今天是:2024年08月27日(星期二)
正在发生
2020年08月27日 | PIC16F887 串口 LCD1602 按键
发布者:TranquilVibes 来源: eefocus关键字:PIC16F887  串口  LCD1602  按键 手机看文章 扫描二维码
随时随地手机看文章
#include
#include
#include
#include
#define uchar unsigned char
#define uint unsigned int
/* CONFIG1 */
#pragma config FOSC = XT        /* Oscillator Selection bits (XT oscillator: Crystal/resonator on RA6/OSC2/CLKOUT and RA7/OSC1/CLKIN) */
#pragma config WDTE = OFF       /* Watchdog Timer Enable bit (WDT disabled and can be enabled by SWDTEN bit of the WDTCON register) */
#pragma config PWRTE = OFF      /* Power-up Timer Enable bit (PWRT disabled) */
#pragma config MCLRE =ON        /* RE3/MCLR pin function select bit (RE3/MCLR pin function is digital input, MCLR internally tied to VDD) */
#pragma config CP = OFF         /* Code Protection bit (Program memory code protection is disabled) */
#pragma config CPD = OFF        /* Data Code Protection bit (Data memory code protection is disabled) */
#pragma config BOREN = OFF      /* Brown Out Reset Selection bits (BOR disabled) */
#pragma config IESO = OFF       /* Internal External Switchover bit (Internal/External Switchover mode is disabled) */
#pragma config FCMEN = OFF      /* Fail-Safe Clock Monitor Enabled bit (Fail-Safe Clock Monitor is disabled) */
#pragma config LVP = OFF        /* Low Voltage Programming Enable bit (RB3 pin has digital I/O, HV on MCLR must be used for programming) */
/* CONFIG2 */
#pragma config BOR4V = BOR40V   /* Brown-out Reset Selection bit (Brown-out Reset set to 4.0V) */
#pragma config WRT = OFF        /* Flash Program Memory Self Write Enable bits (Write protection off) */
void delaya_US( unsigned char n );
void LCD_CSH( void );
void LCD_WRITE_4( unsigned char R1, unsigned char FLAG );
void LCD_WRITE( unsigned char R1, unsigned char FLAG );
unsigned char LCD_READ( void );
void LCD_BUSY( void );
void delaya( unsigned int n );
/* LCD显示相关 */
#define DATA 1                                       /* LCD写数据时为1 */
#define COM 0                                       /* LCD写命令时为0 */
#define LINE1 0b10000000
#define LINE2 0b11000000
#define LCD_E RD6
#define LCD_RW RD5
#define LCD_RS RD4
/* ======延时(n×10)us */
unsigned char j;
for ( j = 0; j < n; j++ )
NOP(); NOP();
/* LCD初始化 */
TRISD = 0x00;  /* RD方向输出 */
delaya( 20 );
LCD_WRITE_4( 0b0011, COM );
delaya( 5 );
delaya_US( 10 );
delaya_US( 10 );
LCD_WRITE_4( 0b0010, COM );
LCD_BUSY();
LCD_WRITE( 0b00101000, COM );
LCD_WRITE( 0b00001100, COM );
LCD_WRITE( 0b00000001, COM );
delaya( 2 );
LCD_WRITE( 0b00000110, COM );
/* LCD写4位命令 */
LCD_RW = 0; NOP();
LCD_RS = FLAG;
PORTD &= 0xF0;
LCD_E = 1; NOP();
PORTD |= R1;
NOP(); NOP();
LCD_E = 0; NOP();
LCD_RS = 0; NOP();
PORTD &= 0xF0;
/* LCD写命令 */
unsigned char R2;
LCD_BUSY();
LCD_RW = 0; NOP();
LCD_RS = FLAG;
R2 = (R1 >> 4) & 0x0F;
PORTD &= 0xF0; NOP();
LCD_E = 1;
PORTD |= R2;
NOP(); NOP();
LCD_E = 0;
R2 = R1 & 0x0F;
LCD_E = 1; NOP();
PORTD |= R2;
NOP(); NOP();
LCD_E = 0; NOP();
LCD_RS = 0; NOP();
PORTD &= 0xF0;
/* 读LCD状态 */
unsigned char R1;
TRISD = 0x0F;
LCD_RS = 0; NOP();
LCD_RW = 1;
NOP(); NOP();
LCD_E = 1;
NOP(); NOP();
NOP(); NOP();
R1 = 0;
R1 = (PORTD << 4) & 0xF0;
LCD_E = 0;
NOP(); NOP();
NOP(); NOP();
LCD_E = 1;
NOP(); NOP();
R1 |= (PORTD & 0x0F);
LCD_E = 0; NOP();
LCD_RW = 0;
TRISD = 0x00;
return(R1);
/* 检测LCD是否忙 */
unsigned char R1;
do
R1 = LCD_READ();
while ( (R1 & 0x80) == 0x80 );
/* ======延时(n)ms */
unsigned int j;
unsigned char k;
for ( k = 246; k > 0; k-- )
NOP();
 * 显示屏字符串写入函数
void LCD_write_str( unsigned char x, unsigned char y, char *s )
if ( y == 0 )
