start.S源码:
.global _start
_start:
    ldr sp, =0xD0030000  // 初始化栈,因为后面要调用C函数
    bl clock_init                // 初始化时钟
    bl ddr_init                   // 初始化内存
    bl nand_init                // 初始化NAND
    ldr r0, =0x36000000   // 要拷贝到DDR中的位置
    ldr r1, =0x0                 // 从NAND的0地址开始拷贝
    ldr r2, =bss_start         // BSS段的开始地址
    sub r2,r2,r0                  // 要拷贝的大小
    bl nand_read              // 拷贝数据
clean_bss:
    ldr r0, =bss_start
    ldr r1, =bss_end
    mov r3, #0
    cmp r0, r1
    ldreq pc, =on_ddr
clean_loop:
    str r3, [r0], #4
    cmp r0, r1
    bne clean_loop
    ldr pc, =on_ddr
on_ddr:
    ldr sp, =0x3f000000    // 重新初始化栈,指向内存
    ldr pc, =main
clock.c源码:
#define APLL_CON      (*(volatile unsigned int *)0xe0100100)
#define CLK_SRC0       (*(volatile unsigned int *)0xe0100200)
#define CLK_DIV0        (*(volatile unsigned int *)0xe0100300)
#define MPLL_CON     (*(volatile unsigned int *)0xe0100108)
void clock_init(void)
    // 设置时钟为:
    // ARMCLK=1000MHz, HCLKM=200MHz, HCLKD=166.75MHz
    // HCLKP =133.44MHz, PCLKM=100MHz, PCLKD=83.375MHz,
    // PCLKP =66.7MHz
    // SDIV[2:0]  : S = 1
    // PDIV[13:8] : P = 0x3
    // MDIV[25:16]: M = 0x7d
    // LOCKED [29]: 1 = 使能锁
    // ENABLE [31]: 1 = 使能APLL控制器
    // 得出FoutAPLL = 500MHz
    APLL_CON = (1<<31)|(1<<29)|(0x7d<<16)|(0x3<<8)|(1<<0);
    // 时钟源的设置
    // APLL_SEL[0] :1 = FOUTAPLL
    // MPLL_SEL[4] :1 = FOUTMPLL
    // EPLL_SEL[8] :1 = FOUTEPLL
    // VPLL_SEL[12]:1 = FOUTVPLL
    // MUX_MSYS_SEL[16]:0 = SCLKAPLL
    // MUX_DSYS_SEL[20]:0 = SCLKMPLL
    // MUX_PSYS_SEL[24]:0 = SCLKMPLL
    // ONENAND_SEL [28]:1 = HCLK_DSYS
    CLK_SRC0 = (1<<28)|(1<<12)|(1<<8)|(1<<4)|(1<<0);
    // 设置分频系数
    // APLL_RATIO[2:0]: APLL_RATIO = 0x0
    // A2M_RATIO [6:4]: A2M_RATIO  = 0x4
    // HCLK_MSYS_RATIO[10:8]: HCLK_MSYS_RATIO = 0x4
    // PCLK_MSYS_RATIO[14:12]:PCLK_MSYS_RATIO = 0x1
    // HCLK_DSYS_RATIO[19:16]:HCLK_DSYS_RATIO = 0x3
    // PCLK_DSYS_RATIO[22:20]:PCLK_DSYS_RATIO = 0x1
    // HCLK_PSYS_RATIO[27:24]:HCLK_PSYS_RATIO = 0x4
    // PCLK_PSYS_RATIO[30:28]:PCLK_PSYS_RATIO = 0x1
    CLK_DIV0 = (0x1<<28)|(0x4<<24)|(0x1<<20)|(0x3<<16)|(0x1<<12)|(0x4<<8)|(0x4<<4);
    // PDIV[13:8] : P = 0xc
    // MDIV[25:16]: M = 0x29b
    // VSEL   [27]: 0
    // ENABLE [31]: 1 = 使能MPLL控制器
    // 得出FoutAPLL = 667MHz
    APLL_CON = (1<<31)|(1<<29)|(0x29d<<16)|(0xc<<8)|(1<<0);
mem_setup.S源码:
// SDRAM Controller
#define APB_DMC_0_BASE                    0xF0000000
#define APB_DMC_1_BASE                    0xF1400000
#define ASYNC_MSYS_DMC0_BASE      0xF1E00000
#define ELFIN_GPIO_BASE                     0xE0200000
// MemControl    BL=4, 1Chip, DDR2 Type, dynamic self refresh, force precharge, dynamic power down off
#define DMC0_MEMCONTROL     0x00202400
// MemConfig0    256MB config, 8 banks,Mapping Method[12:15]0:linear, 1:linterleaved, 2:Mixed
#define DMC0_MEMCONFIG_0    0x20E00323
#define DMC0_MEMCONFIG_1    0x00E00323    // MemConfig1
#define DMC0_TIMINGA_REF        0x00000618      // TimingAref   7.8us*133MHz=1038(0x40E), 100MHz=780(0x30C), 20MHz=156(0x9C), 10MHz=78(0x4E)
#define DMC0_TIMING_ROW         0x2B34438A      // TimingRow    for @200MHz
#define DMC0_TIMING_DATA        0x24240000      // TimingData   CL=3
#define DMC0_TIMING_PWR         0x0BDC0343      // TimingPower
#define    DMC1_MEMCONTROL        0x00202400    // MemControl    BL=4, 2 chip, DDR2 type, dynamic self refresh, force precharge, dynamic power down off
