以下为.h文件:
#ifndef __MAX7219_H
#define __MAX7219_H
#include "stm8s_gpio.h"
#include "stm8s.h"
#include #include #include "tim1.h" #define uchar unsigned char #define uint unsigned int #define count 8 void Init_MAX7219(void); void MAX7219_Init(void); void Write_Max7219_byte(uchar Data); void Write_Max7219(u8 address1,u8 dat1,u8 address2,u8 dat2); #define High 1 #define Low 0 #define Din(High_Low) if(High_Low == 0)GPIO_WriteLow(GPIOC, GPIO_PIN_4); else GPIO_WriteHigh(GPIOC, GPIO_PIN_4); #define Cs(High_Low) if(High_Low == 0)GPIO_WriteLow(GPIOC, GPIO_PIN_3); else GPIO_WriteHigh(GPIOC, GPIO_PIN_3); #define Clk(High_Low) if(High_Low == 0)GPIO_WriteLow(GPIOC, GPIO_PIN_2); else GPIO_WriteHigh(GPIOC, GPIO_PIN_2); #endif 以下为.c文件: #include "main.h" void Init_MAX7219(void) { GPIO_Init(GPIOC, GPIO_PIN_4, GPIO_MODE_OUT_PP_HIGH_FAST);//PC4高速推挽输出高电平控制DIN GPIO_Init(GPIOC, GPIO_PIN_3, GPIO_MODE_OUT_PP_HIGH_FAST);//PC3高速推挽输出高电平控制CS GPIO_Init(GPIOC, GPIO_PIN_2, GPIO_MODE_OUT_PP_HIGH_FAST);//PC2高速推挽输出高电平控制CLK } //-------------------------------------------- //功能:向MAX7219(U3)写入字节 //入口参数:DATA //出口参数:无 //说明: void Write_Max7219_byte(uchar Data) { uchar i; Cs(0); for(i=8;i>=1;i--) { Clk(0); if(Data&0x80) { Din(1); } else { Din(0); } Data=Data<<1; Clk(1); delay_us(10); Clk(0); } } //------------------------------------------- //功能:向MAX7219写入数据 //入口参数:address、dat //出口参数:无 //说明: void Write_Max7219(u8 address1,u8 dat1,u8 address2,u8 dat2) { Cs(0); Write_Max7219_byte(address1); //写入地址,即数码管编号 Write_Max7219_byte(dat1); //写入数据,即数码管显示数字 Write_Max7219_byte(address2); //写入地址,即数码管编号 Write_Max7219_byte(dat2); //写入数据,即数码管显示数字 nop(); Cs(1); } void MAX7219_Init(void) { /* Write_Max7219(0x09, 0x00,0x09, 0x00); //译码方式:BCD码 Write_Max7219(0x0a, 0x03,0x0a, 0x03); //亮度 Write_Max7219(0x0b, 0x07,0x0b, 0x07); //扫描界限;8个数码管显示 Write_Max7219(0x0c, 0x01,0x0c, 0x01); //掉电模式:0,普通模式:1 Write_Max7219(0x0f, 0x00,0x0f, 0x00); //显示测试:1;测试结束,正常显示:0 */ u8 i; Cs(0); for(i=0;i Write_Max7219_byte(0x09); //译码方式:BCD码 Write_Max7219_byte(0x00); } Cs(1); nop(); Cs(0); for(i=0;i Write_Max7219_byte(0x0a); //亮度 Write_Max7219_byte(0x03); } Cs(1); nop(); Cs(0); for(i=0;i Write_Max7219_byte(0x0b); // //扫描界限;8个数码管显示 Write_Max7219_byte(0x07); } Cs(1); nop(); Cs(0); for(i=0;i Write_Max7219_byte(0x0c); // //掉电模式:0,普通模式:1 Write_Max7219_byte(0x01); } Cs(1); nop(); Cs(0); for(i=0;i Write_Max7219_byte(0x0f); //显示测试:1;测试结束,正常显示:0 Write_Max7219_byte(0x00); } Cs(1); nop(); }
上一篇:STM8S TM1650芯片控制程序
下一篇:单片机常用芯片MAX7219驱动
对于电子消毒柜电路,网友可能的问题涉及多个方面,包括故障排查、日常维护、使用注意事项等。以下是一些可能的问题及详细回答:
一、故障排查类问题
1. 消毒柜通电后跳闸怎么办?
