加入交流群
扫一扫,添加管理员微信
备注:参考设计,即可被拉入群
和也在搞设计小伙伴们碰一碰
收藏
评论
ghaytweyhtoo 发布
FEBFHR1200-SPG01A-GEVB:高性能并联稳压器
FEBFHR1200-SPG01A-GEVB: High-Performance Shunt Regulator
设计简介
The FHR1200 is a high-efficiency regulator that outperforms a typical shunt regulator in applications where low operating power, wide temperature range, and wide voltage range are important. The regulator also features better stability and faster response than many existing regulators.
The FHR1200 can be used for isolated and non-isolated secondary side regulation plus, primary side, and floating regulation because the regulator can directly drive a power supply controller. This reduces parts count and circuit complexity in many applications. Non-isolated secondary-side regulation saves the cost of OPTOs and simplifies the power supply design.
The FHR1200 can be used in many diverse applications. For example: VCC regulators to >100 V, small additional auxiliary power supplies, programmable precision Zener diodes (both high and low power), plus numerous analog circuits.
The FHR1200 can also be used as a standalone, low-cost, thermally stable, ~7.5 V voltage reference.
Features and Applications
  • Reference Voltage Accuracy: ±2%
  • Sink Current Capability: 10 µA to 50 mA
  • Low Output Noise
  • Fast Turn-On
  • Low Dynamic Impedance
  • Temperature Compensated: Typical
  • Fewest External Component Count
  • Programmable Output: 7.5 to >100 V
  • Low Current Operation:
  • Wide Operating Temperature Range: -55 to 150°C
  • Available in the 6-Lead SC70 Package
参考设计图片
参考设计下载
!注意:请使用浏览器自带下载,迅雷等下载软件可能无法下载到有效资源。
群聊设计,与管理员及时沟通
欢迎加入EEWorld参考设计群,也许能碰到搞同一个设计的小伙伴,群聊设计经验和难点。 入群方式:微信搜索“helloeeworld”或者扫描二维码,备注:参考设计,即可被拉入群。 另外,如您在下载此设计遇到问题,也可以微信添加“helloeeworld”及时沟通。
查找数据手册?
EEWorld Datasheet 技术支持
论坛推荐 更多
更新时间2024-11-10 01:48:49
About Us 关于我们 客户服务 联系方式 器件索引 网站地图 最新更新 手机版 版权声明
EEWORLD参考设计中心
站点相关: TI培训 德州仪器(TI)官方视频课程培训
