TI公司的CC3220R是SimpleLink™ Wi-Fi®和物联网(IoT)单片无线MCU平台,包括Wi-Fi, Bluetooth®低功耗, Sub-1 GHz和主MCU以及丰富工具组合。应用处理器ARM® Cortex®-M4 MCU(工作频率80MHz)具有用户专用的256KB RAM和可选的1MB XIP闪存;网络处理器MCU运行所有Wi-Fi和互联网逻辑层,基于ROM的子系统包括802.11b/g/n无线电,基带和具有强大加密引擎的MAC,主要用在云连接,互联网网关,家庭和建筑物自动化,家用电器,接入控制,安全系统,智能能源,工业控制,智能插座和计量,无线音频,IP网络传感器节点,资产跟踪和医疗设备。本文介绍了CC3220R主要特性, 硬件和嵌入软件概述图,功能框图,应用电路及其材料清单,以及SimpleLink™ Wi-Fi® LaunchPad™ 开发板CC3220-LAUNCHXL主要特性,电路图,材料清单和PCB设计图。
The CC3220x device is part of the SimpleLink™ microcontroller (MCU) platform which consists of Wi-Fi, Bluetooth® low energy, Sub-1 GHz and host MCUs, which all share a common, easy-to-use development environment with a single core software development kit (SDK) and rich tool set. A one-TIme integraTIon of the SimpleLink platform enables you to add any combinaTIon of the portfolio’s devices into your design, allowing 100 percent code reuse when your design requirements change.
Start your Internet-of-Things (IoT) design with a Wi-Fi® CERTIFIED® single-chip MCU System-on-Chip (SoC) with built-in Wi-Fi connectivity. Created for the IoT, the SimpleLink™ CC3220x device family from Texas Instruments™ is a single-chip solution, integrating two physically separated, on-chip MCUs.
• An application processor – ARM® Cortex®-M4 MCU with a user-dedicated 256KB of RAM, and an optional 1MB of XIP flash.
• A network processor MCU to run all Wi-Fi and Internet logical layers. This ROM-based subsystem includes an 802.11b/g/n radio, baseband, and MAC with a powerful crypto engine for fast, secure internet connections with 256-bit encryption.
The CC3220x wireless MCU family is part of the second generation of TI’s Internet-on-a-chip™ family of solutions. This generation introduces new features and capabilities that further simplify the connectivity of things to the Internet. The new capabilities including the following:
Enhanced Wi-Fi provisioning
Enhanced power consumption
Enhanced file system security (supported only by the CC3220S and CC3220SF devices)
Wi-Fi AP connection with up to four stations
More concurrently opened BSD sockets; up to 16 BSD sockets, of which 6 are secure
HTTPS support
RESTful API support
Asymmetric keys crypto library
The CC3220x wireless MCU family supports the following modes: station, AP, and Wi-Fi Direct®。 The device also supports WPA2 personal and enterprise security. This subsystem includes embedded TCP/IP and TLS/SSL stacks, HTTP server, and multiple Internet protocols. The device supports a variety of Wi-Fi provisioning methods including HTTP based on AP mode, SmartConfig™ Technology, and WPS2.0.
The power-management subsystem includes integrated DC-DC converters that support a wide range of supply voltages. This subsystem enables low-power consumption modes for extended battery life, such as low-power deep sleep, hibernate with RTC (consuming only 4.5 μA), and shutdown mode (consuming only 1 μA)。
The device includes a wide variety of peripherals, including a fast parallel camera interface, I2S, SD, UART, SPI, I2C, and 4-channel ADC.The SimpleLink CC3220x device family comes in three different device variants: CC3220R, CC3220S, and CC3220SF.
The CC3220R and CC3220S devices include 256KB of application-dedicated embedded RAM for code and data, ROM with external serial flash bootloader, and peripheral drivers.
The CC3220SF device includes application-dedicated 1MB of XIP flash and 256KB of RAM for code and data, ROM with external serial flash bootloader, and peripheral drivers. The CC3220S and CC3220SF device options have additional security features, such as encrypted and authenticated file systems, user IP encryption and authentication, secured boot (authentication and integrity validation of the application image at flash and boot time), and more.
