今天是:2024年11月15日(星期五)
正在发生
2019年11月15日 | ARM11 S3C6410 的地址表
发布者:数字翻飞 来源: 51hei关键字:ARM11  S3C6410  地址表 手机看文章 扫描二维码
随时随地手机看文章
参考:1)《ARM1176 JZF-S Technical Reference Manual》:
Chapter 3 System Control Coprocessor
Chapter 6 Memory Management Unit
2)u-boot源码:
u-boot-x.x.x/cpu/s3c64xx/start.S
u-boot-x.x.x/board/samsung/smdk6410/lowlevel_init.S
1. ARMv6 MMU简述
1)MMU由协处理器CP15控制;
2)MMU功能:地址映射(VA->PA),内存访问权限控制;
3)虚拟地址到物理地址的转换过程:Micro TLB->Main TLB->Page Table Walk
参考《ARM1176 JZF-S Technical Reference Manual》6.3节,Memory access sequence
摘录参考手册中的一段描述:
When the processor generates a memory access, the MMU:
1. Performs a lookup for a mapping for the requested virtual address and current ASID and
   current world, Secure or Non-secure, in the relevant Instruction or Data MicroTLB.
2. If step 1 misses then a lookup for a mapping for the requested virtual address and current
   ASID and current world, Secure or Non-secure, in the main TLB is performed.
If no global mapping, or mapping for the currently selected ASID, or no matching NSTID, for
the virtual address can be found in the TLBs then a translation table walk is automatically
performed by hardware, unless Page Table Walks are disabled by the PD0 or PD1 bits in the
TTB Control register, that cause the processor to return a Section Translation fault. See
Hardware page table translation on page 6-36.
If a matching TLB entry is found then the information it contains is used as follows:
1. The access permission bits and the domain are used to determine if the access is permitted.
   If the access is not permitted the MMU signals a memory abort, otherwise the access is
   enabled to proceed. Memory access control on page 6-11 describes how this is done.
2. The memory region attributes control the cache and write buffer, and determine if the
   access is Secure or Non-secure cached, uncached, or device, and if it is shared, as Memory
   region attributes on page 6-14 describes.
3. The physical address is used for any access to external or tightly coupled memory to
   perform Tag matching for cache entries.
2. 址映射过程详述
参考《ARM1176 JZF-S Technical Reference Manual》6.11节,Hardware page table translation
关于页表:ARMv6的MMU进行地址映射时涉及到两种页表,一级页表(first level page table)和二级页表(coarse page table)。
关于映射方式:映射方式有两种,段映射和页映射。段映射只用到一级页表,页映射用到一级页表和二级页表。
关于映射粒度:段映射的映射粒度有两种,1M section和16M supersection;页映射的映射粒度也有两种,4K small page和64K large page。
硬件在做地址转换时,如何知道当前是什么映射方式以及映射粒度是多少呢?
这些信息可以从页表的入口描述符中获得。
一级页表的入口描述符(first-level descriptor)格式如下:
第[1:0]位决定映射方式:
[1:0]=10b时,是段映射,此时只需作一级映射,描述符的最高12或8位存放的是段基址;
[1:0]=01b时,是页映射,此时虚拟地址转换为物理地址需要经历二级映射,描述符的最高22位存放的是二级页表的物理地址;
第[18]位决定段映射的粒度:
[18]=0b时,映射粒度为1M,描述符的最高12位存放段基址;
[18]=1b时,映射粒度为16M,描述符的最高8位存放段基址;
当映射方式为页映射时,我们用到二级页表,二级页表的入口描述符(second-level descriptor)格式如下:
第[1:0]位决定页映射的映射粒度:
[1:0]=10b或11b时,映射粒度为4KB,描述符的最高20位为页基址;
[1:0]=01b时,映射粒度为64KB,描述符的最高16位为页基址;
下面分4种情况对地址映射过程做详细描述:
1)段映射,映射粒度为1M
2)段映射,映射粒度为16M
3)页映射,映射粒度为4K
4)页映射,映射粒度为64K
2.1段映射,映射粒度为1M
当映射方式为段映射,且映射粒度为1M时,映射图如下:
虚拟地址到物理地址的映射过程如下:
虚拟地址的[31:20]位存放一级页表的入口index,[19:0]位存放段偏移;