#define DMC1_MEMCONFIG_0    0x40F00313    // MemConfig0    512MB config, 8 banks,Mapping Method[12:15]0:linear, 1:linterleaved, 2:Mixed
#define DMC1_MEMCONFIG_1    0x00F00313    // MemConfig1
#define DMC1_TIMINGA_REF        0x00000618      // TimingAref   7.8us*133MHz=1038(0x40E), 100MHz=780(0x30C), 20MHz=156(0x9C), 10MHz=78(0x4E)
#define DMC1_TIMING_ROW         0x2B34438A      // TimingRow    for @200MHz
#define DMC1_TIMING_DATA        0x24240000      // TimingData   CL=3
#define DMC1_TIMING_PWR         0x0BDC0343      // TimingPower
#define MP1_0DRV_SR_OFFSET         0x3CC
#define MP1_1DRV_SR_OFFSET         0x3EC
#define MP1_2DRV_SR_OFFSET         0x40C
#define MP1_3DRV_SR_OFFSET         0x42C
#define MP1_4DRV_SR_OFFSET         0x44C
#define MP1_5DRV_SR_OFFSET         0x46C
#define MP1_6DRV_SR_OFFSET         0x48C
#define MP1_7DRV_SR_OFFSET         0x4AC
#define MP1_8DRV_SR_OFFSET         0x4CC
#define MP2_0DRV_SR_OFFSET         0x4EC
#define MP2_1DRV_SR_OFFSET         0x50C
#define MP2_2DRV_SR_OFFSET         0x52C
#define MP2_3DRV_SR_OFFSET         0x54C
#define MP2_4DRV_SR_OFFSET         0x56C
#define MP2_5DRV_SR_OFFSET         0x58C
#define MP2_6DRV_SR_OFFSET         0x5AC
#define MP2_7DRV_SR_OFFSET         0x5CC
#define MP2_8DRV_SR_OFFSET         0x5EC
#define DMC_CONCONTROL             0x00
#define DMC_MEMCONTROL             0x04
#define DMC_MEMCONFIG0             0x08
#define DMC_MEMCONFIG1             0x0C
#define DMC_DIRECTCMD             0x10
#define DMC_PRECHCONFIG         0x14
#define DMC_PHYCONTROL0         0x18
#define DMC_PHYCONTROL1         0x1C
#define DMC_RESERVED                 0x20
#define DMC_PWRDNCONFIG         0x28
#define DMC_TIMINGAREF             0x30
#define DMC_TIMINGROW             0x34
#define DMC_TIMINGDATA             0x38
#define DMC_TIMINGPOWER         0x3C
#define DMC_PHYSTATUS             0x40
#define DMC_CHIP0STATUS         0x48
#define DMC_CHIP1STATUS         0x4C
#define DMC_AREFSTATUS             0x50
#define DMC_MRSTATUS             0x54
#define DMC_PHYTEST0             0x58
#define DMC_PHYTEST1              0x5C
#define DMC_QOSCONTROL0         0x60
#define DMC_QOSCONFIG0             0x64
#define DMC_QOSCONTROL1         0x68
#define DMC_QOSCONFIG1             0x6C
#define DMC_QOSCONTROL2         0x70
#define DMC_QOSCONFIG2             0x74
#define DMC_QOSCONTROL3         0x78
#define DMC_QOSCONFIG3             0x7C
#define DMC_QOSCONTROL4         0x80
#define DMC_QOSCONFIG4             0x84
#define DMC_QOSCONTROL5         0x88
#define DMC_QOSCONFIG5             0x8C
#define DMC_QOSCONTROL6         0x90
#define DMC_QOSCONFIG6             0x94
#define DMC_QOSCONTROL7         0x98
#define DMC_QOSCONFIG7             0x9C
#define DMC_QOSCONTROL8         0xA0
#define DMC_QOSCONFIG8             0xA4
#define DMC_QOSCONTROL9         0xA8
#define DMC_QOSCONFIG9             0xAC
#define DMC_QOSCONTROL10         0xB0
#define DMC_QOSCONFIG10         0xB4
#define DMC_QOSCONTROL11         0xB8
#define DMC_QOSCONFIG11         0xBC
#define DMC_QOSCONTROL12         0xC0
#define DMC_QOSCONFIG12         0xC4
#define DMC_QOSCONTROL13         0xC8
#define DMC_QOSCONFIG13         0xCC
#define DMC_QOSCONTROL14         0xD0
#define DMC_QOSCONFIG14         0xD4
#define DMC_QOSCONTROL15         0xD8
#define DMC_QOSCONFIG15         0xDC
// SDRAM Controller
    .globl ddr_init
ddr_init:
    // DMC0 Drive Strength (Setting 2X)
    ldr    r0, =ELFIN_GPIO_BASE
    ldr    r1, =0x0000AAAA
    str    r1, [r0, #0x3cc]
