今天是:2024年08月27日(星期二)
正在发生
2019年08月27日 | 【STM32H7教程】第12章 STM32H7的HAL库框架设计学习
发布者:dswecd 来源: eefocus关键字:STM32H7  HAL库  框架设计 手机看文章 扫描二维码
随时随地手机看文章
12.1 初学者重要提示
学习使用HAL库前,有必要对他们的基本设计框架有所了解,然后深入学习,效果更好。
为了方便调用,HAL库为各种外设基本都配了三套API,查询,中断和DMA。
12.2 HAL库的配置文件
HAL库有一个专门的配置文件叫stm32h7xx_hal_conf.h,这个文件里面有一个很重要的参数,就是HSE_VALUE,大家所设计板子使用的实际晶振大小一定要与这个数值一致。比如V7的外置晶振是25MHz,那么这里就务必配置宏定义为:
#define HSE_VALUE    ((uint32_t)25000000)
完整的代码如下:
/* ########################## Module Selection ############################## */
  * @brief This is the list of modules to be used in the HAL driver
#define HAL_MODULE_ENABLED
#define HAL_ADC_MODULE_ENABLED
#define HAL_CEC_MODULE_ENABLED
 /* 省略未写 */
/* ########################## Oscillator Values adaptation ####################*/
  * @brief Adjust the value of External High Speed oscillator (HSE) used in your application.
  *        This value is used by the RCC HAL module to compute the system frequency
  *        (when HSE is used as system clock source, directly or through the PLL).
#if !defined  (HSE_VALUE)
#define HSE_VALUE    ((uint32_t)25000000) /*!< Value of the External oscillator in Hz */
#endif /* HSE_VALUE */
#if !defined  (HSE_STARTUP_TIMEOUT)
  #define HSE_STARTUP_TIMEOUT    ((uint32_t)5000)   /*!< Time out for HSE start up, in ms */
#endif /* HSE_STARTUP_TIMEOUT */
  * @brief Internal  oscillator (CSI) default value.
  *        This value is the default CSI value after Reset.
#if !defined  (CSI_VALUE)
  #define CSI_VALUE    ((uint32_t)4000000) /*!< Value of the Internal oscillator in Hz*/
#endif /* CSI_VALUE */
  * @brief Internal High Speed oscillator (HSI) value.
  *        (when HSI is used as system clock source, directly or through the PLL).
#if !defined  (HSI_VALUE)
  #define HSI_VALUE    ((uint32_t)64000000) /*!< Value of the Internal oscillator in Hz*/
#endif /* HSI_VALUE */
  * @brief External Low Speed oscillator (LSE) value.
  *        This value is used by the UART, RTC HAL module to compute the system frequency
#if !defined  (LSE_VALUE)
  #define LSE_VALUE    ((uint32_t)32768) /*!< Value of the External oscillator in Hz*/
#endif /* LSE_VALUE */
#if !defined  (LSE_STARTUP_TIMEOUT)
  #define LSE_STARTUP_TIMEOUT    ((uint32_t)5000)   /*!< Time out for LSE start up, in ms */
#endif /* LSE_STARTUP_TIMEOUT */
  * @brief External clock source for I2S peripheral
  *        This value is used by the I2S HAL module to compute the I2S clock source
  *        frequency, this source is inserted directly through I2S_CKIN pad.
