NAND read: device 0 offset 0x400000, size 0x500000 //0x500000是2G?
.....Boot with zImage
Starting kernel ...
Uncompressing Linux... done, booting the kernel.
Initializing cgroup subsys cpu
Linux version 2.6.38-FriendlyARM (root@jensen) (gcc version 4.5.1 (ctng-1.8.1-FA) ) #13 PREEMPT Mon Jul 18 17:07:42 HKT 2011
CPU: ARMv6-compatible processor [410fb766] revision 6 (ARMv7), cr=00c5387f
CPU: VIPT nonaliasing data cache, VIPT nonaliasing instruction cache
Machine: MINI6410
Memory policy: ECC disabled, Data cache writeback
CPU S3C6410 (id 0x36410101)
S3C24XX Clocks, Copyright 2004 Simtec Electronics
camera: no parent clock specified
S3C64XX: PLL settings, A=532000000, M=532000000, E=24000000 //PLL设置
S3C64XX: HCLK2=266000000, HCLK=133000000, PCLK=66500000
mout_apll: source is fout_apll (1), rate is 532000000
mout_epll: source is epll (1), rate is 24000000
mout_mpll: source is mpll (1), rate is 532000000
mmc_bus: source is mout_epll (0), rate is 24000000
usb-bus-host: source is clk_48m (0), rate is 48000000
uclk1: source is dout_mpll (1), rate is 66500000
spi-bus: source is mout_epll (0), rate is 24000000
audio-bus: source is mout_epll (0), rate is 24000000
irda-bus: source is mout_epll (0), rate is 24000000
s3c64xx: 10485760 bytes SDRAM reserved for fimc at 0x5f5f8000
s3c64xx: 8388608 bytes SDRAM reserved for pp at 0x5edf8000
s3c64xx: 8388608 bytes SDRAM reserved for tv at 0x5e5f8000
s3c64xx: 6291456 bytes SDRAM reserved for mfc at 0x5dff8000
s3c64xx: 4194304 bytes SDRAM reserved for jpeg at 0x5dbf8000
Built 1 zonelists in Zone order, mobility grouping on. Total pages: 65024
Kernel command line: root=ubi0:FriendlyARM-root ubi.mtd=2 rootfstype=ubifs init=/linuxrc console=ttySAC0,115200
PID hash table entries: 1024 (order: 0, 4096 bytes)
Dentry cache hash table entries: 32768 (order: 5, 131072 bytes)
Inode-cache hash table entries: 16384 (order: 4, 65536 bytes)
Memory: 256MB = 256MB total //256M内存
Memory: 215160k/215160k available, 46984k reserved, 0K highmem
Virtual kernel memory layout:
vector : 0xffff0000 - 0xffff1000 ( 4 kB)
fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB)
DMA : 0xff600000 - 0xffe00000 ( 8 MB)
vmalloc : 0xd0800000 - 0xf6000000 ( 600 MB)
lowmem : 0xc0000000 - 0xd0000000 ( 256 MB)
modules : 0xbf000000 - 0xc0000000 ( 16 MB)
.init : 0xc0008000 - 0xc0168000 (1408 kB)
.text : 0xc0168000 - 0xc0719d3c (5832 kB)
.data : 0xc071a000 - 0xc075f380 ( 277 kB)
SLUB: Genslabs=13, HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
Preemptable hierarchical RCU implementation.
RCU-based detection of stalled CPUs is disabled.
Verbose stalled-CPUs detection is disabled.