    str    r1, [r0, #MP1_0DRV_SR_OFFSET]
    ldr    r1, =0x0000AAAA
    str    r1, [r0, #MP1_1DRV_SR_OFFSET]
    ldr    r1, =0x0000AAAA
    str    r1, [r0, #MP1_2DRV_SR_OFFSET]
    ldr    r1, =0x0000AAAA
    str    r1, [r0, #MP1_3DRV_SR_OFFSET]
    ldr    r1, =0x0000AAAA
    str    r1, [r0, #MP1_4DRV_SR_OFFSET]
    ldr    r1, =0x0000AAAA
    str    r1, [r0, #MP1_5DRV_SR_OFFSET]
    ldr    r1, =0x0000AAAA
    str    r1, [r0, #MP1_6DRV_SR_OFFSET]
    ldr    r1, =0x0000AAAA
    str    r1, [r0, #MP1_7DRV_SR_OFFSET]
    ldr    r1, =0x00002AAA
    str    r1, [r0, #MP1_8DRV_SR_OFFSET]
    // DMC0 initialization at single Type
    ldr    r0, =APB_DMC_0_BASE
    ldr    r1, =0x00101000                @PhyControl0 DLL parameter setting, manual 0x00101000
    str    r1, [r0, #DMC_PHYCONTROL0]
    ldr    r1, =0x00000086                @PhyControl1 DLL parameter setting, LPDDR/LPDDR2 Case
    str    r1, [r0, #DMC_PHYCONTROL1]
    ldr    r1, =0x00101002                @PhyControl0 DLL on
    ldr    r1, =0x00101003                @PhyControl0 DLL start
find_lock_val:
    ldr    r1, [r0, #DMC_PHYSTATUS]        @Load Phystatus register value
    and    r2, r1, #0x7
    cmp    r2, #0x7                @Loop until DLL is locked
    bne    find_lock_val
    and    r1, #0x3fc0
    mov    r2, r1, LSL #18
    orr    r2, r2, #0x100000
    orr    r2 ,r2, #0x1000
    orr    r1, r2, #0x3                @Force Value locking
    // setting DDR2
    ldr    r1, =0x0FFF2010                @ConControl auto refresh off
    str    r1, [r0, #DMC_CONCONTROL]
    ldr    r1, =DMC0_MEMCONTROL            @MemControl BL=4, 1 chip, DDR2 type, dynamic self refresh, force precharge, dynamic power down off
    str    r1, [r0, #DMC_MEMCONTROL]
    ldr    r1, =DMC0_MEMCONFIG_0            @MemConfig0 256MB config, 8 banks,Mapping Method[12:15]0:linear, 1:linterleaved, 2:Mixed
    str    r1, [r0, #DMC_MEMCONFIG0]
    ldr    r1, =DMC0_MEMCONFIG_1            @MemConfig1
    str    r1, [r0, #DMC_MEMCONFIG1]
    ldr    r1, =0xFF000000                @PrechConfig
    str    r1, [r0, #DMC_PRECHCONFIG]
    ldr    r1, =DMC0_TIMINGA_REF            @TimingAref    7.8us*133MHz=1038(0x40E), 100MHz=780(0x30C), 20MHz=156(0x9C), 10MHz=78(0x4E)
    str    r1, [r0, #DMC_TIMINGAREF]
    ldr    r1, =DMC0_TIMING_ROW            @TimingRow    for @200MHz
    str    r1, [r0, #DMC_TIMINGROW]
    ldr    r1, =DMC0_TIMING_DATA            @TimingData    CL=4
    str    r1, [r0, #DMC_TIMINGDATA]
    ldr    r1, =DMC0_TIMING_PWR            @TimingPower
    str    r1, [r0, #DMC_TIMINGPOWER]
    ldr    r1, =0x07000000                @DirectCmd    chip0 Deselect
    str    r1, [r0, #DMC_DIRECTCMD]
    ldr    r1, =0x01000000                @DirectCmd    chip0 PALL
    ldr    r1, =0x00020000                @DirectCmd    chip0 EMRS2
    ldr    r1, =0x00030000                @DirectCmd    chip0 EMRS3
    ldr    r1, =0x00010400                @DirectCmd    chip0 EMRS1 (MEM DLL on, DQS# disable)
    ldr    r1, =0x00000542                @DirectCmd    chip0 MRS (MEM DLL reset) CL=4, BL=4
    ldr    r1, =0x05000000                @DirectCmd    chip0 REFA
    ldr    r1, =0x00000442                @DirectCmd    chip0 MRS (MEM DLL unreset)
    ldr    r1, =0x00010780                @DirectCmd    chip0 EMRS1 (OCD default)
    ldr    r1, =0x00010400                @DirectCmd    chip0 EMRS1 (OCD exit)
    ldr    r1, =0x07100000                @DirectCmd    chip1 Deselect
    ldr    r1, =0x01100000                @DirectCmd    chip1 PALL
