先提个问题:看到有的网卡是连在ISA总线或者是PCI总线上的,那在mini2440上dm9000和CPU是直接相连的,这个算是什么总线? 没弄明白这个问题
首先是平台设备的register和unregister.
static int __init
dm9000_init(void)
#if defined(CONFIG_ARCH_S3C2410)
unsigned int oldval_bwscon = *(volatile unsigned int *)S3C2410_BWSCON;
unsigned int oldval_bankcon4 = *(volatile unsigned int *)S3C2410_BANKCON4;
*((volatile unsigned int *)S3C2410_BWSCON) =
(oldval_bwscon & ~(3<<16)) | S3C2410_BWSCON_DW4_16 | S3C2410_BWSCON_WS4 | S3C2410_BWSCON_ST4;
*((volatile unsigned int *)S3C2410_BANKCON4) = 0x1f7c;
#endif
printk(KERN_INFO "%s Ethernet Driver, V%sn", CARDNAME, DRV_VERSION);
return platform_driver_register(&dm9000_driver);
static void __exit
dm9000_cleanup(void)
platform_driver_unregister(&dm9000_driver);
dm9000_init中,#if defined 中间的内容是什么意思我不清楚。以上两个函数就是平台设备的注册和取消。
一、下面分析dm9000_probe函数,这个是平台设备主要的初始化函数
* Search DM9000 board, allocate space and register it
static int __devinit
dm9000_probe(struct platform_device *pdev)
struct dm9000_plat_data *pdata = pdev->dev.platform_data;
struct board_info *db; /* Point a board information structure */
struct net_device *ndev;
const unsigned char *mac_src;
int ret = 0;
int iosize;
int i;
u32 id_val;
/* Init network device */
ndev = alloc_etherdev(sizeof(struct board_info));
if (!ndev) {
dev_err(&pdev->dev, "could not allocate device.n");
return -ENOMEM;
SET_NETDEV_DEV(ndev, &pdev->dev);
dev_dbg(&pdev->dev, "dm9000_probe()n");
/* setup board info structure */
db = netdev_priv(ndev);
db->dev = &pdev->dev;
db->ndev = ndev;
spin_lock_init(&db->lock);
mutex_init(&db->addr_lock);
INIT_DELAYED_WORK(&db->phy_poll, dm9000_poll_work);
db->addr_res = platform_get_resource(pdev, IORESOURCE_MEM, 0);
db->data_res = platform_get_resource(pdev, IORESOURCE_MEM, 1);
db->irq_res = platform_get_resource(pdev, IORESOURCE_IRQ, 0);
if (db->addr_res == NULL || db->data_res == NULL ||
db->irq_res == NULL) {
dev_err(db->dev, "insufficient resourcesn");
ret = -ENOENT;
goto out;
iosize = resource_size(db->addr_res);
db->addr_req = request_mem_region(db->addr_res->start, iosize,
pdev->name);
if (db->addr_req == NULL) {
dev_err(db->dev, "cannot claim address reg arean");
ret = -EIO;
goto out;
db->io_addr = ioremap(db->addr_res->start, iosize);
if (db->io_addr == NULL) {
dev_err(db->dev, "failed to ioremap address regn");
ret = -EINVAL;
goto out;
iosize = resource_size(db->data_res);
db->data_req = request_mem_region(db->data_res->start, iosize,
pdev->name);
if (db->data_req == NULL) {
dev_err(db->dev, "cannot claim data reg arean");
ret = -EIO;
goto out;
db->io_data = ioremap(db->data_res->start, iosize);
if (db->io_data == NULL) {
dev_err(db->dev, "failed to ioremap data regn");
ret = -EINVAL;
goto out;
/* fill in parameters for net-dev structure */
ndev->base_addr = (unsigned long)db->io_addr;
ndev->irq = db->irq_res->start;
/* ensure at least we have a default set of IO routines */
dm9000_set_io(db, iosize);
/* check to see if anything is being over-ridden */
if (pdata != NULL) {
/* check to see if the driver wants to over-ride the
* default IO width */
if (pdata->flags & DM9000_PLATF_8BITONLY)
dm9000_set_io(db, 1);
if (pdata->flags & DM9000_PLATF_16BITONLY)
dm9000_set_io(db, 2);
if (pdata->flags & DM9000_PLATF_32BITONLY)
dm9000_set_io(db, 4);
/* check to see if there are any IO routine
* over-rides */
if (pdata->inblk != NULL)
db->inblk = pdata->inblk;
if (pdata->outblk != NULL)