回答:
消毒柜通电后跳闸可能是由电路短路引起的。首先,检查电源插座的火线(L)、零线(N)、地线(E)是否接线正确。其次,按照消毒柜上的线路图检查柜内线路接线是否正确,以及线路绝缘层是否被破坏(如被螺丝钻破、被金属边角划破等)。如果以上检查均正常,可能是电源板或继电器等部件损坏,建议联系专业维修人员进行检查和更换。
2. 消毒柜插上电源后无法启动,指示灯不亮怎么办?
回答:
消毒柜无法启动且指示灯不亮,可能是由以下原因造成:电源插座无电或接触不良、熔断器烧坏、电源线与机体接触不良或断路、变压器烧坏或断路、电路板烧坏、继电器失灵等。解决方法包括检查电源插座、更换熔断器、检查并修复线路、更换电路板或继电器等。如果问题依然存在,建议联系专业维修人员进行检查。
二、日常维护类问题
1. 消毒柜需要定期清洁哪些部位?
回答:
消毒柜需要定期清洁的部位包括柜体内部、层架、门封条以及散热孔等。清洁时,应使用柔软的布或海绵,避免使用腐蚀性强的清洁剂。同时,要注意不要将水溅入电路板等电子元件区域,以免造成短路或损坏。
2. 消毒柜的电源线应该如何保养?
回答:
消毒柜的电源线应定期检查是否老化或破损,如有发现应及时更换。在使用过程中,应避免电源线过度弯折或受到重物压迫,以免影响其使用寿命和安全性。此外,电源线应远离高温、潮湿和腐蚀性强的环境,以确保其绝缘性能不受影响。
三、使用注意事项类问题
1. 消毒柜在使用时需要注意哪些安全问题?
回答:
消毒柜在使用时需要注意以下安全问题:
- 确保电源插座接地良好,避免漏电危险。
- 不要将易燃易爆物品放入消毒柜内,以免发生火灾或爆炸。
- 在使用过程中,应避免频繁开关柜门,以免影响消毒效果和能耗。
- 使用完毕后,应及时关闭电源并拔掉插头,以节约能源和延长设备使用寿命。
2. 消毒柜是否可以一直插电使用?
回答:
消毒柜是否可以一直插电使用取决于用户的使用情况和需求。如果用户经常使用消毒柜且没有其他特殊需求,可以保持电源连接;如果用户不经常使用消毒柜或者有其他特殊需求(如节约能源、避免设备老化等),建议在使用前提前通电,并在非使用状态下拔掉电源。此外,为了确保安全,插座应具备防水、防漏电等功能。
综上所述,对于电子消毒柜电路的问题,网友可能关注故障排查、日常维护和使用注意事项等方面。通过了解这些问题的解决方法和注意事项,可以更好地使用和维护消毒柜,确保其正常运行和延长使用寿命。
随着业务的不断拓展和市场的不断扩大,屹晶微逐渐意识到与合作伙伴建立长期战略合作关系的重要性。于是,在2023年,他们与电子产业一站式服务平台华秋电子达成了授权代理合作。这一合作不仅为屹晶微提供了更广阔的市场渠道和客户资源,也为其未来的发展奠定了坚实的基础。
在合作过程中,华秋电子为屹晶微提供了全方位的支持和服务。他们共同推广屹晶微的芯片产品,为客户提供更优质的解决方案和服务。同时,华秋电子还利用自身的技术优势和渠道优势,帮助屹晶微拓展海外市场,提升品牌知名度和影响力。
以上两个故事只是屹晶微在电子行业中发展起来的一部分。他们的发展历程充满了挑战和机遇,但黄米龙和他的团队始终保持着坚定的信念和不懈的努力,为中国的芯片产业做出了积极的贡献。
随着公司技术的成熟和知名度的提升,Computer Conversions Corp开始将目光投向国际市场。公司派出专业的市场拓展团队,深入欧洲、亚洲等多个地区进行市场调研。经过一系列精准的市场分析和产品定位,公司成功地将产品推向了全球市场。这一过程中,他们不仅赢得了众多国际客户的信赖,还通过与当地企业的合作,进一步提升了品牌的影响力和市场份额。