    ldr    r1, =0x00120000                @DirectCmd    chip1 EMRS2
    ldr    r1, =0x00130000                @DirectCmd    chip1 EMRS3
    ldr    r1, =0x00110400                @DirectCmd    chip1 EMRS1 (MEM DLL on, DQS# disable)
    ldr    r1, =0x00100542                @DirectCmd    chip1 MRS (MEM DLL reset) CL=4, BL=4
    ldr    r1, =0x05100000                @DirectCmd    chip1 REFA
    ldr    r1, =0x00100442                @DirectCmd    chip1 MRS (MEM DLL unreset)
    ldr    r1, =0x00110780                @DirectCmd    chip1 EMRS1 (OCD default)
    ldr    r1, =0x00110400                @DirectCmd    chip1 EMRS1 (OCD exit)
    ldr    r1, =0x0FF02030                @ConControl    auto refresh on
    ldr    r1, =0xFFFF00FF                @PwrdnConfig
    str    r1, [r0, #DMC_PWRDNCONFIG]
    ldr    r1, =0x00202400                @MemControl    BL=4, 1 chip, DDR2 type, dynamic self refresh, force precharge, dynamic power down off
    mov    pc, lr
nand.c源码:
#define    NFCONF  (*(volatile unsigned int *)0xB0E00000)
#define    NFCONT  (*(volatile unsigned int *)0xB0E00004)
#define    NFCMMD  (*(volatile unsigned char *)0xB0E00008)
#define    NFADDR  (*(volatile unsigned char *)0xB0E0000C)
#define    NFDATA  (*(volatile unsigned char *)0xB0E00010)
#define    NFSTAT  (*(volatile unsigned int *)0xB0E00028)
#define    MP0_3CON  (*(volatile unsigned int *)0xE0200320)
#define    MP0_1CON  (*(volatile unsigned int *)0xE02002E0)
#define PAGE_SIZE    2048
#define NAND_SECTOR_SIZE_LP    2048
void wait_idle(void)
    int i;
    while(!(NFSTAT&(1<<0)));
    for(i=0; i<10; i++);
void nand_select_chip(void)
    int i;
    NFCONT &= ~(1<<1);
void nand_deselect_chip(void)
    NFCONT |= (1<<1);
void write_cmd(int cmd)
    NFCMMD = cmd;
void write_addr(unsigned int addr)
    int i;
    NFADDR = (addr>>0) & 0xFF;
    wait_idle();
    NFADDR = (addr>>8) & 0x7;
    wait_idle();
    NFADDR = (addr>>11) & 0xFF;
    wait_idle();
    NFADDR = (addr>>19) & 0xFF;
    wait_idle();
    NFADDR = (addr>>27) & 0x1;
    wait_idle();
unsigned char read_data(void)
    return NFDATA;
static void nand_reset(void)
    nand_select_chip();
    write_cmd(0xff);  // 复位命令
    wait_idle();
    nand_deselect_chip();
void nand_init(void)
    // 设置时间参数(HCLK_PSYS = 667MHz/5 = 133MHz)
    // TACLS[15:12]: TACLS  = 1     1/133Mhz  = 7.5ns
    // TWRPH0[11:8]: TWRPH0 = 1     7.5ns * 2 = 15ns
    // TWRPH1 [7:4]: TWRPH1 = 1     7.5ns * 2 = 15ns
    // AddrCycle[1]: 1 = 指明地址周期为5次,这个是和2440的区别
    NFCONF |= 1<<12 | 1<<8 | 1<<4;
    NFCONF |= 1<<1;
    // 使能NAND控制器
    // 关闭片选信号
    NFCONT |= (1<<0)|(1<<1);
    // 设置相应管脚用于Nand Flash控制器
    MP0_3CON = 0x22222222;
    // 复位NAND Flash
    nand_reset();
    return;
// 读ID
void nand_read_id(char id[])
    int i;
    nand_select_chip();
    write_cmd(0x90);
    write_addr(0x00);
    for (i = 0; i < 5; i++)
        id[i] = read_data();
// 读一页的函数
void nand_read(unsigned char *buf, unsigned long start_addr, int size)
    int i, j;
    // 选中芯片
    nand_select_chip();
    for(i=start_addr; i < (start_addr + size);)
        // 发出READ0命令
        write_cmd(0);
        // Write Address
        write_addr(i);
        write_cmd(0x30);
        wait_idle();
        for(j=0; j < NAND_SECTOR_SIZE_LP; j++, i++)
            *buf = read_data();
            buf++;
    // 取消片选信号
void nand_write(int sdram_addr, int nand_addr, int size)
main.c源码:
#include "clock.h"
#include "uart.h"
#include "lib.h"
#include "nand.h"