LCD_WRITE( 0x80 + x, COM );
}else {
LCD_WRITE( 0xC0 + x, COM );
while ( *s )
LCD_WRITE( *s, DATA );
s++;
#define K1 RC0
#define K2 RC1
int Keyscan( void )
TRISC |= 0x03;                   /*按键是输入 */
if ( K1 == 0 )
delaya( 5 );
if ( K1 == 0 )
while ( K1 == 0 )
;       /* 等待按键松开 */
return(1);
if ( K2 == 0 )
delaya( 5 );
if ( K2 == 0 )
while ( K2 == 0 )
;  /* 等待按键松开 */
return(2);
return(0);
 * 【函 数 名】: void send_cmd(unsigned char dat)
 * 【功    能】: 串口发送数据命令
void send( unsigned char dat )
TXREG = dat;
while ( TRMT != 1 )
;  /* 等待发送完成 */
 * 【函 数 名】: Print_Str(unsigned char *s)
 * 【功    能】: 串口发送 一个字符串
void Print_Str( unsigned char *s )
while ( *s != '' )
send( *s++ );
void dispaly_rtctime(unsigned char h,unsigned char m,unsigned char s)
    char xianshi[15];
    char count=0;
    xianshi[count++]='0'+h%100/10;
    xianshi[count++]='0'+h%10;
     xianshi[count++]=':';
    xianshi[count++]='0'+m%100/10;
    xianshi[count++]='0'+m%10;
    xianshi[count++]='0'+s%100/10;
    xianshi[count++]='0'+s%10;
    xianshi[count++]=0;
    LCD_write_str(0,0,xianshi);
#define LED RB0
int led_flash = 0;                  /* 为1就闪烁灯定时器闪烁  串口接受会改变这个值 */
unsigned int T1_10MS;                        /* 频率 */
char recdata;                        /* 接受字符 */
char rev_ifg = 0;
char rev_buffer[5];                  /* 装下信息 */
char rev_buffer_count = 0;
int time = 0;    /* 计时 */
char ledifg = 0;
int time1 = 0;
unsigned char rtc_hour = 23;
unsigned char rtc_min = 59;
unsigned char rtc_sec = 55;
void main( void )
int key = 0;
ANSEL = 0;                            /*选择ADC引脚 */
ANSELH = 0;
T1CON = 0b00100001;                   /* 内部时钟源 (F OSC /4) */
GIE = 1; PEIE = 1; TMR1IE = 1;
TMR1IF = 0;
T1_10MS = 100;                          /* 执行定时器中断的频率 */
T1_10MS = 1000000 / T1_10MS;            /* 多少时间 也就是选择频率 */
T1_10MS = (65535 - T1_10MS / 4);        /* 给到硬件定时器 */
TMR1H = T1_10MS >> 8;
TMR1L = T1_10MS;
/* 串口初始化 */
SPBRG = 25;                           /* 4mhz 9600 */
TXSTA = 0X24;
RCSTA = 0X90;
RCIE = 1;
CREN = 1;
SYNC = 0;
SPEN = 1;
GIE = 1;
PEIE = 1;
TRISC6 = 0;
TRISC7 = 1;
RC6 = 1;
RC7 = 1;
/* 小灯是输出 */
TRISB = 0x00;
LED = 1; /* 输出高 不亮的 */
    LCD_CSH();
delaya( 30 );
while ( 1 )
key = Keyscan();        /* key 有按键1或者2 否则就是0 */
if ( key != 0 )
led_flash = 0;  /*不再闪烁灯 */
void interrupt high_isr( void )         /* 也可以加 high_priority */
unsigned char xianshi[20];
if ( TMR1IF )                   /* 中断一次 */
/* 重新给时间 */
TMR1IF = 0;
TMR1L = T1_10MS;
time1++;
if ( time1 > 100 )
time1 = 0; /* 1s时间 */
            //更新时间
rtc_sec++;
if ( rtc_sec == 60 )
rtc_sec = 0;
rtc_min++;
if ( rtc_min == 60 )
rtc_min = 0;
rtc_hour++;
if ( rtc_hour == 24 )
rtc_hour = 0;
            //显示时间
            if(led_flash==0)
                dispaly_rtctime(rtc_hour,rtc_min,rtc_sec);
/*下面就是控制小灯闪烁 */
time++;
if ( time > 10 )
time = 0;
if ( led_flash == 1 )
ledifg = !ledifg;
if ( ledifg == 0 )
LED = 0;
else LED = 1;
}  else if ( RCIF )
/* 串口接受中断 */
RCIF = 0;
recdata = RCREG;
send( recdata );
        if ( rev_ifg == 2 )
            rev_buffer[rev_buffer_count++] = recdata;       /* 接受 */
if ( rev_buffer_count == 4 )
/* 接受到了4个字符 比如2房3床 就是接收到0203 */
                LCD_CSH();
                delaya( 30 );
LCD_write_str( 0, 0, rev_buffer );      /* 显示出来 */
                rev_ifg=0;
[1] [2]
关键字:PIC16F887  串口  LCD1602  按键 引用地址:PIC16F887 串口 LCD1602 按键
上一篇:PICC编译错误
下一篇:PIC18F45K80 CAN通讯示例代码
中国国际工业博览会(简称"中国工博会")是以创新、智能、绿色制造为展示交易主体的国际工业展,将于2018年9月19日至23日在上海举行。今年德承将在中国工博会的工业自动化展(IAS),展示其强固型无风扇计算机、转换型嵌入式系统、工业平板电脑和工业触摸显示器给国内各地的客户。凭借领先的产品和以应用需求为导向的功能,德承在国内外多个行业中实现了新...
