BAJ0BC0FP-E2 10V/1A 固定输出 LDO 稳压器的典型应用电路。 BAxxBC0 是低饱和度稳压器,输出电流为 1A,输出电压精度为 ±2%。提供 1.5V 至 10V 的宽输出电压范围,内置过流保护和热关断 (TSD) 电路分别防止因短路和过载而造成的损坏
说明
Typical Application Circuit for BAJ0BC0FP-E2 10V/1A Fixed Output LDO Regulator. The BAxxBC0 are low-saturation regulators with an output current of 1A and an output voltage accuracy of ±2%. A broad output voltage range is offered from 1.5V to 10V and built-in overcurrent protection and thermal shut-down (TSD) circuits prevent damage due to short-circuiting and overloading, respectively
主要特色
Conversion Type
DC to DC
Input Voltage
16 V
Output Voltage
10 V
Output Current
1 A
Topology
LDO
