首页 > 控制电路 >报警控制电路 > 水面高度报警器电路图
水面高度报警器电路图
来源:互联网发布者:张三叔 更新时间: 2018/08/07
水面高度报警器电路图
This circuit will trigger with any fluid with a resistance under 900K between the maximum separation distance of the probes. Let me explain further. The circuit uses a 4050B CMOS hex buffer working on a 5 volt supply. All gates are biased off by the 10M resistors connected between ground and buffer input. The "common" probe the topmost probe above probe 1 in the diagram above is connected to the positive 5 volt supply. If probe 1 is spaced 1 cm away from the common probe and tap water at 25 ?C is detected between the probes (a resistance of 20k) then the top gate is activated and the LED 1 will light. Similarly if probe 2 at 2 cm distance from the common probe detects water, LED 2 will light and so on. Switch 1 is used to select which output from the hex buffer will trigger the audible oscillator made from the gates of a CMOS 4011B IC.
Placement of Probes:
As 7 wires are needed for the probe I reccommend the use of 8 way computer ribbon cable. The first two wires may be doubled and act as the common probe wire. Each subsequent wire may be cut to required length, if required a couple of millimetres of insulation may be stripped back, though the open "cut off" wire end should be sufficient to act as the probe. The fluid and distance between probe 6 and the common probe wire must be less than 900k. This is because any voltage below 0.5 Volt is detected by the CMOS IC as logic 0. A quick potential check using a 900k resistance and the divider formed with the 10M resistor at the input proves this point:
5 x (0.9 / (0.9+10) = 0.41 Volt.
As this voltage is below 0.5 volt it is interpreted as a logic 0 and the LED will light. If measuring tap water at 25 ?C then the distance between top probe and common may be up to 45 cm apart. For other temperatures and fluids, it is advisable to use an ohmmeter first. When placing the probes the common probe must be the lowest placed probe, as the water level rises, it will first pass probe 1, then 2 and fin
提问/讨论 常见疑问?
这里还没有内容,您有什么问题吗?
我要提问/讨论
推荐帖子 最新更新时间:2024-11-21 16:44
求助!LPC2103对UART口的操作上的问题!
我现在在LPC2103上编程时,对于这个芯片的UART口理解不深,现在想写一个单纯的利用中断接收电脑下发的信息。然后再回发回来。 可是参照例程里好多的都用了FIFO。我现在不想用。不开启FIFO又没有反应。弄得我头大得不行。希望有人能指点一下. 求助!LPC2103对UART口的
 QinhuaARM技术
最新版的TivaWare_C_Series-2.0.1.11577出来了
俺刚装的这个版本软件,但不知道是否有所提高, 然而在dk-tm4c123g增加了新的例程,俺原来装的是1.0版的 最新版的TivaWare_C_Series-2.0.1.11577出来了 固件库增加超过250页,改动不能说不大 固件库增加超过250页 奈斯~~~ 在哪下载啊。
 平湖秋月微控制器 MCU
WiMAX始终是3G服务的配角
来源:中国高新技术产业导报 作者:李辉 在3G的一派大热之中,结合了宽带和移动两大特征的WiMAX一直是业界关注的焦点。3G和WiMAX谁将主导无线市场的未来?在近日召开的2005年WiMAX全球峰会上,业内人士普遍认为,WiMAX的无线宽带技术虽然具有很多优势,但在
 mdreamjRF/无线
一起玩树莓派3+迟来的Pi3开箱评测
一起玩树莓派3+迟来的Pi3开箱评测 今天刚出差回到办公室,在办公桌上看到了期待已久的EEworld的快递,树莓派3终于到手了。这个过程真是一波三折。 第一次参加EEworld的开发板评测,并幸运获得了评测的机会,心里急切期待着评测开发板的到来。由于临时安排了25
 shenlan1986嵌入式系统
cannot open file 'ceddk.lib'(急寻解决办法)
别人考我一个工程EVC的 在他那可以运行 在我电脑上运行报错如下: LINK : fatal error LNK1104: cannot open file \'ceddk.lib\' 是要将这个库加到工程中吗? 哪位有这个库的发我一个 万分感谢! mickeyhao66@16
 xiaozhou嵌入式系统
删除之前布的某根线AD09就卡死
如图,要删除这跟V+线,但是选中按Delete后AD09就死掉了,每次都是这样,这款板子的其他部分我已经都删的差不多了,就是删这跟线的时候老是会让AD卡住,然后无响应。跪求大佬解释这个现象,小弟在此谢过。 删除之前布的某根线AD09就卡死 1.切换使用英文输入法试试 2.
 反倒是fdsfPCB设计
About Us 关于我们 客户服务 联系方式 器件索引 网站地图 最新更新 手机版 版权声明
EEWORLD 电路图 站点相关: 下载中心 Datasheet 参考设计