9.1 初学者重要提示1、 如果对C语言不熟练的话,可以阅读C语言书:C Primer Plus(第五版)中文版.pdf论坛下载:http://forum.armfly.com/forum.php?mod=viewthread&tid=91219。 2、 为了更好的学习本章知识点,可以看之前做的视频教程第10章,针对H7也将在今年发布视频教程:http://forum.armfly.com/forum.php?mod=viewthread&tid=15408 。9.2 ...
  一、工业机器人内部组成   1.机械部分   机械部分是机器人的血肉组成部分,也就是我们常说的机器人本体部分。这部分主要可以分为两个系统:   (1)驱动系统   要使机器人运行起来,需要各个关节安装传感装置和传动专治,这就是驱动系统。它的作用是提供机器人各部分、各关节动作的原动力。驱动系统传动部分可以是传动系统、电动传动系...
当你读到这里时,或许会问,FFT有什么好讨论的,难道ZDS2022示波器会有什么本质的不同吗?我们不妨简单地回顾一下FFT中几个重要的参数和关系表达式。采样率:示波器的采样频率,用Fs表示。ZDS2022示波器每通道均支持1GS/S采样率,下面将以最高采样率1GS/S为基准描述相关的问题;FFT点数:与示波器死区时间对应的参数是示波器的波形刷新率,又叫波形捕获率...
直流逆变器的研究
直流逆变器的研究…
查看全部问答∨
WinCE6.0如何制作SDK
以前在Wince5.0上做SDK都很好用,现在换到6.0 VS2005中我想做个SDK但是做出来的SDK拿去一编译就出错了,用系统默认给的就没问题,在我的SDK制作的过程中,系统提示没有加入一些头文件和库,我想就是这里的问题,使得我做的SDK使用的时候出错。有没 ...…
查看全部问答∨
SPI接口程序
有没有人有YC2440板子WCE系统下的SPI接口程序啊?? 或者例程之类的,能不能给我一份啊??…
查看全部问答∨
wince 2.11是否支持.net
如题, 如果不支持那怎么开发程序(各种语言都可) 如有资料请传给我 shuwu520@sina.com…
查看全部问答∨
分析LED照明趋势,来谈谈吧
 LED的效率趋势如何?以各种光源的发光效率来看,白炽灯和卤素灯只有20~30lm/W,省电灯泡大约在70lm/W,HID能够增加到100lm/W,灯管发光效率目前微增至近120lm/W,不过在2010年分别只有约80lm/W和不到30lm/W的LED和OLED,却都呈现快速改善的态势,未来 ...…
查看全部问答∨
有没有用AVR控制USB芯片PDIUSBD12进行数据传输的啊
有没有用AVR控制USB芯片PDIUSBD12进行数据传输的啊 我最近要做一个AVR16与PC机数据传输的项目,有没有调过USB的 我选择的芯片是PDIUSBD12,如果有调试过的朋友可以联系我么,或者分享给我点经验,谢谢了 (不知道我把帖子发表到这个AVR板块对不 ...…
查看全部问答∨
做了一块单通道功率放大器,单电源供电,加上直流稳压源后按电容有声音,什么情况?
就是用手触碰电解电容的时候稳压电源会有声音,为什么??极性应该没有反,两种接都会有声音。…
查看全部问答∨
【晒心得】+ eZ430-Chronos 无线手表初体验
      于9月7日在德州仪器estore官网下订单,11日发货,14日到达深圳,由于周末不派送,如预期在今天(16日)下午收到。话说联邦快递的服务真心不错,先询问我是否方便收货,询问收货的地点,之后再次通知我去我指定的地点取货 ...…
查看全部问答∨
使用ADSP-CM408F ADC控制器的电机控制反馈采样时序
使用ADSP-CM408F ADC控制器的电机控制反馈采样时序 …
查看全部问答∨
小广播
设计资源 培训 开发板 精华推荐
最新单片机文章
何立民专栏 单片机及嵌入式宝典
换一换 更多 相关热搜器件
随便看看
电子工程世界版权所有 京ICP证060456号 京ICP备10001474号-1 电信业务审批[2006]字第258号函 京公网安备 11010802033920号 Copyright © 2005-2024 EEWORLD.com.cn, Inc. All rights reserved