#if !defined  (EXTERNAL_CLOCK_VALUE)
  #define EXTERNAL_CLOCK_VALUE    12288000U /*!< Value of the External clock in Hz*/
#endif /* EXTERNAL_CLOCK_VALUE */
/* Tip: To avoid modifying this file each time you need to use different HSE,
   ===  you can define the HSE value in your toolchain compiler preprocessor. */
/* ########################### System Configuration ######################### */
  * @brief This is the HAL system configuration section
#define  VDD_VALUE                    ((uint32_t)3300) /*!< Value of VDD in mv */
#define  TICK_INT_PRIORITY            ((uint32_t)0x0F) /*!< tick interrupt priority */
#define  USE_RTOS                     0
/* #define  USE_SD_TRANSCEIVER           1U   */            /*!< use uSD Transceiver */
/* ########################### Ethernet Configuration ######################### */
#define ETH_TX_DESC_CNT         4  /* number of Ethernet Tx DMA descriptors */
#define ETH_RX_DESC_CNT         4  /* number of Ethernet Rx DMA descriptors */
#define ETH_MAC_ADDR0    ((uint8_t)0x02)
#define ETH_MAC_ADDR1    ((uint8_t)0x00)
#define ETH_MAC_ADDR2    ((uint8_t)0x00)
#define ETH_MAC_ADDR3    ((uint8_t)0x00)
#define ETH_MAC_ADDR4    ((uint8_t)0x00)
#define ETH_MAC_ADDR5    ((uint8_t)0x00)
/* ########################## Assert Selection ############################## */
  * @brief Uncomment the line below to expanse the "assert_param" macro in the
  *        HAL drivers code
/* #define USE_FULL_ASSERT    1 */
/* ################## SPI peripheral configuration ########################## */
  * @brief Used to activate CRC feature inside HAL SPI Driver
  *        Activated   (1U): CRC code is compiled within HAL SPI driver
  *        Deactivated (0U): CRC code excluded from HAL SPI driver
#define USE_SPI_CRC                   1U
/* Includes ------------------------------------------------------------------*/
  * @brief Include module's header file
#ifdef HAL_RCC_MODULE_ENABLED
  #include "stm32h7xx_hal_rcc.h"
#endif /* HAL_RCC_MODULE_ENABLED */
/* 省略未写 */
/* Exported macro ------------------------------------------------------------*/
#ifdef  USE_FULL_ASSERT
  * @brief  The assert_param macro is used for function's parameters check.
  * @param  expr: If expr is false, it calls assert_failed function
  *         which reports the name of the source file and the source
  *         line number of the call that failed.
  *         If expr is true, it returns no value.
  * @retval None
  #define assert_param(expr) ((expr) ? (void)0 : assert_failed((uint8_t *)__FILE__, __LINE__))
/* Exported functions ------------------------------------------------------- */
  void assert_failed(uint8_t* file, uint32_t line);
#else
  #define assert_param(expr) ((void)0)
#endif /* USE_FULL_ASSERT */
除了HSE_VALUE,下面几个也要作为了解:
  第72行,滴答定时器的优先级设置。这个优先级的设置至关重要。因为HAL库中各个外设驱动里面的延迟实现是基于此文件提供的时间基准。