从TTBR(translation table base register,协处理器CP15中的一个寄存器,用于存放一级页表的基址)寄存器中获取一级页表的基址;
一级页表基址+ VA[31:20] = 该虚拟地址对应的页表描述符的入口地址;
页表描述符的[31:20]位为该虚拟地址对应的物理段基址;
物理段基址+ VA[19:0]段偏移= 物理地址
由映射图可知,一个虚拟地址可以索引2^12个一级页表入口,每个入口映射2^20大小的内存,故虚拟地址可以映射的最大物理内存为:2^12 * 2^20,即4G。
2.2 段映射,映射粒度为16M
当映射方式为段映射,且映射粒度为16M时,映射图如下:
虚拟地址到物理地址的映射过程如下:
虚拟地址的[31:24]位存放一级页表的入口index,[23:0]位存放段偏移;
一级页表基址+ VA[31:24] = 该虚拟地址对应的页表描述符的入口地址;
页表描述符的[31:24]位为该虚拟地址对应的物理段基址;
物理段基址+ VA[23:0]段偏移= 物理地址
由映射图可知,一个虚拟地址可以索引2^8个一级页表入口,每个入口映射2^24大小的内存,故虚拟地址可以映射的最大物理内存为:2^8 * 2^24,即4G。
2.3 页映射,映射粒度为4K
当映射方式为页映射,且映射粒度为4K时,映射图如下:
虚拟地址到物理地址的映射过程如下:
虚拟地址的[31:20]位存放一级页表的入口index,[19:12]位存放二级页表的入口index,[11:0]位存放页偏移;
一级页表基址+ VA[31:20] = 一级页表描述符的入口地址;
一级页表描述符的[31:10]位存放二级页表的基址;
二级页表基址+ VA[19:12] = 二级页表描述符的入口地址;
二级页表描述符的[31:12]位存放该虚拟地址在内存中的物理页基址;
物理页基址+ VA[11:0]页偏移= 物理地址
由映射图可知,一个虚拟地址可以索引2^12个一级页表入口,每个一级页表入口指向的二级页表最大可以有2^8个二级页表入口,每个二级页表入口映射2^12大小的内存,故虚拟地址可以映射的最大物理内存为:2^12 * 2^8 * 2^12 ,即4G。
2.4 页映射,映射粒度为64K
当映射方式为页映射,且映射粒度为64K时,映射图如下:
虚拟地址到物理地址的映射过程如下:
虚拟地址的[31:20]位存放一级页表的入口index,[19:16]位存放二级页表的入口index,[15:0]位存放页偏移;
二级页表基址+ VA[19:16] = 二级页表描述符的入口地址;
二级页表描述符的[31:16]位存放该虚拟地址在内存中的物理页基址;
物理页基址+ VA[15:0]页偏移= 物理地址
由映射图可知,一个虚拟地址可以索引2^12个一级页表入口,每个一级页表入口指向的二级页表最大可以有2^4个二级页表入口,每个二级页表入口映射2^16大小的内存,故虚拟地址可以映射的最大物理内存为:2^12 * 2^4 * 2^16 ,即4G。
2.5 地址映射总图
《ARM1176 JZF-S Technical Reference Manual》中有一张对上述四种映射情况的汇总图:
3. 关于一级页表基址
参考《ARM1176 JZF-S Technical Reference Manual》6.12 MMU descriptors
ARMv6中有两个协处理器寄存器用来存放一级页表基地址,TTBR0和TTBR1。操作系统把虚拟内存划分为内核空间和用户空间,TTBR0存放用户空间的一级页表基址,TTBR1存放内核空间的一级页表基址。
In this model, the virtual address space is divided into two regions:
? 0x0 -> 1<<(32-N) that TTBR0 controls
? 1<<(32-N) -> 4GB that TTBR1 controls.
N的大小由TTBCR寄存器决定。0x0 -> 1<<(32-N)为用户空间,由TTBR0控制,1<<(32-N) -> 4GB为内核空间,由TTBR1控制。
N的大小与一级页表大小的关系图如下:
操作系统为用户空间的每个进程分配各自的页表,即每个进程的一级页表基址是不一样的,故当发生进程上下文切换时,TTBR0需要被存放当前进程的一级页表基址;TTBR1中存放的是内核空间的一级页表基址,内核空间的一级页表基址是固定的,故TTBR1中的基址值不需要改变。
4.  u-boot中MMU初始化代码分析
u-boot中的MMU地址映射方式为段映射,映射粒度为1M,只用到一级页表。
start.S中的MMU初始化代码如下:
#ifdef CONFIG_ENABLE_MMU
enable_mmu:
    /* enable domain access */
    ldr    r5, =0x0000ffff
    mcr    p15, 0, r5, c3, c0, 0        @ load domain access register
    /* Set the TTB register */
    ldr    r0, _mmu_table_base
    ldr    r1, =CFG_PHY_UBOOT_BASE
    ldr    r2, =0xfff00000
    bic    r0, r0, r2
    orr    r1, r0, r1
    mcr    p15, 0, r1, c2, c0, 0
    /* Enable the MMU */
mmu_on:
    mrc    p15, 0, r0, c1, c0, 0
    orr    r0, r0, #1            /* Set CR_M to enable MMU */
    mcr    p15, 0, r0, c1, c0, 0
    nop
    nop
    nop
    nop
#endif
_mmu_table_base:
    .word mmu_table
#endif
对协处理器的寄存器操作参考:
《ARM1176 JZF-S Technical Reference Manual》Chapter 3 System Control Coprocessor
MMU初始化过程中有一步是将页表基址(CFG_PHY_UBOOT_BASE + mmu_table)存入TTBR0中,在lowlevel_init.S中可以看到对页表的初始化:
* MMU Table for SMDK6400
    /* form a first-level section entry */
.macro FL_SECTION_ENTRY base,ap,d,c,b
    .word (ase << 20) | (ap << 10) |
          (d << 5) | (1<<4) | (c << 3) | ( << 2) | (1<<1)
.endm
.section .mmudata, 'a'
    .align 14
    // the following alignment creates the mmu table at address 0x4000.
