今天是:2024年10月16日(星期三)
正在发生
2018年10月16日 | stm32之滴答定时器(4):滴答定时器的优先级设置
发布者:TechWhizKid 来源: eefocus关键字:stm32  滴答定时器  优先级设置 手机看文章 扫描二维码
随时随地手机看文章
上次讲的只剩滴答定时器的优先级设置函数NVIC_SetPriority没有讲,这个函数具体如下
static __INLINE void NVIC_SetPriority(IRQn_Type IRQn, uint32_t priority)
  if(IRQn < 0) {
    SCB->SHP[((uint32_t)(IRQn) & 0xF)-4] = ((priority << (8 - __NVIC_PRIO_BITS)) & 0xff); } * set Priority for Cortex-M3 System Interrupts */
  else {
    NVIC->IP[(uint32_t)(IRQn)] = ((priority << (8 - __NVIC_PRIO_BITS)) & 0xff);    }        * set Priority for device specific Interrupts  */
    它是设置中断标号以及优先级的函数,由于滴答定时器是系统内部中断因此优先级是通过SCB中的SHP寄存器设置的。
    这里的SCB无论是STM32技术手册还是CORTEX技术手册都没有具体的说明,在英文的cortex编程手册中介绍,这个是系统控制块system control block。
    库函数中,SCB的基地址为0xE000ED00,其结构体如下(注释符还是跟原来同理。。怕被注释)
typedef struct
  __I  uint32_t CPUID;                         *!< Offset: 0x00  CPU ID Base Register                                  */
  __IO uint32_t ICSR;                         *!< Offset: 0x04  Interrupt Control State Register                      */
  __IO uint32_t VTOR;                         *!< Offset: 0x08  Vector Table Offset Register                          */
  __IO uint32_t AIRCR;                  *!< Offset: 0x0C  Application Interrupt / Reset Control Register        */
  __IO uint32_t SCR;                          *!< Offset: 0x10  System Control Register                               */
  __IO uint32_t CCR;                          *!< Offset: 0x14  Configuration Control Register                        */
  __IO uint8_t  SHP[12];             *!< Offset: 0x18  System Handlers Priority Registers (4-7, 8-11, 12-15) */
  __IO uint32_t SHCSR;                       *!< Offset: 0x24  System Handler Control and State Register       */
  __IO uint32_t CFSR;                         *!< Offset: 0x28  Configurable Fault Status Register                    */
  __IO uint32_t HFSR;                         *!< Offset: 0x2C  Hard Fault Status Register                            */
  __IO uint32_t DFSR;                         *!< Offset: 0x30  Debug Fault Status Register                           */
  __IO uint32_t MMFAR;                        *!< Offset: 0x34  Mem Manage Address Register                      */
  __IO uint32_t BFAR;                         *!< Offset: 0x38  Bus Fault Address Register                            */
  __IO uint32_t AFSR;                         *!< Offset: 0x3C  Auxiliary Fault Status Register                       */
  __I  uint32_t PFR[2];                       *!< Offset: 0x40  Processor Feature Register                            */
  __I  uint32_t DFR;                          *!< Offset: 0x48  Debug Feature Register                                */
  __I  uint32_t ADR;                          *!< Offset: 0x4C  Auxiliary Feature Register                            */
  __I  uint32_t MMFR[4];                      *!< Offset: 0x50  Memory Model Feature Register                  */
  __I  uint32_t ISAR[5];                      *!< Offset: 0x60  ISA Feature Register                                  */
} SCB_Type;
    其结构体与技术手册中的寄存器完全对应,可以看到 __IO uint8_t  SHP[12] ,其是系统异常优先级寄存器,关于这个为什么8位寄存器,12个8位,同样需要参考cm3编程手册。
  其地址虽然是连续的,但是实际寄存器内部分布比较特殊
下面回到程序
查滴答定时器的中断标号为-1,这里涉及了uint32_t(32位无符号整形)强制转换一个负数,由于stm32必须通过硬件才能进入调试状态,因此使用visual C/C++编个程序验证一下.
 #include
typedef unsigned __int32 uint32_t;
void main()
//typedef unsigned __int32 uint32_t;
int aa=-1;
uint32_t bb = 888;
    bb=(uint32_t)aa;
    printf("bb is %x",  bb);
    最后得出的结果是0xFFFFFFFF,这里的原因在于机器存储负数的机制,最高位为符号位,负数为其补码,补码为反码加一,因此-1表示就是10000001,反码11111110,补码1111111,32位表示就是0xFFFFFFFF。
    回到程序中其实就是0xF-4,也就是SHP[11],也就是寄存器组的最后一个。
#define __NVIC_PRIO_BITS          4  *!< STM32 uses 4 Bits for the Priority Levels    */
代入得出优先级是15,也就是系统中断的最低优先级。
    滴答定时器就全部介绍完毕啦,实际滴答定时器用起来只要会算计数值就可以了,为什么这么详细呢,因为我自己认为这是学stm32的一个方法,学会了这种思路,以后学习stm32不论是内核还是外设,都能触类旁通,明白学习库函数到寄存器到数据手册的流程
关键字:stm32  滴答定时器  优先级设置 引用地址:stm32之滴答定时器(4):滴答定时器的优先级设置
上一篇:stm32之nRF24L01无线模块(2):无线模块的地址
下一篇:stm32之滴答定时器(3):滴答定时器的初始化设置
一。STM32 CAN控制器简介-bxCAN什么是bxCAN:STM32自带了基本扩展CAN外设,又称bxCAN。F103最多有14个过滤器组,F407有28个。(二)STM32 CAN控制器的模式简介工作模式:开始必须是初始化模式,对CAN进行初始化,然后是正常模式,可以正常的收发数据,通过CAN_MCR寄存器控制INRQ和SLEEP。睡吗模式是为了降低功耗用的。测试模式:通过CAN_BTR寄存器控制LB...