db->outblk = pdata->outblk;
if (pdata->dumpblk != NULL)
db->dumpblk = pdata->dumpblk;
db->flags = pdata->flags;
#ifdef CONFIG_DM9000_FORCE_SIMPLE_PHY_POLL
db->flags |= DM9000_PLATF_SIMPLE_PHY;
#endif
dm9000_reset(db);
/* try multiple times, DM9000 sometimes gets the read wrong */
for (i = 0; i < 8; i++) {
id_val = ior(db, DM9000_VIDL);
id_val |= (u32)ior(db, DM9000_VIDH) << 8;
id_val |= (u32)ior(db, DM9000_PIDL) << 16;
id_val |= (u32)ior(db, DM9000_PIDH) << 24;
if (id_val == DM9000_ID)
break;
dev_err(db->dev, "read wrong id 0x%08xn", id_val);
if (id_val != DM9000_ID) {
dev_err(db->dev, "wrong id: 0x%08xn", id_val);
ret = -ENODEV;
goto out;
/* Identify what type of DM9000 we are working on */
id_val = ior(db, DM9000_CHIPR);
dev_dbg(db->dev, "dm9000 revision 0x%02xn", id_val);
switch (id_val) {
case CHIPR_DM9000A:
db->type = TYPE_DM9000A;
break;
case CHIPR_DM9000B:
db->type = TYPE_DM9000B;
break;
default:
dev_dbg(db->dev, "ID %02x => defaulting to DM9000En", id_val);
db->type = TYPE_DM9000E;
/* dm9000a/b are capable of hardware checksum offload */
if (db->type == TYPE_DM9000A || db->type == TYPE_DM9000B) {
db->can_csum = 1;
db->rx_csum = 1;
ndev->features |= NETIF_F_IP_CSUM;
/* from this point we assume that we have found a DM9000 */
/* driver system function */
ether_setup(ndev);
ndev->netdev_ops = &dm9000_netdev_ops;
ndev->watchdog_timeo = msecs_to_jiffies(watchdog);
ndev->ethtool_ops = &dm9000_ethtool_ops;
// db->msg_enable = NETIF_MSG_LINK;
db->msg_enable = 0xffff;
db->mii.phy_id_mask = 0x1f;
db->mii.reg_num_mask = 0x1f;
db->mii.force_media = 0;
db->mii.full_duplex = 0;
db->mii.dev = ndev;
db->mii.mdio_read = dm9000_phy_read;
db->mii.mdio_write = dm9000_phy_write;
mac_src = "eeprom";
/* try reading the node address from the attached EEPROM */
for (i = 0; i < 6; i += 2)
dm9000_read_eeprom(db, i / 2, ndev->dev_addr+i);
if (!is_valid_ether_addr(ndev->dev_addr) && pdata != NULL) {
mac_src = "platform data";
memcpy(ndev->dev_addr, pdata->dev_addr, 6);
if (!is_valid_ether_addr(ndev->dev_addr)) {
/* try reading from mac */
mac_src = "chip";
for (i = 0; i < 6; i++)
ndev->dev_addr[i] = ior(db, i+DM9000_PAR);
memcpy(ndev->dev_addr, "x08x90x90x90x90x90", 6);
dev_warn(db->dev, "%s: Invalid ethernet MAC address. Please "
"set using ifconfign", ndev->name);
platform_set_drvdata(pdev, ndev);
ret = register_netdev(ndev);
if (ret == 0)
printk(KERN_INFO "%s: dm9000%c at %p,%p IRQ %d MAC: %pM (%s)n",
ndev->name, dm9000_type_to_char(db->type),
db->io_addr, db->io_data, ndev->irq,
ndev->dev_addr, mac_src);
return 0;
out:
dev_err(db->dev, "not found (%d).n", ret);
dm9000_release_board(pdev, db);
free_netdev(ndev);
return ret;
上面这段代码中, 有几个地方说明一下:
1. struct dm9000_plat_data *pdata = pdev->dev.platform_data;这个 pdata得到的内容是在文件 arch/arm/mach-s3c2440/mach-mini2440.c 中定义的,定义如下
/* DM9000AEP 10/100 ethernet controller */
#define MACH_MINI2440_DM9K_BASE (S3C2410_CS4 + 0x300)
static struct resource mini2440_dm9k_resource[] = {
[0] = {
.start = MACH_MINI2440_DM9K_BASE,
.end = MACH_MINI2440_DM9K_BASE + 3,
.flags = IORESOURCE_MEM
[1] = {
.start = MACH_MINI2440_DM9K_BASE + 4,
.end = MACH_MINI2440_DM9K_BASE + 7,
[2] = {
.start = IRQ_EINT7,
.end = IRQ_EINT7,
.flags = IORESOURCE_IRQ | IORESOURCE_IRQ_HIGHEDGE,
* * The DM9000 has no eeprom, and it's MAC address is set by
* * the bootloader before starting the kernel.
