一、使用proteus绘制简单的电路图,用于后续仿真
二、编写程序
----@Project:LED-74HC595
----@File:main.c
----@Edit:ZHQ
----@Version:V1.0
----@CreationTime:20200526
----@ModifiedTime:20200526
----@Description:第9个至第16个LED灯,依次逐个亮灯并且每次只能亮一个灯。第1至第8个LED灯一直灭。
----单片机:AT89C52
#include "reg52.h"
/*——————宏定义——————*/
#define FOSC 11059200L
#define T1MS (65536-FOSC/12/1000) /*1ms timer calculation method in 12Tmode*/
#define const_time_level_09_16 400
/*——————变量函数定义及声明——————*/
/*定义74HC595*/
sbit Hc595_Sh = P2^3;
sbit Hc595_St = P2^4;
sbit Hc595_Ds = P2^5;
unsigned char ucLED1 = 0; /*代表16个灯的亮灭状态,0代表灭,1代表亮*/
unsigned char ucLED2 = 0;
unsigned char ucLED3 = 0;
unsigned char ucLED4 = 0;
unsigned char ucLED5 = 0;
unsigned char ucLED6 = 0;
unsigned char ucLED7 = 0;
unsigned char ucLED8 = 0;
unsigned char ucLED9 = 0;
unsigned char ucLED10 = 0;
unsigned char ucLED11 = 0;
unsigned char ucLED12 = 0;
unsigned char ucLED13 = 0;
unsigned char ucLED14 = 0;
unsigned char ucLED15 = 0;
unsigned char ucLED16 = 0;
unsigned char ucLed_update = 0; /*刷新变量。每次更改LED灯的状态都要更新一次。*/
unsigned char ucLedStep_09_16 = 0; /*第9个至第16个LED跑马灯的步骤变量*/
unsigned int uiTimeCnt_09_16 = 0; /*第9个至第16个LED跑马灯的统计定时中断次数的延时计数器*/
unsigned char ucLedStatus16_09 = 0; /*代表底层74HC595输出状态的中间变量*/
unsigned char ucLedStatus08_01 = 0; /*代表底层74HC595输出状态的中间变量*/
* @brief 定时器0初始化函数
* @param 无
* @retval 初始化T0
void Init_T0(void)
TMOD = 0x01; /*set timer0 as mode1 (16-bit)*/
TL0 = T1MS; /*initial timer0 low byte*/
TH0 = T1MS >> 8; /*initial timer0 high byte*/
* @brief 外围初始化函数
* @param 无
* @retval 初始化外围
void Init_Peripheral(void)
ET0 = 1;/*允许定时中断*/
TR0 = 1;/*启动定时中断*/
EA = 1;/*开总中断*/
* @brief 初始化函数
* @param 无
* @retval 初始化单片机
voidInit(void)
Init_T0();
* @brief 延时函数
* @param 无
* @retval 无
void Delay_Long(unsigned int uiDelayLong)
unsigned int i;
unsigned int j;
for(i=0;i for(j=0;j<500;j++) /*内嵌循环的空指令数量*/ { ; /*一个分号相当于执行一条空语句*/ } } } /** * @brief 延时函数 * @param 无 * @retval 无 **/ void Delay_Short(unsigned int uiDelayShort) { unsigned int i; for(i=0;i ; /*一个分号相当于执行一条空语句*/ } } /** * @brief 595驱动函数 * @param 无 * @retval * 两个联级74HC595的工作过程: * 每个74HC595内部都有一个8位的寄存器,两个联级起来就有两个寄存器。ST引脚就相当于一个刷新 * 信号引脚,当ST引脚产生一个上升沿信号时,就会把寄存器的数值输出到74HC595的输出引脚并且锁存起来, * DS是数据引脚,SH是把新数据送入寄存器的时钟信号。