1、特点:
• Interrupt vector base register (IVBR)
•中断向量基址寄存器(IVBR)
• One spurious interrupt vector (at address vector base1 + 0x0010).
•一个伪中断向量(矢量base1在地址+ 0x0010)。
• One non-maskable system call interrupt vector request (at address vector base + 0x0012).
•一个不可屏蔽系统调用中断向量请求(在地址向量基地+ 0x0012)。
• Three non-maskable access violation interrupt vector requests (at address vector base + 0x0014−
0x0018).•三个不可屏蔽中断访问冲突(在地址向量基地+ 载体的要求−0x0014 0x0018)。
• 2–109 I bit maskable interrupt vector requests (at addresses vector base + 0x001A–0x00F2).
•2-109余位屏蔽中断向量请求(在地址向量基地+ 0x001A - 0x00F2)。
• Each I bit maskable interrupt request has a configurable priority level and can be configured to be handled by either the CPU or the XGATE module2.
•每个余位屏蔽中断请求有一个可配置的优先级,可配置为一方的CPU了XGATE模块2处理。
• I bit maskable interrupts can be nested, depending on their priority levels.
•余位屏蔽中断可以嵌套,根据其优先级。
• One X bit maskable interrupt vector request (at address vector base + 0x00F4).
•一个X位屏蔽中断向量请求(在地址向量基地+ 0x00F4)
• One non-maskable software interrupt request (SWI) or background debug mode vector request (at
address vector base + 0x00F6).•一个非屏蔽软件中断请求或背景调试模式(在请求处理向量向量基地+ 0x00F6)。
• One non-maskable unimplemented op-code trap (TRAP) vector (at address vector base + 0x00F8).
•一个非屏蔽没有得到执行操作码矢量(向量在地址基地+ 0x00F8)。
• Three system reset vectors (at addresses 0xFFFA–0xFFFE).•三个系统(在复位向量地址0xFFFA - 0xFFFE)。
• Determines the highest priority XGATE and interrupt vector requests, drives the vector to the
XGATE module or to the bus on CPU request, respectively.•确定最优先的XGATE的中断向量和要求,驱动的矢量,XGATE模块或请求总线在CPU
• Wakes up the system from stop or wait mode when an appropriate interrupt request occurs or
whenever XIRQ is asserted, even if X interrupt is masked.•一个适当的中断请求时,或当XIRQ被中断,甚至如果X中断屏蔽都可以使系统在停止或等待模式响应。
• XGATE can wake up and execute code, even with the CPU remaining in stop or wait mode.•XGATE可以响应和执行代码,甚至与CPU,在停止或等待模式剩余。
4.1.3 Modes of Operation
工作模式
• Run mode运行模式
This is the basic mode of operation.这是基本的运作模式
• Wait mode等待模式
In wait mode, the XINT module is frozen. It is however capable of either waking up the CPU if an interrupt occurs or waking up the XGATE if an XGATE request occurs. Please refer to Section 4.5.3, “Wake Up from Stop or Wait Mode” for details.
在等待模式下,XINT模块被冻结。然而,它是否能够在中断发生的时候使CPU响应或者XGATE请求发生的时候使XGATE响应。请参阅 第4.5.3节“在停止或等待模式中响应”的细节。
• Stop Mode停止模式
In stop mode, the XINT module is frozen. It is however capable of either waking up the CPU if an interrupt occurs or waking up the XGATE if an XGATE request occurs. Please refer to Section 4.5.3, “Wake Up from Stop or Wait Mode” for details.
在停止模式下,XINT模块被冻结。然而,它是否能够在中断发生的时候使CPU响应或者XGATE请求发生的时候使XGATE响应。请参阅 第4.5.3节“在停止或等待模式中响应”的细节。
• Freeze mode (BDM active)
In freeze mode (BDM active), the interrupt vector base register is overridden internally. Please refer to Section 4.3.2.1, “Interrupt Vector Base Register (IVBR)” for details.