#include "lcd.h"
int main(void)
    int i;
    uart_init(); // 初始化UART
    wy_printf("LCD initialize ...\n");
    lcd_init();
    while (1)
        wy_printf("display red\n");
        lcd_clear_screen(0xff0000);
        for(i=50;i>0;i--)
            delay();
        wy_printf("display green\n");
        lcd_clear_screen(0x00ff00);
        for(i=50;i>0;i--)
            delay();
        wy_printf("display blue\n");
        lcd_clear_screen(0x0000ff);
        for(i=50;i>0;i--)
            delay();
        wy_printf("draw rectangle\n");
        Glib_Rectangle(33,33,555,400,0xff0000);
        Glib_Rectangle(55,55,666,422,0x00ff00);
        Glib_Rectangle(77,77,777,444,0xffffff);
        for(i=50;i>0;i--)
            delay();
    return 0;
lcd.S源码:
#define GPF0CON        (*(volatile unsigned int *)0xE0200120)
#define GPF1CON        (*(volatile unsigned int *)0xE0200140)
#define GPF2CON        (*(volatile unsigned int *)0xE0200160)
#define GPF3CON        (*(volatile unsigned int *)0xE0200180)
#define GPD0CON        (*(volatile unsigned int *)0xE02000A0)
#define GPD0DAT        (*(volatile unsigned int *)0xE02000A4)
#define CLK_SRC1    (*(volatile unsigned int *)0xe0100204)
#define CLK_DIV1    (*(volatile unsigned int *)0xe0100304)
#define DISPLAY_CONTROL    (*(volatile unsigned int *)0xe0107008)
#define VIDCON0        (*(volatile unsigned int *)0xF8000000)
#define VIDCON1        (*(volatile unsigned int *)0xF8000004)
#define VIDTCON2     (*(volatile unsigned int *)0xF8000018)
#define VIDTCON3     (*(volatile unsigned int *)0xF800001c)
#define WINCON0     (*(volatile unsigned int *)0xF8000020)
#define WINCON2     (*(volatile unsigned int *)0xF8000028)
#define SHADOWCON     (*(volatile unsigned int *)0xF8000034)
#define VIDOSD0A     (*(volatile unsigned int *)0xF8000040)
#define VIDOSD0B     (*(volatile unsigned int *)0xF8000044)
#define VIDOSD0C     (*(volatile unsigned int *)0xF8000048)
#define VIDW00ADD0B0     (*(volatile unsigned int *)0xF80000A0)
#define VIDW00ADD1B0     (*(volatile unsigned int *)0xF80000D0)
#define VIDW00ADD2       (*(volatile unsigned int *)0xF8000100)
#define VIDTCON0     (*(volatile unsigned int *)0xF8000010)
#define VIDTCON1     (*(volatile unsigned int *)0xF8000014)
#define VSPW       9
#define VBPD       13
#define LINEVAL    479
#define VFPD       21
#define HSPW       19
#define HBPD       25
#define HOZVAL     799
#define HFPD       209
#define LeftTopX     0
#define LeftTopY     0
#define RightBotX   799
#define RightBotY   479
#define SCR_XSIZE_TFT     (800)
#define SCR_YSIZE_TFT     (480)
volatile unsigned long LCD_BUFFER[SCR_YSIZE_TFT][SCR_XSIZE_TFT];
void lcd_init(void)
    // 1. 设置相关GPIO引脚用于LCD
    GPF0CON = 0x22222222;        // GPF0[7:0]
    GPF1CON = 0x22222222;        // GPF1[7:0]
    GPF2CON = 0x22222222;        // GPF2[7:0]
    GPF3CON = 0x22222222;        // GPF3[7:0]
    // 使能LCD本身
    GPD0CON |= 1<<4;
    GPD0DAT |= 1<<1;
    // 该寄存器是时钟相关
    // Display path selection
    // 10: RGB=FIMD I80=FIMD ITU=FIMD
    DISPLAY_CONTROL = 2<<0;
    // 2. 初始化210的display controller
    // 2.1 hsync,vsync,vclk,vden的极性和时间参数
    // 2.2 行数、列数(分辨率),象素颜色的格式
    // 2.3 分配显存(frame buffer),写入display controller
    // CLKVAL_F[13:6]:该值需要根据LCD手册做相应的修改
    //                  HCLKD=166.75MHz,DCLK(min) = 20ns(50MHz)
    //                VCLK = 166.75 / (4+1) = 33.35MHz
    // CLKDIR  [4]:1 = Divided by CLKVAL_F
    // ENVID   [1]:1 = Enable the video output and the Display control signal.