static struct dm9000_plat_data mini2440_dm9k_pdata = {
.flags = (DM9000_PLATF_16BITONLY | DM9000_PLATF_NO_EEPROM),
static struct platform_device mini2440_device_eth = {
.name = "dm9000",
.id = -1,
.num_resources = ARRAY_SIZE(mini2440_dm9k_resource),
.resource = mini2440_dm9k_resource,
.dev = {
.platform_data = &mini2440_dm9k_pdata,
从上面的27行,就可以知道pdata的值是什么。驱动移植时,一般就是修改mach-mini2440.c这个文件,当然也有些版本将dm9000的resource包含在文件 archarmplat-s3c24xx这个文件中,我觉得这两个文件应该是特殊与一般的关系,最通用的resource就定义在plat-s3c24xx文件中,而因开发板各异的resource就包含在mach-mini2440.c文件中。
2. probe函数第23行中, SET_NETDEV_DEV(ndev, &pdev->dev) 这个宏展开之后, /* Set the sysfs physical device reference for the network logical device * if set prior to registration will cause a symlink during initialization. */#define SET_NETDEV_DEV(net, pdev) ((net)->dev.parent = (pdev))应该是与sysfs有关,但是目前不是很理解这句话的作用。当把这句话去掉之后,驱动是可以正常运行的,唯一的区别是去掉之后,目录/sys/devices/platform/dm9000/net 将不存在。sysfs的用法还没有彻底弄明白。
上一篇:mini2440上dm9000驱动分析(二)
下一篇:S3C2440上MMC/SD卡驱动分析(二)
Active-Semi是一家专注于功率管理芯片和解决方案的领先企业。以下是该公司发展的五个相关故事:
公司成立与初期发展: Active-Semi成立于2004年,总部位于美国德克萨斯州达拉斯。公司的创始人致力于研发创新的功率管理解决方案,以满足日益增长的电子设备对于高效能耗、高性能和低成本的需求。初期,公司聚焦于LED照明、消费电子和工业应用等领域。
技术创新与产品推出: Active-Semi在功率管理领域取得了多项技术创新,不断推出具有高性能和高集成度的芯片产品。公司的产品涵盖了DC-DC转换器、AC-DC转换器、LED驱动器、电池管理器等多个子领域,并通过不断创新提高了产品性能和稳定性。
市场拓展与国际化发展: 随着产品线的扩展和市场认可度的提高,Active-Semi逐步拓展了国内外市场。公司在美国、中国、日本等地设立了销售和技术支持中心,与全球各地的客户建立了合作关系。通过与国际渠道商合作,Active-Semi的产品远销至全球各地,赢得了广泛的市场认可。
并购与战略合作: 为了加强自身的技术实力和市场地位,Active-Semi进行了一系列的并购和战略合作。其中最重要的是2018年,Active-Semi被斯图尔特半导体(Stewart Semiconductor)收购。这一并购进一步扩大了Active-Semi在功率管理领域的影响力和市场份额。
持续创新与未来展望: Active-Semi致力于持续创新,不断推出符合市场需求的新产品和解决方案。公司将继续加强技术研发投入,提升产品性能和稳定性,以满足客户在不断变化的市场需求。未来,Active-Semi将继续致力于成为功率管理领域的领先企业,并在全球范围内提供优质的产品和服务。
在埃派克森微电子的发展过程中,著名投资机构多尔基金和华登国际的风险投资起到了重要的推动作用。这些投资不仅为公司提供了资金支持,还带来了宝贵的市场资源和管理经验。借助这些资源,埃派克森加快了国际化步伐,积极拓展海外市场,与全球范围内的客户和合作伙伴建立了紧密的合作关系。