面对电子行业供应链复杂多变的挑战,Gem Asia积极实施供应链优化和数字化转型战略。公司引入先进的ERP系统和物联网技术,实现了从原材料采购、生产制造到物流配送的全链条数字化管理。这一举措不仅提高了生产效率和产品质量,还降低了运营成本,增强了企业的市场竞争力。同时,Gem Asia还加强了与上下游企业的合作,共同构建了一个高效协同的供应链生态系统。
固驰电子深知产品质量是企业生存之本,因此始终将品质控制放在首位。公司不仅建立了完善的质量管理体系,还通过了ISO9001:2015质量管理体系认证和美国UL产品认证,这标志着固驰电子的产品质量达到了国际先进水平。此外,公司还积极申请专利,目前已拥有50项国家专利,进一步巩固了其在行业内的技术领先地位。
Attenuators are devices used to adjust signal levels, to control impedance mismatch and to isolate circuit stages.… 查看全部问答∨ |
【手机拍摄】 图文:孤独的天狗 初到成都,阴霾的天空下让我找不着北了。打开旅游交通图,然后按照自己预想的计划,背着硕大的行囊找到了住的地方——文殊院附近——此后换了三个地方,都是围着文殊院——要不是文武路,要不 ...… 查看全部问答∨ |
(1)时钟偏差要加以控制 在同步电路里,时钟信号要连接到所有的寄存器,触发器以及锁存器等器件上。这些巨大的负载就象一个大电容加在时钟线上,再加上时钟线本身的分布电容和电阻,这样时钟线就象分布的RC线。由于RC线的延时是线长的函数,这样 ...… 查看全部问答∨ |
【SynPlify技术问题】综合约束与ISE的周期约束的区别 一个给综合软件参考,一个给布局布线操作作参考,当然,这个区别只存在于你单独用综合软件综合,之后再用ISE跑布局布线的情况下 (如果直接用ISE的XST做综合的话就只用作一次约束)… 查看全部问答∨ |
在pc上可以直接使用capDriverConnect(m_hCapWnd,0)使用摄像头, 请问在wince中如果使用摄像头? 在模拟器中,手机应该自带摄像头的,但是模拟器中应该怎么使用? 在线等,分不多,100分,需要完整点,谢谢!… 查看全部问答∨ |
请教一下,我发现在2440init.s里面复制NAND到SDRAM是用 CopyProgramFromNand()如下: [ [color=#FF0000]{TRUE} nand_boot_beg bl CopyProgramFromNand[/color] &nb ...… 查看全部问答∨ |
同志们帮俺看看吧,按又遇到难题了,自己能力有限,只能求救了,阿米托佛…… 我用keil c编写程序后出现一系列警告, send_peli.c(99):warning c258:\'num2\':mspace on parameter ignored ***warning l16:uncalled segment,ignored for overlay ...… 查看全部问答∨ |
我想用platform builder 5开发一个WINCE5 的directshow的filter。 我做了一个CE系统,之后在该系统下建立了一个DLL工程,并且把PB下的FILTER的例子文件加入了工程,并且按照MSDN的文档,配置链接了Strmbase.lib,Strmiids.lib,Ole32.lib,Ole32au ...… 查看全部问答∨ |