    // ENVID_F [0]:1 = Enable the video output and the Display control signal.
    VIDCON0 &= ~((3<<26) | (1<<18) | (0xff<<6)  | (1<<2));     // RGB I/F, RGB Parallel format,
    VIDCON0 |= ((4<<6) | (1<<4) );
    // 设置极性(该值需要根据LCD手册做相应的修改)
    // IVDEN [4]:0 = Normal
    // IVSYNC[5]:1 = Inverted
    // IHSYNC[6]:1 = Inverted
    // IVCLK [7]:0 = Video data is fetched at VCLK falling edge
    VIDCON1 &= ~(1<<7);            // 在vclk的下降沿获取数据
    VIDCON1 |= ((1<<6) | (1<<5));  // HSYNC极性反转, VSYNC极性反转
    // 设置时序(需要修改)
    VIDTCON0 = (VBPD << 16) | (VFPD << 8) | (VSPW << 0);
    VIDTCON1 = (HBPD << 16) | (HFPD << 8) | (HSPW << 0);
    // 设置屏幕的大小
    // LINEVAL[21:11]:多少行   = 480
    // HOZVAL [10:0] :水平大小 = 800
    VIDTCON2 = (LINEVAL << 11) | (HOZVAL << 0);
    // WSWP_F   [15] :1    = Swap Enable(为什么要使能),很关键的一位,能够解决掉重影问题
    // BPPMODE_F[5:2]:1011 = unpacked 24 BPP (non-palletized R:8-G:8-B:8 )
    // ENWIN_F  [0]:  1    = Enable the video output and the VIDEO control signal.
    WINCON0 &= ~(0xf << 2);
    WINCON0 |= (0xB<<2)|(1<<15);
    // 窗口0,左上角的位置(0,0)
    // 窗口0,右下角的位置(800,480)
    VIDOSD0A = (LeftTopX<<11) | (LeftTopY << 0);
    VIDOSD0B = (RightBotX<<11) | (RightBotY << 0);
    // 大小
    VIDOSD0C = (LINEVAL + 1) * (HOZVAL + 1);
    VIDW00ADD0B0 = LCD_BUFFER;
    // VBASEL = VBASEU + (LINEWIDTH+OFFSIZE) x (LINEVAL+1)
    //        = 0 + (800*4 + 0) * 479
    VIDW00ADD1B0 =  (((HOZVAL + 1)*4 + 0) * (LINEVAL + 1)) & (0xffffff);
    //VIDW00ADD1B0 = FRAME_BUFFER + HOZVAL * LINEVAL * 4; // 新加的,是该这个吗?