NR_IRQS:246
VIC @f6000000: id 0x00041192, vendor 0x41
VIC @f6010000: id 0x00041192, vendor 0x41
Console: colour dummy device 80x30
console [ttySAC0] enabled
Calibrating delay loop... 530.84 BogoMIPS (lpj=2654208)
pid_max: default: 32768 minimum: 301
Mount-cache hash table entries: 512
CPU: Testing write buffer coherency: ok
NET: Registered protocol family 16
s3c64xx_dma_init: Registering DMA channels
PL080: IRQ 73, at d0808000, channels 0..8
PL080: IRQ 74, at d080c000, channels 8..16
S3C6410: Initialising architecture
bio: create slab SCSI subsystem initialized usbcore: registered new interface driver usbfs usbcore: registered new interface driver hub usbcore: registered new device driver usb s3c-i2c s3c2440-i2c: slave address 0x10 s3c-i2c s3c2440-i2c: bus frequency set to 64 KHz s3c-i2c s3c2440-i2c: i2c-0: S3C I2C adapter Advanced Linux Sound Architecture Driver Version 1.0.23. NET: Registered protocol family 2 IP route cache hash table entries: 2048 (order: 1, 8192 bytes) TCP established hash table entries: 8192 (order: 4, 65536 bytes) TCP bind hash table entries: 8192 (order: 5, 163840 bytes) TCP: Hash tables configured (established 8192 bind 8192) TCP reno registered UDP hash table entries: 128 (order: 0, 6144 bytes) UDP-Lite hash table entries: 128 (order: 0, 6144 bytes) NET: Registered protocol family 1 RPC: Registered udp transport module. RPC: Registered tcp transport module. RPC: Registered tcp NFSv4.1 backchannel transport module. NetWinder Floating Point Emulator V0.97 (double precision) squashfs: version 4.0 (2009/01/31) Phillip Lougher msgmni has been set to 420 io scheduler noop registered (default) io scheduler cfq registered S3C_LCD clock got enabled :: 133.000 Mhz LCD TYPE :: N43 will be initialized Window[0] - FB1: map_video_memory: clear ff600000:0007f800 FB1: map_video_memory: dma=5d780000 cpu=ff600000 size=0007f800 Window[0] - FB2: map_video_memory: clear ff63fc00:0003fc00 FB2: map_video_memory: dma=5d7bfc00 cpu=ff63fc00 size=0003fc00 Console: switching to colour frame buffer device 60x34 fb0: s3cfb frame buffer device Window[1] - FB1: map_video_memory: clear ff680000:0007f800 FB1: map_video_memory: dma=5cc00000 cpu=ff680000 size=0007f800 Window[1] - FB2: map_video_memory: clear ff6bfc00:0003fc00 FB2: map_video_memory: dma=5cc3fc00 cpu=ff6bfc00 size=0003fc00 fb1: s3cfb frame buffer device Window[2] - FB1: map_video_memory: clear ff700000:0003fc00 FB1: map_video_memory: dma=5d740000 cpu=ff700000 size=0003fc00 fb2: s3cfb frame buffer device Window[3] - FB1: map_video_memory: clear ff740000:0003fc00 FB1: map_video_memory: dma=5cc80000 cpu=ff740000 size=0003fc00 fb3: s3cfb