加入交流群
扫一扫,添加管理员微信
备注:参考设计,即可被拉入群
和也在搞设计小伙伴们碰一碰
收藏
评论
宋元浩 发布
LT1510 的典型应用 - 恒压/恒流电池充电器
使用 Analog Devices 的 LT1510 的参考设计
设计简介
LT1510 的典型应用 - 恒压/恒流电池充电器。 LT 1510 电流模式 PWM 电池充电器的开关频率高达 500kHz,是对现代可充电电池(包括锂离子 (Li-Ion)、镍氢 (NiMH))进行快速充电的最小、最简单、最高效的解决方案* 和镍镉 (NiCd)* 需要恒流和/或恒压充电
说明
  • Typical Application for LT1510 - Constant-Voltage/Constant-Current Battery Charger. The With switching frequency as high as 500kHz, The LT 1510 current mode PWM battery charger is the smallest, simplest, most efficient solution to fast-charge modern rechargeable batteries including lithium-ion (Li-Ion), nickel metal-hydride (NiMH)* and nickel-cadmium (NiCd)* that require constant-current and/or constant-voltage charging
参考设计图片
参考设计下载
相关文档
!注意:请使用浏览器自带下载,迅雷等下载软件可能无法下载到有效资源。
相关器件
器件 类型 描述 数据手册
LT1510IS Battery Management ICs Switching Battery Charger Lead-Acid/Li-Ion/Li-Pol/NiCd/NiMH 1500mA 2V to 20V 16-Pin SOIC N 点击下载
LT1510CS Battery Management ICs Switching Battery Charger Lead-Acid/Li-Ion/Li-Pol/NiCd/NiMH 1500mA 2V to 20V 16-Pin SOIC N 点击下载
LT1510IN#PBF Battery Management ICs Switching Battery Charger Lead-Acid/Li-Ion/Li-Pol/NiCd/NiMH 1500mA 2V to 20V 16-Pin PDIP N Tube 点击下载
LT1510-5IGN#TRPBF Battery Management ICs Switching Battery Charger Lead-Acid/Li-Ion/Li-Pol/NiCd/NiMH 1500mA 2V to 20V Automotive 16-Pin SSOP N T/R 点击下载
LT1510-5CGN#TR Battery Management ICs Switching Battery Charger Lead-Acid/Li-Ion/Li-Pol/NiCd/NiMH 1500mA 2V to 20V 16-Pin SSOP N T/R 点击下载
LT1510-5CGN Battery Management ICs Switching Battery Charger Lead-Acid/Li-Ion/Li-Pol/NiCd/NiMH 1500mA 2V to 20V 16-Pin SSOP N 点击下载
LT1510IGN#TRPBF Battery Management ICs Switching Battery Charger Lead-Acid/Li-Ion/Li-Pol/NiCd/NiMH 1500mA 2V to 20V Automotive 16-Pin SSOP N T/R 点击下载
LT1510IGN Battery Management ICs Switching Battery Charger Lead-Acid/Li-Ion/Li-Pol/NiCd/NiMH 1500mA 2V to 20V 16-Pin SSOP N 点击下载
LT1510CS#PBF Battery Management ICs Switching Battery Charger Lead-Acid/Li-Ion/Li-Pol/NiCd/NiMH 1500mA 2V to 20V 16-Pin SOIC N Tube 点击下载
LT1510IS8#PBF Battery Management ICs Switching Battery Charger Lead-Acid/Li-Ion/Li-Pol/NiCd/NiMH 1500mA 2V to 20V 8-Pin SOIC N Tube 点击下载
LT1510IS#TRPBF Battery Management ICs Switching Battery Charger Lead-Acid/Li-Ion/Li-Pol/NiCd/NiMH 1500mA 2V to 20V 16-Pin SOIC N T/R 点击下载
LT1510CS8#TRPBF Battery Management ICs Switching Battery Charger Lead-Acid/Li-Ion/Li-Pol/NiCd/NiMH 1500mA 2V to 20V 8-Pin SOIC N T/R 点击下载
群聊设计,与管理员及时沟通
欢迎加入EEWorld参考设计群,也许能碰到搞同一个设计的小伙伴,群聊设计经验和难点。 入群方式:微信搜索“helloeeworld”或者扫描二维码,备注:参考设计,即可被拉入群。 另外,如您在下载此设计遇到问题,也可以微信添加“helloeeworld”及时沟通。
查找数据手册?
EEWorld Datasheet 技术支持
论坛推荐 更多
更新时间2024-11-10 18:11:10
About Us 关于我们 客户服务 联系方式 器件索引 网站地图 最新更新 手机版 版权声明
EEWORLD参考设计中心
站点相关: TI培训 德州仪器(TI)官方视频课程培训