    SHADOWCON = 0x1; // 使能通道0
    // LCD控制器开启
    VIDCON0  |= 0x3; // 开启总控制器
    WINCON0 |= 1;     // 开启窗口0
// 画一个像素点
void PutPixel(unsigned long x,unsigned long y, unsigned long c )
    if ( (x < SCR_XSIZE_TFT) && (y < SCR_YSIZE_TFT) )
        LCD_BUFFER[(y)][(x)] = c;
// 清屏
void lcd_clear_screen( unsigned long c)
    unsigned int x,y ;
    for( y = 0 ; y < SCR_YSIZE_TFT ; y++ )
        for( x = 0 ; x < SCR_XSIZE_TFT ; x++ )
            LCD_BUFFER[y][x] = c ;
// 用于黄直线:横线和竖线
void Glib_Line(int x1,int y1,int x2,int y2,int color)
    int dx,dy,e;
    dx=x2-x1;
    dy=y2-y1;
    if(dx>=0)
        if(dy >= 0) // dy>=0
            if(dx>=dy) // 1/8 octant
                e=dy-dx/2;
                while(x1<=x2)
                    PutPixel(x1,y1,color);
                    if(e>0){y1+=1;e-=dx;}
                    x1+=1;
                    e+=dy;
            else        // 2/8 octant
                e=dx-dy/2;
                while(y1<=y2)
                    if(e>0){x1+=1;e-=dy;}
                    y1+=1;
                    e+=dx;
        else           // dy<0
            dy=-dy;   // dy=abs(dy)
            if(dx>=dy) // 8/8 octant
                e=dy-dx/2;
                while(x1<=x2)
                    if(e>0){y1-=1;e-=dx;}
                    x1+=1;
                    e+=dy;
            else        // 7/8 octant
                e=dx-dy/2;
                while(y1>=y2)
                    y1-=1;
                    e+=dx;
    else //dx<0
        dx=-dx;        //dx=abs(dx)
            if(dx>=dy) // 4/8 octant
                e=dy-dx/2;
                while(x1>=x2)
                    x1-=1;
                    e+=dy;
            else        // 3/8 octant
                e=dx-dy/2;
                while(y1<=y2)
                    if(e>0){x1-=1;e-=dy;}
                    y1+=1;
                    e+=dx;
        else           // dy<0
            if(dx>=dy) // 5/8 octant
                e=dy-dx/2;
                while(x1>=x2)
                    x1-=1;
                    e+=dy;
            else        // 6/8 octant
                e=dx-dy/2;
                while(y1>=y2)
                    y1-=1;
                    e+=dx;
// 用于画方框
void Glib_Rectangle(int x1,int y1,int x2,int y2,int color)
    Glib_Line(x1,y1,x2,y1,color);
    Glib_Line(x2,y1,x2,y2,color);
    Glib_Line(x1,y2,x2,y2,color);
    Glib_Line(x1,y1,x1,y2,color);
Makefeile文件:
uart.bin:start.s main.c uart.c clock.c lib.c nand.c lcd.c mem_setup.S
    arm-linux-gcc -nostdlib -c start.s -o start.o
    arm-linux-gcc -nostdlib -c main.c -o main.o
    arm-linux-gcc -nostdlib -c uart.c -o uart.o
    arm-linux-gcc -nostdlib -c lib.c -o lib.o
    arm-linux-gcc -nostdlib -c clock.c -o clock.o
    arm-linux-gcc -nostdlib -c lcd.c -o lcd.o
    arm-linux-gcc -nostdlib -c nand.c -o nand.o
    arm-linux-gcc -nostdlib -c mem_setup.S -o mem_setup.o
    arm-linux-ld -T bootloader.lds start.o main.o uart.o lib.o clock.o lcd.o nand.o mem_setup.o -o uart_elf
    arm-linux-objcopy -O binary -S uart_elf uart.bin
clean:
    rm -rf *.o *.bin uart_elf *.dis
bootloader.lds链接文件:
SECTIONS {
    . = 0x36000010;
    .text : {
        * (.text)
    . = ALIGN(4);
    .rodata : {
        * (.rodata)
    . = ALIGN(4);
    .data : {
        * (.data)
    . = ALIGN(4);
    bss_start = .;
    .bss  : { *(.bss)  *(COMMON) }
    bss_end = .;
简单测试源码分析,以下为初始化LCD的代码:
void lcd_init(void)
    // 使能LCD本身
    GPD0CON |= 1<<4;
    GPD0DAT |= 1<<1;
    // 该寄存器是时钟相关
    // 设置时序(需要修改)
    // 设置屏幕的大小
    // 窗口0,左上角的位置(0,0)
    // 大小
    VIDW00ADD0B0 = FRAME_BUFFER;
    // LCD控制器开启
注意:
1).该程序适用的LCD型号是S70,若为其他型号,请根据自己的LCD手册修改注有要修改字样的地方!!
2).该部分程序放在了"Tiny210学习日记_代码"目录下了,名为"10_lcd",该部分程序只是循环显示红,绿,蓝,画了几个框框而已!!
3).另外一个程序放在了"Tiny210学习日记_代码"目录下了,名为"11_lcd",该部分程序显示一张图片!!
注意:
测试"11_lcd"的程序时,图片需要单独烧写到nand的0xC00000处!!!
关键字:Tiny210  裸机  LCD显示 引用地址:Tiny210裸机之LCD显示测试
上一篇:Tiny210裸机之LCD显示图片
下一篇:Tiny210裸机之bootm命令启动内核
   LOGO是一个品牌的代表,也是品牌对外展示的形象,看到一个LOGO就立刻会在脑中想起这个品牌的产品以及品牌文化。一个品牌在产品上在不影响美观的前提下往往会尽量的使LOGO醒目,也有的使LOGO成为外观设计的一部分,这样的设计在服装鞋包行业非常常见,如像Gucci、Dior或者耐克、阿迪以及现在很火的Superme,大LOGO成为了一个大潮流。而在科技行业,由...
