此篇限定研究范围为FLASH区域的访问规则。
以下结论均为实测所得:
一、读
1.单字节读例程,单字节读可以从任意地址开始读
uint8_t STMFLASH_ReadByte(uint32_t faddr)
return *(volatile uint8_t*)faddr;
2.半字(2个字节)读例程, 半字读只能从偶数地址开始读 ,从奇数地址读的话单片机就死机了
uint16_t STMFLASH_ReadHalfWord(uint32_t faddr)
return *(volatile uint16_t*)faddr;
3.字(4个字节)读例程, 按字读只能从4的整数倍地址开始读 ,否则单片机死机
uint32_t STMFLASH_ReadWord(uint32_t faddr)
return *(volatile uint32_t*)faddr;
二、写
1.单次写入字节数:
我看G0x1的技术参考手册上说一次写入是72bit(64bit加ecc),我实际测试是单次写入只能是32bit,以实际测试为准
(1)单字节写,写不了,单片机死机
我在HAL库里面把库函数FLASH_Program_DoubleWord改成如下进行验证的
static void FLASH_Program_DoubleWord(uint32_t Address, uint64_t Data)
/* Set PG bit */
SET_BIT(FLASH->CR, FLASH_CR_PG);
*(uint8_t *)Address = (uint8_t)(Data&0xff);__ISB();
*((uint8_t *)Address+1) = (uint8_t)((Data>>8U)&0xff);__ISB();
*((uint8_t *)Address+2) = (uint8_t)((Data>>16U)&0xff);__ISB();
*((uint8_t *)Address+3) = (uint8_t)((Data>>24U)&0xff);__ISB();
*((uint8_t *)Address+4) = (uint8_t)((Data>>32U)&0xff);__ISB();
*((uint8_t *)Address+5) = (uint8_t)((Data>>40U)&0xff);__ISB();
*((uint8_t *)Address+6) = (uint8_t)((Data>>48U)&0xff);__ISB();
*((uint8_t *)Address+7) = (uint8_t)((Data>>56U)&0xff);
(2)**半字写,写不了,单片机死机
/* Set PG bit */
*(uint16_t *)Address = (uint16_t)(Data&0xffff);__ISB();
*((uint16_t *)Address+2) = (uint16_t)((Data>>16U)&0xffff);__ISB();
*((uint16_t *)Address+4) = (uint16_t)((Data>>32U)&0xffff);__ISB();
*((uint16_t *)Address+6) = (uint16_t)((Data>>48U)&0xffff);
(3)按字写(4个字节,32bit),可以,HAL库函数FLASH_Program_DoubleWord里面就是按字写的
/* Set PG bit */
/* Program first word */
*(uint32_t *)Address = (uint32_t)Data;
/* Barrier to ensure programming is performed in 2 steps, in right order
(independently of compiler optimization behavior) */
__ISB();
/* Program second word */
*(uint32_t *)(Address + 4U) = (uint32_t)(Data >> 32U);
(4) 按64bit写, 写不了,单片机死机
/* Set PG bit */
*(uint64_t *)Address = (uint64_t)Data;
2.写入的首地址规则
经过实际验证得出:**写入首地址必须为8的整数倍,不然就会发生错误:如果为4的整数倍但不是8的整数倍,单片机不会死机,但是写入的值全部变成0x3F,其他既不是4的整数倍也不是8的整数倍的地址,单片机会死机。
按以下代码改变写入首地址即可进行验证
STMFLASH_Write(FLASH_CALIBRATION_ADDR+8,String,sizeof(String));
HAL_Delay(10);
STMFLASH_Read(FLASH_CALIBRATION_ADDR,buffer,sizeof(String)/4+1);
HAL_Delay(10);
Uart_Send_Data(buffer, sizeof(String));
上一篇:STM32驱动ESP8266连接阿里云(2)----接入阿里IoT Studio实现Web可视化
下一篇:正点原子stm32精英开发板串口一键下载电路原理分析
推荐阅读最新更新时间:2024-11-02 00:08
设计资源 培训 开发板 精华推荐
- ADP8863DBCB-EVALZ,用于 7 通道趣味照明 LED 驱动器的评估板
- 127832-HMC836LP6CE,用于评估 HMC836LP6CE PLL 时钟发生器的评估板
- DC2317A,基于 LTC7103 5-100V 输入和 5V/2.3A 输出@400kHz 降压稳压器的演示板
- Sp6699 升压型 4 白光 LED 转换器的典型应用
- TM4642IY 双路 4A 1V 和 1.2V DC/DC 降压稳压器典型应用电路
- EG8010功率底板 DC-AC逆变器(1/2)
- 用于简单时钟振荡器的 NCP301HSN30T1 3V 电压检测器的典型应用
- LT3990EDD 1.8V 降压转换器的典型应用
- 【涂鸦智能】温湿度传感器
- UMFT231XC-01,UMFT231XC USB转UART开发模块,支持电池充电器
- 下载《TI MCU与无线连接技术研讨会讲座实录》抽奖赢好礼!
- 答题抽奖:Mentor Tessent Automotive相关测试解决方案(奖品池还剩不少奖品哟)
- 感恩季 送礼季!EEWORLD陪你玩着游戏奔新年
- 有奖直播:恩智浦基于RT06F的人脸识别技术解决方案
- TI即将直播【 MSP430 系列最新超声波流量测量方案】,你会错过?报名看直播赢双重好礼喽!
- 有奖直播:安森美汽车热管理e- Compressor 应用
- 你评论,我送礼!《玩转TI MSP430 Launchpad》TI社区与EEWORLD联合首发!
- 直播已结束【英飞凌全新Wi-Fi6单芯片SoC助力物联网产品的快速开发】(9:30入场)
- 【实时抽奖】MPS AI电源解决方案合集,咨询抽【按摩眼罩、体脂秤、电脑支架】等好礼