frame buffer device backlight initialized s3c6400-uart.0: ttySAC0 at MMIO 0x7f005000 (irq = 16) is a S3C6400/10 //四个串口 s3c6400-uart.1: ttySAC1 at MMIO 0x7f005400 (irq = 20) is a S3C6400/10 s3c6400-uart.2: ttySAC2 at MMIO 0x7f005800 (irq = 24) is a S3C6400/10 s3c6400-uart.3: ttySAC3 at MMIO 0x7f005c00 (irq = 28) is a S3C6400/10 leds initialized buttons initialized pwm initialized adc initialized loop: module loaded S3C NAND Driver, (c) 2008 Samsung Electronics MLC nand initialized, 2011 ported by FriendlyARM S3C NAND Driver is using hardware ECC. NAND device: Manufacturer ID: 0xec, Chip ID: 0xd5 (Samsung NAND 2GiB 3,3V 8-bit) Creating 3 MTD partitions on "NAND 2GiB 3,3V 8-bit": 0x000000000000-0x000000400000 : "Bootloader" //Boot,内核和文件系统存储地址区间 0x000000400000-0x000000c00000 : "Kernel" 0x000000c00000-0x000080000000 : "File System" UBI: attaching mtd2 to ubi0 UBI: physical eraseblock size: 1048576 bytes (1024 KiB) UBI: logical eraseblock size: 1032192 bytes UBI: smallest flash I/O unit: 8192 UBI: VID header offset: 8192 (aligned 8192) UBI: data offset: 16384 UBI: max. sequence number: 9 UBI: attached mtd2 to ubi0 UBI: MTD device name: "File System" UBI: MTD device size: 2036 MiB UBI: number of good PEBs: 2030 UBI: number of bad PEBs: 6 UBI: number of corrupted PEBs: 0 UBI: max. allowed volumes: 128 UBI: wear-leveling threshold: 4096 UBI: number of internal volumes: 1 UBI: number of user volumes: 1 UBI: available PEBs: 0 UBI: total number of reserved PEBs: 2030 UBI: number of PEBs reserved for bad PEB handling: 20 UBI: max/mean erase counter: 2/0 UBI: image sequence number: 1618989453 UBI: background thread "ubi_bgt0d" started, PID 634 PPP generic driver version 2.4.2 PPP Deflate Compression module registered PPP BSD Compression module registered PPP MPPE Compression module registered NET: Registered protocol family 24 dm9000 Ethernet Driver, V1.31 eth0: dm9000a at d0930000,d0e00004 IRQ 108 MAC: 08:90:90:90:90:90 (chip) ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver s3c2410-ohci s3c2410-ohci: S3C24XX OHCI s3c2410-ohci s3c2410-ohci: new USB bus registered, assigned bus number 1 s3c2410-ohci s3c2410-ohci: irq 79, io mem 0x74300000 usb usb1: New USB device found, idVendor=1d6b, idProduct=0001 usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1 usb usb1: Product: S3C24XX OHCI usb usb1: Manufacturer: Linux 2.6.38-FriendlyARM ohci_hcd usb usb1: SerialNumber: s3c24xx hub 1-0:1.0: USB hub found hub 1-0:1.0: 2 ports detected usbcore: registered new interface driver usbserial USB Serial support registered for generic usbcore: registered new interface driver usbserial_generic usbserial: USB Serial