新闻亮点● ART采用恩智浦i.MX 8QuadMax设计ARTIST 8开发平台,针对以速度、功率和个性而著称的豪华跑车,创建超直观的信息娱乐系统● 恩智浦i.MX 8QuadMax应用处理器可实现安全域分区、多操作系统平台在单个处理器上的独特部署和高级汽车仪表盘图形,包括信息娱乐视觉效果、仪表盘、抬头显示器和4个独立的屏幕● 支持ART的ARTIST 8信息娱乐系统的i.M...
智能物流即物流的智能化,在现代物流的基础上,结合物联网、计算机、互联网、自动控制和智能决策等技术,使物流系统具有自我思维、自我感知、自我学习、自我检测、自我推断、自我决策、自我修复等一系列智能化的能力。智能物流可以通过自动化设备和信息系统独立进行订单处理、物流运输、仓储配送等各环节作业,实现经济、高效、可靠和环保的发展目标,因此...
据网友反馈,华为 P10 手机开始推送鸿蒙 Harmony OS 2.0 系统重要补丁包,大小为 82.55MB,包含重要补丁修复,建议立即升级。  IT之家获悉,本次更新修复了部分第三方应用无法使用指纹登录和部分界面显示异常的问题,并优化了通信体验,建议进行更新。  IT之家获悉,在 9 月份的华为 nova 9 系列发布会上,华为消费者业务首席运...
什么是Wi-Fi?
wiFi的全称是Wireless Fidelity,又叫802.11b标准,是IEEE定义的一个无线网络通信的工业标准。该技术使用的使2.4GHz附近的频段,该频段目前尚属没用许可的无线频段。其主要特性为:速度快,可靠性高,在开放性区域,通讯距离可达305米,在封闭性区 ...…
查看全部问答∨
基于FPGA的以太网控制器设计
引言 目前,以太网802.3协议和TCP/IP协议是现今嵌入式系统接入Internet的首选协议。而以太网(Ethernet)的核心思想是多用户使用共享的公共传输信道,它通过带冲突检测的载波侦听多路访问协议(CSMA/CD)来控制对介质的访问。 本文给出了完全用FPGA ...…
查看全部问答∨
招聘验证工程师,工艺工程师等职位
上海公司招聘以下职位,有兴趣请速发简历到xinjihr_cn@126.com,或者msn: mouhuitou@hotmail.com,谢谢 ASIC Verfication Engineer: 1)本科以上学历 2)有3年左右验证工作背景. 3)熟悉system verilog最好. Process Engineer: 1)本科以上学历 2) ...…
查看全部问答∨
WinCE下声音的问题(急请达人指教)
程序要分离系统声音和按键声音,使两者互不干扰。 现在系统声音的设置通过waveOutSetVolume(0, 音量值) 这种情况下,可不可以实现另外做一个音频的通道,使其不受主音量的干扰,成为按键的声音? 要怎么做才能实现呢? 请指教啊~~~~~谢谢…
查看全部问答∨
[UC/OS II 中怎样增加添加路由功能]
各位大大,知道怎样在UC/OS II 中实现route add , rout delete之类的路由函数功能? 或者这些函数的原型是怎么样的? 谢谢!…
查看全部问答∨
hid设备控制问题? audio与usb复合设备
现在有个心片,是一个usb的audio设备 ,我现在可以把她作为一个普通的usb设备读写,但是现在有个问题就是希望该设备作为audio 设备来播放音乐,除了控制命令用endpoint1和4来传外,另外的audio channel怎么指定啊? 谢谢指定一下!…
查看全部问答∨
请问在MTK开发平台上后缀名为.pth文件是做什么用的?
请问在MTK开发平台上后缀名为.pth文件是做什么用的?…
查看全部问答∨
QQ的内嵌技术
您好,我使用MVC架构(java语言)来作QQ内嵌,实现用户可通过QQ和在线的管理员进行交流。我在网上搜索后,没有找到可用的资源。请您指教!…
查看全部问答∨
LM3开发笔记_2.时钟和GPIO
        今天熟悉了一下LM提供的StellarisWare固件库,感觉跟STM32的固件库有很大的差异,使用上有点像Windows平台API函数的意思,使用外设的时候到对应的固件库看看有啥函数可以用就行了。   &nbs ...…
查看全部问答∨
请问版主STR710的IIC功能现在有没有解决?
                                 没有波形出来呀,还会死机。…
查看全部问答∨
小广播
设计资源 培训 开发板 精华推荐
最新单片机文章
何立民专栏 单片机及嵌入式宝典
换一换 更多 相关热搜器件
随便看看
电子工程世界版权所有 京ICP证060456号 京ICP备10001474号-1 电信业务审批[2006]字第258号函 京公网安备 11010802033920号 Copyright © 2005-2024 EEWORLD.com.cn, Inc. All rights reserved
