涉及6个文件
head.S,init.c,main.c,makefile,nand.c,out.lds
head.S
.text
.global _start
_start:
b Reset
HandleUndef:
b HandleUndef
HandleSWI:
b HandleSWI
HandlePrefetchAbort:
b HandlePrefetchAbort
HandleDataAbort:
b HandleDataAbort
HandleNotUsed:
b HandleNotUsed
b HandleIRQ
HandleFIQ:
b HandleFIQ
Reset:
ldr r0, =0x53000000
mov r1, #0x0
str r1, [r0] @disable watchdog
msr cpsr_c, #0xd2 @IRQ mode,ARM mode,IRQ disable
ldr sp, =3072
msr cpsr_c, #0xd3 @Supervisor mode,ARM mode,IRQ disable
ldr sp, =1024*4 @set up stack,4K
msr cpsr_c, #0x53 @Supervisor mode,ARM mode,IRQ enable
ldr sp, =4096
bl clock_init
bl memsetup
bl nand_init
ldr r0, =0x30000000 @target address(sdram),nand_read 1parameter
mov r1, #4096 @start address,nand_read 2parameter
mov r2, #2048*2 @size copy to sdram,nand_read 3parameter
bl nand_read
bl create_page_table
bl mmu_init
ldr sp, =0xB4000000 @pstack go to sdram
ldr lr, =halt_loop
ldr pc, =main
halt_loop:
b halt_loop
HandleIRQ:
sub lr, lr, #4
stmdb sp!, {r0-r12,lr}
ldr lr, =int_return
ldr pc, =TIMER_Handle
int_return:
ldmia sp!, { r0-r12,pc }^
init.c
#define BWSCON (*(volatile unsigned long *)0x48000000)
#define BANKCON0 (*(volatile unsigned long *)0x48000004)
#define BANKCON1 (*(volatile unsigned long *)0x48000008)
#define BANKCON2 (*(volatile unsigned long *)0x4800000C)
#define BANKCON3 (*(volatile unsigned long *)0x48000010)
#define BANKCON4 (*(volatile unsigned long *)0x48000014)
#define BANKCON5 (*(volatile unsigned long *)0x48000018)
#define BANKCON6 (*(volatile unsigned long *)0x4800001C)
#define BANKCON7 (*(volatile unsigned long *)0x48000020)
#define REFRESH (*(volatile unsigned long *)0x48000024)
#define BANKSIZE (*(volatile unsigned long *)0x48000028)
#define MRSRB6 (*(volatile unsigned long *)0x4800002C)
#define MRSRB7 (*(volatile unsigned long *)0x48000030)
#define CLKDIVN (*(volatile unsigned long *)0x4C000014)
#define MPLLCON (*(volatile unsigned long *)0x4C000004)
#define S3C2440_MPLL_400MHZ 0x5C011
void memsetup()
BWSCON=0x22011110;
BANKCON0=0x00000700;//sram
BANKCON1=0x00000700;//rom
BANKCON2=0x00000700;
BANKCON3=0x00000700;
BANKCON4=0x00000700;
BANKCON5=0x00000700;
BANKCON6=0x00018005;//sdram
BANKCON7=0x00018005;
REFRESH=0x008C04F4;
BANKSIZE=0x000000B1;
MRSRB6=0x00000030;
MRSRB7=0x00000030;
void clock_init()
CLKDIVN=0x05;