(文章来源:仙知机器人) 近年来,随着电商、快递行业的迅猛增长及智慧物流的深入推进,带动了移动机器人行业的蓬勃发展。新的移动机器人公司如雨后春笋般快速增长,并得到了资本的青睐。据不完全统计,2012年国内生产移动机器人本体的企业在20家以内,2015年12月达到了60家左右,2018年超过了120家企业,增长速度惊人。 生产移动机器人企业爆发式增...
10月13日,精测电子公告披露了公司向特定对象发行A股股票预案。据悉,精测电子本次发行拟募集资金总额不超过人民币14.94亿元,(含本数),扣除发行费用后拟将全部用于上海精测半导体技术有限公司研发及产业化建设项目、Micro-LED显示全制程检测设备的研发及产业化项目、补充流动资金项目。精测电子指出,本次是发行的目的一方面是支持半导体研发及产业化建...
用于更大工作温度范围的汽车和工业应用的电压基准IC需要低漂移、高可靠性和高性能。Microchip Technology Inc.(美国微芯科技公司)近日宣布推出一款高精度电压基准 (Vref) IC,以高性价比满足这些需求。新款MCP1502是一款通过AEC-Q100 1级(-40 °C至+125 °C环境工作温度范围)汽车认证的Vref,最大温度系数为7 ppm/°C。Microchip混合信号和线性...
mdkarm3.05问题target not created
初学arm,用keil老生成不了目标文件,请高手指教,怎么解决啊 build target \'lpc2106\' assembling startup.s... /cygdrive/c/cygnus/arm-tools/bin/../lib/gcc-lib/arm-thunb-elf/3.3.1/../../../../arm-thumb-elf/bin/ld: warning:cannot fin ...…
查看全部问答∨
红外灯介绍
红外灯主要有以下三种: 卤素灯泡加滤光片:照射距离较远,功率较大,但能量损失也大,因为加有滤光片,大部分可见光被滤掉而转变成热能,所以这种红外灯寿命很短,售后服务问题很多; 激光管:照射距离最远,但角度很小,如果角度调大以后,由于能 ...…
查看全部问答∨
印刷电子当选2010年影响世界的十大潜力新技术
2. 印刷电子      能快速印刷出多个导体/绝缘体或半导体层以形成电路的技术,可望催生比目前采用传统制程生产之IC成本更低芯片。通常印刷半导体意味着使用性能与硅大不相同 的有机材料,甚至所生产之组件尺寸也能超越硅材料的 ...…
查看全部问答∨
编译交叉工具时遇到的问题
我想在cygwin下编译基于目标cpu i960的交叉编译工具链 在编译bootrap gcc的时候遇到一个libgcc1.a的问题 mv libgcc1.a libgcc1.cross || (echo You must find a way to make libgcc1.a; false) mv: cannot stat `libgcc1.a\': No such file or d ...…
查看全部问答∨
杭州,嵌入式项目开发合作,有兴趣的进来看看
准备上个项目,人手不够,打算找人合作。 杭州有产品经验,有业余时间,熟悉工业级ARM,51,tcp/ip,RTOS等之一的技术便可。 有兴趣的回个贴。 技术专长,业余时间,要求等。 sssbang@163.com …
查看全部问答∨
超级广场效果的耳机放大器电路
本帖最后由 jameswangsynnex 于 2015-3-3 19:54 编辑 用头戴式耳机,尤其是小型耳机听音乐,总感到音乐味不够足,在低频段的效果更差。因此用本机增强耳机的低频特性,并采用立体声反相合成的办法,加上内藏简易矩阵环绕声电路,能获得强劲的低音 ...…
查看全部问答∨
是不是现在支持STM32F的GCC编译器开发环境都是命令行模式的
我下载了一个WINARM20080331里面没找到XP可以运行的程序CodeSourcery 里面用的好象也是命令行模式 …
查看全部问答∨
求一个基于MSP430F149或F449芯片的LCD键盘显示系统的完整C程序
求一个基于MSP430F149或F449芯片的LCD键盘显示系统的完整C程序 说明:本人刚开始学习MSP430,想用MSP430做一个键盘LCD显示控制系统 求一个完整的C程序,来学习和模仿下。 控制系统要求:1,键盘是3*4列的行列式扫描键盘。LCD最好用truely(信利公 ...…
查看全部问答∨
小广播
设计资源 培训 开发板 精华推荐
最新单片机文章
何立民专栏 单片机及嵌入式宝典
电子工程世界版权所有 京ICP证060456号 京ICP备10001474号-1 电信业务审批[2006]字第258号函 京公网安备 11010802033920号 Copyright © 2005-2024 EEWORLD.com.cn, Inc. All rights reserved
