据给NEO-6M delay_ms(200); //等待发送完成 USART2_Init_JAVE(baudrate); //重新初始化串口2 return Ublox_Cfg_Ack_Check();//这里不会反回0,因为UBLOX发回来的应答在串口重新初始化的时候已经被丢弃了. } //配置保存 //将当前配置保存在外部EEPROM里面 //返回值:0,执行成功;1,执行失败. unsigned char Ublox_Cfg_Cfg_Save(void) { unsigned char i; _ublox_cfg_cfg *cfg_cfg=(_ublox_cfg_cfg *)USART2_TX_BUF; cfg_cfg->header=0X62B5; //cfg header cfg_cfg->id=0X0906; //cfg cfg id cfg_cfg->dlength=13; //数据区长度为13个字节. cfg_cfg->clearmask=0; //清除掩码为0 cfg_cfg->savemask=0XFFFF; //保存掩码为0XFFFF cfg_cfg->loadmask=0; //加载掩码为0 cfg_cfg->devicemask=4; //保存在EEPROM里面 Ublox_CheckSum((unsigned char*)(&cfg_cfg->id),sizeof(_ublox_cfg_cfg)-4,&cfg_cfg->cka,&cfg_cfg->ckb); // while(DMA1_Channel7->CNDTR!=0); //等待通道7传输完成 // UART_DMA_Enable(DMA1_Channel7,sizeof(_ublox_cfg_cfg)); //通过dma发送出去 Ublox_Send_Date((unsigned char*)cfg_cfg,sizeof(_ublox_cfg_cfg));//发送数据给NEO-6M for(i=0;i<6;i++)if(Ublox_Cfg_Ack_Check()==0)break; //EEPROM写入需要比较久时间,所以连续判断多次 return i==6?1:0; } //配置UBLOX NEO-6的更新速率 //measrate:测量时间间隔,单位为ms,最少不能小于200ms(5Hz) //reftime:参考时间,0=UTC Time;1=GPS Time(一般设置为1) //返回值:0,发送成功;其他,发送失败. unsigned char Ublox_Cfg_Rate(unsigned short measrate,unsigned char reftime) { _ublox_cfg_rate *cfg_rate=(_ublox_cfg_rate *)USART2_TX_BUF; if(measrate<200)return 1; //小于200ms,直接退出 cfg_rate->header=0X62B5; //cfg header cfg_rate->id=0X0806; //cfg rate id cfg_rate->dlength=6; //数据区长度为6个字节. cfg_rate->measrate=measrate;//脉冲间隔,ms cfg_rate->navrate=1; //导航速率(周期),固定为1 cfg_rate->timeref=reftime; //参考时间为GPS时间 Ublox_CheckSum((unsigned char*)(&cfg_rate->id),sizeof(_ublox_cfg_rate)-4,&cfg_rate->cka,&cfg_rate->ckb); // while(DMA1_Channel7->CNDTR!=0); //等待通道7传输完成 // UART_DMA_Enable(DMA1_Channel7,sizeof(_ublox_cfg_rate));//通过dma发送出去 Ublox_Send_Date((unsigned char*)cfg_rate,sizeof(_ublox_cfg_rate));//发送数据给NEO-6M return Ublox_Cfg_Ack_Check(); } //从buf里面得到第cx个逗号所在的位置 //返回值:0~0XFE,代表逗号所在位置的偏移. // 0XFF,代表不存在第cx个逗号 unsigned char NMEA_Comma_Pos(unsigned char *buf,unsigned char cx) { unsigned char *p=buf; while(cx) { if(*buf=='*'||*buf<' '||*buf>'z')return 0XFF;//遇到'*'或者非法字符,则不存在第cx个逗号 if(*buf==',')cx--; buf++; } return buf-p; } //m^n函数 //返回值:m^n次方. unsigned int NMEA_Pow(unsigned char m,unsigned char n) { unsigned int result=1; while(n--) result*=m; return result; } //str转换为数字,以','或者'*'结束 //buf:数字存储区 //dx:小数点位数,返回给调用函数 //返回值:转换后的数值 int NMEA_Str2num(unsigned char *buf,unsigned char*dx) { unsigned char *p=buf; unsigned int ires=0,fres=0; unsigned char ilen=0,flen=0,i; unsigned char mask=0; int res; while(1) //得到整数和小数的长度 { if(*p=='-'){mask|=0X02;p++;}//是负数 if(*p==','||(*p=='*'))break;//遇到结束了 if(*p=='.'){mask|=0X01;p++;}//遇到小数点了 else if(*p>'9'||(*p<'0')) //有非法字符 { ilen=0; flen=0; break; } if(mask&0X01)flen++; else ilen++; p++; } if(mask&0X02)buf++; //去掉负号 for(i=0;i { ires+=NMEA_Pow(10,ilen-1-i)*(buf[i]-'0'); } if(flen>5)flen=5; //最多取5位小数 *dx=flen; //小数点位数 for(i=0;i { fres+=NMEA_Pow(10,flen-1-i)*(buf[ilen+1+i]-'0'); } res=ires*NMEA_Pow(10,flen)+fres; if(mask&0X02)res=-res; return res; } //分析GPGGA信息 //gpsx:nmea信息结构体 //buf:接收到的GPS数据缓冲区首地址 void NMEA_GPGGA_Analysis(GPS_PacketTypeDef *GPS_Packet,u8 *buf) { unsigned char *p1,dx,posx; unsigned int temp; float rs; p1=(unsigned char *)strstr((const char *)buf,"$GPGGA"); //此处可改为"$GPGGA" posx=NMEA_Comma_Pos(p1,9); //得到海拔高度 if(posx!=0XFF){ GPS_Packet->altitude=NMEA_Str2num(p1+posx,&dx); MyPrintf("altitude=%d\r\n",GPS_Packet->altitude); } posx=NMEA_Comma_Pos(p1,2); //得到纬度 if(posx!=0XFF) { temp=NMEA_Str2num(p1+posx,&dx); GPS_Packet->latitude=temp/NMEA_Pow(10,dx+2); //得到° rs=temp%NMEA_Pow(10,dx+2); //得到' GPS_Packet->latitude=GPS_Packet->latitude*NMEA_Pow(10,5)+(rs*NMEA_Pow(10,5-dx))/60;//转换为° MyPrintf("latitude=%d\r\n",GPS_Packet->latitude); } posx=NMEA_Comma_Pos(p1,4); //得到经度 if(posx!=0XFF) { temp=NMEA_Str2num(p1+posx,&dx); GPS_Packet->longitude=temp/NMEA_Pow(10,dx+2); //得到° rs=temp%NMEA_Pow(10,dx+2); //得到' GPS_Packet->longitude=GPS_Packet->longitude*NMEA_Pow(10,5)+(rs*NMEA_Pow(10,5-dx))/60;//转换为° MyPrintf("longitude=%d\r\n",GPS_Packet->longitude); } posx=NMEA_Comma_Pos(p1,6); //定位状态 if(posx!=0XFF){ GPS_Packet->status=*(p1+posx)-'0'; MyPrintf("status=%d\r\n",GPS_Packet->status); } } void Ublox_Send_Date(unsigned char* dbuf,unsigned short len) { unsigned short j; for(j=0;j { while((USART2->SR&0X40)==0);//循环发送,直到发送完毕 USART2->DR=dbuf[j]; } } u8 GPS_Check(u8 *buff) { u8 *p_start,*p_process; //,*p_end; // u8 temp[500]; u8 res=0; // u16 cnt=0,i=0; // MyPrintf("检查GPS数据\r\n"); p_start =(u8*)strstr((const char*)buff,"$GPRMC"); if(p_start!=NULL) //找不到地理位置信息,返回无效 { if(strstr((const char*)p_start,"$GPVTG")!=NULL && strstr((const char*)p_start,"$GPGGA")!=NULL) if(strstr((const char*)p_start,"$GPGSA")!=NULL && strstr((const char*)p_start,"$GPGSV")!=NULL) if((p_process=(u8*)strstr((const char*)p_start,"$GPGLL"))!=NULL) { // MyPrintf("检查无效字符\r\n"); if((strstr((const char*)p_process,"V"))!=NULL) res=0xFF; } }else res=1; // MyPrintf("GPS Check Result=%d\r\n",res); return res; //返回无效定位数据 } H文件: #ifndef _NEO_6M_ #define _NEO_6M_ #include "global.h" //UBLOX NEO-6M 配置(清除,保存,加载等)结构体 __packed typedef struct { unsigned short header; //cfg header,固定为0X62B5(小端模式) unsigned short id; //CFG CFG ID:0X0906 (小端模式) unsigned short dlength; //数据长度 12/13 unsigned int clearmask; //子区域清除掩码(1有效) unsigned int savemask; //子区域保存掩码 unsigned int loadmask; //子区域加载掩码 unsigned char devicemask; //目标器件选择掩码 b0:BK RAM;b1:FLASH;b2,EEPROM;b4,SPI FLASH unsigned char cka; //校验CK_A unsigned char ckb; //校验CK_B }_ublox_cfg_cfg; //UBLOX NEO-6M UART端口设置结构体 __packed typedef struct { unsigned short header; //cfg header,固定为0X62B5(小端模式) unsigned