__asm__(
"mrc p15, 0, r1, c1, c0, 0n"
"orr r1, r1, #0xc0000000n"
"mcr p15, 0, r1, c1, c0, 0n"
MPLLCON=S3C2440_MPLL_400MHZ;
void create_page_table(void)
#define MMU_FULL_ACCESS (3 << 10)
#define MMU_DOMAIN (0 << 5)
#define MMU_SPECIAL (1 << 4)
#define MMU_CACHEABLE (1 << 3)
#define MMU_BUFFERABLE (1 << 2)
#define MMU_SECTION (2)
#define MMU_SECDESC (MMU_FULL_ACCESS | MMU_DOMAIN | MMU_SPECIAL | MMU_SECTION)
#define MMU_SECDESC_WB (MMU_FULL_ACCESS | MMU_DOMAIN | MMU_SPECIAL |
MMU_CACHEABLE | MMU_BUFFERABLE | MMU_SECTION)
#define MMU_SECTION_SIZE 0x00100000
unsigned long virtuladdr, physicaladdr;
unsigned long *mmu_tlb_base = (unsigned long *)0x30000000;
virtuladdr = 0;
physicaladdr = 0;
*(mmu_tlb_base + (virtuladdr >> 20)) = (physicaladdr & 0xFFF00000) | MMU_SECDESC_WB;//0~4096 the same
virtuladdr = 0x56000000;
physicaladdr = 0x56000000;
*(mmu_tlb_base + (virtuladdr >> 20)) = (physicaladdr & 0xFFF00000) | MMU_SECDESC;
virtuladdr = 0x4A000000;
physicaladdr = 0x4A000000;
virtuladdr = 0x51000000;
physicaladdr = 0x51000000;
/*SDRAM to 0xB0000000~0xB4000000*/
virtuladdr = 0xB0000000;
physicaladdr = 0x30000000;
while (virtuladdr < 0xB4000000)
virtuladdr += 0x100000;
physicaladdr += 0x100000;
* 启动MMU
void mmu_init(void)
unsigned long ttb = 0x30000000;
__asm__(
"mov r0, #0n"
"mcr p15, 0, r0, c7, c7, 0n"
"mcr p15, 0, r0, c7, c10, 4n"
"mcr p15, 0, r0, c8, c7, 0n"
"mov r4, %0n"
"mcr p15, 0, r4, c2, c0, 0n"
"mvn r0, #0n"
"mcr p15, 0, r0, c3, c0, 0n"
"mrc p15, 0, r0, c1, c0, 0n"
"bic r0, r0, #0x3000n"
"bic r0, r0, #0x0300n"
"bic r0, r0, #0x0087n"
"orr r0, r0, #0x0002n"
"orr r0, r0, #0x0004n"
"orr r0, r0, #0x1000n"
"orr r0, r0, #0x0001n"
"mcr p15, 0, r0, c1, c0, 0n"
: "r" (ttb) );
main.c
led1 f4,led2 f5,led3 f6,int0 f0
#define GPFCON (*(volatile unsigned long *)0x56000050)
#define GPFDAT (*(volatile unsigned long *)0x56000054)
#define GPF4_OUT (1<<(4*2))
#define GPF5_OUT (1<<(5*2))
#define GPF6_OUT (1<<(6*2))
#define GPF4_CON_MSK (3<<(4*2))
#define GPF5_CON_MSK (3<<(5*2))
#define GPF6_CON_MSK (3<<(6*2))
#define GPF4_DAT_MSK (1<<(4))
#define GPF5_DAT_MSK (1<<(5))
#define GPF6_DAT_MSK (1<<(6))
#define TIMER0_MSK (1<<(10))
#define TCFG0 (*(volatile unsigned long *)0x51000000)
#define TCON (*(volatile unsigned long *)0x51000008)
#define TCNTB0 (*(volatile unsigned long *)0x5100000C)
