今天是:2024年11月25日(星期一)
2020年11月25日 | 51单片机简易波形发生器(正弦波 锯齿波 三角波)
发布者:wmghyu 来源: 51hei关键字:51单片机吗  正弦波  锯齿波  三角波 手机看文章 扫描二维码
随时随地手机看文章
下面是51单片机简易波形发生器源程序:
#include
#include
#define ADDR1 0x2c //MAX5820LEUA
sbit key_sin=P1^0;
sbit key_tran=P1^2;
sbit key_tooth=P1^4;
sbit SCL = P2 ^ 0;
sbit SDA = P2 ^ 1;
unsigned char code sin[256]=     //正弦表
        0x80,0x83,0x86,0x89,0x8d,0x90,0x93,0x96,0x99,0x9c,0x9f,0xa2,0xa5,0xa8,0xab,0xae,0xb1,0xb4,0xb7,0xba,0xbc,0xbf,0xc2,0xc5,
        0xc7,0xca,0xcc,0xcf,0xd1,0xd4,0xd6,0xd8,0xda,0xdd,0xdf,0xe1,0xe3,0xe5,0xe7,0xe9,0xea,0xec,0xee,0xef,0xf1,0xf2,0xf4,0xf5,
        0xf6,0xf7,0xf8,0xf9,0xfa,0xfb,0xfc,0xfd,0xfd,0xfe,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xfe,0xfd,
        0xfd,0xfc,0xfb,0xfa,0xf9,0xf8,0xf7,0xf6,0xf5,0xf4,0xf2,0xf1,0xef,0xee,0xec,0xea,0xe9,0xe7,0xe5,0xe3,0xe1,0xde,0xdd,0xda,
        0xd8,0xd6,0xd4,0xd1,0xcf,0xcc,0xca,0xc7,0xc5,0xc2,0xbf,0xbc,0xba,0xb7,0xb4,0xb1,0xae,0xab,0xa8,0xa5,0xa2,0x9f,0x9c,0x99,
        0x96,0x93,0x90,0x8d,0x89,0x86,0x83,0x80,0x80,0x7c,0x79,0x76,0x72,0x6f,0x6c,0x69,0x66,0x63,0x60,0x5d,0x5a,0x57,0x55,0x51,
        0x4e,0x4c,0x48,0x45,0x43,0x40,0x3d,0x3a,0x38,0x35,0x33,0x30,0x2e,0x2b,0x29,0x27,0x25,0x22,0x20,0x1e,0x1c,0x1a,0x18,0x16,
        0x15,0x13,0x11,0x10,0x0e,0x0d,0x0b,0x0a,0x09,0x08,0x07,0x06,0x05,0x04,0x03,0x02,0x02,0x01,0x00,0x00,0x00,0x00,0x00,0x00,
        0x00,0x00,0x00,0x00,0x00,0x00,0x01,0x02,0x02,0x03,0x04,0x05,0x06,0x07,0x08,0x09,0x0a,0x0b,0x0d,0x0e,0x10,0x11,0x13,0x15,
        0x16,0x18,0x1a,0x1c,0x1e,0x20,0x22,0x25,0x27,0x29,0x2b,0x2e,0x30,0x33,0x35,0x38,0x3a,0x3d,0x40,0x43,0x45,0x48,0x4c,0x4e,
        0x51,0x55,0x57,0x5a,0x5d,0x60,0x63,0x66,0x69,0x6c,0x6f,0x72,0x76,0x79,0x7c,0x80
bit write_addr(unsigned char,bit);//第一个参数表示地址,第二个参数表示 读:1 写:0
bit write_data(unsigned char);//第一个参数表示数据,第二个参数表示 命令字
void stop();
void Delay(unsigned int);
I2C_Delay(unsigned int I2C_VALUE)
        while ( --I2C_VALUE!= 0 );
函数:I2C_Init()
功能:I2C 总线初始化,使总线处于空闲状态
说明:在 main()函数的开始处,通常应当要执行一次本函数
void I2C_Init()
        SCL = 1;
        I2C_Delay(5);
        SDA = 1;
        I2C_Delay(5);
函数:I2C_Start()
功能:产生I2C 总线的起始状态
说明:
SCL处于高电平期间,当SDA 出现下降沿时启动I2C 总线
不论 SDA 和SCL 处于什么电平状态,本函数总能正确产生起始状态
本函数也可以用来产生重复起始状态
本函数执行后,I2C 总线处于忙状态
void I2C_Start()
        SDA = 1;
        I2C_Delay(5);
        SCL = 1;
        I2C_Delay(5);
        SDA = 0;
        I2C_Delay(5);
        SCL = 0;
        I2C_Delay(5);
函数:I2C_Write()
功能:向I2C 总线写1 个字节的数据
参数:
dat:要写到总线上的数据
void I2C_Write(char dat)
        unsigned char t = 8;
        do
                SDA = (bit)(dat & 0x80);
                dat <<= 1;
                SCL = 1;
                I2C_Delay(5);
                SCL = 0;
