里面宏定义了uchar和uint分别叫u8和u16,写程序添加头文件后省了这两个宏定义,可以直接引用。
REG52.H
Header file for generic 80C52 and 80C32 microcontroller.
Copyright (c) 1988-2002 Keil Elektronik GmbH and Keil Software, Inc.
All rights reserved.
#ifndef __STC89C52_H__
#define __STC89C52_H__
typedef unsigned char u8;
typedef unsigned int u16;
/*  BYTE Registers  */
sfr P0    = 0x80;
sfr P1    = 0x90;
sfr P2    = 0xA0;
sfr P3    = 0xB0;
sfr PSW   = 0xD0;
sfr ACC   = 0xE0;
sfr B     = 0xF0;
sfr SP    = 0x81;
sfr DPL   = 0x82;
sfr DPH   = 0x83;
sfr PCON  = 0x87;
sfr TCON  = 0x88;
sfr TMOD  = 0x89;
sfr TL0   = 0x8A;
sfr TL1   = 0x8B;
sfr TH0   = 0x8C;
sfr TH1   = 0x8D;
sfr IE    = 0xA8;
sfr IP    = 0xB8;
sfr SCON  = 0x98;
sfr SBUF  = 0x99;
/*  8052 Extensions  */
sfr T2CON  = 0xC8;
sfr RCAP2L = 0xCA;
sfr RCAP2H = 0xCB;
sfr TL2    = 0xCC;
sfr TH2    = 0xCD;
/*  BIT Registers  */
/*  PSW  */
sbit CY    = PSW^7;
sbit AC    = PSW^6;
sbit F0    = PSW^5;
sbit RS1   = PSW^4;
sbit RS0   = PSW^3;
sbit OV    = PSW^2;
sbit P     = PSW^0; //8052 only
/*  TCON  */
sbit TF1   = TCON^7;
sbit TR1   = TCON^6;
sbit TF0   = TCON^5;
sbit TR0   = TCON^4;
sbit IE1   = TCON^3;
sbit IT1   = TCON^2;
sbit IE0   = TCON^1;
sbit IT0   = TCON^0;
/*  IE  */
sbit EA    = IE^7;
sbit ET2   = IE^5; //8052 only
sbit ES    = IE^4;
sbit ET1   = IE^3;
sbit EX1   = IE^2;
sbit ET0   = IE^1;
sbit EX0   = IE^0;
/*  IP  */
sbit PT2   = IP^5;
sbit PS    = IP^4;
sbit PT1   = IP^3;
sbit PX1   = IP^2;
sbit PT0   = IP^1;
sbit PX0   = IP^0;
/*  P3  */
sbit RD    = P3^7;
sbit WR    = P3^6;
sbit T1    = P3^5;
sbit T0    = P3^4;
sbit INT1  = P3^3;
sbit INT0  = P3^2;
sbit TXD   = P3^1;
sbit RXD   = P3^0;
/*  SCON  */
sbit SM0   = SCON^7;
sbit SM1   = SCON^6;
sbit SM2   = SCON^5;
sbit REN   = SCON^4;
sbit TB8   = SCON^3;
sbit RB8   = SCON^2;
sbit TI    = SCON^1;
sbit RI    = SCON^0;
/*  P1  */
sbit T2EX  = P1^1; // 8052 only
sbit T2    = P1^0; // 8052 only
/*  T2CON  */
sbit TF2    = T2CON^7;
sbit EXF2   = T2CON^6;
sbit RCLK   = T2CON^5;
sbit TCLK   = T2CON^4;
sbit EXEN2  = T2CON^3;
sbit TR2    = T2CON^2;
sbit C_T2   = T2CON^1;
sbit CP_RL2 = T2CON^0;
sfr ISP_DATA  = 0xe2;
sfr ISP_ADDRH = 0xe3;
sfr ISP_ADDRL = 0xe4;
sfr ISP_CMD   = 0xe5;
sfr ISP_TRIG  = 0xe6;
sfr ISP_CONTR = 0xe7;
#endif
关键字:STC89C52  头文件  宏定义 引用地址:分享一个STC89C52的头文件
上一篇:简易同位升降系统的单片机源码(用超声波测距实现)
下一篇:51单片机驱动直流电机,测试可用,可调速
最近博主用STM32F103C8T6做了一个温度测控模块,用到PB3,PB4,PA15等引脚控制外设。发现不管怎么配置,这三个引脚都不能置零。后来发现是包括这三个引脚在内的PB3,PB4,PA13,PA14,PA15是特殊的IO口,用作JTAG/SWD仿真器的调试接口。其中PA13,PA14分别作为SWD调试的SWIO和SWCLK;PB3,PB4,PA13,PA14,PA15共同用于JTAG。这五个引脚的中英文描述如下...