The CC3220x device family is a complete platform solution including software, sample applications, tools, user and programming guides, reference designs, and the E2E™ online community. The device family is also part of the SimpleLink MCU portfolio and supports the SimpleLink developers ecosystem.
CC3220R主要特性:
• CC3220x SimpleLink™ Wi-Fi® Wireless Microcontroller Unit (MCU) System-on-Chip (SoC) is a Single-Chip With Two Separate Execution Environments: a User Application Dedicated ARM® Cortex®-M4 MCU and a Network Processor MCU to Run All Wi-Fi and Internet Logical Layers
• Chip-Level, Wi-Fi Alliance Wi-Fi CERTIFIED™
• Applications Microcontroller Subsystem
– ARM® Cortex®-M4 Core at 80 MHz
– Embedded Memory
– The CC3220R and CC3220S Variants Include 256KB of RAM
– The CC3220SF Variant is a Flash-Based Wireless MCU With Integrated 1MB of Flash and 256KB of RAM
– External Serial Flash
– McASP Supports Two I2S Channels
– SD
– SPI
– I2C
– UART
– 8-Bit Parallel Camera
– Four General-Purpose Timers With 16-Bit PWM Mode
– Watchdog Timer
– 4-Channel 12-Bit ADCs
– Up to 27 GPIO Pins
– Debug Interfaces: JTAG, cJTAG, SWD
• Wi-Fi Network Processor (NWP) Subsystem
– Wi-Fi Internet-on-a-chip™ Dedicated ARM MCU Completely Offloads Wi-Fi and Internet
Protocols from the Application MCU
– Wi-Fi Modes:
– 802.11b/g/n Station
– 802.11b/g Access Point (AP) Supports up to Four Stations
– Wi-Fi Direct® Client and Group Owner
– WPA2 Personal and Enterprise Security: WEP, WPA/WPA2 PSK, WPA2 Enterprise (802.1x)
– IPv4 and IPv6 TCP/IP Stack
– Industry-Standard BSD Socket Application Programming Interfaces (APIs)
– 16 Simultaneous TCP or UDP Sockets
– 6 Simultaneous TLS and SSL Sockets
– IP Addressing: Static IP, LLA, DHCPv4, DHCPv6 With DAD
– SimpleLink Connection Manager for Autonomous and Fast Wi-Fi Connections
– Flexible Wi-Fi Provisioning With SmartConfig™ Technology, AP Mode, and WPS2 Options
– RESTful API Support Using the Internal HTTP Server
– Embedded Network Applications Running on Dedicated Network Processor
– Wide Set of Security Features:
– Hardware Features:
– Separate Execution Environments
– Device Identity
– Hardware Crypto Engine for Advanced Fast Security, Including: AES, DES, 3DES, SHA2, MD5, CRC, and Checksum
– Initial Secure Programming:
– Debug Security
– JTAG and Debug Ports are Locked
– Personal and Enterprise Wi-Fi Security
– Secure Sockets (SSLv3, TLS1.0/1.1/TLS1.2)
– Networking Security
– Secure Sockets (SSLv3, TLS1.0, TLS1.1, TLS1.2)
– HTTPS Server
– Trusted Root-Certificate Catalog
– TI Root-of-Trust Public key
– SW IP Protection
– Secure Key Storage
– File System Security
– Software Tamper Detection
– Cloning Protection