                I2C_Delay(5);
        } while ( --t != 0 );
bit I2C_GetAck()
        bit ack;
        SDA = 1;
        I2C_Delay(5);
        SCL = 1;
        I2C_Delay(5);
        ack = SDA;
        SCL = 0;
        I2C_Delay(5);
        return ack;
void I2C_Stop()
        unsigned int t = 10;
        SDA = 0;
        I2C_Delay(5);
        SCL = 1;
        I2C_Delay(5);
        SDA = 1;
        I2C_Delay(5);
        while ( --t != 0 ); //在下一次产生Start 之前,要加一定的延时
void Delay(unsigned int I2C_Delay_t)
        while ( --I2C_Delay_t!= 0 );
bit write_addr(unsigned char addr,bit mod)
        unsigned char address;
        address=addr<<1;
        if(mod)
                address++;
        I2C_Start();
        I2C_Write(address);
        Delay(10);
        if(I2C_GetAck())
                return 1;
        return 0;
bit write_data(unsigned char dat)
        I2C_Write(dat);
        if(I2C_GetAck())
                return 1;
        return 0;
void stop()
        I2C_Stop();
        I2C_Init();
void main(void)
        unsigned char i;
        loop:
        I2C_Init();
        while(1)
                if(key_sin==0)        //产生正弦波
                        while(1)
                                for(i=192;i<255;i++)
                                        write_addr(ADDR1,0);
                                        write_data(0);
                                        write_data(sin[i]);
                                        stop();
                                        if(!(key_tran!=0&&key_tooth!=0))
                                                goto loop;
                                for(i=0;i<192;i++)
                                        write_data(0);
                                        write_data(sin[i]);
                                        stop();
                                                goto loop;
                if(key_tran==0)        //产生三角波
                        while(1)
                                 for(i=0;i<255;i++)
                                        write_data(0);
                                        write_data(i);
                                        stop();
                                        if(!(key_sin!=0&&key_tooth!=0))
[1] [2]
关键字:51单片机吗  正弦波  锯齿波  三角波 引用地址:51单片机简易波形发生器(正弦波 锯齿波 三角波)
上一篇:STC15W408AS单片机白光T12控制器
下一篇:51单片机Keil C51的使用(C语言)
在不久前举行的首届世界博览会上,由浙江中感传感器有限研发的“神龙号” 水下机器人得到了与会专家的关注。11月22日,记者采访了带队参加本次展览会的浙江中感传感器有限公司企划部经理丁明沁。 据介绍,首届世界传感器博览会以“感知世界、智赢未来”为主题,于11月12日至14日在郑州国家会展中心召开,吸引了国内外众多专家学者的参加。浙江中感传感...
技术创新和新趋势可以产生更灵活、更有弹性和更高效的能源网格。 监管机构是否会大胆地释放这些新系统的真正力量。 在大阪的Dotonburi区散步是一项精力充沛的活动。 彩虹色的莫扎里拉热狗只是其中一个古怪的东西。 在欣赏霓虹灯的同时,我喜欢彩虹色的奶酪。这些生动的灯光激发了Blade Runner电影中的未来城市景观,但直到今天,它们还是由一个基...