#define INTOFFSET (*(volatile unsigned long *)0x4A000014)
#define SRCPND (*(volatile unsigned long *)0X4A000000)
#define INTMSK (*(volatile unsigned long *)0X4A000008)
#define PRIORITY (*(volatile unsigned long *)0x4A00000C)
#define INTPND (*(volatile unsigned long *)0X4A000010)
void init_timer0()
SRCPND=0x0;
INTMSK=~TIMER0_MSK;
TCFG0=0xff;
TCNTB0=0xffff;
TCON=0xa;
TCON=0x9;
void led_set_out()
GPFCON&=~(GPF4_CON_MSK|GPF5_CON_MSK|GPF6_CON_MSK);
GPFCON|=GPF4_OUT|GPF5_OUT|GPF6_OUT;
GPFDAT&=~(GPF4_DAT_MSK);
GPFDAT&=~(GPF5_DAT_MSK);
GPFDAT&=~(GPF6_DAT_MSK);
GPFDAT|=(1<<4);
GPFDAT|=(1<<5);
GPFDAT|=(1<<6);
void led_reset(int ledn)
if(ledn==1)
GPFDAT|=(1<<4);
else if(ledn==2)
GPFDAT|=(1<<5);
else
GPFDAT|=(1<<6);
void led_set(int ledn)
if(ledn==1)
else if(ledn==2)
else
void TIMER_Handle()
int i;
led_set(1);
for(i=0;i<1000000;i++);
led_reset(1);
SRCPND=1< int main() { int i; led_set_out(); init_timer0(); while(1) { led_reset(2); for(i=0;i<10000000;i++); led_set(2); for(i=0;i<10000000;i++); } return 0; } makefile out.bin : head.S main.c nand.c init.c arm-linux-gcc -c -o head.o head.S arm-linux-gcc -c -o main.o main.c arm-linux-gcc -c -o nand.o nand.c arm-linux-gcc -c -o init.o init.c arm-linux-ld -Tout.lds head.o main.o nand.o init.o -o out_elf arm-linux-objcopy -O binary -S out_elf out.bin arm-linux-objdump -D -m arm out_elf > out.dis #rm -f out.dis out_elf *.o clean: rm -f out.dis out.bin out_elf *.o nand.c #define LARGER_NAND_PAGE #define GSTATUS1 (*(volatile unsigned int *)0x560000B0) #define BUSY 1 #define NAND_SECTOR_SIZE 512 #define NAND_BLOCK_MASK (NAND_SECTOR_SIZE - 1) #define NAND_SECTOR_SIZE_LP 2048 #define NAND_BLOCK_MASK_LP (NAND_SECTOR_SIZE_LP - 1) typedef unsigned int S3C24X0_REG32; /* NAND FLASH (see S3C2410 manual chapter 6) */ typedef struct { S3C24X0_REG32 NFCONF; S3C24X0_REG32 NFCMD; S3C24X0_REG32 NFADDR; S3C24X0_REG32 NFDATA; S3C24X0_REG32 NFSTAT; S3C24X0_REG32 NFECC; } S3C2410_NAND; /* NAND FLASH (see S3C2440 manual chapter 6, www.100ask.net) */ typedef struct { S3C24X0_REG32 NFCONF;
上一篇:s3c6410 系统时钟
下一篇:ARM的step内存到SDRAM内存代码复制程序调试之罪魁祸首 ADR与LDR
- 创业初期:
- 描述Clulite公司的创始人或核心团队如何识别电子行业中的某个市场机遇。
- 讲述他们是如何筹集初始资金,设立公司,并开发出第一款产品或解决方案的。
- 可以提及公司在初创阶段面临的挑战,如技术难题、市场竞争等。
- 技术创新:
- 讲述Clulite如何通过研发创新,推出了一款颠覆性的产品或技术,从而获得了市场认可。
- 详细描述这一创新过程,包括研发团队的努力、关键技术的突破等。