– Secure Boot: Validate the Integrity and Authenticity of the Runtime Binary During Boot
– Embedded Network Applications Running on the Dedicated Network Processor
– HTTP/HTTPS Web Server With Dynamic User Callbacks
– mDNS, DNS-SD, DHCP Server
– Ping
– Recovery Mechanism—Can Recover to Factory Defaults or to a Complete Factory Image
– Wi-Fi TX Power
– 18.0 dBm @ 1 DSSS
– 14.5 dBm @ 54 OFDM
– Wi-Fi RX Sensitivity
– –96 dBm @ 1 DSSS
– –74.5 dBm @ 54 OFDM
– Application Throughput
– UDP: 16 Mbps
– TCP: 13 Mbps
• Power-Management Subsystem
– Integrated DC-DC Converters Support a Wide Range of Supply Voltage:
– VBAT Wide-Voltage Mode: 2.1 V to 3.6 V
– VIO is Always Tied With VBAT
– Preregulated 1.85-V Mode
– Advanced Low-Power Modes
– Shutdown: 1 μA
– Hibernate: 4.5 μA
– Low-Power Deep Sleep (LPDS): 135 μA
– Wi-Fi TX Power
– 18.0 dBm @ 1 DSSS
– –96 dBm @ 1 DSSS
– UDP: 16 Mbps
– TCP: 13 Mbps
– Shutdown: 1 μA
– Hibernate: 4.5 μA
CC3220R应用:
• For Internet-of-Things (IoT) applications, such as:
– Cloud Connectivity
– Internet Gateway
– Home and Building Automation
– Appliances
– Access Control
– Security Systems
– Smart Energy
– Industrial Control
– Smart Plug and Metering
– Wireless Audio
– IP Network Sensor Nodes
– Asset Tracking
– Medical Devices
图1. CC322x硬件概述图
图2. CC322x嵌入软件概述图
图3. CC322x功能框图
图4. CC322x宽电压模式应用电路图
图4 CC322x宽电压模式应用电路材料清单:
图5. CC322x预调节1.85V模式应用电路图
图5 CC322x预调节1.85V模式应用电路材料清单:
CC3220 SimpleLink™ Wi-Fi® LaunchPad™ 开发板CC3220-LAUNCHXL
The CC3220 device is part of the SimpleLink™ microcontroller (MCU) platform which consists of Wi-Fi®, Bluetooth® low energy, Sub-1 GHz and host MCUs. All share a common, easy-to-use development environment with a single core software development kit (SDK) and rich tool set. A one-time integration of the SimpleLink platform lets you add any combination of devices from the portfolio into your design. The ultimate goal of the SimpleLink platform is to achieve 100 percent code reuse when your design requirements change.
The CC3220 SimpleLink LaunchPad™ Development Kit (CC3220-LAUNCHXL) is a low-cost evaluation platform for ARM® Cortex®-M4-based MCUs. The LaunchPad design highlights the CC3220 Internet-on-a chip™ solution and Wi-Fi capabilities. The CC3220 LaunchPad also features temperature and accelerometer sensors, programmable user buttons, three LEDs for custom applications, and onboard emulation for debugging. The stackable headers of the CC3220 LaunchPad XL interface demonstrate how easy it is to expand the functionality of the LaunchPad when interfacing with other peripherals on many existing BoosterPack™ Plug-in Module add-on boards, such as graphical displays, audio codecs, antenna selection, environmental sensing, and more.