Driver core USB Serial support registered for aircable usbcore: registered new interface driver aircable USB Serial support registered for ark3116 usbcore: registered new interface driver ark3116 ark3116:v0.6:USB ARK3116 serial/IrDA driver USB Serial support registered for Belkin / Peracom / GoHubs USB Serial Adapter usbcore: registered new interface driver belkin belkin_sa: v1.3:USB Belkin Serial converter driver
上一篇:NXPLPC ARM 必须知道的知识
下一篇:tiny6410开发板的Linux系统修改IP地址
在二十世纪末,ETA Electric Industry Co Ltd还只是一个小型的电子设备制造商,专注于生产简单的电子元器件。当时,公司的创始人李先生看到了电子行业快速发展的潜力,并决定投身于这一行业。最初,公司面临着资金紧张、技术落后、市场竞争加剧等诸多挑战。然而,李先生凭借其敏锐的市场洞察力和不懈的努力,逐渐打开了市场局面。他们通过与小型科技企业合作,为其提供定制化的电子元器件,逐渐在市场上站稳了脚跟。
上海如韵电子有限公司,简称如韵(CONSONANCE),总部位于上海张江高新产业园嘉定园。公司由一群热爱电子技术的专业人士于2004年共同创立,注册资本200万元人民币。在创立初期,公司面临着资金紧张、市场竞争激烈等多重挑战。然而,凭借着对电子行业的深刻理解和敏锐的市场洞察力,如韵逐渐在市场上站稳了脚跟。
初期,如韵主要致力于微电子集成电路的设计与销售。公司创始人于志升带领团队,通过不断创新和技术突破,成功开发出一系列具有市场竞争力的产品。这些产品在华北、华东、华南、西南等地区建立了庞大的销售网络,与几十家专业代理商建立了长期合作关系,为公司的稳步发展奠定了坚实基础。
Holt在支持ARINC 429标准方面展现出了强大的实力。其ARINC 429 IC产品系列从简单的线路接收器到集成RAM的完整协议解决方案,覆盖了业内最广泛的范围。这些产品设计精巧,能够在单个3.3V电源上运行,显著降低了系统复杂性和板空间,为航空电子系统带来了更高的效率和可靠性。Holt的这一系列创新产品,不仅满足了航空制造商的严格需求,也推动了ARINC 429标准在全球范围内的广泛应用。
为了进一步扩大市场份额和提升品牌影响力,Allianc公司开始实施国际化战略。公司积极开拓海外市场,与多家国际知名企业建立了合作关系。同时,公司还加强了对海外市场的调研和分析,针对不同地区的消费者需求推出了定制化产品。这些举措使得Allianc公司在国际市场上的份额不断攀升,品牌影响力也逐渐增强。
在XXXX年,Allianc公司迎来了一次重大的技术突破。公司研发团队成功开发出了一款具有领先性能的新型电子产品,该产品不仅具有更高的性能和更低的能耗,还具备更好的用户体验。这一技术突破使得Allianc公司在市场上迅速脱颖而出,赢得了大量客户的青睐。随着产品销量的不断攀升,公司的知名度和影响力也逐渐扩大。
随着技术的不断成熟,Globaltech开始积极拓展国际市场。公司通过与国内外多家系统厂商建立紧密的合作关系,共同开发新产品,进一步提升了其市场竞争力。特别是在亚洲市场,Globaltech凭借其高性价比的产品和快速的响应能力,迅速占据了大量市场份额。同时,公司还积极参与国际展会,与全球客户面对面交流,进一步提升了品牌知名度和影响力。
随着汽车拥有量的增加,发生交通事故的概率也随之增加,发生事故后用传统的方法进行分析、判断、维修有一定的困难。这样,就给人们提出了一个问题,怎样及时、准备地分析故障的存在,客观地分析事故的责任。由此联系到飞机上装的“黑匣子”,一旦飞 ...… 查看全部问答∨ |
如何以DSD模式将多个,Pcm4222,pcm1792,连接到Ti的dsp上? 如何以DSD模式将多个,Pcm4222,pcm1792,连接到Ti的dsp上? 还有个什么TDM模式是什么? Tms320vc5402如何连接到异步SRam?… 查看全部问答∨ |
版主,请教一个问题。我用的是STM8S103K3的片子,由于是第一次使用ST单片机,所以很多的地方不明白。我现在用TIM2 的第三通道来捕获一个脉冲信号,并要把脉冲宽度读出来。我按着数据手册上一步一步的做,结果还是没有出来,能在进入捕获中断, ...… 查看全部问答∨ |
TinyOS在MSP430F2618+CC2520平台上移植交流 目前TinyOS还仅支持MSP430低端的MCU比如f1611,以及CC2420等射频芯片。针对MSP430高端系列单片机,以及TI推出的第二代射频芯片CC2520还未能支持 前段时间把TinyOS移植到了上述平台上,基本功能都已经实现,针对无线协议栈还需要进一步优化!希望有 ...… 查看全部问答∨ |
设计资源 培训 开发板 精华推荐
- 是德科技有奖直播|感恩月开幕式——示波器大讲堂
- 共抗疫情 少出门多学习: 多部TI实用课程奉上, 身体不能在路上就让灵魂在路上
- 答题赢京东卡|PI InnoSwitch产品系列学习中心
- 免费申请测评:超小型 Linux 开发套件:Quantum Tiny Linux(带 SoM 和扩展板)
- 观看安森美半导体高灵敏度触摸传感器应用视频,轻松答题赢好礼!
- 关注、评论赢好礼!《美光2022台北国际电脑展主题演讲精选:智能边缘与智能制造专辑》
- 【直播已结束】一起深挖 TI 新发布的 Robotics SDK,看干货直播赢好礼!
- 《美光2022台北国际电脑展主题演讲精选:数据中心专辑》,关注、评论赢固态硬盘等好礼!
- 新用户限时福利:e络盟商城迎新季,全场包邮+打折~买一只电阻也包邮!
- 下载有好礼!未来已来,你准备好了吗?益莱储5G白皮书!