也就是说,SH引脚负责把数据送入到寄存器里,ST引脚 * 负责把寄存器的数据更新输出到74HC595的输出引脚上并且锁存起来。 **/ void HC595_Drive(unsigned char ucLedStatusTemp16_09, unsigned char ucLedStatusTemp08_01) { unsigned char i; unsigned char ucTempData; Hc595_Sh = 0; Hc595_St = 0; ucTempData = ucLedStatusTemp16_09;/*先送高8位*/ for(i = 0; i < 8; i ++) { if(ucTempData >= 0x80) { Hc595_Ds = 1; } else { Hc595_Ds = 0; } Hc595_Sh = 0;/*SH引脚的上升沿把数据送入寄存器*/ Delay_Short(15); Hc595_Sh = 1; Delay_Short(15); ucTempData = ucTempData <<1; } ucTempData = ucLedStatusTemp08_01;/*再先送低8位*/ for(i = 0; i < 8; i ++) { if(ucTempData >= 0x80) { Hc595_Ds = 1; } else { Hc595_Ds = 0; } Hc595_Sh = 0;/*SH引脚的上升沿把数据送入寄存器*/ Delay_Short(15); Hc595_Sh = 1; Delay_Short(15); ucTempData = ucTempData <<1; } Hc595_St = 0;/*ST引脚把两个寄存器的数据更新输出到74HC595的输出引脚上并且锁存起来*/ Delay_Short(15); Hc595_St = 1; Delay_Short(15); Hc595_Sh = 0;/*拉低,抗干扰就增强*/ Hc595_St = 0; Hc595_Ds = 0; } /** * @brief LED更新函数 * @param 无 * @retval * 把74HC595驱动程序翻译成类似单片机IO口直接驱动方式的过程。 * 每次更新LED输出,记得都要把ucLed_update置1表示更新。 **/ void LED_Update() { if(ucLed_update == 1) { ucLed_update = 0;/*及时清零,让它产生只更新一次的效果,避免一直更新。*/ if(ucLED1 == 1) { ucLedStatus08_01 = ucLedStatus08_01 | 0x01; } else { ucLedStatus08_01 = ucLedStatus08_01 & 0xfe; } if(ucLED2 == 1) { ucLedStatus08_01 = ucLedStatus08_01 | 0x02; } else { ucLedStatus08_01 = ucLedStatus08_01 & 0xfd; } if(ucLED3 == 1) { ucLedStatus08_01 = ucLedStatus08_01 | 0x04; } else { ucLedStatus08_01 = ucLedStatus08_01 & 0xfb; } if(ucLED4 == 1) { ucLedStatus08_01 = ucLedStatus08_01 | 0x08; } else { ucLedStatus08_01 = ucLedStatus08_01 & 0xf7; } if(ucLED5 == 1) { ucLedStatus08_01 = ucLedStatus08_01 | 0x10; } else { ucLedStatus08_01 = ucLedStatus08_01 & 0xef; } if(ucLED6 == 1) { ucLedStatus08_01 = ucLedStatus08_01 | 0x20; } else { ucLedStatus08_01 = ucLedStatus08_01 & 0xdf; } if(ucLED7 == 1) { ucLedStatus08_01 = ucLedStatus08_01 | 0x40; } else { ucLedStatus08_01 = ucLedStatus08_01 & 0xbf; } if(ucLED8 == 1) { ucLedStatus08_01 = ucLedStatus08_01 | 0x80; } else { ucLedStatus08_01 = ucLedStatus08_01 & 0x7f; } if(ucLED9 == 1) { ucLedStatus16_09 = ucLedStatus16_09 | 0x01; } else { ucLedStatus16_09 = ucLedStatus16_09 & 0xfe; } if(ucLED10 == 1) { ucLedStatus16_09 = ucLedStatus16_09 | 0x02; } else { ucLedStatus16_09 = ucLedStatus16_09 & 0xfd; } if(ucLED11 == 1) { ucLedStatus16_09 = ucLedStatus16_09 | 0x04; } else { ucLedStatus16_09 = ucLedStatus16_09 & 0xfb; } if(ucLED12 == 1) { ucLedStatus16_09 = ucLedStatus16_09 | 0x08; } else { ucLedStatus16_09 = ucLedStatus16_09 & 0xf7; } if(ucLED13 == 1) { ucLedStatus16_09 = ucLedStatus16_09 | 0x10; } else { ucLedStatus16_09 = ucLedStatus16_09 & 0xef; } if(ucLED14 == 1) { ucLedStatus16_09 = ucLedStatus16_09 | 0x20; } else { ucLedStatus16_09 = ucLedStatus16_09 & 0xdf; } if(ucLED15 == 1) { ucLedStatus16_09 = ucLedStatus16_09 | 0x40; } else { ucLedStatus16_09 = ucLedStatus16_09 & 0xbf; } if(ucLED16 == 1) { ucLedStatus16_09 = ucLedStatus16_09 | 0x80; } else { ucLedStatus16_09 = ucLedStatus16_09 & 0x7f; } HC595_Drive(ucLedStatus16_09, ucLedStatus08_01); } } /** * @brief LED闪烁函数 * @param 无 * @retval 无 **/ void LED_Flicker_09_16(void) { switch(ucLedStep_09_16) { case 0: if(uiTimeCnt_09_16 >= const_time_level_09_16) { uiTimeCnt_09_16 = 0;/*时间计数器清零*/ ucLED16 = 0; ucLED9 = 1; ucLed_update = 1; /*更新显示*/ ucLedStep_09_16 = 1; } break; case 1: if(uiTimeCnt_09_16 >= const_time_level_09_16) { uiTimeCnt_09_16 = 0;/*时间计数器清零*/ ucLED9 = 0; ucLED10 = 1; ucLed_update = 1; /*更新显示*/ ucLedStep_09_16 = 2; } break; case 2: if(uiTimeCnt_09_16 >= const_time_level_09_16) { uiTimeCnt_09_16 = 0;/*时间计数器清零*/ ucLED10 = 0; ucLED11 = 1; ucLed_update = 1; /*更新显示*/ ucLedStep_09_16 = 3; } break; case 3: if(uiTimeCnt_09_16 >= const_time_level_09_16) { uiTimeCnt_09_16 = 0;/*时间计数器清零*/ ucLED11 = 0; ucLED12 = 1; ucLed_update = 1; /*更新显示*/ ucLedStep_09_16 = 4; } break; case 4: if(uiTimeCnt_09_16 >= const_time_level_09_16) { uiTimeCnt_09_16 = 0;/*时间计数器清零*/ ucLED12 = 0; ucLED13 = 1; ucLed_update = 1; /*更新显示*/ ucLedStep_09_16 = 5; } break; case 5: if(uiTimeCnt_09_16 >= const_time_level_09_16) { uiTimeCnt_09_16 = 0;/*时间计数器清零*/ ucLED13 = 0; ucLED14 = 1; ucLed_update = 1; /*更新显示*/ ucLedStep_09_16 = 6; } break; case 6: if(uiTimeCnt_09_16 >= const_time_level_09_16) { uiTimeCnt_09_16 = 0;/*时间计数器清零*/ ucLED14 = 0; ucLED15 = 1; ucLed_update = 1; /*更新显示*/ ucLedStep_09_16 = 7; } break; case 7: if(uiTimeCnt_09_16 >= const_time_level_09_16) { uiTimeCnt_09_16 = 0;/*时间计数器清零*/ ucLED15 = 0; ucLED16 = 1; ucLed_update = 1; /*更新显示*/ ucLedStep_09_16 = 0; } break; } } /** * @brief 定时器0中断函数 * @param 无 * @retval 无 **/ void ISR_T0(void)interrupt 1 { TF0 = 0; /*清除中断标志*/ TR0 = 0; /*关中断*/ if(uiTimeCnt_09_16 < 0xffff)/*设定这个条件,防止uiTimeCnt超范围。