- 提及这一创新如何帮助公司在市场上取得了竞争优势。
- 市场拓展:
- 描述Clulite如何逐步扩大市场份额,从地区市场走向全国乃至国际市场。
- 可以讲述公司如何建立销售网络、与合作伙伴建立合作关系,以及参与行业展会等活动来推广品牌和产品。
- 提及公司在市场拓展过程中遇到的挑战和应对策略。
- 品质管理:
- 讲述Clulite如何注重产品质量和客户体验,通过严格的质量控制流程来提升产品可靠性。
- 描述公司如何建立完善的售后服务体系,为客户提供及时、专业的支持。
- 提及这些举措如何帮助公司赢得了客户的信任和口碑。
- 可持续发展:
- 讲述Clulite如何关注环境保护和社会责任,推动公司的可持续发展。
- 描述公司如何采取环保措施,减少生产过程中的污染排放。
- 提及公司如何参与社会公益事业,回馈社会。
请注意,这些故事需要根据Clulite公司的实际情况进行调整和补充。如果你需要更具体的内容,建议查阅Clulite公司的官方网站、新闻报道或行业分析报告,以获取更详细的信息和数据。
ASI Semiconductor, Inc.(以下简称ASI)的故事始于1979年,当时它在美国加利福尼亚州北好莱坞成立。作为一家初创企业,ASI专注于设计、供应和市场先进的高功率、脉冲射频晶体管和托盘。在早期,ASI以其独特的技术视角和市场需求洞察,迅速在行业中站稳了脚跟。通过与摩托罗拉、飞利浦等公司的合作,ASI开始为商用航空电子设备、雷达、医疗和工业应用提供高质量的射频功率晶体管。这种初步的成功为ASI日后的快速发展奠定了坚实的基础。
在追求经济效益的同时,Ericsson Power Modules也注重环保和可持续发展。公司积极采用环保材料和绿色生产工艺,降低生产过程中的能耗和排放。此外,Ericsson Power Modules还积极参与环保公益活动,推动电子行业的绿色发展。这种环保意识和行动体现了Ericsson Power Modules对社会的责任感和对可持续发展的承诺。
进入20世纪80年代和90年代,Harbour Industries继续深化其在电缆领域的研发。为了满足军事和国防部门对电缆的特殊需求,公司开始研发并生产Mil-Spec(军用规格)电缆。这些电缆不仅具备高度的耐用性和可靠性,还符合严格的军事标准。Harbour凭借其在技术上的不断创新和产品质量的持续提升,成功地将Mil-Spec电缆推向市场,并赢得了众多军事客户和合作伙伴的信赖。
背景:2004年,为了适应国家经济发展和产业布局调整的需要,振华新云面临从凯里白午山区调迁至贵阳市新添高新技术开发区的挑战。
内容:在调迁过程中,公司克服了种种困难,如设备搬迁、员工安置、生产线重建等。通过精心组织和周密安排,确保了调迁工作的顺利进行。
成果:调迁完成后,振华新云在贵阳市新添高新技术开发区迎来了新的发展机遇,为公司后续的快速发展提供了有力保障。
背景:随着电子行业的快速发展,振华新云不断加大技术创新和产品研发力度。
内容:公司积极引进先进技术和设备,加强与国际先进企业的合作与交流。同时,注重培养高素质的技术人才队伍,为技术创新和产品研发提供有力支持。
成果:通过持续不断的技术创新和产品研发,振华新云在电子元器件领域取得了多项重要成果,如开发出具有国际先进水平的钽电解电容器等产品,进一步巩固了公司在行业中的领先地位。
来源:今日电子 作者:Michael Hsieh 所有的数字电路都需要依靠时钟信号来使组件的运作同步,每单位时间内电路可运作的次数取决于时钟的频率,因此时钟运作的频率即被大家视为系统运作的性能指针。 主机板时钟电路的需求--- &nb ...… 查看全部问答∨ |
不法分子通常利用银行下班后的时间作案,因此持卡人在银行下班后,尤其是在夜间或凌晨进入自助银行使用ATM机时应格外提高警惕,观察周围有无尾随、偷窥等可疑情况。所以要尽量避免在太晚的时候进入自助银行,或避免进入位置僻静的自助银行。 而且进 ...… 查看全部问答∨ |
摘 要:本文主要介绍汽车电子产品供应商给车厂供货时,由于严酷EMC要求,往往电磁兼容验证不能通过,导致供货受到一定的影响;本文结合实际设计一个普通的产品 EMC进行分析,说明车厂的EMC要求以及常见问题与解决方法。 关键词: BCI(大电流注 ...… 查看全部问答∨ |
byteflight协议由BMW联合Motorola,Elmos及Infineon公司联合开发,主要用于机动车辆中的安全临界应用。该系统应用在BMW 7系列汽车中,主要用于安全气囊系统中时间临界(time-critical)数据的传输。另外,还可用于传输车身及底盘电子系统的相关数据。 ...… 查看全部问答∨ |
高价收购现有手持嵌入式或单片机RFID数据采集产品的方案 我现在有个项目要用手持的数据采集产品,现高价收购 要求如下: 1.提供原理图,PCB Layout 2.提供系统软件原代码 3.使用单片机或嵌入式CPU 4.读写RFID 5.将RFID资料用GRPS发给服务器 ...… 查看全部问答∨ |
最近相当的崩溃阿,设计一点进展都没有,只好来求助各路达人了。 我要实现一个远程监控系统,终端与中心采用GPRS通信。目前我负责终端采集和通信部分。通信采用了华为的GPRS模块GTM900,自带TCP/IP协议的。我知道,只要用单片机串口写AT命令给模块 ...… 查看全部问答∨ |