如果在中断服务程序里面调用基于此时间基准的延迟函数HAL_Delay要特别注意,因为这个函数的时间基准是基于滴答定时器或者其他通用定时器实现,实现方式是滴答定时器或者其他通用定时器里面对变量计数。如此以来,结果是显而易见的,如果其他中断服务程序调用了此函数,且中断优先级高于滴答定时器,会导致滴答定时器中断服务程序一直得不到执行,从而卡死在里面。所以滴答定时器的中断优先级一定要比他们高。
另外这个时间基准既可以使用滴答定时器实现也可以使用通用的定时器实现,默认情况下是用的滴答定时器。
  第73行,当前HAL库还不支持RTOS方式。
  第74行,STM32H7的SDIO外接支持UHS-I 模式 (SDR12, SDR25, SDR50, SDR104和DDR50)的SD卡,需要1.8的电平转换器,此选项就是来使能此功能用的。
  第92行,用于使能断言功能,在HAL库的API里面都有用到,用来判断函数形参是否有效。默认情况下是关闭的。
  第126行,使能断言功能后,实际对应的代码位置。这里没有对函数void assert_failed(uint8_t* file, uint32_t line)做具体实现,大家可以根据自己的需求去实现,这里提供一个参考:
ST库函数使用了C编译器的断言功能,如果定义了USE_FULL_ASSERT,那么所有的ST库函数将检查函数形参
是否正确。如果不正确将调用 assert_failed() 函数,这个函数是一个死循环,便于用户检查代码。
关键字 __LINE__ 表示源代码行号。
关键字__FILE__表示源代码文件名。
断言功能使能后将增大代码大小,推荐用户仅在调试时使能,在正式发布软件是禁止。
用户可以选择是否使能ST固件库的断言供能。使能断言的方法有两种:
(1) 在C编译器的预定义宏选项中定义USE_FULL_ASSERT。
(2) 在本文件取消"#define USE_FULL_ASSERT    1"行的注释。
* 函 数 名: assert_failed
* 形    参:file : 源代码文件名称。关键字__FILE__表示源代码文件名。
*   line :代码行号。关键字 __LINE__ 表示源代码行号
* 返 回 值: 无
用户可以添加自己的代码报告源代码文件名和代码行号,比如将错误文件和行号打印到串口
printf("Wrong parameters value: file %s on line %drn", file, line) */
/* 这是一个死循环,断言失败时程序会在此处死机,以便于用户查错 */
while (1)
12.3 HAL库的时间基准
为了方便各种外设延迟的实现,HAL库专门搞了一个时间基准,默认来源是滴答定时器,也可以通过重定向使用其他定时器实现。相关函数全部集中在stm32h7xx_hal.c文件里面实现,关于这些函数在本教程的第16章有详细讲解。
12.4 HAL库的启动流程
这里通过V7板子初始化流程做个说明:
* 函 数 名: bsp_Init
* 功能说明: 初始化所有的硬件设备。该函数配置CPU寄存器和外设的寄存器并初始化一些全局变量。
*              只需要调用一次
* 形    参:无
* 返 回 值: 无
void bsp_Init(void)
    /* 配置MPU */
MPU_Config();
/* 使能L1 Cache */
CPU_CACHE_Enable();
       STM32H7xx HAL 库初始化,此时系统用的还是H7自带的64MHz,HSI时钟:
   - 调用函数HAL_InitTick,初始化滴答时钟中断1ms。
   - 设置NVIV优先级分组为4。
HAL_Init();
       配置系统时钟到400MHz
       - 切换使用HSE。
       - 此函数会更新全局变量SystemCoreClock,并重新配置HAL_InitTick。
SystemClock_Config();
bsp_InitKey();    /* 按键初始化,要放在滴答定时器之前,因为按钮检测是通过滴答定时器扫描 */
bsp_InitTimer();  /* 初始化滴答定时器 */
bsp_InitUart(); /* 初始化串口 */
bsp_InitExtIO(); /* 初始化FMC总线74HC574扩展IO. 必须在 bsp_InitLed()前执行 */
bsp_InitLed();    /* 初始化LED */
bsp_InitLPTIMOutPWM(); /* 低功耗定时器PWM输出 */
  第13 – 16行,配置MPU和使能Cache,对于H7而已,这两个函数要优先执行,因为Flash速度,SRAM速度跟CPU和TCM有些差距的,所以要使能Cache。而不同存储区的Cache策略要通过MPU分别进行配置。
  第23行,调用函数HAL_Init时,系统依然使用的64MHz HSI时钟,这点要特别注意。此函数会调用函数HAL_InitTick,初始化滴答时钟中断1ms,并设置NVIV优先级分组为4。
这里就隐含了一个知识点,就是它会开启滴答定时器中断,如果用户也要使用滴答定时器中断,此问题就要引起注意,我们的bsp_timer.C文件解决办法如下:
* 函 数 名: SysTick_Handler
* 功能说明: 系统嘀嗒定时器中断服务程序。启动文件中引用了该函数。
* 形    参:  无
* 返 回 值: 无
[1] [2]
关键字:STM32H7  HAL库  框架设计 引用地址:【STM32H7教程】第12章 STM32H7的HAL库框架设计学习
上一篇:【STM32H7教程】第13章 STM32H7启动过程详解
下一篇:【STM32H7教程】第11章 STM32H7移植SEGGER的硬件异常分析
在电动和混合动力汽车中,需要一种方法将高压电池与车辆的其他部分断开连接。专门设计的大电流继电器(接触器)历来一直是执行此功能的首选方案。此继电器的设计必须支持在负载下断开连接,而不受损坏。这是通过使用带有真空封装触点的继电器来实现的。这些接触器通常充满惰性气体,包围触点以消除空气。通常,在高压电池系统中,需要三个接触器:一个用于两...
上个月底,上海贝岭发布2019半年度业绩预告,预计2019年上半年实现归属于上市公司股东的净利润为14,383.08万元左右,同比增加122.27%左右。然而,实际营收却存在不小的差异。上海贝岭日前正式披露2019年半年报,公司上半年营收为3.93亿元,同比增长1.79%;净利为1.44亿元,同比增长96%。不过,上半年,上海贝岭非经常性损益收入为8020万元,占其2019半年度...