美国不断对中国半导体产业设限,已演变成为整体科技行业面临的挑战。而美国大选后,中美对决又将对半导体业产生何种影响,国际半导体产业协会(SEMI)董事长兼首席执行官马诺查(Ajit Manocha)近日阐释了自己的看法。Ajit Manocha在接受《天下杂志》采访时明确指出,首先,脱钩不是解决中美当前地缘政治紧张局势的答案。半导体是改善全球人类生活质量的...
该合作支持双方去实现提供业内质量最佳RISC-V的共同愿景中国上海,2021年11月25日——RISC-V验证解决方案的领导者Imperas Software Ltd.和领先的定制化RISC-V处理器半导体知识产权(IP)内核供应商Codasip日前联合宣布:Codasip已为其IP设计引入了Imperas参考设计和Imperas DV解决方案。Codasip已在处理器验证方面进行了巨大的投入,以提供业界最高质量...
手机充电原理图
手机充电原理图…
查看全部问答∨
【UCOSII】(OS_TCB *)0 为什么可以理解为在该优先级无任务
请教各位,如题。 难道不是指向0x00000000这个地址? OS_TCB * 类型为 任务控制块结构体的指针.. (OS_TCB *)0是指向空的任务块,(OS_TCB *)1表示有任务 这该如何理解呢? …
查看全部问答∨
如何给英文版WinCE装中文语言包?
如何给英文版WinCE装中文语言包? 在网上找了一下语言包,没发现支持WinCE的语言包,不知道大家有没有什么方法,请指教。 另外,听人说没有语言包,只能在安装CE系统时用Platform Builder来定制,是这样吗? 但是,怎样定制呢,怎样安装WinCE操 ...…
查看全部问答∨
找培训学校
要求从基础开始 在上海上课周末    教师有能力 有实力 具有一定的开发经验 我想学习硬件设计 最终目标 能自己设计系统 请大家推荐下好的培训学校 …
查看全部问答∨
eboot下使用usb下载nk.nb0问题??
在eboot下使用usb下载nk,可是在PC上提示USB unkown设备。请问使用呢个usb driver???…
查看全部问答∨
请教AD DA的问题
各位高手:     我用AD芯片采集模拟量,然后将数据传到DSP芯片中,DSP直接将数据送给DA芯片。     当我将一个固定电压给到AD时,从DA出来的电压就与AD输入的电压幅值相差20mv左右。当我将一个波形给到AD时,从DA出来的波形是 ...…
查看全部问答∨
在BAT1位置装上电池,充电电路好像不能充电
    在BAT1装上锂电池,电池电压3.5V,LED2还和原来一样,半天闪一下,应该是没有充电。     以前没装电池也是半天闪一下。   U3-STAT  3.87V U3-VSS   0.001V U3-VBAT 3.602V   U3 ...…
查看全部问答∨
【MSP430共享】TI+MSP430单片机教程(很全面)
很全面的MSP430单片机教程,与大家共享,相互交流,相互学习。 …
查看全部问答∨
自己当上帝,DIY闪电!
特斯拉线圈,效果相当壮观,但是工程也相当浩大,造价挺高,并不是每人都能亲手做一个的。如果你只是想领略一下高压电火花的魅力,马克思发生器是一个比较好的选择。只要几个电容、电阻,简单的组合一下,很容易得到几厘米长的电弧,相当漂亮。 ...…
查看全部问答∨
beaglebone心得六:CCS5安装体会
我最近看了下linux,觉得特别繁琐。我是个实用主义的人,不是说linux不搞,只是不是时候。 于是想到了那个久违了的TI库。这就必须用到CCS了。 http://software-dl.ti.com/dsps/dsps_public_sw/am_bu/starterware/02_00_00_07/index_FDS.html 从 ...…
查看全部问答∨
小广播
设计资源 培训 开发板 精华推荐
最新单片机文章
何立民专栏 单片机及嵌入式宝典
电子工程世界版权所有 京ICP证060456号 京ICP备10001474号-1 电信业务审批[2006]字第258号函 京公网安备 11010802033920号 Copyright © 2005-2024 EEWORLD.com.cn, Inc. All rights reserved
