首页 > 其他 > 汽车电子点火电路 (Electronic car ignition)
来源:互联网发布者:笑流年 更新时间: 2021/12/21
汽车电子点火电路 (ElectrONic car igniTIon)
click image for higher resolution
ATTENTION: Don"t construct this project until this label is removed. There are some corrections that must be done in order to be full working. Sorry for the inconvenience.
Description:
This scheme is for 4 cylinder motor. This will make your car spent less fuel, be a little bit faster and you won’t have to frequently open your distributor cap to change the contact buttons thus wasting less money.
T1/T2 create one monostable multivibrator in which C2 and R5 determine the length of impulse which is 1,5 msec. Next in line are T3 and then T4 which is Darlington transistor specially developed for electronic ignition which is used as a switch to turn on/off primary coil. Impulses from switch P turn on monostable multivibrator T1/T2. You need to un-connect capacitor that is in distributor cap because it is not needed anymore. While switch P is closed T1 is in off state but T2 is in on state, also T3 and T4 which enables current to flow trough primary coil. When switch P is opened, T1 gets in on state for a moment causing C2 to charge over R6 which makes T2 go to off state because of voltage drop on R6. When T2 is off also T3 and T4 are off and current that was flowing trough primary coil is stopped. Because T2 is in off state, voltage on R8 is increased which is passed trough R5 on T1 base which is still in on state and C2 is still charging. After 1,5 msec. C2 value reaches the level where T2 goes to on state again and T1 goes to off state. Now T2, T3 and T4 are in on state, again, and current flows trough primary coil again. R2 and D1 are used to neutralize the effect of impulses caused from «jumping» of switch P which could turn on monostable multivibrator when it shouldn"t.
Zener diodes Z5 and Z6 are together with R10 limit overcharged voltage impulses that are caused by self induction of primary coil which could damage T4. They should be connected as close as possible to T4.
D7 protects device from wrong polarity.
Coil should have ratio of 1:80 or 1:100 with external resistor Rv which is used for better cooling. Total resisting value (Rp) of primary coil and Rv resistor shouldn"t be under 1,6 ohm"s so current trough T4 wouldn’t be bigger than 10A.
Depending on Rp, R9 have different values:
120Ω/2W for Rp tot > 2,2Ω
100Ω/2W for 1,8Ω < Rp tot < 2,2Ω
82Ω/3W for 1,5Ω < Rp tot <1,8Ω
T4 has to be heatsinked!!!
All resistors are 1/2W +/-5%
Parts:
D1-D4 = 1N4148
D5-D6 = BZX85C – 180 (replicable with all equivalent types with power of 1,3W)
D7 = 1N4001
R1 = 470 - 1W
R2 = 22k
R3 = 2,2k
R4 = 1k
R5 = 4,7k
R6 = 39k
R7 – R10 = 100
R8 = 680
C1 – C2 = 47nF (ceramic)
C3 = 0,22uF 400V (ceramic)
C4 = 100uF (electrolytic)
T1 – T2 = BC327 (BC327-25, BC327-40)
T3 = BC237B (BC547B, BC547C)
T4 = BUX37 (BU323, BU920, BU921, BU922, BUV37B (u TOP3), BUW29, BUW81, MJ10012, MJ10013, MJ10014, TIP662, TIP665, 2SD683)
提问/讨论
这里还没有内容,您有什么问题吗?
我要提问/讨论
推荐帖子 最新更新时间:2024-11-13 08:53
【设计工具】演示如何使用ISE开发FPGA项目(3)
【设计工具】演示如何使用ISE开发FPGA项目(3) 顶!
 鑫海宝贝FPGA/CPLD
移动全网IVR接入大全
一、进入 首先你要看看自己的资格是否符合申请移动全网IVR要求并准备下诉文件: 《信息服务业务经营许可证》-ICP证 《互联网信息服务许可证》或者《移动增值业务许可证》-SP证 《跨地区电信增值业务许可证》-全网证 《企业法人营业执照》-工商证 《银行开户许可证》-这个还需要解
 mdreamjRF/无线
C2000 DSP中stack用量的计算
电力电子软件的,一般这一行的代码不多,往往几行代码调几个月,比如并网算法、H桥控制。前段时间同事做通讯的时候,发现TMS320F280XX这款芯片有时会死机。他通讯的软件使用了TI给的库,自己做了通讯的协议层。虽然死机后有主芯片将这块通讯芯片复位,但我们仍然想解决问题。当我们发现
 Jacktang微控制器 MCU
《CMake构建实战》 - 引入CMake
# CMake引入 ### 为什么使用CMake 从之前的介绍中可知Linux平台中的Makefile和Windows不能做到很好的兼容。而CMake很好的解决了跨平台问题。CMake能做到一次编写,到处编译 CMake是高效的,写CMakeLists.txt比写Makefile
 小麦克嵌入式系统
新手请教一个PCB电源设计问题
做一个数据接收处理转发的设备。工作电流很小( 100mA)。 板子上的器件只有单片机和串口扩展芯片及MAX232,全用+5V的供电。 板子用开关电源模块或电源适配器供电。 电源输入部分设计如图所示,输入经过一个二极管防反接,经过一个磁珠和100uF的大电容组成的LC做滤波
 godjohsn电源技术
PK啦,老XU对DT,电子负载"三级管"VS"MOS管",哪个更实用
首先,这是一个伪命题, 三级管(包括IGBT) 和 MOS管 ,作为未级功率驱动有源元件,各有所长,应用很广泛~~~ 本次PK,只是寻找一个合适的话题讨论------关于直流电子负载,选用哪种类型的管子更合适而已~~~ DT版主的基本观点,MOS管是电阻型输出,三极管(包括IGB
 xuyiyiDIY/开源硬件专区
About Us 关于我们 客户服务 联系方式 器件索引 网站地图 最新更新 手机版 版权声明
EEWORLD 电路图 站点相关: 下载中心 Datasheet 参考设计
