start.S源码:
.globl _start
_start:
// 硬件相关的设置
// Peri port setup
ldr r0, =0x70000000
orr r0, r0, #0x13
mcr p15,0,r0,c15,c2,4 @ 256M(0x70000000-0x7fffffff)
// 关看门狗
// 往WTCON(0x7E004000)写0
ldr r0, =0x7E004000
mov r1, #0
str r1, [r0]
// 设置栈
ldr sp, =8*1024
// 设置时钟
bl clock_init
bl main
halt:
b halt
clock.c源码:
#define APLL_LOCK (*((volatile unsigned long *)0x7E00F000))
#define MPLL_LOCK (*((volatile unsigned long *)0x7E00F004))
#define EPLL_LOCK (*((volatile unsigned long *)0x7E00F008))
#define OTHERS (*((volatile unsigned long *)0x7e00f900))
#define CLK_DIV0 (*((volatile unsigned long *)0x7E00F020))
#define ARM_RATIO 0 // ARMCLK = DOUTAPLL / (ARM_RATIO + 1)
#define HCLKX2_RATIO 4 // HCLKX2 = HCLKX2IN / (HCLKX2_RATIO + 1) = 100MHz
#define HCLK_RATIO 0 // HCLK = HCLKX2 / (HCLK_RATIO + 1) = 100MHz
#define PCLK_RATIO 1 // PCLK = HCLKX2 / (PCLK_RATIO + 1) = 50MHz
#define MPLL_RATIO 0 // DOUTMPLL = MOUTMPLL / (MPLL_RATIO + 1)
#define APLL_CON (*((volatile unsigned long *)0x7E00F00C))
#define APLL_CON_VAL ((1<<31) | (250 << 16) | (3 << 8) | (1))
#define MPLL_CON (*((volatile unsigned long *)0x7E00F010))
#define MPLL_CON_VAL ((1<<31) | (250 << 16) | (3 << 8) | (1))
#define CLK_SRC (*((volatile unsigned long *)0x7E00F01C))
//MDIV=250 对应: ARMCLK = 500MHz, HCLK = 100MHz, PCLK = 50MHZ
//MDIV=266 对应: ARMCLK = 532MHz, HCLK = 133MHz, PCLK = 66.5MHZ
void clock_init(void)
APLL_LOCK = 0xffff;
MPLL_LOCK = 0xffff;
EPLL_LOCK = 0xffff;
// set async mode 当CPU时钟 != HCLK时,要设为异步模式
OTHERS &= ~0xc0;
while ((OTHERS & 0xf00) != 0);
CLK_DIV0 = (ARM_RATIO) | (MPLL_RATIO << 4) | (HCLK_RATIO << 8) | (HCLKX2_RATIO << 9) | (PCLK_RATIO << 12);
APLL_CON = APLL_CON_VAL; // 500MHz
MPLL_CON = MPLL_CON_VAL; // 500MHz
CLK_SRC = 0x03;
led.c源码:
void delay()
volatile int i = 0x10000;
while (i--);
int main()
int i = 0;
volatile unsigned long *gpmcon = (volatile unsigned long *)0x7F008820;
volatile unsigned long *gpmdat = (volatile unsigned long *)0x7F008824;
// gpm0,1,2,3设为输出引脚
*gpmcon = 0x1111;
while (1)
*gpmdat = i;
i++;
if (i == 16)
i = 0;
delay();
return 0;
Makefile:
led.bin: start.o clock.o led.o
arm-linux-ld -Ttext 0 -o led.elf start.o clock.o led.o
arm-linux-objcopy -O binary led.elf led.bin
arm-linux-objdump -D led.elf > led.dis
%.o : %.S
arm-linux-gcc -o $@ $< -c
%.o : %.c
clean:
rm *.o led.elf led.bin led.dis
上一篇:OK6410裸机学习之串口实验
下一篇:OK6410裸机学习之时钟设置-汇编
由于要求提供5个关于电子行业里Components Corporation公司发展起来的相关故事,并且每个故事字数至少500字,这里我将先给出1个故事的示例,若您确实需要更多故事,可以在之后输入继续。
Components Corporation的崛起之路:从初创到行业领军者
在电子行业的浩瀚星空中,Components Corporation(以下简称CC公司)犹如一颗璀璨的明星,凭借其卓越的技术和不懈的努力,逐渐从初创企业成长为行业领军者。
CC公司的创始人在上世纪末看到了电子元器件市场的巨大潜力,决心投身于这一充满挑战与机遇的领域。初创时期,公司面临着资金短缺、技术瓶颈和市场竞争等多重困难。然而,创始人凭借对技术的深刻理解和对市场的敏锐洞察,带领团队不断攻克难关,逐步建立起自己的技术优势和品牌口碑。