    .globl mmu_table
mmu_table:
    .set __base,0
    // 1:1 mapping for debugging
    .rept 0xA00
    FL_SECTION_ENTRY __base,3,0,0,0
    .set __base,__base+1
    .endr
    // access is not allowed.
    .rept 0xC00 - 0xA00
    .word 0x00000000
    .endr
    // 128MB for SDRAM 0xC0000000 -> 0x50000000
    .set __base, 0x500
    .rept 0xC80 - 0xC00
    FL_SECTION_ENTRY __base,3,0,1,1
    .endr
    .rept 0x1000 - 0xc80
    .word 0x00000000
    .endr
#endif
下面对页表的初始化代码作详细解释:
.endm
定义一个宏FL_SECTION_ENTRY用来设置页表入口描述符,base即物理基址,ap即access permission,d即domain,c即cacheable,b即bufferable。
内存访问控制和段属性相关描述请参考:
《ARM1176 JZF-S Technical Reference Manual》6.6 Memory access control和6.7 Memory region attributes。
    .align 14
定义一个名为mmudata的段,段属性为“a”,allowable,该段16K对齐。从u-boot.lds中可以看到,u-boot的各个段在内存中的分布依次为:.text,.rodata,.data,.got,.u_boot_cmd,.mmudata,.bss。
为什么页表是16K对齐呢?
在上一节我们讲过:有两个寄存器TTBR0和TTBR1用来存放一级页表基址,操作系统把虚拟地址空间划分为用户空间和内核空间,0x0 -> 1<<(32-N)为用户空间,由TTBR0控制,1<<(32-N) -> 4GB为内核空间,由TTBR1控制,N的大小由TTBCR寄存器决定。由于u-boot主要作用是硬件初始化和引导操作系统,所以没有必要对虚拟地址空间进行划分,即N=0,整个虚拟地址空间由TTBR0控制,TTBR0的格式如下:
N=0时,[31:14]存放页表基址,即一级页表的基址为([31:14]<<14),2^14为16K。
    .set __base,0
    .rept 0xA00
    .endr
对虚拟地址0x0-0xA0000000作平行映射(flat mapping),即把虚拟地址0x0-0xA0000000映射到物理地址0x0-0xA0000000。
    .rept 0xC00 - 0xA00
    .word 0x00000000
    .endr
不对虚拟地址空间0xA0000000-0xC0000000作映射,即禁止访问虚拟地址空间0xA0000000-0xC0000000。
    .set __base, 0x500
    .rept 0xC80 - 0xC00
    .endr
把虚拟地址空间0xC0000000-0xC8000000映射到物理地址空间0x50000000-0x58000000,0x50000000-0x58000000为sdram的地址空间,此时sdram有128M。
    .word 0x00000000
    .endr
不对虚拟地址空间0xc8000000-0xffffffff作映射,即禁止访问虚拟地址空间0xc8000000-0xffffffff。
关键字:ARM11  S3C6410  地址表 引用地址:ARM11 S3C6410 的地址表
上一篇:ADC&&触摸屏实验及心得体会
下一篇:ARM9的寄存器
集微网消息,11月14日,日本半导体商社INNOTECH宣布,与显示器制造设备企业V-Technology展开业务合作。双方将携手向中国企业销售INNOTECH相关的半导体存储器和图像传感器用测试设备。将争取在政府主导下加快培育半导体产业的中国需求。        V-Technology于今年4月在中国与当地企业共同成立了生产和销售制造设备的合资公司。INNOTECH将受让V-Tec...
