首页 > 控制电路 >其他控制电路 > 4字控制键盘电路
4字控制键盘电路
来源:互联网发布者:无人共我 更新时间: 2019/07/15
4字控制键盘电路
The Keypad must be the kind with a common terminal and a separate connection for each key. On a 12-key pad, look for 13 terminals. The matrix type with 7 terminals will NOT do. The Alarm is set by pressing a single key. Choose the key you want to use and wire it to 'E'. Choose the four keys you want to use to switch the alarm off, and connect them to 'A B C & D'. Your code can include the non-numeric symbols. With a 12-key pad, over 10 000 different codes are available. Wire the common to R1 and all the remaining keys to 'F'. When 'E' is pressed, current through D2 and R9 switches Q5 on. The relay energises, and then holds itself on by providing base current for Q5 through R10. The 12-volt output is switched from the "off " to the "set " terminal, and the LED lights. To switch the Alarm off again it is necessary to press A, B, C & D in the right order. The IC is a quad 2-input AND gate, a Cmos 4081. These gates only produce a high output when both inputs are high. Pin 1 is held high by R5. This 'enables' gate 1, so that when 'A' is pressed, the output at pin 3 will go high. This output does two jobs. It locks itself high using R2 and it enables gate 2 by taking pin 5 high. The remaining gates operate in the same way, each locking itself on through a resistor and enabling its successor. If the correct code is entered, pin 10 will switch Q4 on and so connect the base of Q5 to ground. This causes Q5 to switch off and the relay to drop out. Any keys not wired to 'A B C D or E' are connected to the base of Q3 by R7. Whenever one of these 'wrong' keys is pressed, Q3 takes pin 1 low. This removes the 'enable' from gate 1,
提问/讨论 常见疑问?
这里还没有内容,您有什么问题吗?
我要提问/讨论
推荐帖子 最新更新时间:2024-11-21 19:30
ACS550 变频器在分离机械行业中的应用
分离机械的驱动电动机一般分为单 转矩控制,所以该款变频器不仅能够适合于最简 电动机驱动和多电动机驱动两种。 单的电动机运转,同时也可以应用在复杂的工作 主要介绍了 ACS550 变频器在作为 场合。其可靠的过载能力设计,也可以同时满足 单电动机驱动的典型案例三足式离 普通负载和重
 frozenviolet工控电子
大家用launch的时候觉得缺什么模块吗?
做个调查,看看用launch的过程中缺哪些东西。 大家用launch的时候觉得缺什么模块吗? 我就是觉得板子自带的串口不怎么好 缺个显示的小液晶片,应该TI做个小的液晶片在上面。
 wstt微控制器 MCU
微信直播:TE专家解密 “压力传感器-微熔技术”
随着生活的日益智能化,传感器渗透了方方面面。作为工业生产中不可或缺的压力传感器,哪种最能应对您的工程挑战? 扫码注册,观看微信视频直播 。TE Connectivity专家为您在线揭秘微熔技术怎样促进压力传感器的发展。 小贴士:
 EEWORLD社区综合技术交流
CBB电容会烧毁,基本上炸开了,怎么回事? 请高手指点.
最近做一个DC-DC的电源,在调试的时候出现0.22uF的CBB电容会烧毁,基本上炸开了,怎么回事? 请高手指点. CBB电容会烧毁,基本上炸开了,怎么回事? 请高手指点. 什么牌子的CBB?纹波电流多大? 什么牌子的CBB? 调试的时候,加电多长时间烧,温度多高? CBB电容耐
 mydepc3721模拟与混合信号
二、硬件介绍及开发环境安装
二、硬件介绍及开发环境安装 1、硬件介绍 BG22-EK4108A 板子做工还是非常精细的,包括整体的 PCB 布局是 very 奈斯的 可以从官网上了解的有关资源的介绍及说明 官网地址: https://cn.silabs.com/developme
 webber310Silicon Labs 开发套件评测专区
六大SP抱团共谋无线音乐市场
搜狐、TOM在线、华友世纪、空中网、掌上灵通、龙腾阳光六大SP(信息内容提供商),共同组建了国内首个手机唱片发行联盟。该联盟今后将主要在无线音乐市场进行签约唱片的联合推广发行。   据悉,该联盟是首个基于移动互联网平台的数字音乐发行模式。著名互联网评论人士吕伟钢表示,“对于传统
 yxh99RF/无线
About Us 关于我们 客户服务 联系方式 器件索引 网站地图 最新更新 手机版 版权声明
EEWORLD 电路图 站点相关: 下载中心 Datasheet 参考设计