  工业机器人控制系统的组成   控制:控制系统的调度指挥机构。一般为微型机、微处理器有32位、64位等,如奔腾系列以及其他类型CPU。   示教盒:示教机器人的工作轨迹和参数设定,以及所有人机交互操作,拥有自己独立的CPU以及存储单元,与主计算机之间以串行通信方式实现信息交互。   操作面板:由各种操作按键、状态构成,只完成基本功能操...
台积电涨价传闻持续发酵,加上此前联电等也都传出再次涨价的消息,引发业内对下游设计厂毛利率的担忧,但台媒分析指出,不同产品情况不同,如电源管理IC和MCU厂向下游转嫁成本问题不大。钜亨网报道指出,部分电源管理IC厂近期陆续收到涨价通知,增加的成本已在新订单上反映给客户,大多数可以完全转嫁,体现需求仍然稳固,下半年毛利率有望维持第二季度的...
DSP集成开发与应用实例 张雄伟.rar
DSP集成开发与应用实例 张雄伟.rar 电子书,要用超星阅览器看…
查看全部问答∨
电信设备的功率测量电路(转载)
本文讨论如何监测采用两个独立输入(-48V(A)和-48V(B))的电信设备的输入电压和电流。每个独立输入的电压范围不窄于-42.5V~-56.5V,而且处于冗余考虑,对这两个独立输入在模块上进行了”或”操作。从维护和支持的角度出发,测量输入电压值、输入是否 ...…
查看全部问答∨
74系列电路与CMOS系列电路的点滴差异
前不久,需要设计一个延时5秒钟的定时电路,设计思路是定下来了,但是在实验时出现了问题。     下图就是需要实施的电路。     电路的工作过程是:利用三极管的开关特性延时控制一个光耦4N25。     具体原理: ...…
查看全部问答∨
求助
哪位大侠能给我帮忙画CC2430的元件库啊&nbsp; 小弟我才疏学浅&nbsp;&nbsp; 实在是画不出来了&nbsp; CC2430的图片在&nbsp; 附件中…
查看全部问答∨
tcpmp如何制作播放的可视化效果
能不能调用MediaPlayer的Visualization模块mpvis.dll就能实现,或者其它的方法 …
查看全部问答∨
问下怎么写驱动的啦
我现在要写一个信号接收器的驱动 比如:在考场放置很多信号接收器,写个驱动后在电脑上就可以观察所有的信号接收器的情况。 我就想问像这种驱动使用什么写的? 用的是什么技术? 最好能说些看些什么书? 因为前面没学过这种东西,希望高手指定 ...…
查看全部问答∨
软键盘问题
自己写了一个软键盘程序,是通过keybd_event模拟发送软键盘消息的,可是编辑框却收不到软键盘的输入,但编辑框所在的对话框却可以接收到象回车键、退出键等消息,所以我想是不是编辑框没有输入焦点造成的,可是同样的代码在模拟器上却可以实现输入 ...…
查看全部问答∨
求16QAM里面的星座映射代码
最近在用FPGA实现16QAM,由于是新手,不会用Verilog编写里面的星座映射,求大侠帮忙!万分感谢!…
查看全部问答∨
分立电阻器检定测试系统的配置
分立电阻器在最后的封装状态要进行单点通过/失败测试,这对确保产品符合制造商性能指标至关重要,而且可以在出货前识别劣质电阻器以及轻微不良的电阻器。通常要对电阻器进行两项测试:电阻器电压系数测试以及电阻器公差带测试。为了确保产品质量 ...…
查看全部问答∨
Cortex-M0+, 到底“+”了什么(有视频,有中文文档)
也许大家已经发现了,飞思卡尔Kinetis L系列采用的内核是Cortex-M0+,而不是Cortex-M0。这个小小的加号到底增加了什么呢?小小视频讲的一清二楚。 $(\'flv_ERb\').innerHTML=(AC_FL_RunContent(\'width\', \'500\', \'height\', \'375\', \'allowNe ...…
查看全部问答∨
小广播
设计资源 培训 开发板 精华推荐
最新单片机文章
何立民专栏 单片机及嵌入式宝典
换一换 更多 相关热搜器件
随便看看
电子工程世界版权所有 京ICP证060456号 京ICP备10001474号-1 电信业务审批[2006]字第258号函 京公网安备 11010802033920号 Copyright © 2005-2024 EEWORLD.com.cn, Inc. All rights reserved