在冻结模式(BDM活动),中断向量基址寄存器重写内部。请参阅第4.3.2.1“中断向量基址寄存器(IVBR)”的细节。
上一篇:飞思卡尔启动过程
下一篇:飞思卡尔MC9S12系列单片机地址影射以及分页问题
Amecon Magnetics公司成立于XXXX年,初始阶段主要专注于磁性材料的研发与生产。在创立初期,公司面临着资金短缺、技术挑战以及市场竞争激烈等多重困难。然而,创始人凭借对磁性材料领域的深刻理解和坚定信念,带领团队不断突破技术难题,逐步开发出具有竞争力的产品。
芯佰微(Corebai)公司自创立之初,就致力于成为电子行业中微电子领域的领军企业。创始人团队凭借对半导体技术的深厚理解和对市场需求的敏锐洞察,确立了公司的核心技术路线——专注于高性能模拟和数字集成电路的研发。在创业初期,芯佰微就投入大量资源用于技术研发,成功研发出多款具有自主知识产权的集成电路产品,奠定了公司在行业中的技术基础。
在竞争激烈的电子照明市场中,Califia Lighting始终坚持以技术创新为核心竞争力。公司不断投入研发资源,推动LED照明技术的升级和突破。通过引入先进的生产工艺和设计理念,Califia Lighting成功开发出了一系列具有独特优势的产品,如高效节能、长寿命、环保等,赢得了市场的广泛认可。
近年来,All Sensors通过与深圳电通纬创微电子股份有限公司的合作,成立了中美合资企业——深圳华美澳通传感器有限公司。这一合资企业的成立,不仅加强了All Sensors在中国市场的地位,也为其在全球范围内的业务拓展提供了有力支持。华美澳通公司利用All Sensors的专利技术,专业从事MEMS压力传感器及应用模组的研发、生产及销售,为电子行业提供了更多优质的产品和服务。
为了进一步扩大市场份额,华宇创开始积极拓展国内外市场。公司参加了多场国际电子展和博览会,与全球各地的客户建立了广泛的联系。同时,华宇创还与国际知名电子企业建立了战略合作关系,共同研发新技术、新产品。这些国际合作不仅为华宇创带来了更多的商业机会,也提升了公司在国际市场的地位和影响力。
基本知识 ADC0809是带有8位A/D转换器、8路多路开关以及微处理机兼容的控制逻辑的CMOS组件。它是逐次逼近式A/D转换器,可以和单片机直接接口。 (1).ADC0809的内部逻辑结构 由上图可知,ADC0809由一个8路模拟开关、一个地址锁存与译 ...… 查看全部问答∨ |
我用的LPC2138芯片,开发软件是ADS 程序如下: int main(void) { uint8 flag = 0; sys = (SYS_TYPE *) malloc(sizeof(SYS_TYPE)); &nb ...… 查看全部问答∨ |
platformbuilder编译错误,请高手指点,谢谢啦! 这是build.err的内容 D:\\WINCE500\\build.log(1) : error SYSGEN0000: error(s) in sysgen phase 这是build.log的内容 Starting sysgen phase for project ( common ) Found localized resources for Languages ( 0404 0407 040C 0410 0411 ...… 查看全部问答∨ |
在X86平台下硬件寄存器可以映射到IO地址空间也可以映射到物理地址空间,那硬件寄存器又是怎样实现不同的映射的了? 一个硬件寄存器我又如何区分是那一种映射了?… 查看全部问答∨ |
小弟现有一个勤研的2410开发板 但是没有显示器,板上提供的LCD接口是那种40针的IDE线,我弄了个LCD,不知道怎么接?请了解的给与帮助,,先在此谢过!… 查看全部问答∨ |
RT,就是点击一个按钮后弹出的只有OK键的那种对话框, 小弟对win32不熟悉,望各位详细讲解,谢谢, 另外,想问一下,因为是做手机应用软件的开发, 看一些教程都是用MFC的一个工程去做,为什么我们这用win32呢, 这两个开发手机应用软件有什么 ...… 查看全部问答∨ |