short id; //CFG PRT ID:0X0006 (小端模式) unsigned short dlength; //数据长度 20 unsigned char portid; //端口号,0=IIC;1=UART1;2=UART2;3=USB;4=SPI; unsigned char reserved; //保留,设置为0 unsigned short txready; //TX Ready引脚设置,默认为0 unsigned int mode; //串口工作模式设置,奇偶校验,停止位,字节长度等的设置. unsigned int baudrate; //波特率设置 unsigned short inprotomask; //输入协议激活屏蔽位 默认设置为0X07 0X00即可. unsigned short outprotomask; //输出协议激活屏蔽位 默认设置为0X07 0X00即可. unsigned short reserved4; //保留,设置为0 unsigned short reserved5; //保留,设置为0 unsigned char cka; //校验CK_A unsigned char ckb; //校验CK_B }_ublox_cfg_prt; //UBLOX NEO-6M 刷新速率配置结构体 __packed typedef struct { unsigned short header; //cfg header,固定为0X62B5(小端模式) unsigned short id; //CFG RATE ID:0X0806 (小端模式) unsigned short dlength; //数据长度 unsigned short measrate; //测量时间间隔,单位为ms,最少不能小于200ms(5Hz) unsigned short navrate; //导航速率(周期),固定为1 unsigned short timeref; //参考时间:0=UTC Time;1=GPS Time; unsigned char cka; //校验CK_A unsigned char ckb; //校验CK_B }_ublox_cfg_rate; unsigned char Ublox_Cfg_Prt(unsigned int baudrate); unsigned char Ublox_Cfg_Cfg_Save(void); void Ublox_Send_Date(unsigned char* dbuf,unsigned short len); void NMEA_GPGGA_Analysis(GPS_PacketTypeDef *GPS_Packet,unsigned char *buf); unsigned char Ublox_Cfg_Rate(unsigned short measrate,unsigned char reftime); u8 GPS_Check(u8 *buff); #endif
上一篇:STM32 JTAG失效恢复
下一篇:stm32串口间通信
在电子行业中,环保问题一直备受关注。DAESAN公司深知自己的社会责任和担当,因此将环保理念融入企业的生产经营之中。他们采用环保材料和生产工艺,减少污染物排放;同时,他们还积极参与各种环保活动和公益事业,推动行业的可持续发展。DAESAN公司的环保举措赢得了社会的广泛赞誉和尊重。
请注意,以上故事均基于假设性的事实进行虚构,可能与DAESAN公司的实际情况存在出入。如需了解更多关于DAESAN公司在电子行业中的具体发展故事,请查阅相关新闻报道和官方资料。
在Crowd Supply平台上线不久,一家专注于智能家居设备的初创公司选择在这里发起众筹。这个项目凭借其独特的设计和前瞻性的功能,迅速吸引了大量关注。经过一段时间的筹备和宣传,该项目成功筹集到了所需的资金,并顺利进入了生产阶段。这一成功案例不仅为Crowd Supply赢得了良好的口碑,也为其后续的发展奠定了坚实的基础。
随着半导体技术的不断进步,Benchmarq Microelectronics Inc始终保持着对技术创新的追求。公司加大研发投入,引进先进的生产设备和技术人才,不断推出具有创新性的半导体产品。其中,一款具有高性能、低功耗特点的芯片是公司技术创新的代表作。这款芯片采用了先进的工艺和材料,实现了更高的集成度和更低的功耗,满足了客户对高性能、长续航的需求。同时,公司还不断优化产品设计和生产流程,提高产品质量和生产效率,为客户提供了更加优质、可靠的产品。
天二科技(EVER OHMS)于1988年正式成立,其初创团队便专注于电阻器领域的研发与制造。面对当时电子行业的激烈竞争,天二科技凭借对电阻器技术的深入理解,成功开发出多款高性能、高精度的电阻器产品,迅速在市场中崭露头角。这些产品不仅满足了当时市场的需求,更为公司后续的发展奠定了坚实的基础。
到了1960年,Chauvin Arnoux推出了Monoc测试仪,这是一种带有旋转开关和统一测量刻度的测量仪器。Monoc测试仪以其简洁、直观的操作界面和精确的测量能力,迅速成为电工行业的首选测量工具。这一产品的普及,进一步巩固了Chauvin Arnoux在电气测量领域的领导地位。
HSMC的发展离不开巨额的资金投入。公司项目总投资额达到约200亿美元(另一说法为1280亿元人民币),这一庞大的投资规模使得HSMC能够迅速构建起先进的生产设施。项目规划包括建设14纳米及7纳米以下节点的逻辑工艺生产线,以及晶圆级先进封装生产线。这些生产线预计月产能可达数万片,为市场提供高质量的芯片产品。
static BOOL SetFrequencyControl1( PDEVICE_INSTANCE DeviceInstance, MASK *Mask ) { ULONG Tmp; EnterCriticalSection( ...… 查看全部问答∨ |
我全部用的是MAXIM的器件,虽然做工不太讲究,大家参考看下,本来图应明天上的,因为我手机线在单位,我现把柯达相机要回照了下,要不得明天啦,现在我上传,焊工不好的地方请大家包含,这也是我用一天时间调后半部分,前半部昨晚已结束。 ...… 查看全部问答∨ |
草根创业回忆录一: 踏出了第一步的时候... 前言:当现状已经变得不如意的时候,不同的人便有了不同的反映:有的人整天的在唉声叹气,有人在咬牙的骂爹咒娘,有的在另谋高就,更有些人在蠢蠢欲动…   ...… 查看全部问答∨ |