据外媒消息报道,大众汽车官方展示了用于ID.3车型上的电动动力总成,并命名为APP 310电驱动器。此前在2019年法兰克福车展上,大众汽车从零开始专门为电动汽车提供支持的高度灵活的体系结构,它包装了装在大众汽车内的最先进的电动动力总成,动力总成包括了电机控制器、一台永磁同步电机以及一套单速变速箱。驱动电机的最大功率为150kW(200Ps),峰值扭矩...
三星和华为等智能手机公司开始进入第二代可折叠手机的时代,而苹果仍在开发其首款可折叠 iPhone。近日有不少报道指出,苹果正在稳步推进可折叠手机的开发。现在,一份新的报告表明,当苹果推出可折叠的 iPhone 时,它将停售 iPad mini 这一产品类别。其背后的原因是,即将到来的可折叠 iPhone 将是 iPhone 和 iPad mini 的结合体,并将运行 ...
日前,硅宝科技公告表示,将在四川彭山经济开发区设立全资子公司硅宝科技(眉山)新能源科技有限公司建设1万吨/年锂电池用硅碳负极材料、4万吨/年专用粘合剂生产基地、锂电材料研发中心。据了解,项目计划总投资5.6亿元,其中固定资产投资人民币4.6亿元。公开资表显示,硅宝科技成立于1998年,主要从事有机硅密封胶等新材料的研发、生产及销售,2009年在中...
简易无线话筒
如果你的收录机有调频接收波段,不妨动手制作一个无线话筒,可给你的生活增添不少乐趣。这里介绍一个无线话筒,在开阔地区有效距离约100 m左右。…
查看全部问答∨
这样的情况是装减速机好,还是不装好呢?
现有一设备用伺服电机驱动丝杆带动平台做往复运动,现算出达到平台最高运动速度,丝杆的转速需要500转每分钟,伺服电机的额定转速为3000转每分钟. 请问一下各位这时是电机直连丝杆好呢,还是电机通过1:4减速机减速后连接丝杆好呢,电机直联也能驱动,但 ...…
查看全部问答∨
急求DSP控制写CF卡的程序代码,相关资料也可以,谢谢帮助!
要用DSP控制向CF卡写数据,具体流程是什么?请高手指点 急求DSP控制写CF卡的程序代码,相关资料也可以,谢谢帮助! 我的邮箱:haolinchen_0@126.com…
查看全部问答∨
在tf卡上CeMountDBVol为什么会出错?
{                         CeMountDBVol(&g_guidDB, szPath, …
查看全部问答∨
请问哪位大大有TMS320F2812的SCI初始化代码啊?
老师要我写一个SCI的初始化代码,我看了这个芯片的文档后,还是感觉云里雾里的,后天就要交了,着急死了。。。 一直弄不明白TXWAKE、WUT这两个信号到底是干嘛用的。。。求牛人解救啊。。。…
查看全部问答∨
JTAG烧程序
小弟刚刚开始接触MSP430,请问斑主MSP-FET430P140可否对MSP430F149通过JTAG口直接烧程序进去,谢谢。…
查看全部问答∨
点火线圈不良引起间歇性断火
故障现象:一辆上海通用五菱LZW6360Ei7型微型客车,配备电喷发动机。该车出现严重的加速无力、“缺缸”现象,以致无法正常行驶。据车主反映,每次更换火花塞后,车辆能正常行驶1000km左右,然后就出现高速“闯车”现象,而且越来越严重,最后导致车 ...…
查看全部问答∨
交换开发板
本帖最后由 ddllxxrr 于 2016-1-7 17:04 编辑 我现在想用lm3s8962或者TMS320F交换lpc2000系列开发板。 QQ:81960697 本站强荐:185娱乐≌城.足球≌真_人.彩票齐全≌手机可投≌注任何游戏. 首次开户送10元.首存送58元.信誉绝对保证185.cc …
查看全部问答∨
求一篇dcdc直流开关电源的设计论文
具体要求 1、 开关电源与线性电源进行对比,总结开关电源的优点。 2、 在对开关电源的整体结构进行了介绍的基础上,对开关电源的主回路和控制回路进行设计:在主回路中整流电路采用单相桥式、功率转换电路采用单端正激功率转换电路、采用增加副边 ...…
查看全部问答∨
LPC1114如何加密
rt, 我使用LPCxpresso 编译器。 #define NO_CRP          0xFFFFFFFF #define NO_ISP_MAGIC    0x4E697370 #define CRP1_MAGIC      0x12345678 #define CRP2_MAGIC    ...…
查看全部问答∨
小广播
设计资源 培训 开发板 精华推荐
最新单片机文章
何立民专栏 单片机及嵌入式宝典
电子工程世界版权所有 京ICP证060456号 京ICP备10001474号-1 电信业务审批[2006]字第258号函 京公网安备 11010802033920号 Copyright © 2005-2024 EEWORLD.com.cn, Inc. All rights reserved
