警报器控制键盘电路
来源:互联网发布者:武林萌主 更新时间: 2012/04/01
This switch will suit the Modular Burglar Alarm circuit. However, it also has other applications. The Keypad must be the kind with a common terminal and a separate connection for each key. On a 12-key pad, look for 13 terminals. The matrix type with 7 terminals will NOT do. Choose the five keys you want as your code, and connect them to 'A, B, C, D & E'. Wire the common to R1 and all the remaining keys to 'F'. Because your choice can include the non-numeric symbols, almost 100 000 different codes are available. The Alarm is set using the first four of your five chosen keys. When 'A, B, C & D' are pressed in the right order and within the time set by C1 and R2 (about 10 seconds), current through R11 switches Q6 on. The relay energizes, and then holds itself on by providing base current for Q6 through R12. The 12-volt output switches from the "off " to the "set " terminal, and the LED lights. To switch the Alarm off again it is necessary to press A, B, C, D & E in the right order. The IC is a quad 2-input AND gate, a Cmos 4081. These gates only produce a high output when both inputs are high. Pressing 'A' takes pin 1 high for a period of time set by C1 and R2. This 'enables' gate 1, so that when 'B' is pressed, the output at pin 3 will go high. This output does two jobs. It locks itself high using R3 and it enables gate 2 by taking pin 5 high. The remaining gates operate in the same way, each locking itself on through a resistor and enabling its successor. If the correct code is entered within the time allowed, pin 10 will switch Q5 on and so connect the base of Q6 to ground. This causes Q6 to switch off and the relay to drop out. Any keys not wired to 'A, B, C, D or E ' are connected to the base of Q4 by R9. Whenever one of these 'wrong' keys is pressed, Q4 takes pin 1 low. This removes the 'enable' from gate 1, and the code entry process fails. If C, D or E is pressed out of sequence, Q1, Q2 or Q3 will also take pin 1 low, with the same r
这里还没有内容,您有什么问题吗?
电子电路资源推荐
- 西门子S7-200SMART PLC编程技巧与案例
来源:下载中心
- ADS应用详解-射频电路设计与仿真 pdf
来源:下载中心
- 信号完整性及高速数字电路设计
来源:大学堂
- 了解和优化采样数据系统
来源:大学堂
- 戴维宁定理:概念介绍及其求解过程
来源:电路图
- PCB板基础知识讲解
来源:电路图
推荐帖子 最新更新时间:2024-11-21 17:38
- PowerLogic 5.0
- PowerLogic 5.0
- 刘小飞PCB设计
- 如何在设备上加usb device,连接上电脑可当做移动硬盘
- 现在手头上有一个设备(一个播放器),挂有大容量的硬盘,设备本身支持很多种接口(SATA,PCI,USB HOST),现在需要在上面加上一个usb device 接口,并能实现接上PC是能认出大容量存储器,目前还没有思路,请这方面的牛人们指点一下。 如何在设备上加usb devic
- weiaa1911嵌入式系统
- 如何诠释power by linear
- ADI 电源管理产品有了一个新名字: Power by Linear ™ 如何诠释呢? 看众多网友怎么说吧,当然说出你的诠释,还有机会获得 ADI 准备的好礼哦 ~ 详情: https://ezchina.analog.com/thread/1
- 墨尔本的电路模拟电子
- 超小型封装 TI MSPM0 MCU 可优化设计空间,实现更多可能 直播入口已开放!
- 进入直播间 【直播时间】 6月12日(今日)上午10:00-11:00 注:已报名用户可以登录报名邮箱,查看 超小型封装 TI MSPM0 MCU 可优化设计空间,实现更多可能直播报名确认函 邮件,点击【直播间链接】观看直播~ 【 直播内容 】
- EEWORLD社区单片机
- FPGA中dsp部分的问题
- 本帖最后由 青城山下 于 2014-12-18 19:07 编辑 FPGA芯片中DSP48A1模块, MULT18X18 是什么东西?求告诉 CARRYINSELREG = 0, LEGACY_MODE = MULT18X18 , CREG = 1, MREG = 0,
- 青城山下FPGA/CPLD
- 工程师的新年大福包,ADI一次性呈送七本精选合集电子书!
- ADI 七本精选合集电子书全放送! ADI 工程师精心奉上 非常见问题解答 、模拟对话、应用笔记、参考电路及应用解决方案完整合集电子书,现在只需点击相应的 https://ezchina.analog.com/thread/17765 ,即可统统抱走哦 ~ Anal
- 小杜鹃ADI参考电路
- 残缺的六度理论和SNS的实践者们(转帖)
- 用msp430内部AD进行信号采集,然后用PWM和简单的低通滤波实现DA输出采集进来的数据
- 上海ACM32F070开发板评测3、USART
- 这个板块很火,我来倒水!
- 共模电感的仿真应用来了,满满的干货送给大家!
- 有奖直播:TI 图形化界面助力快速开发,这就是您想要的MSP430™通用MCU!
- 【先到先得 双重有礼】成为前100位体验FLUKE新时代640红外热像仪的先锋者
- 初学windows mobile,关于开发工具的问题
- 【玄铁杯第三届RISC-V应用创新大赛】Lichee PI 4A 之OpenCV与摄像头抓拍
- LaunchPad实现AD转换 转换结果经UART通讯送给上位机
- 微波射频测量技术基础
- 测评周报20220228:小熊派鸿蒙折叠开发板来啦,沁恒ch582开测
- linux 下3g驱动的问题~!!!!
- 扭动行进的贪吃蛇
- 衣服上的 触摸板
- 初学者入门之arm开发经验之谈
- 国内一流的移动开发论坛
- 2012湖北电赛所有芯片资料
- 433双向通信
- 算法之美
- 使用 Analog Devices 的 ADP2230ACPZ 的参考设计
- AST1S31HF 的典型应用适用于汽车应用的高达 4 V、3 A 降压型 2.3 MHz 开关稳压器
- NCV3063 1.5A 降压型开关稳压器的典型降压应用原理图
- 16 位 ADC 简化了电流测量设计电路
- LTC1290、12 位数据采集系统通过 4 线与英特尔 8051 微处理器通信
- LTC3633AIFE-3 双通道 3A、12V 同步降压稳压器的设计示例电路
- 6 W 单输出 VIPer17 演示板
- MC33PF3000A6ES PMIC 解决方案电源管理的典型应用
- DER-365 - 14.35W 高效率>89% TRIAC可调光LED驱动器,适用于PAR30灯。
- LT1934,独立的 350mA 锂离子电池充电器接受 28V 输入并且不需要散热器