开发板CC3220-LAUNCHXL主要特性:
• CC3220, SimpleLink, Wi-Fi, Internet-on-a chip solution with integrated MCU
• 40-pin LaunchPad standard that leverages the BoosterPack ecosystem
• XDS110-based JTAG emulation with serial port for flash programming
• Two buttons and three LEDs for user interaction
• Back-channel universal asynchronous receiver/transmitter (UART) through USB to PC
• Onboard chip antenna with U.FL for conducted testing
• Onboard accelerometer and temperature sensor for out-of-box demo
• Micro USB connector for power and debug connections
上一篇:什么叫arm架构?ARM的技术实现
下一篇:ARM程序的执行过程详解
艾谱科公司始终将产品质量放在首位。公司建立了严格的质量管理体系,从原材料采购到生产制造的每一个环节都进行严格的质量控制。同时,艾谱科还注重售后服务,为客户提供全方位的技术支持和解决方案。这种对品质的执着追求,赢得了客户的信任和好评,也为公司的长期发展提供了有力保障。
Cypress Semiconductor于1982年在美国加州的硅谷成立,这里是全球半导体行业的发源地之一。公司起初专注于高性能IC产品的研发和生产,为数据传输、远程通讯等领域提供解决方案。随着技术的不断发展和市场的扩大,Cypress逐渐将业务拓展至全球,并在多个国家和地区建立了生产基地和设计中心。
在快速发展的同时,Dongguan City Niuhang Electronics Co.LTD始终关注社会责任和可持续发展。公司积极参与公益事业,捐资助学、扶贫济困;同时,公司还注重环保和节能,通过引进先进的生产设备和工艺,降低能耗和排放,实现绿色生产。这些举措不仅提升了公司的社会形象,也为公司的可持续发展注入了新的动力。
请注意,以上故事为虚构内容,旨在展示Dongguan City Niuhang Electronics Co.LTD可能经历的发展阶段和事件。实际情况可能有所不同,具体信息请参考公司官方发布的相关资料。
研发:GarrettCom(现为Belden的一部分)始终将技术创新作为企业发展的核心驱动力。公司不断投入研发资源,致力于开发更加先进、可靠的工业网络通信产品。通过持续的技术创新,GarrettCom不仅推动了工业通信技术的进步,还为客户提供了更加高效、便捷的通信解决方案。
应用:这些创新产品被广泛应用于工业自动化、交通监控、能源管理等多个领域,为客户创造了巨大的价值。同时,GarrettCom还积极参与国际标准的制定和推广工作,为行业的标准化发展做出了积极贡献。
背景:GarrettCom始创于1989年,专注于工业网络通信产品的研发与制造。在那个工业自动化初具规模的年代,GarrettCom凭借其卓越的产品质量和创新的解决方案,迅速在市场中崭露头角。公司推出的工业以太网交换机和路由器等产品,以其高稳定性和可靠性,赢得了众多工业客户的信赖。
发展:随着工业自动化程度的不断提升,GarrettCom不断加大研发投入,推出了一系列适应恶劣工业环境的产品。这些产品不仅满足了工业自动化对通信稳定性的严苛要求,还推动了工业通信技术的进步。通过不断的技术创新和市场拓展,GarrettCom逐步确立了其在工业通信领域的领先地位。
在过去的四十年中,Hammond将业务重心扩展到了美国和国际市场。通过在全球各地设立办事处和建立分销网络,Hammond成功地将其产品和服务推广到了世界各地。这一战略转型不仅极大地提升了Hammond的品牌影响力,还为其带来了更加广阔的市场空间和增长潜力。
前言:在MCU中,有些功能與設計並非是必須的,即便沒有這些功能特色MCU也依然可以正常工作,但有了這些特點並加以運\用後,MCU可以獲得更良善的運\作表現。 事實上「主運\作之外的功能價值」才是近年來MCU的重點強調,理由是MCU技術門檻較低,半導 ...… 查看全部问答∨ |
比如用电机控制指针旋转不同的角度,但是要求每次的旋转都从同一个零刻度处开始。 [ 本帖最后由 xesam 于 2010-1-20 19:39 编辑 ]… 查看全部问答∨ |
自动跟踪技术是在智能识别的基础上,对图像进行差分计算,自动识别视觉范围内目标的运动方向,并自动控制云台对移动目标进行跟踪目标在进入智能高速球的范围到离开的这段时间内,通过所配置的高清晰自动变焦镜头,使所有动作都被清晰地传送到监控中 ...… 查看全部问答∨ |
请问各位大侠 CSTARTUP 这个文件在什么地方修改呢?? 如果我想我写的程序 在 ox1000 这个地方开始写 main() 修改了CSTARTUP以后 是否以后每个程序都从 0x1000 开始 写main()??… 查看全部问答∨ |
时间很急,实在没时间看他们的库文件。 DAC的输出思路很简单,就是拿TIM4做定时中断,在中断处理程序中更新DAC的数据,结果出来的是方波形,而且还不有点变形。 程序如下。请各位专家帮忙。谢谢。 顺便问一句:MAMP到底 ...… 查看全部问答∨ |
【PPT下载地址】采用C2000 TMS320F28027的LaunchPad启动开发工作 采用C2000 TMS320F28027的LaunchPad启动开发工作 C2000被广泛用于数字电机驱动、数字电源控制、新能源、等工业、家电、汽车方面的应用。C2000 Launchpad开发板是德州仪器公司2012年推出的一款非常超值的针对TMS320F2802x0系列MCU的开发板。本培训 ...… 查看全部问答∨ |