*/ { uiTimeCnt_09_16 ++; } TL0 = T1MS; /*initial timer0 low byte*/ TH0 = T1MS >> 8; /*initial timer0 high byte*/ TR0 = 1; /*开中断*/ } /*——————主函数——————*/ /** * @brief 主函数 * @param 无 * @retval 实现LED灯闪烁 **/ void main() { /*单片机初始化*/ Init(); /*延时,延时时间一般是0.3秒到2秒之间,等待外围芯片和模块上电稳定*/ Delay_Long(100); /*单片机外围初始化*/ Init_Peripheral(); while(1) { /*按键服务函数*/ LED_Flicker_09_16(); /*LED更新函数*/ LED_Update(); } } 三、仿真实现
上一篇:51单片机实现两片联级74HC595多任务并行处理两路跑马灯
下一篇:51单片机实现两片联级74HC595依次点亮LED后依次熄灭
随着技术的不断进步和产品的不断创新,西铁城公司开始积极拓展全球市场。公司的产品以其高品质、精确度和创新技术而闻名,逐渐赢得了全球消费者的青睐。同时,公司也积极参与国际性的钟表展会和活动,通过展示最新产品和技术成果,进一步提升品牌知名度和影响力。这一系列的举措使得西铁城在全球市场上的地位日益稳固。
随着国内市场的饱和,宜源科技公司积极寻求海外市场的发展机会。公司加强与国际知名企业的合作,共同开发新产品,拓展市场份额。同时,宜源科技还积极参加国际展会和论坛,提升品牌知名度和影响力。通过不懈的努力,宜源科技的产品已经成功进入多个国家和地区,实现了国际化发展。
作为一家在电子行业具有影响力的企业,Emulation始终关注社会责任和可持续发展。公司积极参与各种公益活动,为当地社区的发展做出了贡献。同时,Emulation还注重环保和节能,致力于推动绿色电子产品的设计和生产。这些举措不仅提升了公司的社会形象,还为公司的长期发展奠定了坚实的基础。
随着产品质量的不断提升和市场份额的逐步扩大,ACCUTEK公司开始将目光投向国际市场。公司积极参加国际电子展会和技术交流活动,与全球多家知名企业建立了合作关系。同时,公司还在海外设立了多个分支机构,以便更好地服务当地客户。这些举措不仅提升了公司的国际影响力,也为公司的长远发展注入了新的活力。
在电子行业的初期,Connection One公司凭借其创始人对半导体技术的深刻理解,成功研发出一款具有划时代意义的芯片。这款芯片不仅性能卓越,而且功耗极低,立即在市场上引起了轰动。公司因此迅速积累了第一笔资金,为后续的研发和扩展打下了坚实基础。
为了进一步提升国际竞争力,Connection One公司开始实施全球化战略布局。公司在全球范围内设立研发中心和销售网络,以便更好地了解当地市场需求并提供定制化产品。这一举措不仅加速了公司的国际化进程,还为其带来了更多的商业机会。
请大家看下下面打问号几行代码,抛开其功能不说,真的是奇怪了,我都看了又看,头都大了,就是不知道为什么,请朋友们指点下 #include<reg52.h> &nbs ...… 查看全部问答∨ |
error C2065: \'GetRunningObjectTable\' : undeclared identifier error C2065: \'CreateItemMoniker\' : undeclared identifier 我用的是EVC 4.0+SP4… 查看全部问答∨ |
STM32的驱动库好用吗?效率高吗?优化的吗?准备上STM32 N多年没买过开发板了,也没用过仿真器了。都是用软件编译调试好,直接ISP,然后通过串口命令开启调试信息的输出。 昨天买了块STM32F103全功能型开发板,他们的办事效率真低(深圳到广州通常当 ...… 查看全部问答∨ |
求IAR Embedded Workbench for MCS-51 完整版 各位高手,小弟求IAR Embedded Workbench for MCS-51完整版,有哪位高人有,能否分享一下。我的邮箱jinghongchen@126.com… 查看全部问答∨ |
还是说说今天参加安富利的“ARM研讨会”,参观展台时,逛到了英蓓特(EMBEST)那里。大家可能知道,这家公司就是专门围绕ARM生存的,有很多ARM开发板。我在看到英蓓特展台的易拉宝时,楞了一下,原来上面罗列的产品线时,赫然有“Luminary系列”。 ...… 查看全部问答∨ |