在红米新品发布会上,红米品牌总经理卢伟冰发布70英寸Redmi电视,对比智慧荣耀屏,吐槽三连:把两秒息屏唤醒称作开机、设计的界面雷同,拿来主义、价格贵。他称,真正的智慧是同样的价钱买更大的小米。
万用表是电力维修人员必备的故障查找工具,“一人,一笔,一表”很形象的告诉我们电工作业人员的基本要求就是:电工+电笔+万用表,这是作为一个电力作业人员的基本配置,,在日常的维修保养过程中,万用表发挥着极其重要的作用。今天就给大家具体说说,万用表各个档位的含义,怎么测电压、电流、电阻、电容等等问题,可以说是非常详细了。一,万用表使用前...
链接脚本的语法SECTIONS {...secname start BLOCK(align) (NOLOAD) : AT ( ldadr ) { contents } >region :phdr =fill...}解释: secname :段名 start :起始地址:运行时的地址(runtime addr);重定位地址(relocate addr) AT ( ldadr ) :可有可无(load addr:加载地址) 不写时LoadAddr = runtime addr { contents } ...
认识ARM体系结构的发展
处理器的体系结构定义了指令集(ISA)和基于这一体系结构下处理器的程序员模型。尽管每个处理器 性能不同,所面向的应用不同,每个处理器的实现都要遵循这一体系结构。ARM体系结构为嵌入系统发展 商提供很高的系统性能,同时保持优异的功耗和 面 ...…
查看全部问答∨
FPGA、CPLD常用protel库
FPGA、CPLD常用protel库…
查看全部问答∨
那位大虾帮帮忙,明天就考试了,开卷完全找不到答案
11.        基于ARM7 、9、11处理器设计的产品,类似Intel的Xscale架构产品的设计方案 (功能特点、结构、作用  举例子说明设计方案,如GPS、游戏机、POS……) 12.        嵌入式系统实时性? ...…
查看全部问答∨
我的cisco2600路由器被人把IOS删掉了,我要从另一个2600路由器下载IOS,怎么下呢??高分求助!
        我用的是COPY FLASH  TFTP命令 ,但是总是报错:TFTP://10.1.1.3 timeout 10.1.1.3是我设置的本机IP。 怎么解决呢》?求高手指教啊 …
查看全部问答∨
网卡后面的显示灯是红色的,为什么?
以前不是这样的,并且在电脑属性里面的硬件里面的设备管理器中看不到网络适配器.高手们快点过来指点下…
查看全部问答∨
linux下gcc的安装
请问linux下gcc怎么安装,我没有光盘,只有一个gcc-3.2.2-5.i386.rpm,安装的错误提示为: Missing Dependency: glibc-devel >= 2.2.90-12 is needed by package gcc Missing Dependency: cpp = 3.2.2-5 is needed by package gcc 还有,linux ...…
查看全部问答∨
[求助]求高人帮我看下程序
;-------------------------------------------------------------------------- ;[H1+H2]+[ADR]+[CMD]+[CRC] ;[L1+L2]+[ID]+[TEM_1]+[TEM_2]+[TEM_3]+[TEM_4]+[TEM_5]+[DOOR] ;-------------------------------------------------------------- ...…
查看全部问答∨
水质检测器电路
本帖最后由 jameswangsynnex 于 2015-3-3 19:54 编辑   …
查看全部问答∨
MC68HC711K4VFU4代替型号
各位大侠,有谁用过这块芯片MC68HC711K4VFU4,谁知道其他的可以代替?…
查看全部问答∨
user error: Reset failed - Target not halted
ST研讨会的时候拿了一块 DISCOVERY的板子,最近在学习,现在用IAR下程序的时候碰到错误提示user error: Reset failed - Target not halted,有知道为什么会出现这个错误的吗?怎么解决…
查看全部问答∨
小广播
设计资源 培训 开发板 精华推荐
最新单片机文章
何立民专栏 单片机及嵌入式宝典
电子工程世界版权所有 京ICP证060456号 京ICP备10001474号-1 电信业务审批[2006]字第258号函 京公网安备 11010802033920号 Copyright © 2005-2024 EEWORLD.com.cn, Inc. All rights reserved