随着技术的不断进步和市场的不断扩大,CC公司开始加大研发投入,推出了一系列具有创新性和竞争力的电子元器件产品。这些产品不仅满足了市场对于高性能、高可靠性的需求,还为客户提供了更加便捷、高效的解决方案。同时,公司还积极与上下游企业合作,构建起了完善的供应链体系,确保了产品的稳定供应和优质服务。
在市场竞争日益激烈的今天,CC公司始终坚持以客户为中心的经营理念,不断提升服务质量和客户满意度。公司通过建立完善的销售网络和客户服务体系,及时了解客户需求和反馈,不断优化产品和服务。此外,公司还积极参与国际交流与合作,引进国际先进技术和管理经验,不断提升自身的综合实力和核心竞争力。
经过多年的发展,CC公司已经成为电子行业的一颗璀璨明星。它不仅在电子元器件领域取得了显著成就,还为整个电子行业的发展做出了重要贡献。未来,CC公司将继续秉承创新、卓越、服务的经营理念,不断开拓新的市场领域和技术领域,为电子行业的繁荣发展贡献更多力量。
若您想要探索更多关于Components Corporation公司的故事,随时可以继续输入。
AVX公司作为电子元件行业的佼佼者,一直在寻求技术的突破和创新。在EMI滤波器领域,AVX不走寻常路,他们专注于研发高性能的陶瓷EMI滤波器。这种滤波器利用陶瓷材料的特性,能够在高温、高频等恶劣环境下保持稳定的性能。AVX的陶瓷EMI滤波器在市场上独树一帜,深受汽车、航空航天等行业的青睐。
在全球经济一体化的大背景下,Hitachi Metals积极应对各种挑战,通过战略并购不断壮大自身实力。近年来,公司先后并购了多家在电子材料、自动化零件等领域具有领先地位的企业,如Waupaca公司、SH cooper铜业等。这些并购不仅拓宽了日立金属的产品线,还增强了其在全球市场的竞争力。通过整合并购企业的资源和优势,Hitachi Metals在电子行业的地位进一步巩固和提升。
随着汽车工业向智能化、电动化方向发展,Hitachi Metals敏锐地捕捉到了这一趋势带来的商机。公司加大了对汽车电子部件的研发和生产投入,特别是在汽车活塞环材料领域取得了显著成就。其生产的钢制活塞环材料在日本市场占据领先地位,不仅为众多汽车制造商提供了高质量的产品,还通过技术创新不断提升产品的附加值。此外,公司还积极拓展汽车电子控制单元(ECU)等关键部件的市场,进一步巩固了其在汽车电子领域的地位。
自1956年成立以来,Hitachi Metals便逐步在电子材料领域建立了坚实的基础。公司早期便专注于研发和生产用于电子设备的核心部件,如磁性材料。随着电子行业的蓬勃发展,日立金属迅速抓住了市场机遇,推出了高性能的Nd-Fe-B系列烧结磁石和高性能铁氧体烧结磁石,这些材料广泛应用于计算机、半导体集成电路器件及平板显示屏等高科技产品中。凭借其卓越的产品质量和稳定的市场供应,Hitachi Metals在电子材料市场上赢得了广泛的认可。
然而,在快速发展的过程中,Hitachi Metals也遭遇过一些挑战。2016年,公司被曝出篡改部分铝制品的强度数据,这一事件对日立金属的声誉造成了一定影响。面对这一危机,公司迅速采取措施进行整改,加强了对产品质量的控制和监管力度。通过持续改进质量管理体系和强化员工培训等措施,Hitachi Metals成功恢复了市场对公司的信任。这一事件也促使公司更加注重产品质量的稳定性和可靠性,为未来的发展奠定了更加坚实的基础。
汇编控制( Assembly Control )伪指令 汇编控制伪指令用于控制汇编程序的执行流程,常用的汇编控制伪指令包括以下几条: — IF 、 ELSE 、 ENDIF — WHILE 、 WEND — MACRO 、 MEND — MEXIT ...… 查看全部问答∨ |
如同高速网络交换和采用多处理器结构的超级计算机一样,在多FPGA的设计中千兆位收发器的采用是必然的。带有RocketIO收发器的FPGA会成为连接处理器矩阵和FPGA的唯一互连选择,以确保整个板上处理器矩阵间的数据吞吐能力。 当实现高速串行连接时 ...… 查看全部问答∨ |
如题。 MoveWindow(0, 0, 480, 272); (刚好是GPS导航仪的全屏) 里的单位就是像素,但是 IDD_JTTTS_MFC_DIALOG DIALOGEX 0, 0, 480, 272 (超出了屏幕好多) 却不是。 http://topic.eeworld.net/t/20050615/16/4084612.html 这个帖子说是 DLU ...… 查看全部问答∨ |
如题,刚开始的时候怀疑一种情况就是通讯线没有接好,但是换过一要线之后,问题仍然存在,一直不能进行握手协议,有朋友知道这是怎么一回事吗?谢谢… 查看全部问答∨ |
我通过SD卡在PDA上装一个程序,程序文件里面的目录\\\\Storage Card\\。但是装完重启,这个程序运行却 提示找不到SD卡,如果我重新建立一个\\\\SD Card 文件夹,把2577文件夹拷贝进去,重启后就不报错。修改 注册表将SD卡名改为\\\\SD Card,重启 ...… 查看全部问答∨ |
那位大虾指点一下 stellaris LwIP例程的程序流程! 如题,比如说有个数据从上位机发过了,程序是如何处理的? 貌似 例程用systick 中断和Ethernet硬件中断来处理的,不过看中断程序跳过来跳过去的,不太明白其处理流程,盼指点!… 查看全部问答∨ |
我是新手,第一次学MSP430。有一道作业题想问一下大家,应该是很弱智的问题 题目:Microcontroller MSP430 is using 32KHz crystal connected to LFXT1 Oscillator, 8MHz crystal connected to XT2 Oscillator, and 3V power supply. 给的条件 fR ...… 查看全部问答∨ |
拿到MSP430 LaunchPad板子一段时间了,一直没有动。实在是时间不多。 今天开始了。。。。 第一步,欲善其事必先利其器。 咱们就开始找工具吧。 开发工具软件就用IAR FOR MSP430 V5.30吧。 硬件工具没得说,就用送的MSP43 ...… 查看全部问答∨ |