为了保持技术领先和市场竞争力,晶岳电子一直注重研发团队的建设。目前,公司在上海、深圳及台湾均建有成熟的产品研发团队,核心功率器件及集成电路设计人员均拥有15年以上的设计研发经验。这些优秀的研发人员不仅为公司带来了源源不断的技术创新,也确保了公司在激烈的市场竞争中始终保持领先地位。此外,晶岳电子还积极与高校和研究机构合作,共同开展前沿技术的研发和应用。
Denyo Europa Gmbh公司始终认为企业是社会的一部分,应该承担起相应的社会责任。公司积极参与各种公益活动,为当地社区的发展贡献力量;同时,公司还关注弱势群体的需求,为他们提供力所能及的帮助。这种对社会责任的担当精神,使公司在社会中树立了良好的企业形象。
随着技术的不断成熟和产品线的不断完善,Dytran开始积极拓展市场。公司不仅在美国本土取得了良好的销售业绩,还通过参加国际展览和建立海外办事处等方式,将产品推向全球。在这个过程中,Dytran的传感器产品得到了众多行业客户的认可,广泛应用于航空航天、工业和汽车行业的产品开发测试和嵌入式监控解决方案。
为了更好地服务全球客户,Dytran在成立两年后将其总部迁至美国加利福尼亚州的查茨沃思市。这里地理位置优越,交通便利,有利于公司进一步拓展北美市场。同时,公司还加强了与全球合作伙伴的合作,共同推动传感器技术的发展和应用。
自1995年成立以来,意华(CZT)始终秉持“诚信”的合作态度和“创新”的发展思路。在公司初创阶段,面对激烈的市场竞争,意华坚持高质量的产品和服务,赢得了客户的信赖。同时,公司不断投入研发,推出了一系列具有创新性的电子产品和连接器,迅速在市场上树立了良好的口碑。
送给大家一本比较完美的99教程 中册:https://bbs.eeworld.com.cn/thread-52306-1-4.html 下册:https://bbs.eeworld.com.cn/thread-52318-1-8.html … 查看全部问答∨ |
本帖最后由 jameswangsynnex 于 2015-3-3 20:00 编辑 曙光信息产业有限公司总裁历军日前在曙光天津产业基地接受新华社记者采访时表示,2010年,曙光将推出基于“龙芯四号”处理器的千万亿次高性能服务器“曙光6000”超级计算机。 200 ...… 查看全部问答∨ |
抑制谐波和提高功率因数是涉及电力电子技术、电气自动化技术和电力系统的一个重大课题。随着电力电子技术的不断进步,新型有源谐波抑制技术和无功补偿技术得到了迅速的发展。本书主要介绍有源电力滤波器、混合型电力滤波器 ...… 查看全部问答∨ |
对于单片机系统来说,复位电路应该是最为最要的一个环节。往往被很多人忽略,因为一般简单的复位电路在开发试验阶段是没有问题的,只有在工作环境中才容易出现问题。所以在此推荐这份资料希望大家重视,复位IC并不会增加太多成本,但是更有保障。 ...… 查看全部问答∨ |
CE50的GWES组件有没公开源码?LCD驱动里面的触摸屏坐标(已经知道怎么修正它了)怎么转成系统的坐标?这两个之间的转换关系是? CE50的GWES组件有没公开源码?LCD驱动里面的触摸屏坐标(已经知道怎么修正它了)怎么转成系统的坐标?这两个之间的转换关系是?… 查看全部问答∨ |
请问在keil c的"Option for target"选项中的"taget选项卡",有项叫xtal(晶震频率)的,我在教程中看到,编译代码前我们要在这里改成跟我们单片机相同的效率才行,但是我怎么知道我的51板子的晶震频率是多少呢?可以从板子或芯片中的某个地方看到 ...… 查看全部问答∨ |
本帖最后由 dontium 于 2015-1-23 13:31 编辑 看看论坛,好象很多战友都遇到了这个问题,不知道大家是怎么解决的, 我遇到的问题是这样的,我用汇编编写了一个小程序,小于1K,作用是把GPIO拉高, 在调试时候运行正确,烧入FLASH中的数据,对应 ...… 查看全部问答∨ |
自恢复保险丝(PPTC)的保护功能在LED技术中在此大展身手 自恢复保险丝(PPTC)的保护功能在LED技术中在此大展身手 自恢复保险丝(PPTC)全称聚合物正温度系数器件(PolymerPositiveTemperatureCoefficients),它的工作情况类似一个开关,故障出现时,自恢复保险丝(PPTC)变热、电阻增加,从而保 ...… 查看全部问答∨ |
